[PATCH 33.4 5/5] LEON: updated drivers to use new AMBAPP Layer
Sun Apr 15 18:40:35 UTC 2012
Largely mechanical and only in sparc BSPs--looks ok.
On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> The drivers are updated to use the new AMBA layer, however the
> backwards-compatibility interface (ambapp_old) is used.
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/leon2/cchip/cchip.c         |   37 +++++++++-----------
>  c/src/lib/libbsp/sparc/leon2/rasta/rasta.c         |   24 ++++++------
>  c/src/lib/libbsp/sparc/shared/1553/b1553brm.c      |   14 ++++----
>  c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c  |    2 +-
>  .../lib/libbsp/sparc/shared/1553/b1553brm_rasta.c  |    2 +-
>  c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c    |   14 +++++++
>  c/src/lib/libbsp/sparc/shared/can/grcan.c          |   16 ++++----
>  c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c    |    2 +-
>  c/src/lib/libbsp/sparc/shared/can/occan.c          |   16 ++++----
>  c/src/lib/libbsp/sparc/shared/can/occan_pci.c      |    2 +-
>  c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c         |   14 ++++----
>  c/src/lib/libbsp/sparc/shared/include/ambapp.h     |    9 +++++
>  c/src/lib/libbsp/sparc/shared/include/apbuart.h    |    4 +-
>  .../lib/libbsp/sparc/shared/include/apbuart_pci.h  |    2 +-
>  .../libbsp/sparc/shared/include/apbuart_rasta.h    |    2 +-
>  c/src/lib/libbsp/sparc/shared/include/b1553brm.h   |    4 +-
>  .../lib/libbsp/sparc/shared/include/b1553brm_pci.h |    4 +-
>  .../libbsp/sparc/shared/include/b1553brm_rasta.h   |    4 +-
>  c/src/lib/libbsp/sparc/shared/include/grcan.h      |    2 +-
>  .../lib/libbsp/sparc/shared/include/grcan_rasta.h  |    2 +-
>  c/src/lib/libbsp/sparc/shared/include/grspw.h      |    2 +-
>  c/src/lib/libbsp/sparc/shared/include/grspw_pci.h  |    4 +-
>  .../lib/libbsp/sparc/shared/include/grspw_rasta.h  |    4 +-
>  c/src/lib/libbsp/sparc/shared/include/i2cmst.h     |    2 +-
>  c/src/lib/libbsp/sparc/shared/include/occan.h      |    2 +-
>  c/src/lib/libbsp/sparc/shared/include/occan_pci.h  |    2 +-
>  c/src/lib/libbsp/sparc/shared/spw/grspw.c          |   29 +++++-----------
>  c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c      |    2 +-
>  c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c    |    2 +-
>  c/src/lib/libbsp/sparc/shared/uart/apbuart.c       |   14 ++++----
>  c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c   |    2 +-
>  c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c |    2 +-
>  32 files changed, 126 insertions(+), 117 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
> index 59c17dd..7924fe8 100644
> --- a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
> +++ b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
> @@ -83,8 +83,8 @@ typedef struct {
>        int bus, dev, fun;
>        /* AMBA bus */
> -       amba_confarea_type amba_bus;
> -       struct amba_mmap amba_maps[2];
> +       struct ambapp_bus amba_bus;
> +       struct ambapp_mmap amba_maps[2];
>        /* FT AHB SRAM */
>        int ftsram_size; /* kb */
> @@ -100,8 +100,7 @@ int init_pcif(void){
>        int i,bus,dev,fun;
>        pci_bridge_regs *pcib;
>        amba_bridge_regs *ambab;
> -       int amba_master_cnt;
> -       amba_confarea_type *abus;
> +       struct ambapp_bus *abus;
>   if ( BSP_pciFindDevice(0x1AC8, 0x0701, 0, &bus, &dev, &fun) == 0 ) {
> @@ -136,13 +135,13 @@ int init_pcif(void){
>        /* AMBA MAP cc1.bars[1] (in CPU) ==> 0xf0000000(remote amba address) */
>        cc1.amba_maps[0].size = 0x04000000;
> -       cc1.amba_maps[0].cpu_adr = cc1.bars[1];
> -       cc1.amba_maps[0].remote_amba_adr = 0xfc000000;
> +       cc1.amba_maps[0].local_adr = cc1.bars[1];
> +       cc1.amba_maps[0].remote_adr = 0xfc000000;
>        /* Mark end of table */
>        cc1.amba_maps[1].size=0;
> -       cc1.amba_maps[1].cpu_adr = 0;
> -       cc1.amba_maps[1].remote_amba_adr = 0;
> +       cc1.amba_maps[1].local_adr = 0;
> +       cc1.amba_maps[1].remote_adr = 0;
>        /* Enable I/O and Mem accesses */
>        pci_read_config_dword(bus, dev, fun, 0x4, &com1);
> @@ -161,16 +160,14 @@ int init_pcif(void){
