[PATCH 33.1 2/5] LEON3: clock driver use new AMBAPP layer
Sun Apr 15 18:39:46 UTC 2012
Looks ok.
On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/leon3/clock/ckinit.c |   14 ++++++++------
>  1 files changed, 8 insertions(+), 6 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> index 3cdbb20..dacfd2e 100644
> --- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> +++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> @@ -22,6 +22,7 @@
>  #include <bsp.h>
>  #include <bspopts.h>
> +#include <ambapp.h>
>  #if SIMSPARC_FAST_IDLE==1
>  #define CLOCK_DRIVER_USE_FAST_IDLE
> @@ -59,14 +60,15 @@ static int clkirq;
>  #define Clock_driver_support_find_timer() \
>   do { \
> -    int cnt; \
> -    amba_apb_device dev; \
> +    struct ambapp_dev *adev; \
> -    /* Find LEON3 GP Timer */ \
> -    cnt = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&dev); \
> -    if ( cnt > 0 ) { \
> +    /* Find first LEON3 GP Timer */ \
> +    adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),\
> +              VENDOR_GAISLER, GAISLER_GPTIMER, ambapp_find_by_idx, NULL); \
> +    if (adev) { \
>       /* Found APB GPTIMER Timer */ \
> -      LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) dev.start; \
> +      LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) \
> +                         DEV_TO_APB(adev)->start; \
>       clkirq = (LEON3_Timer_Regs->status & 0xf8) >> 3; \
>       Adjust_clkirq_for_node(); \
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
