[PATCH 33.0 1/5] LEON: updated AMBA PnP API
Sun Apr 15 18:34:50 UTC 2012
This is a big one! Most of this is specific to the leon bsps so I just
glanced it over. I have just two comments.
First you can eliminate the $Id$ tags.
Second is the indentation. We usually use 2 spaces per indent level
while this code uses 6 or so.
-Gedare
On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> The old layer had some limitations/problems for multiple AHB
> buses since the data structure containing all AMBA devices
> were allocated before scanning.
> The new layer create devices as they are found and memory is
> allocated using malloc() or bsp_early_malloc() during booting.
> The old 8 functions for finding a specific AHB-Slave or
> APB-Slave device has been replaced with one function,
> ambapp_for_each(), which iterates over all devices matching
> the specified search options and calls a user provided
> function. The new way lowers the footprint and makes searching
> more flexible.
> The frequency information is now supported, if the frequency
> of one device is reported by the user.
> More AHB-to-AHB bridges are supported.
> The API has been split into several parts in order to lower the
> footprint.
> The API also introduces the AMBAPP CORE concept, where one
> ambapp_core can be created from one AHB Master, AHB Slave
> and one APB Slave, at least one device is required for creating
> a core.
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/Makefile.am                 |   10 +
>  c/src/lib/libbsp/sparc/leon2/Makefile.am           |   15 +-
>  c/src/lib/libbsp/sparc/leon2/preinstall.am         |   12 +-
>  c/src/lib/libbsp/sparc/leon3/Makefile.am           |   15 +-
>  c/src/lib/libbsp/sparc/leon3/amba/amba.c           |   47 +-
>  c/src/lib/libbsp/sparc/leon3/include/amba.h        |    2 +-
>  c/src/lib/libbsp/sparc/leon3/preinstall.am         |    4 +
>  c/src/lib/libbsp/sparc/shared/amba/ambapp.c        |  866 ++++++++++----------
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c  |   28 +
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c  |   27 +
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c  |   27 +
>  .../libbsp/sparc/shared/amba/ambapp_find_by_idx.c  |   42 +
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c   |  114 +++
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c  |  395 +++++++++
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c    |   92 ++
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c |   26 +
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c   |   76 ++
>  c/src/lib/libbsp/sparc/shared/include/ambapp.h     |  497 +++++++-----
>  c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h |  245 ++++++
>  19 files changed, 1882 insertions(+), 658 deletions(-)
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h
> diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
> index 4f445ba..2b9909c 100644
> --- a/c/src/lib/libbsp/sparc/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/Makefile.am
> @@ -17,7 +17,17 @@ EXTRA_DIST += shared/irq/irq-shared.c
>  # AMBA Plug&Play bus
>  EXTRA_DIST += shared/include/ambapp.h
> +EXTRA_DIST += shared/include/ambapp_ids.h
>  EXTRA_DIST += shared/amba/ambapp.c
> +EXTRA_DIST += shared/amba/ambapp_alloc.c
> +EXTRA_DIST += shared/amba/ambapp_count.c
> +EXTRA_DIST += shared/amba/ambapp_depth.c
> +EXTRA_DIST += shared/amba/ambapp_find_by_idx.c
> +EXTRA_DIST += shared/amba/ambapp_freq.c
> +EXTRA_DIST += shared/amba/ambapp_parent.c
> +EXTRA_DIST += shared/amba/ambapp_names.c
> +EXTRA_DIST += shared/amba/ambapp_old.c
> +EXTRA_DIST += shared/amba/ambapp_show.c
>  # PCI bus
>  EXTRA_DIST += shared/include/pci.h
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index 2acca78..c2310bc 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -14,7 +14,6 @@ include_HEADERS = include/bsp.h
>  include_HEADERS += include/tm27.h
>  include_HEADERS += include/rasta.h
>  include_HEADERS += include/cchip.h
> -include_HEADERS += ../../sparc/shared/include/ambapp.h
>  include_HEADERS += ../../sparc/shared/include/grspw.h
>  include_HEADERS += ../../sparc/shared/include/grspw_pci.h
>  include_HEADERS += ../../sparc/shared/include/grspw_rasta.h
> @@ -79,8 +78,20 @@ libbsp_a_SOURCES += \
>     ../../shared/src/irq-legacy.c \
>     ../../shared/src/irq-server.c \
>     ../../shared/src/irq-shell.c
> -# AMBA PnP Scanning
> +# AMBA bus
> +include_HEADERS += ../../sparc/shared/include/ambapp.h
> +include_HEADERS += ../../sparc/shared/include/ambapp_ids.h
>  libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_alloc.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_count.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_depth.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_find_by_idx.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_freq.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_parent.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_old.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_names.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_show.c
>  # PCI
>  libbsp_a_SOURCES += pci/pci.c ../../sparc/shared/pci/pcifinddevice.c
>  # RASTA Kit
> diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> index 00ed05e..2978d58 100644
> --- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> @@ -53,10 +53,6 @@ $(PROJECT_INCLUDE)/cchip.h: include/cchip.h $(PROJECT_INCLUDE)/$(dirstamp)
>        $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/cchip.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/cchip.h
> -$(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLUDE)/$(dirstamp)
> -       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp.h
> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp.h
>  $(PROJECT_INCLUDE)/grspw.h: ../../sparc/shared/include/grspw.h $(PROJECT_INCLUDE)/$(dirstamp)
>        $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw.h
> @@ -157,6 +153,14 @@ $(PROJECT_INCLUDE)/bsp/irq.h: include/bsp/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstam
>        $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
> +$(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp.h
> +$(PROJECT_INCLUDE)/ambapp_ids.h: ../../sparc/shared/include/ambapp_ids.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp_ids.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp_ids.h
>  $(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLUDE)/$(dirstamp)
>        $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i2cmst.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index ebbeb46..6bcc53f 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -44,10 +44,21 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>  libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
>  # gnatsupp
>  libbsp_a_SOURCES += gnatsupp/gnatsupp.c ../../sparc/shared/gnatcommon.c
> -# amba
> +# AMBA bus
>  include_HEADERS += include/amba.h
> -libbsp_a_SOURCES += amba/amba.c ../../sparc/shared/amba/ambapp.c
> +libbsp_a_SOURCES += amba/amba.c
> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp.c
>  # console
>  libbsp_a_SOURCES += console/console.c
>  # debugio
> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> index 16fb8de..e41d0aa 100644
> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> @@ -1,10 +1,10 @@
> - *  AMBA Plag & Play Bus Driver
> + *  AMBA Plug & Play Bus Driver
>  *  This driver hook performs bus scanning.
> - *  COPYRIGHT (c) 2004.
> - *  Gaisler Research
> + *  COPYRIGHT (c) 2011.
> + *  Aeroflex Gaisler
>  *  The license and distribution terms for this file may be
>  *  found in the file LICENSE in this distribution or at
> @@ -14,9 +14,14 @@
>  #include <bsp.h>
> +#include <ambapp.h>
> -/* Structure containing address to devices found on the Amba Plug&Play bus */
> -amba_confarea_type amba_conf;
> +/* AMBA Plug&Play information description.
> + * After software has scanned AMBA PnP it builds a tree to make
> + * it easier for drivers to work with the bus architecture.
> +struct ambapp_bus ambapp_plb;
>  /* GRLIB extended IRQ controller register */
>  extern void leon3_ext_irq_init(void);
> @@ -38,16 +43,21 @@ extern int scan_uarts(void);
>  void amba_initialize(void)
> -  int i;
>   int icsel;
> -  amba_apb_device dev;
> +  struct ambapp_dev *adev;
> -  /* Scan the AMBA Plug&Play info at the default LEON3 area */
> -  amba_scan(&amba_conf,LEON3_IO_AREA,NULL);
> +  /* Scan AMBA Plug&Play read-only information. The routine builds a PnP
> +   * tree into ambapp_plb in RAM, after this we never access the PnP
> +   * information in hardware directly any more.
> +   * Since on Processor Local Bus (PLB) memory mapping is 1:1
> +  ambapp_scan(&ambapp_plb, LEON3_IO_AREA, NULL, NULL);
>   /* Find LEON3 Interrupt controller */
> -  i = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_IRQMP,&dev);
> -  if (i <= 0){
> +  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
> +                                 VENDOR_GAISLER, GAISLER_IRQMP,
> +                                 ambapp_find_by_idx, NULL);
> +  if (adev == NULL) {
>     /* PANIC IRQ controller not found!
>      *  What else can we do but stop ...
> @@ -55,7 +65,8 @@ void amba_initialize(void)
>     asm volatile( "mov 1, %g1; ta 0x0" );
> -  LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *) dev.start;
> +  LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *)
> +                       DEV_TO_APB(adev)->start;
>   if ((LEON3_IrqCtrl_Regs->ampctrl >> 28) > 0) {
>     /* IRQ Controller has support for multiple IRQ Controllers, each
>      * CPU can be routed to different Controllers, we find out which
> @@ -74,9 +85,15 @@ void amba_initialize(void)
>   leon3_ext_irq_init();
>   /* find GP Timer */
> -  i = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&dev);
> -  if ( i > 0 ) {
> -    LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) dev.start;
> +                                 VENDOR_GAISLER, GAISLER_GPTIMER,
> +  if (adev) {
> +    LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *)DEV_TO_APB(adev)->start;
> +    /* Register AMBA Bus Frequency */
> +    ambapp_freq_init(&ambapp_plb, adev,
> +                     (LEON3_Timer_Regs->scaler_reload + 1) * 1000000);
>   /* find UARTS */
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/amba.h b/c/src/lib/libbsp/sparc/leon3/include/amba.h
> index 9167ff1..aa13f2c 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/amba.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/amba.h
> @@ -34,7 +34,7 @@ extern "C" {
>  #endif
>  /* The AMBA Plug&Play info of the bus that the LEON3 sits on */
> -extern amba_confarea_type amba_conf;
> +extern struct ambapp_bus ambapp_plb;
>  #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> index 8c27b81..540e37b 100644
> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> @@ -85,6 +85,10 @@ $(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLU
>  $(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>        $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
> index 814ee8c..62c96a0 100644
> --- a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
> @@ -1,499 +1,475 @@
> + *  AMBA Plug & Play routines
> - *  This driver hook performs bus scanning.
> + *  Aeroflex Gaisler.
>  *  http://www.rtems.com/license/LICENSE.