>        /* Scan bus for AMBA devices */
>        abus = &cc1.amba_bus;
> -       memset(abus,0,sizeof(amba_confarea_type));
> -       amba_scan(abus,cc1.bars[1]+0x3f00000,&cc1.amba_maps[0]);
> +       memset(abus,0,sizeof(*abus));
> +       ambapp_scan(abus,cc1.bars[1]+0x3f00000,NULL,&cc1.amba_maps[0]);
> -       /* Get number of amba masters */
> -       amba_master_cnt = abus->ahbmst.devnr;
> -#ifdef BOARD_INFO
> -       printk("Found %d AMBA masters\n\r",amba_master_cnt);
> -#endif
> -       for(i=1; i<amba_master_cnt; i++){
> +       /* Init all msters, max 16 */
> +       for(i=1; i<16; i++) {
>                ambab->ambabars[i] = 0x40000000;
> +               if (READ_REG(&ambab->ambabars[i]) != 0x40000000)
> +                       break;
>        /* Enable PCI Master */
> @@ -192,20 +189,20 @@ int init_pcif(void){
>  #define GAISLER_FTAHBRAM 0x50
>  #endif
>  int init_onboard_sram(void){
> -       amba_ahb_device ahb;
> -       amba_apb_device apb;
> +       struct ambapp_ahb_info ahb;
> +       struct ambapp_apb_info apb;
>        unsigned int conf, size;
>        /* Find SRAM controller
>         * 1. AHB slave interface
>         * 2. APB slave interface
> -       if ( amba_find_apbslv(&cc1.amba_bus,VENDOR_GAISLER,GAISLER_FTAHBRAM,&apb) != 1 ){
> +       if ( ambapp_find_apbslv(&cc1.amba_bus,VENDOR_GAISLER,GAISLER_FTAHBRAM,&apb) != 1 ){
>                printk("On Board FT SRAM not found (APB)\n");
>                return -1;
> -       if ( amba_find_ahbslv(&cc1.amba_bus,VENDOR_GAISLER,GAISLER_FTAHBRAM,&ahb) != 1 ){
> +       if ( ambapp_find_ahbslv(&cc1.amba_bus,VENDOR_GAISLER,GAISLER_FTAHBRAM,&ahb) != 1 ){
>                printk("On Board FT SRAM not found (AHB)\n");
>                return -1;
> diff --git a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> index 7b66b07..c6dc93d 100644
> --- a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> +++ b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> @@ -209,16 +209,16 @@ void rasta_interrrupt_register(void *handler, int irqno, void *arg)
> -int rasta_get_gpio(amba_confarea_type *abus, int index, struct gpio_reg **regs, int *irq)
> +int rasta_get_gpio(struct ambapp_bus *abus, int index, struct gpio_reg **regs, int *irq)
> -  amba_apb_device dev;
> +  struct ambapp_apb_info dev;
>   int cores;
>   if ( !abus )
>     return -1;
>   /* Scan PnP info for GPIO port number 'index' */
> -  cores = amba_find_next_apbslv(abus,VENDOR_GAISLER,GAISLER_PIOPORT,&dev,index);
> +  cores = ambapp_find_apbslv_next(abus,VENDOR_GAISLER,GAISLER_GPIO,&dev,index);
>   if ( cores < 1 )
>     return -1;
> @@ -232,8 +232,8 @@ int rasta_get_gpio(amba_confarea_type *abus, int index, struct gpio_reg **regs,
>  /* AMBA Plug&Play information */
> -static amba_confarea_type abus;
> -static struct amba_mmap amba_maps[3];
> +static struct ambapp_bus abus;
> +static struct ambapp_mmap amba_maps[3];
>  int rasta_register(void)
> @@ -316,23 +316,23 @@ int rasta_register(void)
>     /* AMBA MAP bar0 (in CPU) ==> 0x80000000(remote amba address) */
>     amba_maps[0].size = 0x10000000;
> -    amba_maps[0].cpu_adr = bar0;
> -    amba_maps[0].remote_amba_adr = 0x80000000;
> +    amba_maps[0].local_adr = bar0;
> +    amba_maps[0].remote_adr = 0x80000000;
>     /* AMBA MAP bar1 (in CPU) ==> 0x40000000(remote amba address) */
>     amba_maps[1].size = 0x10000000;
> -    amba_maps[1].cpu_adr = bar1;
> -    amba_maps[1].remote_amba_adr = 0x40000000;
> +    amba_maps[1].local_adr = bar1;
> +    amba_maps[1].remote_adr = 0x40000000;
>     amba_maps[2].size=0;
> -    amba_maps[2].cpu_adr = 0;
> -    amba_maps[2].remote_amba_adr = 0;
> +    amba_maps[2].local_adr = 0;
> +    amba_maps[2].remote_adr = 0;
>     memset(&abus,0,sizeof(abus));
>     /* Start AMBA PnP scan at first AHB bus */
> -    amba_scan(&abus,bar0+(AHB1_IOAREA_BASE_ADDR&~0xf0000000),&amba_maps[0]);
> +    ambapp_scan(&abus,bar0+(AHB1_IOAREA_BASE_ADDR&~0xf0000000),NULL,&amba_maps[0]);
>     printk("Registering RASTA GRCAN driver\n\r");
> diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
> index e447df2..7d5bfcd 100644
> --- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
> +++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
