genmcf548x patches
Tue Apr 17 17:05:02 UTC 2012
On 04/17/2012 11:58 AM, Thomas Doerfler wrote:
> Hi,
> it is some years ago I added these specific lines. Background is (as far
> as I remember):
> - that the MCF54xx context switch code avoids swapping out the FPU (or
> FPU-like) registers, if this is not needed
> - access to the FPU is enabled/disabled using a specific bit in the
> Cache(!) Control register CACR
> - RTEMS creates classic init tasks with FPU disabled (?) but POSIX tasks
> implicitly have FPU enabled, since they do not have the corresponding
> task attribute
> - ADA (which is used on this target) uses a POSIX task for initialization.
> Joel is right, there should be a general query to detect this situation.
> My current code is at least sub-optimal.
Thanks. I suspected much of the above.
I need to make the routine return false on configurations without
hardware FP, document it, and test it. Unfortunately, I think this
will take at least two tests. One for POSIX and one for Classic.
--joel
> wkr,
> Thomas.
> Am 17.04.2012 09:30, schrieb Sebastian Huber:
>> Hi,
>> why do we need this special case for initialization tasks?
Joel Sherrill, Ph.D.             Director of Research&   Development