> - *  $Id$
> + *  $Id: ambapp.c,v 1.2 2009/11/29 15:33:27 ralf Exp $
> + *  2008-12-01, Daniel Hellstrom <daniel at gaisler.com>
> + *    Created
> -#include <bsp.h>
> -#include <rtems/bspIo.h>
> +#include <string.h>
> +#include <stdlib.h>
>  #include <ambapp.h>
> +#include <bsp.h>
> +#define AMBA_CONF_AREA 0xff000
> +#define AMBA_AHB_SLAVE_CONF_AREA (1 << 11)
> +#define AMBA_APB_SLAVES 16
> -#define amba_insert_device(tab, address) \
> -  if (*(address)) \
> -    (tab)->addr[(tab)->devnr] = (address); \
> -    (tab)->devnr ++; \
> -} while(0)
> -#define amba_insert_apb_device(tab, address, apbmst) \
> -  if (*(address)) \
> -               (tab)->apbmst[(tab)->devnr] = (apbmst); \
> -} while(0)
> -static unsigned int
> -addr_from (struct amba_mmap *mmaps, unsigned int address)
> +/* Allocate one AMBA device */
> +struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
> -  /* no translation? */
> -  if (!mmaps)
> -    return address;
> -  while (mmaps->size) {
> -    if ((address >= mmaps->remote_amba_adr)
> -        && (address <= (mmaps->remote_amba_adr + (mmaps->size - 1)))) {
> -      return (address - mmaps->remote_amba_adr) + mmaps->cpu_adr;
> -    mmaps++;
> -  return 1;
> +       int size = sizeof(struct ambapp_dev);
> +       struct ambapp_dev *dev;
> +       if (dev_type == DEV_APB_SLV)
> +               size += sizeof(struct ambapp_apb_info);
> +       else
> +               size += sizeof(struct ambapp_ahb_info); /* AHB */
> +       dev = (struct ambapp_dev *)bsp_early_malloc(size);
> +       if (dev == NULL)
> +               return NULL;
> +       memset(dev, 0 , size);
> +       dev->dev_type = dev_type;
> +       return dev;
> -void
> -amba_scan (amba_confarea_type * amba_conf, unsigned int ioarea,
> -           struct amba_mmap *mmaps)
> +unsigned int
> +ambapp_addr_from (struct ambapp_mmap *mmaps, unsigned int address)
> -  unsigned int *cfg_area;       /* address to configuration area */
> -  unsigned int mbar, conf, custom;
> -  int i, j;
> -  unsigned int apbmst;
> -  int maxloops = amba_conf->notroot ? 16 : 64; /* scan first bus for 64 devices, rest for 16 devices */
> -  amba_conf->ahbmst.devnr = 0;
> -  amba_conf->ahbslv.devnr = 0;
> -  amba_conf->apbslv.devnr = 0;
> -  cfg_area = (unsigned int *) (ioarea | AMBA_CONF_AREA);
> -  amba_conf->ioarea = ioarea;
> -  amba_conf->mmaps = mmaps;
> -  for (i = 0; i < maxloops; i++) {
> -    amba_insert_device (&amba_conf->ahbmst, cfg_area);
> -    cfg_area += AMBA_AHB_CONF_WORDS;
> -  cfg_area =
> -    (unsigned int *) (ioarea | AMBA_CONF_AREA | AMBA_AHB_SLAVE_CONF_AREA);
> -    amba_insert_device (&amba_conf->ahbslv, cfg_area);
> -  for (i = 0; i < amba_conf->ahbslv.devnr; i++){
> -    conf = amba_get_confword(amba_conf->ahbslv, i, 0);
> -    mbar = amba_ahb_get_membar(amba_conf->ahbslv, i, 0);
> -    if ( (amba_vendor(conf) == VENDOR_GAISLER) && (amba_device(conf) == GAISLER_AHB2AHB) ){
> -      /* Found AHB->AHB bus bridge, scan it if more free amba_confarea_type:s available
> -       * Custom config 1 contain ioarea.
> -      custom = amba_ahb_get_custom(amba_conf->ahbslv,i,1);
> -      if ( amba_ver(conf) && amba_conf->next ){
> -        amba_conf->next->notroot = 1;
> -        amba_scan(amba_conf->next,custom,mmaps);
> -    }else if ((amba_vendor(conf) == VENDOR_GAISLER) && (amba_device(conf) == GAISLER_APBMST))
> -      apbmst = amba_membar_start(mbar);
> -                       if ( (apbmst=addr_from(mmaps,apbmst)) == 1 )
> -                               continue; /* no available memory translation available, will not be able to access
> -                                          * Plug&Play information for this AHB/APB bridge. Skip it.
> -                       cfg_area = (unsigned int *)( apbmst | AMBA_CONF_AREA);
> -      for (j=0; (amba_conf->apbslv.devnr<AMBA_APB_SLAVES) && (j<AMBA_APB_SLAVES); j++){
> -        amba_insert_apb_device(&amba_conf->apbslv, cfg_area, apbmst);
> -        cfg_area += AMBA_APB_CONF_WORDS;
> +       /* no translation? */
> +       if (!mmaps)
> +               return address;
> +       while (mmaps->size) {
> +               if ((address >= mmaps->remote_adr) &&
> +                   (address <= (mmaps->remote_adr + (mmaps->size - 1)))) {
> +                       return (address - mmaps->remote_adr) + mmaps->local_adr;
> +               mmaps++;
> +       return 1;
> -void
> -amba_print_dev(int devno, unsigned int conf){
> -       int irq = amba_irq(conf);
> -       if ( irq > 0 ){
> -               printk("%x.%x.%x: irq %d\n",devno,amba_vendor(conf),amba_device(conf),irq);
> -       }else{
> -               printk("%x.%x.%x: no irq\n",devno,amba_vendor(conf),amba_device(conf));
> +void ambapp_ahb_dev_init(
> +       unsigned int ioarea,
> +       struct ambapp_mmap *mmaps,
> +       struct ambapp_pnp_ahb *ahb,
> +       struct ambapp_dev *dev,
> +       int ahbidx
> +       int bar;
> +       struct ambapp_ahb_info *ahb_info;
> +       unsigned int addr, mask, mbar;
> +       /* Setup device struct */
> +       dev->vendor = ambapp_pnp_vendor(ahb->id);
> +       dev->device = ambapp_pnp_device(ahb->id);
> +       ahb_info = DEV_TO_AHB(dev);
> +       ahb_info->ver = ambapp_pnp_ver(ahb->id);
> +       ahb_info->irq = ambapp_pnp_irq(ahb->id);
> +       ahb_info->ahbidx = ahbidx;
> +       ahb_info->custom[0] = (unsigned int)ahb->custom[0];
> +       ahb_info->custom[1] = (unsigned int)ahb->custom[1];
> +       ahb_info->custom[2] = (unsigned int)ahb->custom[2];
> +       /* Memory BARs */
> +       for (bar=0; bar<4; bar++) {
> +               mbar = ahb->mbar[bar];
> +               if (mbar == 0) {
> +                       addr = 0;
> +                       mask = 0;
> +               } else {
> +                       addr = ambapp_pnp_start(mbar);
> +                       if (ambapp_pnp_mbar_type(mbar) == AMBA_TYPE_AHBIO) {
> +                               /* AHB I/O area is releative IO_AREA */
> +                               addr = AMBA_TYPE_AHBIO_ADDR(addr, ioarea);
> +                               mask = (((unsigned int)
> +                                       (ambapp_pnp_mbar_mask((~mbar))<<8) |
> +                                       0xff)) + 1;
> +                       } else {
> +                               /* AHB memory area, absolute address */
> +                               addr = ambapp_addr_from(mmaps, addr);
> +                               mask = (~((unsigned int)
> +                                       (ambapp_pnp_mbar_mask(mbar)<<20))) + 1;
> +               ahb_info->start[bar] = addr;
> +               ahb_info->mask[bar] = mask;
> +               ahb_info->type[bar] = ambapp_pnp_mbar_type(mbar);
> -void
> -amba_apb_print_dev(int devno, unsigned int conf, unsigned int address){
> -       if ( irq > 0 ){
> -               printk("%x.%x.%x: irq %d, apb: 0x%lx\n",devno,amba_vendor(conf),amba_device(conf),irq,address);
> -       }else{
> -               printk("%x.%x.%x: no irq, apb: 0x%lx\n",devno,amba_vendor(conf),amba_device(conf),address);
> +void ambapp_apb_dev_init(
> +       unsigned int base,
> +       struct ambapp_pnp_apb *apb,
> +       int ahbidx
> +       struct ambapp_apb_info *apb_info;
> +       dev->vendor = ambapp_pnp_vendor(apb->id);
> +       dev->device = ambapp_pnp_device(apb->id);
> +       apb_info = DEV_TO_APB(dev);
> +       apb_info->ver = ambapp_pnp_ver(apb->id);
> +       apb_info->irq = ambapp_pnp_irq(apb->id);
> +       apb_info->ahbidx = ahbidx;
> +       apb_info->start = ambapp_pnp_apb_start(apb->iobar, base);
> +       apb_info->mask = ambapp_pnp_apb_mask(apb->iobar);
> -/* Print AMBA Plug&Play info on terminal */
> -void
> -amba_print_conf (amba_confarea_type * amba_conf)
> +int ambapp_add_ahbbus(
> +       struct ambapp_bus *abus,
> -       int i,base=0;
> -       unsigned int conf, iobar, address;
> -       /* print all ahb masters */
> -       printk("--- AMBA AHB Masters ---\n");
> -       for(i=0; i<amba_conf->ahbmst.devnr; i++){
> -               conf = amba_get_confword(amba_conf->ahbmst, i, 0);
> -               amba_print_dev(i,conf);
> +       int i;
> +       for (i=0; i<AHB_BUS_MAX; i++) {
> +               if (abus->ahbs[i].ioarea == 0) {
> +                       abus->ahbs[i].ioarea = ioarea;
> +                       return i;
> +               } else if (abus->ahbs[i].ioarea == ioarea) {
> +                       /* Bus already added */
> +                       return -1;
> +       return -1;
> -       /* print all ahb slaves */
> -       printk("--- AMBA AHB Slaves ---\n");
> -       for(i=0; i<amba_conf->ahbslv.devnr; i++){
> +/* Internal AMBA Scanning Function */
> +static int ambapp_scan2(
> +       ambapp_memcpy_t memfunc,
> +       struct ambapp_dev *parent,
> +       struct ambapp_dev **root
> +       struct ambapp_pnp_ahb *ahb, ahb_buf;
> +       struct ambapp_pnp_apb *apb, apb_buf;
> +       struct ambapp_dev *dev, *prev, *prevapb, *apbdev;
> +       int maxloops = 64;
> +       unsigned int apbbase, bridge_adr;
> +       int i, j, ahbidx;
> +       *root = NULL;
> +       if (parent) {
> +               /* scan first bus for 64 devices, rest for 16 devices */
> +               maxloops = 16;
> -       /* print all apb slaves */
> -       apbmst = 0;
> -       for(i=0; i<amba_conf->apbslv.devnr; i++){
> -               if ( apbmst != amba_conf->apbslv.apbmst[i] ){
> -                       apbmst = amba_conf->apbslv.apbmst[i];
> -                       printk("--- AMBA APB Slaves on 0x%x ---\n",apbmst);
> -                       base=i;
> -               conf = amba_get_confword(amba_conf->apbslv, i, 0);
> -    iobar = amba_apb_get_membar(amba_conf->apbslv, i);
> -    address = amba_iobar_start(amba_conf->apbslv.apbmst[i], iobar);
> -               amba_apb_print_dev(i-base,conf,address);
> +       ahbidx = ambapp_add_ahbbus(abus, ioarea);
> +       if (ahbidx < 0) {
> +               /* Bus already scanned, stop */
> +               return 0;
> -/**** APB Slaves ****/
> +       prev = parent;
> -/* Return number of APB Slave devices which has given vendor and device */
> -int
> -amba_get_number_apbslv_devices (amba_confarea_type * amba_conf, int vendor,
> -                                int device)
> -  unsigned int conf;
> -  int cnt, i;
> -  for (cnt = i = 0; i < amba_conf->apbslv.devnr; i++) {
> -    conf = amba_get_confword (amba_conf->apbslv, i, 0);
> -    if ((amba_vendor (conf) == vendor) && (amba_device (conf) == device))
> -      cnt++;
> -  return cnt;
> +       /* AHB MASTERS */
> +       ahb = (struct ambapp_pnp_ahb *) (ioarea | AMBA_CONF_AREA);
> +       for (i = 0; i < maxloops; i++, ahb++) {
> +               memfunc(&ahb_buf, ahb, sizeof(struct ambapp_pnp_ahb), abus);
> +               if (ahb_buf.id == 0)
> +                       continue;