> @@ -279,7 +279,7 @@ typedef struct {
>  static int brm_cores;
>  static unsigned int allbrm_memarea;
>  static brm_priv *brms;
> -static amba_confarea_type *amba_bus;
> +static struct ambapp_bus *amba_bus;
>  static unsigned int    allbrm_cfg_clksel;
>  static unsigned int allbrm_cfg_clkdiv;
>  static unsigned int allbrm_cfg_freq;
> @@ -325,7 +325,7 @@ int brm_register_leon3_ramon_fpga(void){
>         * The BRM is always clocked with 24MHz.
>         * 3 in BRM enhanced register will select 24MHz
> -       return b1553brm_register(&amba_conf,0,0,3);
> +       return b1553brm_register(&ambapp_plb,0,0,3);
>  int brm_register_leon3_ramon_asic(void){
> @@ -335,12 +335,12 @@ int brm_register_leon3_ramon_asic(void){
> -       return b1553brm_register(&amba_conf,2,0,3);
> +       return b1553brm_register(&ambapp_plb,2,0,3);
>  #endif
>  #endif
> -int B1553BRM_PREFIX(_register)(amba_confarea_type *bus, unsigned int clksel, unsigned int clkdiv, unsigned int brm_freq)
> +int B1553BRM_PREFIX(_register)(struct ambapp_bus *bus, unsigned int clksel, unsigned int clkdiv, unsigned int brm_freq)
>     rtems_status_code r;
>     rtems_device_major_number m;
> @@ -568,7 +568,7 @@ static rtems_device_driver brm_initialize(rtems_device_major_number major, rtems
>        int dev_cnt;
>        char fs_name[20];
>        brm_priv *brm;
> -       amba_ahb_device ambadev;
> +       struct ambapp_ahb_info ambadev;
>        char *mem;
>        FUNCDBG("brm_initialize\n");
> @@ -577,7 +577,7 @@ static rtems_device_driver brm_initialize(rtems_device_major_number major, rtems
>        strcpy(fs_name,B1553BRM_DEVNAME);
>        /* Find all BRM devices */
> -       dev_cnt = amba_get_number_ahbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_BRM);
> +       dev_cnt = ambapp_get_number_ahbslv_devices(amba_bus, VENDOR_GAISLER, GAISLER_B1553BRM);
>        if ( dev_cnt < 1 ){
>                /* Failed to find any CAN cores! */
>                printk("BRM: Failed to find any BRM cores\n\r");
> @@ -619,7 +619,7 @@ static rtems_device_driver brm_initialize(rtems_device_major_number major, rtems
>                brm = &brms[minor];
>                /* Get AMBA AHB device info from Plug&Play */
> -               amba_find_next_ahbslv(amba_bus,VENDOR_GAISLER,GAISLER_BRM,&ambadev,minor);
> +               ambapp_find_ahbslv_next(amba_bus,VENDOR_GAISLER,GAISLER_B1553BRM,&ambadev,minor);
>                /* Copy Basic HW info */
>                brm->regs = (void *)ambadev.start[0];
> diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
> index 76c9f2e..3be26b1 100644
> --- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
> +++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
> @@ -82,7 +82,7 @@ static void b1553brmpci_interrupt_handler(int irq, void *arg);
>  int b1553brm_pci_register(
> - amba_confarea_type *bus,
> + struct ambapp_bus *bus,
>  unsigned int brm_freq,
> diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
> index 10adb0a..d1fa4d6 100644
> --- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
> +++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
> @@ -82,7 +82,7 @@ static void b1553brmrasta_interrupt_handler(int irq, void *arg);
>  int b1553brm_rasta_register(
> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
> index c730173..1b543ab 100644
> --- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
> @@ -61,6 +61,13 @@ int ambapp_find_apbslvs(struct ambapp_bus *abus, int vendor, int device, struct
>        return ambapp_find_apbslvs_next(abus, vendor, device, dev, 0, maxno);
> +int ambapp_get_number_apbslv_devices(struct ambapp_bus *abus, int vendor, int device)
> +       return ambapp_dev_count(abus,
> +                       (OPTIONS_ALL|OPTIONS_APB_SLVS),
> +                       vendor, device);
>  int ambapp_find_ahbslvs_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int index, int maxno)
>        struct ambapp_dev_find_match_arg arg;
> @@ -90,3 +97,10 @@ int ambapp_find_ahbslvs(struct ambapp_bus *abus, int vendor, int device, struct
>        return ambapp_find_ahbslvs_next(abus, vendor, device, dev, 0, maxno);
> +int ambapp_get_number_ahbslv_devices(struct ambapp_bus *abus, int vendor, int device)
> +                       (OPTIONS_ALL|OPTIONS_AHB_SLVS),
