[PATCH 1/3] score: Remove _Stack_Adjust_size()
Mon Apr 16 15:11:53 UTC 2012
On Mon, Apr 16, 2012 at 5:00 AM, Sebastian Huber
> On 04/15/2012 08:05 PM, Gedare Bloom wrote:
>> Where did the original stack size adjustment come from / what was its
>> motivation?
> The
> uint32_t _Stack_Adjust_size(size_t size)
>  return size + CPU_STACK_ALIGNMENT;
> is there since 1995-05-11 19:39:37.  It is probably there since the
> workspace allocator only aligns the memory by CPU_HEAP_ALIGNMENT.  The stack
> needs to be aligned by CPU_STACK_ALIGNMENT.  Thus if these values are
> arbitrary you have to adjust the allocated memory to fit as a stack.  You
> need to allocate at least CPU_STACK_ALIGNMENT - 1 additional bytes to do
> this.
>> Will this break something that was "fixed" by the
>> previous approach?
> I think this fixed a non-existing problem.  The CPU_HEAP_ALIGNMENT and
> CPU_STACK_ALIGNMENT are roughly the same on all supported architectures.
>  Also the requested stack size must be considerable larger than
> CPU_STACK_ALIGNMENT, otherwise you cannot call any functions.  Thus it is
> not a problem at all to align the memory.
The change seems reasonable (by sight) to me. The problem with
alignment changes is they can break in unpredictable ways :( But we'll
see if anyone ever complains I guess.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> E-Mail  : sebastian.huber at embedded-brains.de
> PGP     : Public key available on request.