> -/* Get First APB Slave device of this vendor&device id */
> -int
> -amba_find_apbslv (amba_confarea_type * amba_conf, int vendor, int device,
> -                  amba_apb_device * dev)
> -  unsigned int conf, iobar;
> -  int i;
> -  for (i = 0; i < amba_conf->apbslv.devnr; i++) {
> -    if ((amba_vendor (conf) == vendor) && (amba_device (conf) == device)) {
> -      iobar = amba_apb_get_membar (amba_conf->apbslv, i);
> -      dev->start = amba_iobar_start (amba_conf->apbslv.apbmst[i], iobar);
> -      dev->irq = amba_irq (conf);
> -      return 1;
> -  return 0;
> +               /* An AHB device present here */
> +               dev = ambapp_alloc_dev_struct(DEV_AHB_MST);
> +               if (!dev)
> +                       return -1;
> -/* Get APB Slave device of this vendor&device id. (setting nr to 0 is eqivalent to calling amba_find_apbslv() ) */
> -int
> -amba_find_next_apbslv (amba_confarea_type * amba_conf, int vendor, int device,
> -                       amba_apb_device * dev, int index)
> -  int cnt, i;
> -      if (cnt == index) {
> -        /* found device */
> -        return 1;
> -      cnt++;
> -  return 0;
> +               ambapp_ahb_dev_init(ioarea, abus->mmaps, &ahb_buf, dev, ahbidx);
> -/* Get first nr APB Slave devices, put them into dev (which is an array of nr length) */
> -int
> -amba_find_apbslvs (amba_confarea_type * amba_conf, int vendor, int device,
> -                   amba_apb_device * devs, int maxno)
> -  int cnt, i;
> -  for (cnt = i = 0; (i < amba_conf->apbslv.devnr) && (cnt < maxno); i++) {
> -      devs[cnt].start = amba_iobar_start (amba_conf->apbslv.apbmst[i], iobar);
> -      devs[cnt].irq = amba_irq (conf);
> -      cnt++;
> -  return cnt;
> +               if (*root == NULL)
> +                       *root = dev;
> -/***** AHB SLAVES *****/
> +               if (prev != parent)
> +                       prev->next = dev;
> +               dev->prev = prev;
> +               prev = dev;
> -/* Return number of AHB Slave devices which has given vendor and device */
> -int
> -amba_get_number_ahbslv_devices (amba_confarea_type * amba_conf, int vendor,
> -                                int device)
> -  int cnt, i;
> -  for (cnt = i = 0; i < amba_conf->ahbslv.devnr; i++) {
> -    conf = amba_get_confword (amba_conf->ahbslv, i, 0);
> -      cnt++;
> -  return cnt;
> +       /* AHB SLAVES */
> +               (ioarea | AMBA_CONF_AREA | AMBA_AHB_SLAVE_CONF_AREA);
> +                       continue;
> +               dev = ambapp_alloc_dev_struct(DEV_AHB_SLV);
> +               if (!dev)
> +                       return -1;
> +                       *root = dev;
> +                       prev->next = dev;
> +               dev->prev = prev;
> +               prev = dev;
> +               /* Is it a AHB/AHB Bridge ? */
> +               if (((dev->device == GAISLER_AHB2AHB) &&
> +                   (dev->vendor == VENDOR_GAISLER) && (ahb_info->ver>0)) ||
> +                   ((dev->device == GAISLER_L2CACHE) &&
> +                   (dev->vendor == VENDOR_GAISLER)) ||
> +                   ((dev->device == GAISLER_GRIOMMU) &&
> +                   (dev->vendor == VENDOR_GAISLER))) {
> +                       /* AHB/AHB Bridge Found, recurse down the
> +                        * Bridge
> +                       if (ahb_info->custom[1] != 0) {
> +                               bridge_adr = ambapp_addr_from(abus->mmaps,
> +                                                       ahb_info->custom[1]);
> +                               /* Scan next bus if not already scanned */
> +                               if (ambapp_scan2(abus, bridge_adr, memfunc, dev,
> +                                               &dev->children))
> +                                       return -1;
> +               } else if ((dev->device == GAISLER_APBMST) &&
> +                          (dev->vendor == VENDOR_GAISLER)) {
> +                       /* AHB/APB Bridge Found, add the APB devices to this
> +                        * AHB Slave's children
> +                       prevapb = dev;
> +                       apbbase = ahb_info->start[0];
> +                       /* APB SLAVES */
> +                       apb = (struct ambapp_pnp_apb *)
> +                               (apbbase | AMBA_CONF_AREA);
> +                       for (j=0; j<AMBA_APB_SLAVES; j++, apb++) {
> +                               memfunc(&apb_buf, apb, sizeof(*apb), abus);
> +                               if (apb_buf.id == 0)
> +                                       continue;
> +                               apbdev = ambapp_alloc_dev_struct(DEV_APB_SLV);
> +                               if (!dev)
> +                                       return -1;
> +                               ambapp_apb_dev_init(apbbase, abus->mmaps,
> +                                                   &apb_buf, apbdev, ahbidx);
> +                               if (prevapb != dev)
> +                                       prevapb->next = apbdev;
> +                               else
> +                                       dev->children = apbdev;
> +                               apbdev->prev = prevapb;
> +                               prevapb = apbdev;
> -/* Get First AHB Slave device of this vendor&device id */
> -int
> -amba_find_ahbslv (amba_confarea_type * amba_conf, int vendor, int device,
> -                  amba_ahb_device * dev)
> -  unsigned int conf, mbar, addr;
> -  int j, i;
> -  for (i = 0; i < amba_conf->ahbslv.devnr; i++) {
> -      for (j = 0; j < 4; j++) {
> -        mbar = amba_ahb_get_membar (amba_conf->ahbslv, i, j);
> -        addr = amba_membar_start (mbar);
> -        if (amba_membar_type (mbar) == AMBA_TYPE_AHBIO) {
> -          addr = AMBA_TYPE_AHBIO_ADDR (addr, amba_conf->ioarea);
> -        } else {                /* convert address if needed */
> -          if ((addr = addr_from (amba_conf->mmaps, addr)) == 1) {
> -            addr = 0;           /* no available memory translation available, will not be able to access
> -                                 * Plug&Play information for this AHB address. Skip it.
> -        dev->start[j] = addr;
> -      dev->ver = amba_ver (conf);
> -      return 1;
> -  return 0;
> +       /* Remember first AHB MST/SLV device on bus and Parent Bridge */
> +       abus->ahbs[ahbidx].dev = *root;
> +       abus->ahbs[ahbidx].bridge = parent;
> -/* Get AHB Slave device of this vendor&device id. (setting nr to 0 is eqivalent to calling amba_find_ahbslv() ) */
> -int
> -amba_find_next_ahbslv (amba_confarea_type * amba_conf, int vendor, int device,
> -                       amba_ahb_device * dev, int index)
> -  int i, j, cnt;
> -          } else {
> -            /* convert address if needed */
> -        return 1;
> -      cnt++;
> -  return 0;
> +       return 0;
> -/* Get first nr AHB Slave devices, put them into dev (which is an array of nr length) */
> -int
> -amba_find_ahbslvs (amba_confarea_type * amba_conf, int vendor, int device,
> -                   amba_ahb_device * devs, int maxno)
> +/* Build AMBA Plug & Play device graph */
> +int ambapp_scan(
> -  int i, j, cnt;
> -  for (cnt = i = 0; (i < amba_conf->ahbslv.devnr) && (maxno < cnt); i++) {
> -        } else {
> -        devs[cnt].start[j] = addr;
> -      devs[cnt].ver = amba_ver (conf);
> -      cnt++;
> -  return cnt;
> +       memset(abus, 0, sizeof(*abus));
> +       abus->mmaps = mmaps;
> +       /* Default to memcpy() */
> +       if (!memfunc)
> +               memfunc = (ambapp_memcpy_t)memcpy;
> -/***** AHB Masters *****/
> +       return ambapp_scan2(abus, ioarea, memfunc, NULL, &abus->root);
> -int
> -amba_get_number_ahbmst_devices (amba_confarea_type * amba_conf, int vendor,
> -                                int device)
> +/* Match search options againt device */
> +int ambapp_dev_match_options(struct ambapp_dev *dev, unsigned int options, int vendor, int device)
> -  int cnt, i;
> -  for (cnt = i = 0; i < amba_conf->ahbmst.devnr; i++) {
> -    conf = amba_get_confword (amba_conf->ahbmst, i, 0);
> -      cnt++;
> -  return cnt;
> +       if ((((options & (OPTIONS_ALL_DEVS)) == OPTIONS_ALL_DEVS) || /* TYPE */
> +           ((options & OPTIONS_AHB_MSTS) && (dev->dev_type == DEV_AHB_MST)) ||
> +           ((options & OPTIONS_AHB_SLVS) && (dev->dev_type == DEV_AHB_SLV)) ||
> +           ((options & OPTIONS_APB_SLVS) && (dev->dev_type == DEV_APB_SLV))) &&
> +           ((vendor == -1) || (vendor == dev->vendor)) && /* VENDOR/DEV ID */
> +           ((device == -1) || (device == dev->device)) &&
> +           (((options & OPTIONS_ALL) == OPTIONS_ALL) || /* Allocated State */
> +           ((options & OPTIONS_FREE) && DEV_IS_FREE(dev)) ||
> +           ((options & OPTIONS_ALLOCATED) && DEV_IS_ALLOCATED(dev)))) {
> +               return 1;
> +       return 0;
> -int
> -amba_find_ahbmst (amba_confarea_type * amba_conf, int vendor, int device,
> +/* If device is an APB bridge all devices on the APB bridge is processed */
> +static int ambapp_for_each_apb(
> +       unsigned int options,
> +       int vendor,
> +       int device,
> +       ambapp_func_t func,
> +       void *arg)
> -  int j, i;
> -  for (i = 0; i < amba_conf->ahbmst.devnr; i++) {
> -        mbar = amba_ahb_get_membar (amba_conf->ahbmst, i, j);
> -        } else {
> -      return 1;
> -  return 0;
> +       int index, ret;
> +       struct ambapp_dev *apbslv;
> +       ret = 0;
> +       if (dev->children && (dev->children->dev_type == DEV_APB_SLV)) {
> +               /* Found a APB Bridge */
> +               index = 0;
> +               apbslv = dev->children;
> +               while (apbslv) {
> +                       if (ambapp_dev_match_options(apbslv, options,
> +                                                    vendor, device) == 1) {
> +                               ret = func(apbslv, index, arg);
> +                               if (ret != 0)
> +                                       break; /* Signalled stopped */
> +                       index++;
> +                       apbslv = apbslv->next;
> +       return ret;
> -int
> -amba_find_next_ahbmst (amba_confarea_type * amba_conf, int vendor, int device,
> +/* Traverse the prescanned device information */
> +static int ambapp_for_each_dev(
> +       struct ambapp_dev *root,
> +       int vendor,
> +       int device,
> +       void *arg)
> -  int i, j, cnt;
> -          } else {
> -        return 1;
> -      cnt++;
> -  return 0;
> +       int ahb_slave = 0;
> +       int index, ret;
> +       /* Start at device 'root' and process downwards.
> +        * Breadth first search, search order
> +        * 1. AHB MSTS
> +        * 2. AHB SLVS
> +        * 3. APB SLVS on primary bus
> +        * 4. AHB/AHB secondary... -> step to 1.