> +                       vendor, device);
> diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan.c b/c/src/lib/libbsp/sparc/shared/can/grcan.c
> index fb48550..434348b 100644
> --- a/c/src/lib/libbsp/sparc/shared/can/grcan.c
> +++ b/c/src/lib/libbsp/sparc/shared/can/grcan.c
> @@ -212,7 +212,7 @@ struct grcan_priv {
>  static int grcan_core_cnt;
>  struct grcan_priv *grcans;
>  struct grcan_device_info *grcan_cores;
> @@ -1050,7 +1050,7 @@ static rtems_device_driver grcan_initialize(
>   int minor;
>   struct grcan_priv *pDev;
>   rtems_status_code status;
>   char fs_name[20];
>   unsigned int sys_freq_hz;
> @@ -1062,10 +1062,10 @@ static rtems_device_driver grcan_initialize(
>   /* find GRCAN cores */
>   if ( !grcan_cores ) {
> -    grcan_core_cnt = amba_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,deviceid);
> +    grcan_core_cnt = ambapp_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,deviceid);
>     if ( grcan_core_cnt < 1 ){
>       deviceid = GAISLER_GRCAN;
>       if ( grcan_core_cnt < 1 ) {
>         DBG("GRCAN: Using AMBA Plug&Play, found %d cores\n",grcan_core_cnt);
>         return RTEMS_UNSATISFIED;
> @@ -1094,10 +1094,10 @@ static rtems_device_driver grcan_initialize(
>  #if defined(LEON3)
>   /* LEON3: find timer address via AMBA Plug&Play info */
> -    amba_apb_device gptimer;
> +    struct ambapp_apb_info gptimer;
>     LEON3_Timer_Regs_Map *tregs;
> -    if (amba_find_apbslv (&amba_conf, VENDOR_GAISLER, GAISLER_GPTIMER, &gptimer)
> +    if (ambapp_find_apbslv (&ambapp_plb, VENDOR_GAISLER, GAISLER_GPTIMER, &gptimer)
>         == 1) {
>       tregs = (LEON3_Timer_Regs_Map *) gptimer.start;
>       sys_freq_hz = (tregs->scaler_reload + 1) * 1000 * 1000;
> @@ -1132,7 +1132,7 @@ static rtems_device_driver grcan_initialize(
>     /* Find core address & IRQ */
> -      amba_find_next_apbslv(amba_bus,VENDOR_GAISLER,deviceid,&dev,minor);
> +      ambapp_find_apbslv_next(amba_bus,VENDOR_GAISLER,deviceid,&dev,minor);
>       pDev->irq = dev.irq;
>       pDev->regs = (struct grcan_regs *)dev.start;
>     }else{
> @@ -1799,7 +1799,7 @@ int GRCAN_PREFIX(_register_abs)(struct grcan_device_info *devices, int dev_cnt)
>  /* Use prescanned AMBA Plug&Play information to find all GRCAN cores */
> -int GRCAN_PREFIX(_register)(amba_confarea_type *abus)
> +int GRCAN_PREFIX(_register)(struct ambapp_bus *abus)
>   FUNCDBG();
> diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c b/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
> index f9b126f..7fad48e 100644
> --- a/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
> +++ b/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
> @@ -77,7 +77,7 @@ unsigned int grcan_rasta_rambase;
>  #include "grcan.c"
> -int grcan_rasta_ram_register(amba_confarea_type *abus, int rambase)
> +int grcan_rasta_ram_register(struct ambapp_bus *abus, int rambase)
>   grcan_rasta_rambase = rambase;
> diff --git a/c/src/lib/libbsp/sparc/shared/can/occan.c b/c/src/lib/libbsp/sparc/shared/can/occan.c
> index 78c901a..6c06b3d 100644
> --- a/c/src/lib/libbsp/sparc/shared/can/occan.c
> +++ b/c/src/lib/libbsp/sparc/shared/can/occan.c
> @@ -282,7 +282,7 @@ static void occan_interrupt_handler(rtems_vector_number v);
>  #endif
>  static int can_cores;
>  static occan_priv *cans;
>  static unsigned int sys_freq_hz;
> @@ -914,7 +914,7 @@ static int pelican_speed_auto(occan_priv *priv){
>  static rtems_device_driver occan_initialize(rtems_device_major_number major, rtems_device_minor_number unused, void *arg){
>        int dev_cnt,minor,subcore_cnt,devi,subi,subcores;
>        occan_priv *can;
>        char fs_name[20];
> @@ -922,7 +922,7 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>        strcpy(fs_name,OCCAN_DEVNAME);
>        /* find device on amba bus */
> -       dev_cnt = amba_get_number_ahbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_OCCAN);
> +       dev_cnt = ambapp_get_number_ahbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_CANAHB);
>        if ( dev_cnt < 1 ){
>                printk("OCCAN: Failed to find any CAN cores\n\r");
> @@ -934,10 +934,10 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>  #if defined(LEON3)
