[PATCH] no_cpu: replace no_cpu_isr with rtems_isr
Mon Apr 16 23:39:44 UTC 2012
 c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h    |    2 +-
 c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c |    4 ++--
 cpukit/score/cpu/no_cpu/rtems/score/types.h     |    6 ------
 3 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h b/c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
index 8513f7d..c137ab4 100644
--- a/c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
+++ b/c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
@@ -38,7 +38,7 @@ extern "C" {
 /* functions */
-no_cpu_isr_entry set_vector(                    /* returns old vector */
+rtems_isr_entry set_vector(                     /* returns old vector */
   rtems_isr_entry     handler,                  /* isr routine        */
   rtems_vector_number vector,                   /* vector number      */
   int                 type                      /* RTEMS or RAW intr  */
diff --git a/c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c b/c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c
index e72a92f..deb2b13 100644
--- a/c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c
+++ b/c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c
@@ -25,13 +25,13 @@
 #include <bsp.h>
-  no_cpu_isr_entry previous_isr;
+  rtems_isr_entry previous_isr;
   if ( type )
     rtems_interrupt_catch( handler, vector, (rtems_isr_entry *) &previous_isr );
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/types.h b/cpukit/score/cpu/no_cpu/rtems/score/types.h
index c1fdc6d..2fb960c 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/types.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/types.h
@@ -34,12 +34,6 @@ extern "C" {
 /** This defines the type for a priority bit map entry. */
 typedef uint16_t Priority_bit_map_Control;
-/** This defines the return type for an ISR entry point. */
-typedef void no_cpu_isr;
-/** This defines the prototype for an ISR entry point. */
-typedef no_cpu_isr ( *no_cpu_isr_entry )( void );
 #ifdef __cplusplus
 #endif
1.7.1