> +       /* AHB MST / AHB SLV */
> +       if (options & (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_DEPTH_FIRST)) {
> +               index = 0;
> +               dev = root;
> +               while (dev) {
> +                       if ((dev->dev_type == DEV_AHB_SLV) && !ahb_slave) {
> +                               /* First AHB Slave */
> +                               ahb_slave = 1;
> +                               index = 0;
> +                       /* Conditions must be fullfilled for function to be
> +                        * called
> +                       if (ambapp_dev_match_options(dev, options, vendor,
> +                                                     device) == 1) {
> +                               /* Correct device and vendor ID */
> +                               ret = func(dev, index, arg);
> +                               if (ret != 0)
> +                                       return ret; /* Signalled stopped */
> +                       if ((options & OPTIONS_DEPTH_FIRST) &&
> +                           (options & OPTIONS_APB_SLVS)) {
> +                               /* Check is APB bridge, and process all APB
> +                                * Slaves in that case
> +                               ret = ambapp_for_each_apb(dev, options, vendor,
> +                                                         device, func, arg);
> +                               if (ret != 0)
> +                       if (options & OPTIONS_DEPTH_FIRST) {
> +                                   (dev->children->dev_type != DEV_APB_SLV)) {
> +                                       /* Found AHB Bridge, recurse */
> +                                       ret = ambapp_for_each_dev(dev->children,
> +                                                            options, vendor,
> +                                       if (ret != 0)
> +                                               return ret;
> +                       index++;
> +                       dev = dev->next;
> +       /* Find APB Bridges */
> +       if ((options & OPTIONS_APB_SLVS) && !(options & OPTIONS_DEPTH_FIRST)) {
> +               dev = root;
> +               while (dev) {
> +                       /* Check is APB bridge, and process all APB Slaves in
> +                        * that case
> +                       ret = ambapp_for_each_apb(dev, options, vendor, device,
> +                                                 func, arg);
> +                       if (ret != 0)
> +                       dev = dev->next;
> +       /* Find AHB Bridges */
> +       if (!(options & OPTIONS_DEPTH_FIRST)) {
> +               dev = root;
> +               while (dev) {
> +                                                         options, vendor,
> +                               if (ret != 0)
> +                                       return ret;
> +                       dev = dev->next;
> +       return 0;
> -int
> -amba_find_ahbmsts (amba_confarea_type * amba_conf, int vendor, int device,
> +int ambapp_for_each(
> +       int vendor,
> +       int device,
> +       void *arg)
> -  int i, j, cnt;
> -  for (cnt = i = 0; (i < amba_conf->ahbmst.devnr) && (maxno < cnt); i++) {
> -        } else {
> -      cnt++;
> -  return cnt;
> +       return ambapp_for_each_dev(abus->root, options, vendor, device, func,
> +                                  arg);
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c
> new file mode 100644
> index 0000000..0188267
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c
> @@ -0,0 +1,28 @@
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> + *  $Id: ambapp_alloc.c,v
> +int ambapp_alloc_dev(struct ambapp_dev *dev, void *owner)
> +       if (dev->owner)
> +               return -1;
> +       dev->owner = owner;
> +       return 0;
> +void ambapp_free_dev(struct ambapp_dev *dev)
> +       dev->owner = 0;
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c
> index 0000000..5be4607
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c
> @@ -0,0 +1,27 @@
> + *  $Id: ambapp_count.c,v
> +/* Get number of devices matching search options */
> +int ambapp_dev_count(struct ambapp_bus *abus, unsigned int options,
> +                       int vendor, int device)
> +       int count = 10000;
> +       ambapp_for_each(abus, options, vendor, device, ambapp_find_by_idx,
> +                       &count);
> +       return 10000 - count;
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c
> index 0000000..cd1a7b4
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c
> @@ -0,0 +1,27 @@
> + *  $Id: ambapp_depth.c,v
> +int ambapp_depth(struct ambapp_dev *dev)
> +       int depth = 0;
> +       do {
> +               dev = ambapp_find_parent(dev);
> +               depth++;
> +       } while (dev);
> +       return depth - 1;
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c
> index 0000000..9d078c0
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c
> @@ -0,0 +1,42 @@
> + *  $Id: ambapp_find_by_idx.c,v
> +/* AMBAPP helper routine to find a device by index. The function is given to
> + * ambapp_for_each, the argument may be NULL (find first device) or a pointer
> + * to a index which is downcounted until 0 is reached. If the int-pointer
> + * points to a value of:
> + *   0  - first device is returned
> + *   1  - second device is returned
> + * The matching device is returned, which will stop the ambapp_for_each search.
> + * If zero is returned from ambapp_for_each no device matching the index was
> + * found
> +int ambapp_find_by_idx(struct ambapp_dev *dev, int index, void *pcount)
> +       int *pi = pcount;
> +       if (pi) {
> +               if (*pi-- == 0)
> +                       return (int)dev;
> +               else
> +                       return 0;
> +       } else {
> +               /* Satisfied with first matching device, stop search */
> +               return (int)dev;
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
> index 0000000..d3f0e78
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
> @@ -0,0 +1,114 @@
> + *  $Id: ambapp_freq.c,v
> +/* Calculate AHB Bus frequency of
> + *   - Bus[0] (inverse=1), relative to the frequency of Bus[ahbidx]
> + *     NOTE: set freq_hz to frequency of Bus[ahbidx].
> + *   or
> + *   - Bus[ahbidx] (inverse=0), relative to the frequency of Bus[0]
> + *     NOTE: set freq_hz to frequency of Bus[0].
> + * If a unsupported bridge is found the invalid frequncy of 0Hz is
> + * returned.
> +unsigned int ambapp_freq_calc(
> +       int ahbidx,
> +       unsigned int freq_hz,
> +       int inverse)
> +       struct ambapp_ahb_info *ahb;
> +       struct ambapp_dev *bridge;
> +       unsigned char ffact;
> +       int dir;
> +       /* Found Bus0? */
> +       bridge = abus->ahbs[ahbidx].bridge;
> +       if (!bridge)
> +               return freq_hz;
> +       /* Find this bus frequency relative to freq_hz */
> +       if ((bridge->vendor == VENDOR_GAISLER) &&
> +           ((bridge->device == GAISLER_AHB2AHB) ||
> +           (bridge->device == GAISLER_L2CACHE))) {
> +               ahb = DEV_TO_AHB(bridge);
> +               ffact = (ahb->custom[0] & AMBAPP_FLAG_FFACT) >> 4;
> +               if (ffact != 0) {
> +                       dir = ahb->custom[0] & AMBAPP_FLAG_FFACT_DIR;
> +                       /* Calculate frequency by dividing or
> +                        * multiplying system frequency
> +                       if ((dir && !inverse) || (!dir && inverse))
> +                               freq_hz = freq_hz * ffact;
> +                       else
> +                               freq_hz = freq_hz / ffact;
> +               return ambapp_freq_calc(abus, ahb->ahbidx, freq_hz, inverse);
> +       } else {
> +               /* Unknown bridge, impossible to calc frequency */
> +               return 0;
> +/* Find the frequency of all AHB Buses from knowing the frequency of one
> + * particular APB/AHB Device.
> +void ambapp_freq_init(
> +       unsigned int freq_hz)
> +       struct ambapp_common_info *info;
> +       int i;
> +               abus->ahbs[i].freq_hz = 0;
> +       /* Register Frequency at the AHB bus that the device the user gave us
> +        * is located at.
> +       if (dev) {
> +               info = DEV_TO_COMMON(dev);
> +               abus->ahbs[info->ahbidx].freq_hz = freq_hz;
> +               /* Find Frequency of Bus 0 */
> +               abus->ahbs[0].freq_hz =
> +                       ambapp_freq_calc(abus, info->ahbidx, freq_hz, 1);
> +       } else {
> +               abus->ahbs[0].freq_hz = freq_hz;
> +       /* Find Frequency of all except for Bus0 and the bus which frequency
> +        * was reported at
> +       for (i=1; i<AHB_BUS_MAX; i++) {
> +                       break;
> +               if (abus->ahbs[i].freq_hz != 0)
> +                       continue;
> +                       ambapp_freq_calc(abus, i, abus->ahbs[0].freq_hz, 0);
> +/* Assign a AMBA Bus a frequency but reporting the frequency of a
> + * particular AHB/APB device */
> +unsigned int ambapp_freq_get(struct ambapp_bus *abus, struct ambapp_dev *dev)
> +       struct ambapp_common_info *info = DEV_TO_COMMON(dev);
> +       return abus->ahbs[info->ahbidx].freq_hz;
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
> index 0000000..1fe6553
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
> @@ -0,0 +1,395 @@
> + *  AMBA Plug & Play Device and Vendor name database
> + *  COPYRIGHT (c) 2009.
> + *  The device and vendor definitions are extracted with a script from
> + *  GRLIB.
> + *  2009-01-27, Daniel Hellstrom <daniel at gaisler.com>
> + *    Created from GRLIB 3386.
> +#include <ambapp_ids.h>
> +#ifndef NULL
> +#define NULL 0
> +#endif
> +typedef struct {
> +       int device_id;
> +       char *name;
> +} ambapp_device_name;
> +typedef struct {
> +       unsigned int vendor_id;
> +       char *name;
> +       ambapp_device_name *devices;
> +} ambapp_vendor_devnames;
> +/**************** AUTO GENERATED FROM devices.vhd ****************/
> +static ambapp_device_name GAISLER_devices[] =
> +  {GAISLER_LEON2DSU, "LEON2DSU"},
> +  {GAISLER_LEON3, "LEON3"},
> +  {GAISLER_LEON3DSU, "LEON3DSU"},
> +  {GAISLER_ETHAHB, "ETHAHB"},
> +  {GAISLER_APBMST, "APBMST"},
> +  {GAISLER_AHBUART, "AHBUART"},
> +  {GAISLER_SRCTRL, "SRCTRL"},
> +  {GAISLER_SDCTRL, "SDCTRL"},
> +  {GAISLER_SSRCTRL, "SSRCTRL"},
> +  {GAISLER_APBUART, "APBUART"},
> +  {GAISLER_IRQMP, "IRQMP"},
> +  {GAISLER_AHBRAM, "AHBRAM"},
> +  {GAISLER_AHBDPRAM, "AHBDPRAM"},
> +  {GAISLER_GPTIMER, "GPTIMER"},
> +  {GAISLER_PCITRG, "PCITRG"},
> +  {GAISLER_PCISBRG, "PCISBRG"},
> +  {GAISLER_PCIFBRG, "PCIFBRG"},
> +  {GAISLER_PCITRACE, "PCITRACE"},
> +  {GAISLER_DMACTRL, "DMACTRL"},
> +  {GAISLER_AHBTRACE, "AHBTRACE"},
> +  {GAISLER_DSUCTRL, "DSUCTRL"},
> +  {GAISLER_CANAHB, "CANAHB"},
> +  {GAISLER_GPIO, "GPIO"},
> +  {GAISLER_AHBROM, "AHBROM"},
> +  {GAISLER_AHBJTAG, "AHBJTAG"},
> +  {GAISLER_ETHMAC, "ETHMAC"},
> +  {GAISLER_SWNODE, "SWNODE"},
> +  {GAISLER_SPW, "SPW"},
> +  {GAISLER_AHB2AHB, "AHB2AHB"},
> +  {GAISLER_USBDC, "USBDC"},
> +  {GAISLER_USB_DCL, "USB_DCL"},
> +  {GAISLER_DDRMP, "DDRMP"},
> +  {GAISLER_ATACTRL, "ATACTRL"},
> +  {GAISLER_DDRSP, "DDRSP"},
> +  {GAISLER_EHCI, "EHCI"},
> +  {GAISLER_UHCI, "UHCI"},
> +  {GAISLER_I2CMST, "I2CMST"},
> +  {GAISLER_SPW2, "SPW2"},
> +  {GAISLER_AHBDMA, "AHBDMA"},
> +  {GAISLER_NUHOSP3, "NUHOSP3"},
> +  {GAISLER_CLKGATE, "CLKGATE"},