> -               if ( amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&gptimer) == 1 ){
> +               if ( ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_GPTIMER,&gptimer) == 1 ){
>                        tregs = (LEON3_Timer_Regs_Map *)gptimer.start;
>                        sys_freq_hz = (tregs->scaler_reload+1)*1000*1000;
>                        DBG("OCCAN: detected %dHZ system frequency\n\r",sys_freq_hz);
> @@ -973,7 +973,7 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>        for(subcore_cnt=devi=0; devi<dev_cnt; devi++){
> -               amba_find_next_ahbslv(amba_bus,VENDOR_GAISLER,GAISLER_OCCAN,&ambadev,devi);
> +               ambapp_find_ahbslv_next(amba_bus,VENDOR_GAISLER,GAISLER_CANAHB,&ambadev,devi);
>                subcore_cnt += (ambadev.ver & 0x7)+1;
> @@ -987,7 +987,7 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>        for(devi=0; devi<dev_cnt; devi++){
>                /* Get AHB device info */
>                subcores = (ambadev.ver & 0x7)+1;
>                DBG("OCCAN: on dev %d found %d sub cores\n\r",devi,subcores);
> @@ -1802,7 +1802,7 @@ static void occan_interrupt_handler(rtems_vector_number v){
>  static rtems_driver_address_table occan_driver = OCCAN_DRIVER_TABLE_ENTRY;
> -int OCCAN_PREFIX(_register)(amba_confarea_type *bus){
> +int OCCAN_PREFIX(_register)(struct ambapp_bus *bus){
> diff --git a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
> index 2dd2e5b..b27beb1 100644
> --- a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
> +++ b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
> @@ -46,7 +46,7 @@ static void inline occanpci_set_channel(occan_priv *priv, int channel){
>                *chan_sel = 0xffffffff;
> -int occan_pci_register(amba_confarea_type *bus)
> +int occan_pci_register(struct ambapp_bus *bus)
>        /* Setup configuration */
> diff --git a/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c b/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
> index fb6a573..bf321dc 100644
> --- a/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
> +++ b/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
> @@ -285,7 +285,7 @@ static gr_i2cmst_desc_t gr_i2cmst_desc = {
>  /* Scans for I2CMST core and initalizes i2c library */
> -rtems_status_code leon_register_i2c(amba_confarea_type *abus)
> +rtems_status_code leon_register_i2c(struct ambapp_bus *abus)
>  #if defined(DEBUG)
>   printk("leon_register_i2c called...");
> @@ -293,11 +293,11 @@ rtems_status_code leon_register_i2c(amba_confarea_type *abus)
>   int rc;
>   int device_found = 0;
> -  amba_apb_device apbi2cmst;
> +  struct ambapp_apb_info apbi2cmst;
>   /* Scan AMBA bus for I2CMST core */
> -  device_found = amba_find_apbslv(abus, VENDOR_GAISLER, GAISLER_I2CMST,
> -                                 &apbi2cmst);
> +  device_found = ambapp_find_apbslv(abus, VENDOR_GAISLER, GAISLER_I2CMST,
> +                                   &apbi2cmst);
>   if (device_found == 1) {
> @@ -317,11 +317,11 @@ rtems_status_code leon_register_i2c(amba_confarea_type *abus)
>  #if defined(LEON3)
> -         if (amba_find_apbslv(abus,VENDOR_GAISLER,
> -                              GAISLER_GPTIMER,&gptimer) == 1 ) {
> +         if (ambapp_find_apbslv(abus,VENDOR_GAISLER,
> +                                GAISLER_GPTIMER,&gptimer) == 1 ) {
>            gr_i2cmst_desc.prv.sysfreq = (tregs->scaler_reload+1)*1000;
>          } else {
> diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp.h b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> index 5eb3f2a..8c86157 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> @@ -326,6 +326,11 @@ extern int ambapp_find_apbslvs(
>        struct ambapp_apb_info *dev,
>        int maxno);
> +extern int ambapp_get_number_apbslv_devices(
> +       struct ambapp_bus *abus,
> +       int vendor,
> +       int device);
>  extern int ambapp_find_ahbslv(
>        int vendor,
> @@ -354,6 +359,10 @@ extern int ambapp_find_ahbslvs(
>        int maxno);
> +extern int ambapp_get_number_ahbslv_devices(
> +       int vendor,
> +       int device);
>  /******** AMBA DEVICES *******/
> diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart.h b/c/src/lib/libbsp/sparc/shared/include/apbuart.h
