genmcf548x patches
Mon Apr 16 23:25:47 UTC 2012
On 04/16/2012 06:04 PM, Gedare Bloom wrote:
> Seems ok. the filename and function names are a mouthful. how about
> areanyinittasksfp.c as a filename?
Fine with me.  I will add some test code and docs before
merging.
> -Gedare
> On Mon, Apr 16, 2012 at 5:36 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com>  wrote:
>> Hi
>> Attached are two patches for review. The first adds
>> a new method to determine if any initialization
>> tasks/threads in any API use the FPU.
>> The second modifies the genmcf548x BSP to use this
>> new helper routine.
>> If these are OK, then I will need to add some documentation
>> and tests.
>> Joel Sherrill, Ph.D.             Director of Research&     Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>     Support Available             (256) 722-9985
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