> +  {GAISLER_SPICTRL, "SPICTRL"},
> +  {GAISLER_DDR2SP, "DDR2SP"},
> +  {GAISLER_SLINK, "SLINK"},
> +  {GAISLER_GRTM, "GRTM"},
> +  {GAISLER_GRTC, "GRTC"},
> +  {GAISLER_GRPW, "GRPW"},
> +  {GAISLER_GRCTM, "GRCTM"},
> +  {GAISLER_GRHCAN, "GRHCAN"},
> +  {GAISLER_GRFIFO, "GRFIFO"},
> +  {GAISLER_GRADCDAC, "GRADCDAC"},
> +  {GAISLER_GRPULSE, "GRPULSE"},
> +  {GAISLER_GRTIMER, "GRTIMER"},
> +  {GAISLER_AHB2PP, "AHB2PP"},
> +  {GAISLER_GRVERSION, "GRVERSION"},
> +  {GAISLER_APB2PW, "APB2PW"},
> +  {GAISLER_PW2APB, "PW2APB"},
> +  {GAISLER_GRCAN, "GRCAN"},
> +  {GAISLER_I2CSLV, "I2CSLV"},
> +  {GAISLER_U16550, "U16550"},
> +  {GAISLER_AHBMST_EM, "AHBMST_EM"},
> +  {GAISLER_AHBSLV_EM, "AHBSLV_EM"},
> +  {GAISLER_GRTESTMOD, "GRTESTMOD"},
> +  {GAISLER_ASCS, "ASCS"},
> +  {GAISLER_IPMVBCTRL, "IPMVBCTRL"},
> +  {GAISLER_SPIMCTRL, "SPIMCTRL"},
> +  {GAISLER_LEON4, "LEON4"},
> +  {GAISLER_LEON4DSU, "LEON4DSU"},
> +  {GAISLER_GRPWM, "GRPWM"},
> +  {GAISLER_FTAHBRAM, "FTAHBRAM"},
> +  {GAISLER_FTSRCTRL, "FTSRCTRL"},
> +  {GAISLER_AHBSTAT, "AHBSTAT"},
> +  {GAISLER_LEON3FT, "LEON3FT"},
> +  {GAISLER_FTMCTRL, "FTMCTRL"},
> +  {GAISLER_FTSDCTRL, "FTSDCTRL"},
> +  {GAISLER_FTSRCTRL8, "FTSRCTRL8"},
> +  {GAISLER_MEMSCRUB, "MEMSCRUB"},
> +  {GAISLER_APBPS2, "APBPS2"},
> +  {GAISLER_VGACTRL, "VGACTRL"},
> +  {GAISLER_LOGAN, "LOGAN"},
> +  {GAISLER_SVGACTRL, "SVGACTRL"},
> +  {GAISLER_T1AHB, "T1AHB"},
> +  {GAISLER_MP7WRAP, "MP7WRAP"},
> +  {GAISLER_GRSYSMON, "GRSYSMON"},
> +  {GAISLER_GRACECTRL, "GRACECTRL"},
> +  {GAISLER_B1553BC, "B1553BC"},
> +  {GAISLER_B1553RT, "B1553RT"},
> +  {GAISLER_B1553BRM, "B1553BRM"},
> +  {GAISLER_SATCAN, "SATCAN"},
> +  {GAISLER_CANMUX, "CANMUX"},
> +  {GAISLER_GRTMRX, "GRTMRX"},
> +  {GAISLER_GRTCTX, "GRTCTX"},
> +  {GAISLER_GRTMDESC, "GRTMDESC"},
> +  {GAISLER_GRTMVC, "GRTMVC"},
> +  {GAISLER_GEFFE, "GEFFE"},
> +  {GAISLER_AES, "AES"},
> +  {GAISLER_GRAESDMA, "GRAESDMA"},
> +  {GAISLER_ECC, "ECC"},
> +  {GAISLER_PCIF, "PCIF"},
> +  {GAISLER_CLKMOD, "CLKMOD"},
> +  {GAISLER_HAPSTRAK, "HAPSTRAK"},
> +  {GAISLER_TEST_1X2, "TEST_1X2"},
> +  {GAISLER_WILD2AHB, "WILD2AHB"},
> +  {GAISLER_BIO1, "BIO1"},
> +  {GAISLER_GR1553B, "GR1553B"},
> +  {GAISLER_L2CACHE, "L2CACHE"},
> +  {GAISLER_L4STAT, "L4STAT"},
> +  {GAISLER_GRPCI2, "GRPCI2"},
> +  {GAISLER_GRPCI2_DMA, "GRPCI2_DMA"},
> +  {GAISLER_GRIOMMU, "GRIOMMU"},
> +  {GAISLER_SPW2_DMA, "SPW2_DMA"},
> +  {GAISLER_SPW_ROUTER, "SPW_ROUTER"},
> +  {0, NULL}
> +static ambapp_device_name PENDER_devices[] =
> +  {0, NULL}
> +static ambapp_device_name ESA_devices[] =
> +  {ESA_LEON2, "LEON2"},
> +  {ESA_LEON2APB, "LEON2APB"},
> +  {ESA_IRQ, "IRQ"},
> +  {ESA_TIMER, "TIMER"},
> +  {ESA_UART, "UART"},
> +  {ESA_CFG, "CFG"},
> +  {ESA_IO, "IO"},
> +  {ESA_MCTRL, "MCTRL"},
> +  {ESA_PCIARB, "PCIARB"},
> +  {ESA_HURRICANE, "HURRICANE"},
> +  {ESA_SPW_RMAP, "SPW_RMAP"},
> +  {ESA_AHBUART, "AHBUART"},
> +  {ESA_SPWA, "SPWA"},
> +  {ESA_BOSCHCAN, "BOSCHCAN"},
> +  {ESA_IRQ2, "IRQ2"},
> +  {ESA_AHBSTAT, "AHBSTAT"},
> +  {ESA_WPROT, "WPROT"},
> +  {ESA_WPROT2, "WPROT2"},
> +  {ESA_PDEC3AMBA, "PDEC3AMBA"},
> +  {ESA_PTME3AMBA, "PTME3AMBA"},
> +  {0, NULL}
> +static ambapp_device_name ASTRIUM_devices[] =
> +  {0, NULL}
> +static ambapp_device_name OPENCHIP_devices[] =
> +  {OPENCHIP_APBGPIO, "APBGPIO"},
> +  {OPENCHIP_APBI2C, "APBI2C"},
> +  {OPENCHIP_APBSPI, "APBSPI"},
> +  {OPENCHIP_APBCHARLCD, "APBCHARLCD"},
> +  {OPENCHIP_APBPWM, "APBPWM"},
> +  {OPENCHIP_APBPS2, "APBPS2"},
> +  {OPENCHIP_APBMMCSD, "APBMMCSD"},
> +  {OPENCHIP_APBNAND, "APBNAND"},
> +  {OPENCHIP_APBLPC, "APBLPC"},
> +  {OPENCHIP_APBCF, "APBCF"},
> +  {OPENCHIP_APBSYSACE, "APBSYSACE"},
> +  {OPENCHIP_APB1WIRE, "APB1WIRE"},
> +  {OPENCHIP_APBJTAG, "APBJTAG"},
> +  {OPENCHIP_APBSUI, "APBSUI"},
> +  {0, NULL}
> +static ambapp_device_name OPENCORES_devices[] =
> +  {0, NULL}
> +static ambapp_device_name CONTRIB_devices[] =
> +  {CONTRIB_CORE1, "CORE1"},
> +  {CONTRIB_CORE2, "CORE2"},
> +  {0, NULL}
> +static ambapp_device_name EONIC_devices[] =
> +  {0, NULL}
> +static ambapp_device_name RADIONOR_devices[] =
> +  {0, NULL}
> +static ambapp_device_name GLEICHMANN_devices[] =
> +  {GLEICHMANN_CUSTOM, "CUSTOM"},
> +  {GLEICHMANN_GEOLCD01, "GEOLCD01"},
> +  {GLEICHMANN_DAC, "DAC"},
> +  {GLEICHMANN_HPI, "HPI"},
> +  {GLEICHMANN_SPI, "SPI"},
> +  {GLEICHMANN_HIFC, "HIFC"},
> +  {GLEICHMANN_ADCDAC, "ADCDAC"},
> +  {GLEICHMANN_SPIOC, "SPIOC"},
> +  {GLEICHMANN_AC97, "AC97"},
> +  {0, NULL}
> +static ambapp_device_name MENTA_devices[] =
> +  {0, NULL}
> +static ambapp_device_name SUN_devices[] =
> +  {SUN_T1, "SUN_T1"},
> +  {SUN_S1, "SUN_S1"},
> +  {0, NULL}
> +static ambapp_device_name MOVIDIA_devices[] =
> +  {0, NULL}
> +static ambapp_device_name ORBITA_devices[] =
> +  {ORBITA_1553B, "1553B"},
> +  {ORBITA_429, "429"},
> +  {ORBITA_SPI, "SPI"},
> +  {ORBITA_I2C, "I2C"},
> +  {ORBITA_SMARTCARD, "SMARTCARD"},
> +  {ORBITA_SDCARD, "SDCARD"},
> +  {ORBITA_UART16550, "UART16550"},
> +  {ORBITA_CRYPTO, "CRYPTO"},
> +  {ORBITA_SYSIF, "SYSIF"},
> +  {ORBITA_PIO, "PIO"},
> +  {ORBITA_RTC, "RTC"},
> +  {ORBITA_COLORLCD, "COLORLCD"},
> +  {ORBITA_PCI, "PCI"},
> +  {ORBITA_DSP, "DSP"},
> +  {ORBITA_USBHOST, "USBHOST"},
> +  {ORBITA_USBDEV, "USBDEV"},
> +  {0, NULL}
> +static ambapp_device_name SYNOPSYS_devices[] =
> +  {0, NULL}
> +static ambapp_device_name NASA_devices[] =
> +  {NASA_EP32, "EP32"},
> +  {0, NULL}
> +static ambapp_device_name CAL_devices[] =
> +  {CAL_DDRCTRL, "DDRCTRL"},
> +  {0, NULL}
> +static ambapp_device_name EMBEDDIT_devices[] =
> +  {0, NULL}
> +static ambapp_device_name CETON_devices[] =
> +  {0, NULL}
> +static ambapp_device_name ACTEL_devices[] =
> +  {ACTEL_COREMP7, "COREMP7"},
> +  {0, NULL}
> +static ambapp_vendor_devnames vendors[] =
> +  {VENDOR_GAISLER, "GAISLER", GAISLER_devices},
> +  {VENDOR_PENDER, "PENDER", PENDER_devices},
> +  {VENDOR_ESA, "ESA", ESA_devices},
> +  {VENDOR_ASTRIUM, "ASTRIUM", ASTRIUM_devices},
> +  {VENDOR_OPENCHIP, "OPENCHIP", OPENCHIP_devices},
> +  {VENDOR_OPENCORES, "OPENCORES", OPENCORES_devices},
> +  {VENDOR_CONTRIB, "CONTRIB", CONTRIB_devices},
> +  {VENDOR_EONIC, "EONIC", EONIC_devices},
> +  {VENDOR_RADIONOR, "RADIONOR", RADIONOR_devices},
> +  {VENDOR_GLEICHMANN, "GLEICHMANN", GLEICHMANN_devices},
> +  {VENDOR_MENTA, "MENTA", MENTA_devices},
> +  {VENDOR_SUN, "SUN", SUN_devices},
> +  {VENDOR_MOVIDIA, "MOVIDIA", MOVIDIA_devices},
> +  {VENDOR_ORBITA, "ORBITA", ORBITA_devices},
> +  {VENDOR_SYNOPSYS, "SYNOPSYS", SYNOPSYS_devices},
> +  {VENDOR_NASA, "NASA", NASA_devices},
> +  {VENDOR_CAL, "CAL", CAL_devices},
> +  {VENDOR_EMBEDDIT, "EMBEDDIT", EMBEDDIT_devices},
> +  {VENDOR_CETON, "CETON", CETON_devices},
> +  {VENDOR_ACTEL, "ACTEL", ACTEL_devices},
> +  {0, NULL, NULL}
> +static char *ambapp_get_devname(ambapp_device_name *devs, int id)
> +       while (devs->device_id > 0) {
> +               if (devs->device_id == id)
> +                       return devs->name;
> +               devs++;
> +       return NULL;
> +char *ambapp_device_id2str(int vendor, int id)
> +       ambapp_vendor_devnames *ven = &vendors[0];
> +       while (ven->vendor_id > 0) {
> +               if (ven->vendor_id == vendor)
> +                       return ambapp_get_devname(ven->devices,id);
> +               ven++;
> +       return NULL;
> +char *ambapp_vendor_id2str(int vendor)
> +                       return ven->name;
> +               ven++;
> +       return NULL;
> +int ambapp_vendev_id2str(int vendor, int id, char *buf)
> +       char *dstr, *vstr;
> +       *buf = '\0';
> +       vstr = ambapp_vendor_id2str(vendor);
> +       if (vstr == NULL)
> +               return 0;
> +       dstr = ambapp_device_id2str(vendor, id);
> +       if (dstr == NULL)
> +               return 0;
> +       strcpy(buf, vstr);
> +       strcat(buf, "_");
> +       strcat(buf, dstr);
> +       return strlen(buf);
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
> index 0000000..c730173
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
> @@ -0,0 +1,92 @@
> +/* Old AMBA scanning Interface provided for backwards compability */
> +struct ambapp_dev_find_match_arg {
> +       int                     index;
> +       int                     count;
> +       int                     type;
> +       void                    *dev;
> +/* AMBA PP find routines */
> +int ambapp_dev_find_match(struct ambapp_dev *dev, int index, void *arg)
> +       struct ambapp_dev_find_match_arg *p = arg;
> +       if (p->index == 0) {
> +               /* Found controller, stop */
> +               if (p->type == DEV_APB_SLV) {
> +                       *(struct ambapp_apb_info *)p->dev = *DEV_TO_APB(dev);
> +                       p->dev = ((struct ambapp_apb_info *)p->dev)+1;
> +               } else {
> +                       *(struct ambapp_ahb_info *)p->dev = *DEV_TO_AHB(dev);
> +                       p->dev = ((struct ambapp_ahb_info *)p->dev)+1;
> +               p->count--;
> +               if (p->count < 1)
> +                       return 1;
> +       } else {
> +               p->index--;
> +       return 0;
> +int ambapp_find_apbslvs_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int index, int maxno)
> +       struct ambapp_dev_find_match_arg arg;
> +       arg.index = index;
> +       arg.count = maxno;
> +       arg.type = DEV_APB_SLV; /* APB */
> +       arg.dev = dev;
> +       ambapp_for_each(abus, (OPTIONS_ALL|OPTIONS_APB_SLVS), vendor, device,
> +                       ambapp_dev_find_match, &arg);
> +       return maxno - arg.count;
> +int ambapp_find_apbslv(struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev)
> +       return ambapp_find_apbslvs_next(abus, vendor, device, dev, 0, 1);
> +int ambapp_find_apbslv_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int index)
> +       return ambapp_find_apbslvs_next(abus, vendor, device, dev, index, 1);
> +int ambapp_find_apbslvs(struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int maxno)
> +       return ambapp_find_apbslvs_next(abus, vendor, device, dev, 0, maxno);
> +int ambapp_find_ahbslvs_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int index, int maxno)
> +       arg.type = DEV_AHB_SLV; /* AHB SLV */
> +       arg.dev = dev;
> +       ambapp_for_each(abus, (OPTIONS_ALL|OPTIONS_AHB_SLVS), vendor, device,
> +int ambapp_find_ahbslv_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int index)
> +       return ambapp_find_ahbslvs_next(abus, vendor, device, dev, index, 1);
> +int ambapp_find_ahbslv(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev)
> +       return ambapp_find_ahbslvs_next(abus, vendor, device, dev, 0, 1);
> +int ambapp_find_ahbslvs(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int maxno)
> +       return ambapp_find_ahbslvs_next(abus, vendor, device, dev, 0, maxno);
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c
> index 0000000..44d3b26
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c
> @@ -0,0 +1,26 @@
> + *  $Id: ambapp_parent.c,v
> +struct ambapp_dev *ambapp_find_parent(struct ambapp_dev *dev)
> +       while (dev->prev) {
> +               if (dev == dev->prev->children)
> +                       return dev->prev;
> +               dev = dev->prev;
> +       return NULL;
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
> index 0000000..eecca40
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
> @@ -0,0 +1,76 @@
> +/*  AMBA Plug & Play device information printing.