> index c8a6e35..c948b24 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/apbuart.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/apbuart.h
> @@ -72,9 +72,9 @@ typedef struct {
>  /* Register APBUART driver
>  * bus =  pointer to AMBA bus description used to search for APBUART(s).
> - *        (&amba_conf for LEON3), (LEON2: see amba_scan)
> + *        (&ambapp_plb for LEON3), (LEON2: see amba_scan)
> -int apbuart_register (amba_confarea_type * bus);
> +int apbuart_register (struct ambapp_bus *bus);
>  #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h b/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
> index e806429..11ac33e 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
> @@ -24,7 +24,7 @@ extern "C" {
> -int apbuart_pci_register (amba_confarea_type * bus);
> +int apbuart_pci_register (struct ambapp_bus * bus);
>  /* This function must be called on APBUART interrupt. Called from the
>  * PCI interrupt handler.
> diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h b/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
> index 1edf6f9..61c6144 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
> -int apbuart_rasta_register(amba_confarea_type *bus);
> +int apbuart_rasta_register(struct ambapp_bus *bus);
>  * RASTA interrupt handler.
> diff --git a/c/src/lib/libbsp/sparc/shared/include/b1553brm.h b/c/src/lib/libbsp/sparc/shared/include/b1553brm.h
> index f5fd343..f0f09c5 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/b1553brm.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/b1553brm.h
> @@ -158,9 +158,9 @@ int brm_register_leon3_ramon_asic(void);
>  /* Register BRM driver
>  * See (struct brm_reg).w_ctrl for clksel and clkdiv.
>  * See Enhanced register (the least signinficant 2 bits) in BRM Core for brm_freq
> - * bus = &amba_conf for LEON3. (LEON2 not yet supported for this driver)
> + * bus = &ambapp_plb for LEON3. (LEON2 not yet supported for this driver)
> -int b1553brm_register(amba_confarea_type *bus, unsigned int clksel, unsigned int clkdiv, unsigned int brm_freq);
> +int b1553brm_register(struct ambapp_bus *bus, unsigned int clksel, unsigned int clkdiv, unsigned int brm_freq);
>  #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h b/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
> index 74f9d32..9861dc3 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
> @@ -22,7 +22,7 @@ extern "C" {
>  * Memory setup:
>  * memarea = 128k aligned pointer to memory (if zero malloc will be used) (as the CPU sees it)
> @@ -30,7 +30,7 @@ extern "C" {
> diff --git a/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h b/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
> index cd51658..360b72f 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
>  * Memory setup:
> diff --git a/c/src/lib/libbsp/sparc/shared/include/grcan.h b/c/src/lib/libbsp/sparc/shared/include/grcan.h
> index 8b3ed15..f8f577d 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/grcan.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/grcan.h
> @@ -190,7 +190,7 @@ struct grcan_device_info {
>  int grcan_register_abs(struct grcan_device_info *devices, int dev_cnt);
>  /* Use prescanned AMBA Plug&Play information to find all GRFIFO cores */
> -int grcan_register(amba_confarea_type *abus);
> +int grcan_register(struct ambapp_bus *abus);
>  #if 0
>  void grcan_register(unsigned int baseaddr, unsigned int ram_base);
>  void grcan_interrupt_handler(rtems_vector_number v);
> diff --git a/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h b/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
> index 1f96da6..20a2fac 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
> @@ -13,7 +13,7 @@ extern "C" {
>  * rambase is address of the first GRCAN core has it's TX buffer, followed by
>  * it's RX buffer
> -int grcan_rasta_ram_register(amba_confarea_type *abus, int rambase);
> +int grcan_rasta_ram_register(struct ambapp_bus *abus, int rambase);
>  extern void (*grcan_rasta_int_reg)(void *handler, int irq, void *arg);
> diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw.h b/c/src/lib/libbsp/sparc/shared/include/grspw.h
