[PATCH 33.1 2/5] LEON3: clock driver use new AMBAPP layer
Daniel Hellstrom daniel at gaisler.com
Mon Apr 16 08:26:16 UTC 2012
On 04/16/2012 12:54 AM, Joel Sherrill wrote:
> On 04/15/2012 01:39 PM, Gedare Bloom wrote:
>> Looks ok.
> Minor style issue. Arguments are supposed to be "(arg1, arg2)"
> But OK to me if that is fixed and all required patches are OK.
Ok, will repost a fixed patch.
>> On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom<daniel at gaisler.com>  wrote:
>>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>>   c/src/lib/libbsp/sparc/leon3/clock/ckinit.c |   14 ++++++++------
>>>   1 files changed, 8 insertions(+), 6 deletions(-)
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>> index 3cdbb20..dacfd2e 100644
>>> --- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>> +++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>> @@ -22,6 +22,7 @@
>>>   #include<bsp.h>
>>>   #include<bspopts.h>
>>> +#include<ambapp.h>
>>>   #if SIMSPARC_FAST_IDLE==1
>>>   #define CLOCK_DRIVER_USE_FAST_IDLE
>>> @@ -59,14 +60,15 @@ static int clkirq;
>>>   #define Clock_driver_support_find_timer() \
>>>    do { \
>>> -    int cnt; \
>>> -    amba_apb_device dev; \
>>> +    struct ambapp_dev *adev; \
>>> -    /* Find LEON3 GP Timer */ \
>>> -    cnt = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&dev); \
>>> -    if ( cnt>  0 ) { \
>>> +    /* Find first LEON3 GP Timer */ \
>>> +    adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),\
>>> +              VENDOR_GAISLER, GAISLER_GPTIMER, ambapp_find_by_idx, NULL); \
>>> +    if (adev) { \
>>>        /* Found APB GPTIMER Timer */ \
>>> -      LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) dev.start; \
>>> +      LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) \
>>> +                         DEV_TO_APB(adev)->start; \
>>>        clkirq = (LEON3_Timer_Regs->status&  0xf8)>>  3; \
>>>        Adjust_clkirq_for_node(); \
>>> 1.7.0.4
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