> + *  Prints a short description of APB and AHB devices.
> + *    Created
> +#include <stdio.h>
> +extern char *ambapp_device_id2str(int vendor, int id);
> +extern char *ambapp_vendor_id2str(int vendor);
> +struct ambapp_dev_print_arg {
> +       int show_depth;
> +static char *unknown = "unknown";
> +int ambapp_dev_print(struct ambapp_dev *dev, int index, void *arg)
> +       char *dev_str, *ven_str, *type_str;
> +       struct ambapp_dev_print_arg *p = arg;
> +       char dp[32];
> +       int i=0;
> +       unsigned int basereg;
> +       if (p->show_depth) {
> +               for (i=0; i<ambapp_depth(dev)*2; i+=2) {
> +                       dp[i] = ' ';
> +                       dp[i+1] = ' ';
> +       dp[i] = '\0';
> +       ven_str = ambapp_vendor_id2str(dev->vendor);
> +       if (!ven_str) {
> +               ven_str = unknown;
> +               dev_str = unknown;
> +       } else {
> +               dev_str = ambapp_device_id2str(dev->vendor,dev->device);
> +               if (!dev_str)
> +       if (dev->dev_type == DEV_APB_SLV) {
> +               /* APB */
> +               basereg = DEV_TO_APB(dev)->start;
> +               type_str = "apb";
> +       } else {
> +               /* AHB */
> +               basereg = DEV_TO_AHB(dev)->start[0];
> +               type_str = "ahb";
> +       printf("%s |-> 0x%x:0x%x:0x%x: %s_%s, %s: 0x%x, 0x%x (OWNER: 0x%x)\n",
> +               dp, index, dev->vendor, dev->device, ven_str, dev_str, type_str,
> +               basereg, (unsigned int)dev, (unsigned int)dev->owner);
> +       return 0;
> +void ambapp_print(struct ambapp_bus *abus, int show_depth)
> +       struct ambapp_dev_print_arg arg;
> +       arg.show_depth = show_depth;
> +                       (OPTIONS_ALL_DEVS|OPTIONS_ALL|OPTIONS_DEPTH_FIRST), -1,
> +                       -1, ambapp_dev_print, &arg);
> diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp.h b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> index 7ca2d13..5eb3f2a 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> @@ -1,10 +1,8 @@
> - *  AMBA Plag & Play Bus Driver Macros for LEON2
> - *  Macros used for AMBA Plug & Play bus scanning
> - *  COPYRIGHT (c) 2007.
> @@ -16,224 +14,345 @@
>  #ifndef __AMBAPP_H__
>  #define __AMBAPP_H__
> +/* Include VENDOR and DEVICE definitions */
>  #ifdef __cplusplus
>  extern "C" {
>  #endif
> -#define AMBA_CONF_AREA 0xff000
> -#define AMBA_AHB_SLAVE_CONF_AREA (1 << 11)
> -#define AMBA_AHB_CONF_WORDS 8
> -#define AMBA_APB_CONF_WORDS 2
> -#define AMBA_AHB_MASTERS 16
> -#define AMBA_AHB_SLAVES 16
> -#define AMBA_APB_SLAVES 16
> -#define AMBA_APBUARTS 8
> -/* Vendor codes */
> -#define VENDOR_GAISLER   1
> -#define VENDOR_PENDER    2
> -#define VENDOR_ESA       4
> -#define VENDOR_OPENCORES 8
> -/* Gaisler Research device id's */
> -#define GAISLER_LEON3     0x03
> -#define GAISLER_LEON3DSU  0x04
> -#define GAISLER_ETHAHB    0x05
> -#define GAISLER_APBMST    0x06
> -#define GAISLER_AHBUART   0x07
> -#define GAISLER_SRCTRL    0x08
> -#define GAISLER_SDCTRL    0x09
> -#define GAISLER_APBUART   0x0C
> -#define GAISLER_IRQMP     0x0D
> -#define GAISLER_AHBRAM    0x0E
> -#define GAISLER_GPTIMER   0x11
> -#define GAISLER_PCITRG    0x12
> -#define GAISLER_PCISBRG   0x13
> -#define GAISLER_PCIFBRG   0x14
> -#define GAISLER_PCITRACE  0x15
> -#define GAISLER_DMACTRL   0x16
> -#define GAISLER_OCCAN     0x19
> -#define GAISLER_PIOPORT   0x1A
> -#define GAISLER_ETHMAC    0x1D
> -#define GAISLER_SPACEWIRE 0x1f
> -#define GAISLER_AHB2AHB   0x20
> -#define GAISLER_I2CMST    0x28
> -#define GAISLER_GRSPW2    0x29
> -#define GAISLER_GRCAN     0x34
> -#define GAISLER_GRHCAN    0x3d
> -#define GAISLER_GRFIFO    0x35
> -#define GAISLER_GRADCDAC  0x36
> -#define GAISLER_GRPULSE   0x37
> -#define GAISLER_GRTIMER   0x38
> -#define GAISLER_FTAHBRAM  0x50
> -#define GAISLER_FTMCTRL   0x54
> -#define GAISLER_BRM       0x72
> -/* European Space Agency device id's */
> -#define ESA_LEON2        0x2
> -#define ESA_MCTRL        0xF
> -#define ESA_SPW2         0x12
> -/* Opencores device id's */
> -#define OPENCORES_PCIBR  0x4
> -#define OPENCORES_ETHMAC 0x5
> +/* Max supported AHB buses */
> +#define AHB_BUS_MAX 6
> +struct ambapp_dev;
> +struct ambapp_core;
> +struct ambapp_apb_info;
> +struct ambapp_ahb_info;
> +struct ambapp_dev {
> +       struct ambapp_dev *next;        /* Next */
> +       struct ambapp_dev *prev;        /* Previous Device. If (this ==
> +                                        * rev->child) prev is bus bridge */
> +       struct ambapp_dev *children;    /* Points to first device on sub-bus */
> +       void *owner;                    /* Owner of this AMBA device */
> +       unsigned char dev_type;         /* AHB MST, AHB SLV or APB SLV*/
> +       unsigned char vendor;           /* Vendor ID */
> +       unsigned short device;          /* Device ID */
> +       int devinfo[0];                 /* Device info (APB/AHB dep. on type) */
> - * Macros for manipulating Configuration registers
> -#define amba_get_confword(tab, index, word) (*((tab).addr[(index)]+(word)))
> +#define AMBAPP_FLAG_FFACT_DIR  0x100   /* Frequency factor direction, 0=down, 1=up */
> +#define AMBAPP_FLAG_FFACT      0x0f0   /* Frequency factor against top bus */
> +#define AMBAPP_FLAG_MBUS       0x00c
> +#define AMBAPP_FLAG_SBUS       0x003
> +/* Get APB or AHB information from a AMBA device */
> +#define DEV_TO_APB(adev) ((struct ambapp_apb_info *)((adev)->devinfo))
> +#define DEV_TO_AHB(adev) ((struct ambapp_ahb_info *)((adev)->devinfo))
> +#define DEV_TO_COMMON(adev) ((struct ambapp_common_info *)((adev)->devinfo))
> +/* Convert address of ambapp_apb_info/ambapp_ahb_info into ambapp_dev */
> +#define APB_TO_DEV(apb_info) ((struct ambapp_dev *)(unsigned int(apb_info) - \
> +                               offsetof(struct ambapp_dev, devinfo)))
> +#define AHB_TO_DEV(ahb_info) ((struct ambapp_dev *)(unsigned int(ahb_info) - \
> +struct ambapp_common_info {
> +       unsigned char irq;
> +       unsigned char ver;
> +       unsigned char ahbidx;   /* AHB Bus Index */
> -#define amba_vendor(x) (((x) >> 24) & 0xff)
> +struct ambapp_apb_info {
> +       /* COMMON */
> -#define amba_device(x) (((x) >> 12) & 0xfff)
> +       /* APB SPECIFIC */
> +       unsigned int start;
> +       unsigned int mask;
> +struct ambapp_ahb_info {
> +       /* COMMON */
> +       /* AHB SPECIFIC */
> +       unsigned int start[4];
> +       unsigned int mask[4];
> +       char type[4];           /* type[N] Determine type of start[N]-mask[N],
> +                                * 2=AHB Memory Space, 3=AHB I/O Space */
> +       unsigned int custom[3];
> +/* Describes a complete AMBA Core. Each device may consist of 3 interfaces */
> +struct ambapp_core {
> +       char                    irq;            /* irq=-1 indicate no IRQ */
> +       int                     index;          /* Core index */
> +       struct ambapp_ahb_info  *ahb_mst;
> +       struct ambapp_ahb_info  *ahb_slv;
> +       struct ambapp_apb_info  *apb_slv;
> +struct ambapp_ahb_bus {
> +       unsigned int ioarea;    /* AHB Bus IOAREA */
> +       unsigned int freq_hz;   /* Frequency of AHB Bus */
> +       struct ambapp_dev *bridge;/* Bridge Device on Parent AHB Bus */
> +       struct ambapp_dev *dev; /* First Device on AHB Bus */
> -#define amba_ahb_get_membar(tab, index, nr) (*((tab).addr[(index)]+4+(nr)))
> +struct ambapp_mmap {
> +       unsigned int            size;
> +       unsigned int            local_adr;
> +       unsigned int            remote_adr;
> -#define amba_ahb_get_custom(tab, index, nr) (*((tab).addr[(index)]+1+(nr)))
> +/* Complete AMBA PnP information */
> +struct ambapp_bus {
> +       struct ambapp_dev       *root;                  /* AHB/APB Device Tree*/
> +       struct ambapp_mmap      *mmaps;                 /* Memory MAP Array */
> +       struct ambapp_ahb_bus   ahbs[AHB_BUS_MAX];      /* AHB Buses */
> -#define amba_apb_get_membar(tab, index) (*((tab).addr[(index)]+1))
> + * Return values
> + *  0 - continue
> + *  1 - stop scanning
> +typedef int (*ambapp_func_t)(struct ambapp_dev *dev, int index, void *arg);
> +#define DEV_IS_FREE(dev) (dev->owner == NULL)
> +#define DEV_IS_ALLOCATED(dev) (dev->owner != NULL)
> +/* Options to ambapp_for_each */
> +#define OPTIONS_AHB_MSTS       0x00000001
> +#define OPTIONS_AHB_SLVS       0x00000002
> +#define OPTIONS_APB_SLVS       0x00000004
> +#define OPTIONS_ALL_DEVS       (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_APB_SLVS)
> +#define OPTIONS_FREE           0x00000010
> +#define OPTIONS_ALLOCATED      0x00000020
> +#define OPTIONS_ALL            (OPTIONS_FREE|OPTIONS_ALLOCATED)
> +/* Depth first search, Defualt is breath first search. */
> +#define OPTIONS_DEPTH_FIRST    0x00000100
> +#define DEV_AHB_NONE 0
> +#define DEV_AHB_MST  1
> +#define DEV_AHB_SLV  2
> +#define DEV_APB_SLV 3
> +/* Structures used to access Plug&Play information directly */
> +struct ambapp_pnp_ahb {
> +       const unsigned int      id;             /* VENDOR, DEVICE, VER, IRQ, */
> +       const unsigned int      custom[3];
> +       const unsigned int      mbar[4];        /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
> -#define amba_membar_start(mbar) (((mbar) & 0xfff00000) & (((mbar) & 0xfff0) << 16))
> +struct ambapp_pnp_apb {
> +       const unsigned int      iobar;          /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