> index 4c6c869..e60aa87 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/grspw.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/grspw.h
> @@ -111,7 +111,7 @@ typedef struct {
>  #define SPACEWIRE_IOCTRL_START               64
>  #define SPACEWIRE_IOCTRL_STOP                65
> -int grspw_register(amba_confarea_type *bus);
> +int grspw_register(struct ambapp_bus *bus);
>  #if 0
> diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h b/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
> index aea50f3..9e2cd60 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
> @@ -20,14 +20,14 @@ extern "C" {
>  #endif
>  /* Register GRSPW Driver
>  * Memory setup:
>  * hw_address = address that HW must use to access memarea. (used in the translation process)
> -int grspw_pci_register (amba_confarea_type * bus,
> +int grspw_pci_register (struct ambapp_bus *bus,
>                         unsigned int memarea, unsigned int hw_address);
> diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h b/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
> index 0e4e5be..c4c0cd0 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
>  #endif
>  * Memory setup:
>  * ram_base = 128k aligned pointer to memory (as the CPU sees it)
>  int grspw_rasta_register(
> diff --git a/c/src/lib/libbsp/sparc/shared/include/i2cmst.h b/c/src/lib/libbsp/sparc/shared/include/i2cmst.h
> index 21780ee..9f612fa 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/i2cmst.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/i2cmst.h
> @@ -68,7 +68,7 @@ typedef struct gr_i2cmst_desc {
>  } gr_i2cmst_desc_t;
> -rtems_status_code leon_register_i2c(amba_confarea_type *abus);
> +rtems_status_code leon_register_i2c(struct ambapp_bus *abus);
>  #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/sparc/shared/include/occan.h b/c/src/lib/libbsp/sparc/shared/include/occan.h
> index 12ec42a..5c875b3 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/occan.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/occan.h
> @@ -147,7 +147,7 @@ struct occan_afilter {
>  #define OCCAN_BLK_MODE_RX 0x1
>  #define OCCAN_BLK_MODE_TX 0x2
> -int occan_register(amba_confarea_type *bus);
> +int occan_register(struct ambapp_bus *bus);
>  #define OCCAN_SPEED_500K 500000
> diff --git a/c/src/lib/libbsp/sparc/shared/include/occan_pci.h b/c/src/lib/libbsp/sparc/shared/include/occan_pci.h
> index 2f46293..d351f85 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/occan_pci.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/occan_pci.h
> @@ -23,7 +23,7 @@ extern "C" {
>  * bus = pointer to AMBA bus description used to search for OC_CAN contrller(s).
> -int occan_pci_register(amba_confarea_type *bus);
> +int occan_pci_register(struct ambapp_bus *bus);
>  /* This function must be called on OC_CAN interrupt. Called from the
>  * PCI interrupt handler. irq = AMBA IRQ assigned to the OC_CAN device,
> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw.c b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> index 6a9da79..513a53a 100644
> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> @@ -370,9 +370,9 @@ static rtems_device_driver grspw_control(
>     grspw_control }
>  static rtems_driver_address_table grspw_driver = GRSPW_DRIVER_TABLE_ENTRY;
> -int GRSPW_PREFIX(_register)(amba_confarea_type *bus)
> +int GRSPW_PREFIX(_register)(struct ambapp_bus *bus)
> @@ -389,10 +389,10 @@ int GRSPW_PREFIX(_register)(amba_confarea_type *bus)
>  #ifdef LEON3
>                        sys_freq_khz = (tregs->scaler_reload+1)*1000;
>                        SPACEWIRE_DBG("GRSPW: detected %dkHZ system frequency\n\r",sys_freq_khz);
> @@ -609,7 +609,7 @@ static rtems_device_driver grspw_initialize(
>         char c;
>         GRSPW_DEV *pDev;
>         char console_name[20];
>         SPACEWIRE_DBG2("spacewire driver initialization\n");
> @@ -620,19 +620,8 @@ static rtems_device_driver grspw_initialize(
>         i=0; spw_cores = 0; spw_cores2 = 0;
>         /* get number of GRSPW cores */
> -        spw_cores = amba_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_SPACEWIRE);
> -        spw_cores2 = amba_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_GRSPW2);
> -#if 0
> -                               if ( spw_cores > SPACEWIRE_MAX_CORENR )
> -                                       spw_cores = SPACEWIRE_MAX_CORENR;
> -        while (i < amba_conf.apbslv.devnr) {
> -                conf = amba_get_confword(amba_conf.apbslv, i, 0);
> -                if ((amba_vendor(conf) == VENDOR_GAISLER) && (amba_device(conf) == GAISLER_SPACEWIRE))
> -                        spw_cores++;
> -                i++;
> -#endif
> +        spw_cores = ambapp_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_SPW);
> +        spw_cores2 = ambapp_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_SPW2);
>         if ( (spw_cores+spw_cores2) < 1 ){
>                 /* No GRSPW cores around... */
> @@ -653,10 +642,10 @@ static rtems_device_driver grspw_initialize(
>                 /* Get device */
>                 if ( spw_cores > minor ) {
> -                        amba_find_next_apbslv(amba_bus,VENDOR_GAISLER,GAISLER_SPACEWIRE,&dev,minor);
> +                        ambapp_find_apbslv_next(amba_bus,VENDOR_GAISLER,GAISLER_SPW,&dev,minor);
>                         pDev->core_ver = 1;
>                 } else {
> -                        amba_find_next_apbslv(amba_bus,VENDOR_GAISLER,GAISLER_GRSPW2,&dev,minor-spw_cores);
> +                        ambapp_find_apbslv_next(amba_bus,VENDOR_GAISLER,GAISLER_SPW2,&dev,minor-spw_cores);
>                         pDev->core_ver = 2;
> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
> index a8003be..2a9a8d6 100644
> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
> @@ -79,7 +79,7 @@ int grspwpci_interrupt_handler(int irq, void *arg);
>  int grspw_pci_register(
> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
> index 6cd5698..9bf9437 100644
> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
> @@ -88,7 +88,7 @@ unsigned int grspw_rasta_memarea_address;
> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> index b3f4bbd..800d352 100644
> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> @@ -116,7 +116,7 @@ static unsigned int sys_freq_hz;
>  #define APBUART_DRIVER_TABLE_ENTRY { apbuart_initialize, apbuart_open, apbuart_close, apbuart_read, apbuart_write, apbuart_control }
>  static rtems_driver_address_table apbuart_driver = APBUART_DRIVER_TABLE_ENTRY;
>  static void apbuart_interrupt(apbuart_priv *uart);
>  #ifdef APBUART_DEFINE_INTHANDLER
> @@ -322,7 +322,7 @@ static void apbuart_interrupt(apbuart_priv *uart){
> -int APBUART_PREFIX(_register)(amba_confarea_type *bus) {
> +int APBUART_PREFIX(_register)(struct ambapp_bus *bus) {
> @@ -353,13 +353,13 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number  major,
>        int i;
>        char fs_name[20];
>        FUNCDBG("apbuart_initialize\n");
>        /* Find all APB UART devices */
> -       dev_cnt = amba_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_APBUART);
> +       dev_cnt = ambapp_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_APBUART);
>        if ( dev_cnt < 1 ){
>                printk("APBUART: Failed to find any APBUART cores\n\r");
> @@ -384,10 +384,10 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number  major,
>  #if defined(LEON3)
>                        DBG("APBUART: detected %dHZ system frequency\n\r",sys_freq_hz);
> @@ -413,7 +413,7 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number  major,
>        for(i=0; i<dev_cnt; i++){
> -               amba_find_next_apbslv(amba_bus,VENDOR_GAISLER,GAISLER_APBUART,&dev,i);
> +               ambapp_find_apbslv_next(amba_bus,VENDOR_GAISLER,GAISLER_APBUART,&dev,i);
>                printk("APBUART[%d]: at 0x%x irq %d (0x%x)\n\r",i,dev.start,dev.irq,(unsigned int)&apbuarts[i]);
> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
> index 54d14ce..fce1197 100644
> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
> @@ -24,7 +24,7 @@ void apbuartpci_interrupt_handler(int irq, void *arg);
>  #include "apbuart.c"
> -int apbuart_pci_register(amba_confarea_type *bus)
> +int apbuart_pci_register(struct ambapp_bus *bus)
> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
> index 4b8734f..3196bbb 100644
> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
> @@ -24,7 +24,7 @@ void apbuartrasta_interrupt_handler(int irq, void *arg);
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