> -#define amba_iobar_start(base, iobar) ((base) | ((((iobar) & 0xfff00000)>>12) & (((iobar) & 0xfff0)<<4)) )
> +#define ambapp_pnp_vendor(id) (((id) >> 24) & 0xff)
> +#define ambapp_pnp_device(id) (((id) >> 12) & 0xfff)
> +#define ambapp_pnp_ver(id) (((id)>>5) & 0x1f)
> +#define ambapp_pnp_irq(id) ((id) & 0x1f)
> -#define amba_irq(conf) ((conf) & 0x1f)
> +#define ambapp_pnp_start(mbar)  (((mbar) & 0xfff00000) & (((mbar) & 0xfff0) << 16))
> +#define ambapp_pnp_mbar_mask(mbar) (((mbar)>>4) & 0xfff)
> +#define ambapp_pnp_mbar_type(mbar) ((mbar) & 0xf)
> -#define amba_ver(conf) (((conf)>>5) & 0x1f)
> +#define ambapp_pnp_apb_start(iobar, base) ((base) | ((((iobar) & 0xfff00000)>>12) & (((iobar) & 0xfff0)<<4)) )
> +#define ambapp_pnp_apb_mask(iobar) ((~(ambapp_pnp_mbar_mask(iobar)<<8) & 0x000fffff) + 1)
> -#define amba_membar_type(mbar) ((mbar) & 0xf)
> +#define AMBA_TYPE_AHBIO_ADDR(addr,base_ioarea) ((unsigned int)(base_ioarea) | ((addr) >> 12))
>  #define AMBA_TYPE_APBIO 0x1
>  #define AMBA_TYPE_MEM   0x2
>  #define AMBA_TYPE_AHBIO 0x3
> -#define AMBA_TYPE_AHBIO_ADDR(addr,base_ioarea) ((unsigned int)(base_ioarea) | ((addr) >> 12))
> - *  Types and structure used for AMBA Plug & Play bus scanning
> +/* Copy Data from AMBA PnP I/O Area */
> +typedef void *(*ambapp_memcpy_t)(
> +       void *dest,             /* Destination RAM copy */
> +       const void *src,        /* Source AMBA PnP Address to copy from */
> +       int n,                  /* Number of bytes to be copied */
> +       struct ambapp_bus *abus /* Optional AMBA Bus pointer */
> +/* Scan a AMBA Plug & Play bus and create all device structures describing the
> + * the devices. The devices will form a tree, where every node describes one
> + * interface. The resulting tree is placed in the location pointed to by root.
> + * Since it the tree is located in RAM it is easier to work with AMBA buses
> + * that is located over PCI and SpaceWire etc.
> + * \param ioarea   The IO-AREA where Plug & Play information can be found.
> + * \param parent   Used internally when recursing down a bridge. Set to NULL.
> + * \param mmaps    Is used to perform address translation if needed.
> + * \param root     Resulting device node tree root is stored here.
> -typedef struct amba_device_table {
> -  int devnr;                    /* numbrer of devices on AHB or APB bus */
> -  unsigned int *addr[16];       /* addresses to the devices configuration tables */
> -} amba_device_table;
> -typedef struct {
> -  int devnr;
> -  unsigned int *addr[AMBA_APB_SLAVES];  /* addresses to the devices configuration tables */
> -  unsigned int apbmst[AMBA_APB_SLAVES]; /* pointer to AHB slave (which is a APB master) */
> -} amba_apb_dev;
> -struct amba_mmap {
> -  unsigned int cpu_adr;
> -  unsigned int size;
> -  unsigned int remote_amba_adr;
> -typedef struct _amba_confarea_type amba_confarea_type;
> -struct _amba_confarea_type {
> -  amba_confarea_type  *next;   /* next bus in chain */
> -  int                 notroot; /* is root of a bus (mother AHB has 64 masters/slaves rest 16) */
> -       unsigned int        ioarea;
> -  struct amba_mmap    *mmaps;
> -  amba_device_table   ahbmst;
> -  amba_device_table   ahbslv;
> -  amba_apb_dev        apbslv;
> -typedef struct {
> -  unsigned int start, irq, bus_id;
> -} amba_apb_device;
> -typedef struct {
> -  unsigned int start[4], irq, ver;
> -} amba_ahb_device;
> -/* Scans AMBA Plug&Play Information and convers that information
> - * to a more readable format in RAM.
> +extern int ambapp_scan(
> +/* Initialize the frequency [Hz] of all AHB Buses from knowing the frequency
> + * of one particular APB/AHB Device.
> +extern void ambapp_freq_init(
> +       unsigned int freq);
> +/* Returns the frequency [Hz] of a AHB/APB device */
> +extern unsigned int ambapp_freq_get(
> +       struct ambapp_dev *dev);
> +/* Iterates through all AMBA devices previously found, it calls func
> + * once for every device that match the search arguments.
> - * Will scan for - AHB Masters
> - *               - AHB Slaves
> - *               - APB Slaves (if a AHB/APB bridge is found)
> + * SEARCH OPTIONS
> + * All search options must be fulfilled, type of devices searched (options)
> + * and AMBA Plug&Play ID [VENDOR,DEVICE], before func() is called. The options
> + * can be use to search only for AMBA APB or AHB Slaves or AHB Masters for
> + * example. Note that when VENDOR=-1 or DEVICE=-1 it will match any vendor or
> + * device ID, this means setting both VENDOR and DEVICE to -1 will result in
> + * calling all devices matches the options argument.
> - * \param amba_conf AMBA P&P device info is placed here.
> - * \param ioarea address of AMBA Plug&Play information,
> - *             on LEON3 systems default is 0xfff00000
> - * \param mmaps Memory mmap specific to this amba bus,
> - *              if NULL no translation will be made (default).
> - *              A array of maps, ending with a entry with size=0.
> + * \param abus     AMBAPP Bus to search
> + * \param options  Search options, see OPTIONS_* above
> + * \param vendor   AMBAPP VENDOR ID to search for
> + * \param device   AMBAPP DEVICE ID to search for
> + * \param func     Function called for every device matching search options
> + * \param arg      Optional argument passed on to func
> + * func return value affects the search, returning a non-zero value will
> + * stop the search and ambapp_for_each will return immediately returning the
> + * same non-zero value.
> + * Return Values
> + *  0 - all devices was scanned
> + *  non-zero - stopped by user function returning the non-zero value
> -void amba_scan (amba_confarea_type * amba_conf, unsigned int ioarea,
> -                struct amba_mmap *mmaps);
> -void amba_print_conf (amba_confarea_type * amba_conf);
> -/***** APB SLAVES *****/
> -int amba_get_number_apbslv_devices (amba_confarea_type * amba_conf, int vendor,
> -                                    int device);
> -int amba_find_apbslv (amba_confarea_type * amba_conf, int vendor, int device,
> -                      amba_apb_device * dev);
> -int amba_find_next_apbslv (amba_confarea_type * amba_conf, int vendor,
> -                           int device, amba_apb_device * dev, int index);
> -int amba_find_apbslvs (amba_confarea_type * amba_conf, int vendor, int device,
> -                       amba_apb_device * devs, int maxno);
> -int amba_get_number_ahbslv_devices (amba_confarea_type * amba_conf, int vendor,
> -                                    int device);
> -int amba_find_ahbslv (amba_confarea_type * amba_conf, int vendor, int device,
> -                      amba_ahb_device * dev);
> +extern int ambapp_for_each(
> +       int vendor,
> +       int device,
> +       void *arg);
> +/* Helper function for ambapp_for_each(), find a device by index. If pcount
> + * is NULL the first device is returned, else pcount is interpreted as index
> + * by decrementing the value until zero is reaced: *count=0 first device,
> + * *count=1 second device etc.
> + * found
> +extern int ambapp_find_by_idx(struct ambapp_dev *dev, int index, void *pcount);
> -int amba_find_next_ahbslv (amba_confarea_type * amba_conf, int vendor,
> -                           int device, amba_ahb_device * dev, int index);
> +/* Get number of devices matching the options/vendor/device arguments, the
> + * arguments are passed onto ambapp_for_each().
> +extern int ambapp_dev_count(struct ambapp_bus *abus, unsigned int options,
> +                               int vendor, int device);
> -int amba_find_ahbslvs (amba_confarea_type * amba_conf, int vendor, int device,
> -                       amba_ahb_device * devs, int maxno);
> +/* Print short information about devices on the AMBA bus onto the console */
> +extern void ambapp_print(struct ambapp_bus *abus, int show_depth);
> +/* Mark a device taken (allocate), Owner field is set with owner Data. Returns
> + * -1 if device has already been allocated.
> +extern int ambapp_alloc_dev(struct ambapp_dev *dev, void *owner);
> +/* Owner field is cleared, which indicates that device is not allocated */
> +extern void ambapp_free_dev(struct ambapp_dev *dev);
> -/***** AHB MASTERS *****/
> +/* Find AHB/APB Bridge or AHB/AHB Bridge Parent */
> +extern struct ambapp_dev *ambapp_find_parent(struct ambapp_dev *dev);
> -/* Return number of AHB Master devices which has given vendor and device */
> -int amba_get_number_ahbmst_devices (amba_confarea_type * amba_conf, int vendor,
> -                                    int device);
> +/* Returns bus depth (number of sub AHB buses) of device from root bus */
> +extern int ambapp_depth(struct ambapp_dev *dev);
> -/* Get First AHB Master device of this vendor&device id */
> -int amba_find_ahbmst (amba_confarea_type * amba_conf, int vendor, int device,
> +/* Get Device Name from AMBA PnP name database */
> -/* Get AHB Master device of this vendor&device id. (setting nr to 0 is eqivalent to calling amba_find_ahbmst() ) */
> -int amba_find_next_ahbmst (amba_confarea_type * amba_conf, int vendor,
> +/* Get Vendor Name from AMBA PnP name database */
> -/* Get first nr AHB Master devices, put them into dev (which is an array of nr length) */
> -int amba_find_ahbmsts (amba_confarea_type * amba_conf, int vendor, int device,
> +/* Set together VENDOR_DEVICE Name from AMBA PnP name database. Return length
> + * of C-string stored in buf not including string termination '\0'.
> +extern int ambapp_vendev_id2str(int vendor, int id, char *buf);
> +/* Help functions for backwards compability */
> +extern int ambapp_find_apbslv(
> +       int vendor,
> +       int device,
> +       struct ambapp_apb_info *dev);
> +extern int ambapp_find_apbslv_next(
> +       int vendor,
> +       int device,
> +       struct ambapp_apb_info *dev,
> +       int index);
> +extern int ambapp_find_apbslvs_next(
> +       int vendor,
> +       int device,
> +       int index,
> +       int maxno);
> +extern int ambapp_find_apbslvs(
> +       int vendor,
> +       int device,
> +       int maxno);
> +extern int ambapp_find_ahbslv(
> +       int vendor,
> +       int device,
> +       struct ambapp_ahb_info *dev);
> +extern int ambapp_find_ahbslv_next(
> +       int vendor,
> +       int device,
> +       struct ambapp_ahb_info *dev,
> +       int index);
> +extern int ambapp_find_ahbslvs_next(
> +       int vendor,
> +       int device,
> +       int index,
> +       int maxno);
> +extern int ambapp_find_ahbslvs(
> +       int vendor,
> +       int device,
> +       int maxno);
>  /******** AMBA DEVICES *******/
> diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h b/c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h
> index 0000000..e6f3601
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h
> @@ -0,0 +1,245 @@
> +/*  AMBA Plug & Play Bus Vendor and Device IDs.
> + *  COPYRIGHT (c) 2008.
> + *  Gaisler Research
> + *  This header file provide all known VENDOR and DEVICE IDs available
> + *  in the AMBA Plug & Play information. Taken from GRLIB 3386.
> +#ifndef __AMBAPP_DEVS_H__
> +#define __AMBAPP_DEVS_H__
> +/* Vendor codes */
> +#define VENDOR_GAISLER       1
> +#define VENDOR_PENDER        2
> +#define VENDOR_ESA           4
> +#define VENDOR_ASTRIUM       6
> +#define VENDOR_OPENCHIP      7
> +#define VENDOR_OPENCORES     8
> +#define VENDOR_CONTRIB       9
> +#define VENDOR_EONIC         11
> +#define VENDOR_RADIONOR      15
> +#define VENDOR_GLEICHMANN    16
> +#define VENDOR_MENTA         17
> +#define VENDOR_SUN           19
> +#define VENDOR_MOVIDIA       20
> +#define VENDOR_ORBITA        23
> +#define VENDOR_SYNOPSYS      33
> +#define VENDOR_NASA          34
> +#define VENDOR_ACTEL         172
> +#define VENDOR_CAL           202
> +#define VENDOR_EMBEDDIT      234
> +#define VENDOR_CETON         203
> +/* Gaisler Research device id's */
> +#define GAISLER_LEON2DSU     0x002
> +#define GAISLER_LEON3        0x003
> +#define GAISLER_LEON3DSU     0x004
> +#define GAISLER_ETHAHB       0x005
> +#define GAISLER_APBMST       0x006
> +#define GAISLER_AHBUART      0x007
> +#define GAISLER_SRCTRL       0x008
> +#define GAISLER_SDCTRL       0x009
> +#define GAISLER_SSRCTRL      0x00a
> +#define GAISLER_APBUART      0x00c
> +#define GAISLER_IRQMP        0x00d
> +#define GAISLER_AHBRAM       0x00e
> +#define GAISLER_AHBDPRAM     0x00f
> +#define GAISLER_GPTIMER      0x011
> +#define GAISLER_PCITRG       0x012
> +#define GAISLER_PCISBRG      0x013
> +#define GAISLER_PCIFBRG      0x014
> +#define GAISLER_PCITRACE     0x015
> +#define GAISLER_DMACTRL      0x016
> +#define GAISLER_AHBTRACE     0x017
> +#define GAISLER_DSUCTRL      0x018
> +#define GAISLER_CANAHB       0x019
> +#define GAISLER_GPIO         0x01a
> +#define GAISLER_AHBROM       0x01b
> +#define GAISLER_AHBJTAG      0x01c
> +#define GAISLER_ETHMAC       0x01d
> +#define GAISLER_SWNODE       0x01e
> +#define GAISLER_SPW          0x01f
> +#define GAISLER_AHB2AHB      0x020
> +#define GAISLER_USBDC        0x021
> +#define GAISLER_USB_DCL      0x022
> +#define GAISLER_DDRMP        0x023
> +#define GAISLER_ATACTRL      0x024
> +#define GAISLER_DDRSP        0x025
> +#define GAISLER_EHCI         0x026
> +#define GAISLER_UHCI         0x027
> +#define GAISLER_I2CMST       0x028
> +#define GAISLER_SPW2         0x029
> +#define GAISLER_AHBDMA       0x02a
> +#define GAISLER_NUHOSP3      0x02b
> +#define GAISLER_CLKGATE      0x02c
> +#define GAISLER_SPICTRL      0x02d
> +#define GAISLER_DDR2SP       0x02e
> +#define GAISLER_SLINK        0x02f
> +#define GAISLER_GRTM         0x030
> +#define GAISLER_GRTC         0x031
> +#define GAISLER_GRPW         0x032
> +#define GAISLER_GRCTM        0x033
> +#define GAISLER_GRHCAN       0x034
> +#define GAISLER_GRFIFO       0x035
> +#define GAISLER_GRADCDAC     0x036
> +#define GAISLER_GRPULSE      0x037
> +#define GAISLER_GRTIMER      0x038
> +#define GAISLER_AHB2PP       0x039
> +#define GAISLER_GRVERSION    0x03a
> +#define GAISLER_APB2PW       0x03b
> +#define GAISLER_PW2APB       0x03c
> +#define GAISLER_GRCAN        0x03d
> +#define GAISLER_I2CSLV       0x03e
> +#define GAISLER_U16550       0x03f
> +#define GAISLER_AHBMST_EM    0x040
> +#define GAISLER_AHBSLV_EM    0x041
> +#define GAISLER_GRTESTMOD    0x042
> +#define GAISLER_ASCS         0x043
> +#define GAISLER_IPMVBCTRL    0x044
> +#define GAISLER_SPIMCTRL     0x045
> +#define GAISLER_L4STAT       0x047
> +#define GAISLER_LEON4        0x048
> +#define GAISLER_LEON4DSU     0x049
> +#define GAISLER_GRPWM        0x04a
> +#define GAISLER_L2CACHE      0x04b
> +#define GAISLER_GR1553B      0x04d
> +#define GAISLER_GRIOMMU      0x04f
> +#define GAISLER_FTAHBRAM     0x050
> +#define GAISLER_FTSRCTRL     0x051
> +#define GAISLER_AHBSTAT      0x052
> +#define GAISLER_LEON3FT      0x053
> +#define GAISLER_FTMCTRL      0x054
> +#define GAISLER_FTSDCTRL     0x055
> +#define GAISLER_FTSRCTRL8    0x056
> +#define GAISLER_MEMSCRUB     0x057
> +#define GAISLER_APBPS2       0x060
> +#define GAISLER_VGACTRL      0x061
> +#define GAISLER_LOGAN        0x062
> +#define GAISLER_SVGACTRL     0x063
> +#define GAISLER_T1AHB        0x064
> +#define GAISLER_MP7WRAP      0x065
> +#define GAISLER_GRSYSMON     0x066
> +#define GAISLER_GRACECTRL    0x067
> +#define GAISLER_B1553BC      0x070
> +#define GAISLER_B1553RT      0x071
> +#define GAISLER_B1553BRM     0x072
> +#define GAISLER_GRAES        0x073
> +#define GAISLER_SATCAN       0x080
> +#define GAISLER_CANMUX       0x081
> +#define GAISLER_GRTMRX       0x082
> +#define GAISLER_GRTCTX       0x083
> +#define GAISLER_GRTMDESC     0x084
> +#define GAISLER_GRTMVC       0x085
> +#define GAISLER_GEFFE        0x086
> +#define GAISLER_AES          0x073
> +#define GAISLER_ECC          0x074
> +#define GAISLER_PCIF         0x075
> +#define GAISLER_CLKMOD       0x076
> +#define GAISLER_HAPSTRAK     0x077
> +#define GAISLER_TEST_1X2     0x078
> +#define GAISLER_WILD2AHB     0x079
> +#define GAISLER_BIO1         0x07a
> +#define GAISLER_GRAESDMA     0x07b
> +#define GAISLER_GRPCI2       0x07c
> +#define GAISLER_GRPCI2_DMA   0x07d
> +#define GAISLER_SPWCUC       0x089
> +#define GAISLER_SPW2_DMA     0x08a
> +#define GAISLER_SPW_ROUTER   0x08b
> +#define GAISLER_PIPEWRAPPER  0xffa
> +#define GAISLER_L2TIME       0xffd  /* internal device: leon2 timer */
> +#define GAISLER_L2C          0xffe  /* internal device: leon2compat */
> +#define GAISLER_PLUGPLAY     0xfff  /* internal device: plug & play configarea */
> +/* European Space Agency device id's */
> +#define ESA_LEON2            0x002
> +#define ESA_LEON2APB         0x003
> +#define ESA_IRQ              0x005
> +#define ESA_TIMER            0x006
> +#define ESA_UART             0x007
> +#define ESA_CFG              0x008
> +#define ESA_IO               0x009
> +#define ESA_MCTRL            0x00f
> +#define ESA_PCIARB           0x010
> +#define ESA_HURRICANE        0x011
> +#define ESA_SPW_RMAP         0x012
> +#define ESA_SPW2             0x012
> +#define ESA_AHBUART          0x013
> +#define ESA_SPWA             0x014
> +#define ESA_BOSCHCAN         0x015
> +#define ESA_IRQ2             0x016
> +#define ESA_AHBSTAT          0x017
> +#define ESA_WPROT            0x018
> +#define ESA_WPROT2           0x019
> +#define ESA_PDEC3AMBA        0x020
> +#define ESA_PTME3AMBA        0x021
> +#define OPENCHIP_APBGPIO     0x001
> +#define OPENCHIP_APBI2C      0x002
> +#define OPENCHIP_APBSPI      0x003
> +#define OPENCHIP_APBCHARLCD  0x004
> +#define OPENCHIP_APBPWM      0x005
> +#define OPENCHIP_APBPS2      0x006
> +#define OPENCHIP_APBMMCSD    0x007
> +#define OPENCHIP_APBNAND     0x008
> +#define OPENCHIP_APBLPC      0x009
> +#define OPENCHIP_APBCF       0x00a
> +#define OPENCHIP_APBSYSACE   0x00b
> +#define OPENCHIP_APB1WIRE    0x00c
> +#define OPENCHIP_APBJTAG     0x00d
> +#define OPENCHIP_APBSUI      0x00e
> +#define CONTRIB_CORE1        0x001
> +#define CONTRIB_CORE2        0x002
> +#define GLEICHMANN_CUSTOM    0x001
> +#define GLEICHMANN_GEOLCD01  0x002
> +#define GLEICHMANN_DAC       0x003
> +#define GLEICHMANN_HPI       0x004
> +#define GLEICHMANN_SPI       0x005
> +#define GLEICHMANN_HIFC      0x006
> +#define GLEICHMANN_ADCDAC    0x007
> +#define GLEICHMANN_SPIOC     0x008
> +#define GLEICHMANN_AC97      0x009
> +#define SUN_T1               0x001
> +#define SUN_S1               0x011
> +#define ORBITA_1553B         0x001
> +#define ORBITA_429           0x002
> +#define ORBITA_SPI           0x003
> +#define ORBITA_I2C           0x004
> +#define ORBITA_SMARTCARD     0x064
> +#define ORBITA_SDCARD        0x065
> +#define ORBITA_UART16550     0x066
> +#define ORBITA_CRYPTO        0x067
> +#define ORBITA_SYSIF         0x068
> +#define ORBITA_PIO           0x069
> +#define ORBITA_RTC           0x0c8
> +#define ORBITA_COLORLCD      0x12c
> +#define ORBITA_PCI           0x190
> +#define ORBITA_DSP           0x1f4
> +#define ORBITA_USBHOST       0x258
> +#define ORBITA_USBDEV        0x2bc
> +#define NASA_EP32            0x001
> +#define CAL_DDRCTRL          0x188
> +#define ACTEL_COREMP7        0x001
> +/* Opencores device id's */
> +#define OPENCORES_PCIBR  0x4
> +#define OPENCORES_ETHMAC 0x5
> +#endif
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
