[PATCH 33.3 v2 4/5] LEON: updated drivers to use new AMBAPP Layer
Wed Apr 18 00:29:31 UTC 2012
Go ahead and commit the series for amba
Gedare Bloom <gedare at rtems.org> wrote:
>I think this is 33.4 v2.
>The entire series looks good to me.
>On Tue, Apr 17, 2012 at 10:25 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
>> The drivers are updated to use the new AMBA layer, however the
>> backwards-compatibility interface (ambapp_old) is used.
>> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>>  c/src/lib/libbsp/sparc/leon2/cchip/cchip.c         |   45 ++--
>>  c/src/lib/libbsp/sparc/leon2/rasta/rasta.c         |   33 ++-
>>  c/src/lib/libbsp/sparc/shared/1553/b1553brm.c      |   15 +-
>>  c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c  |    2 +-
>>  .../lib/libbsp/sparc/shared/1553/b1553brm_rasta.c  |    2 +-
>>  c/src/lib/libbsp/sparc/shared/can/grcan.c          |   18 +-
>>  c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c    |    2 +-
>>  c/src/lib/libbsp/sparc/shared/can/occan.c          |   20 +-
>>  c/src/lib/libbsp/sparc/shared/can/occan_pci.c      |    2 +-
>>  c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c         |   14 +-
>>  c/src/lib/libbsp/sparc/shared/include/ambapp.h     |  273 ++++++++++----------
>>  c/src/lib/libbsp/sparc/shared/include/apbuart.h    |    4 +-
>>  .../lib/libbsp/sparc/shared/include/apbuart_pci.h  |    2 +-
>>  .../libbsp/sparc/shared/include/apbuart_rasta.h    |    2 +-
>>  c/src/lib/libbsp/sparc/shared/include/b1553brm.h   |    4 +-
>>  .../lib/libbsp/sparc/shared/include/b1553brm_pci.h |    4 +-
>>  .../libbsp/sparc/shared/include/b1553brm_rasta.h   |    4 +-
>>  c/src/lib/libbsp/sparc/shared/include/grcan.h      |    2 +-
>>  .../lib/libbsp/sparc/shared/include/grcan_rasta.h  |    2 +-
>>  c/src/lib/libbsp/sparc/shared/include/grspw.h      |    2 +-
>>  c/src/lib/libbsp/sparc/shared/include/grspw_pci.h  |    4 +-
>>  .../lib/libbsp/sparc/shared/include/grspw_rasta.h  |    4 +-
>>  c/src/lib/libbsp/sparc/shared/include/i2cmst.h     |    2 +-
>>  c/src/lib/libbsp/sparc/shared/include/occan.h      |    2 +-
>>  c/src/lib/libbsp/sparc/shared/include/occan_pci.h  |    2 +-
>>  c/src/lib/libbsp/sparc/shared/spw/grspw.c          |   35 +--
>>  c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c      |    2 +-
>>  c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c    |    2 +-
>>  c/src/lib/libbsp/sparc/shared/uart/apbuart.c       |   16 +-
>>  c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c   |    2 +-
>>  c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c |    2 +-
>>  31 files changed, 266 insertions(+), 259 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
>> index 59c17dd..b3809aa 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
>> +++ b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
>> @@ -1,5 +1,9 @@
>> - * $Id$
>> + *  GR-701 (Companion Chip) PCI board driver
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.com/license/LICENSE.
>>  #include <bsp.h>
>> @@ -83,8 +87,8 @@ typedef struct {
>>        int bus, dev, fun;
>>        /* AMBA bus */
>> -       amba_confarea_type amba_bus;
>> -       struct amba_mmap amba_maps[2];
>> +       struct ambapp_bus amba_bus;
>> +       struct ambapp_mmap amba_maps[2];
>>        /* FT AHB SRAM */
>>        int ftsram_size; /* kb */
>> @@ -100,8 +104,7 @@ int init_pcif(void){
>>        int i,bus,dev,fun;
>>        pci_bridge_regs *pcib;
>>        amba_bridge_regs *ambab;
>> -       int amba_master_cnt;
>> -       amba_confarea_type *abus;
>> +       struct ambapp_bus *abus;
>>   if ( BSP_pciFindDevice(0x1AC8, 0x0701, 0, &bus, &dev, &fun) == 0 ) {
>> @@ -136,13 +139,13 @@ int init_pcif(void){
>>        /* AMBA MAP cc1.bars[1] (in CPU) ==> 0xf0000000(remote amba address) */
>>        cc1.amba_maps[0].size = 0x04000000;
>> -       cc1.amba_maps[0].cpu_adr = cc1.bars[1];
>> -       cc1.amba_maps[0].remote_amba_adr = 0xfc000000;
>> +       cc1.amba_maps[0].local_adr = cc1.bars[1];
>> +       cc1.amba_maps[0].remote_adr = 0xfc000000;
>>        /* Mark end of table */
>>        cc1.amba_maps[1].size=0;
>> -       cc1.amba_maps[1].cpu_adr = 0;
>> -       cc1.amba_maps[1].remote_amba_adr = 0;
>> +       cc1.amba_maps[1].local_adr = 0;
>> +       cc1.amba_maps[1].remote_adr = 0;
>>        /* Enable I/O and Mem accesses */
>>        pci_read_config_dword(bus, dev, fun, 0x4, &com1);
>> @@ -161,16 +164,14 @@ int init_pcif(void){
>>        /* Scan bus for AMBA devices */
>>        abus = &cc1.amba_bus;
>> -       memset(abus,0,sizeof(amba_confarea_type));
>> -       amba_scan(abus,cc1.bars[1]+0x3f00000,&cc1.amba_maps[0]);
>> +       memset(abus,0,sizeof(*abus));
>> +       ambapp_scan(abus, cc1.bars[1]+0x3f00000, NULL, &cc1.amba_maps[0]);
>> -       /* Get number of amba masters */
>> -       amba_master_cnt = abus->ahbmst.devnr;
>> -#ifdef BOARD_INFO
>> -       printk("Found %d AMBA masters\n\r",amba_master_cnt);
>> -#endif
>> -       for(i=1; i<amba_master_cnt; i++){
>> +       /* Init all msters, max 16 */
>> +       for(i=1; i<16; i++) {
>>                ambab->ambabars[i] = 0x40000000;
>> +               if (READ_REG(&ambab->ambabars[i]) != 0x40000000)
>> +                       break;
>>        /* Enable PCI Master */
>> @@ -192,20 +193,22 @@ int init_pcif(void){
>>  #define GAISLER_FTAHBRAM 0x50
>>  #endif
>>  int init_onboard_sram(void){
>> -       amba_ahb_device ahb;
>> -       amba_apb_device apb;
>> +       struct ambapp_ahb_info ahb;
>> +       struct ambapp_apb_info apb;
>>        unsigned int conf, size;
>>        /* Find SRAM controller
>>         * 1. AHB slave interface
>>         * 2. APB slave interface
>> -       if ( amba_find_apbslv(&cc1.amba_bus,VENDOR_GAISLER,GAISLER_FTAHBRAM,&apb) != 1 ){
>> +       if ( ambapp_find_apbslv(&cc1.amba_bus, VENDOR_GAISLER, GAISLER_FTAHBRAM,
>> +                                &apb) != 1 ){
>>                printk("On Board FT SRAM not found (APB)\n");
>>                return -1;
>> -       if ( amba_find_ahbslv(&cc1.amba_bus,VENDOR_GAISLER,GAISLER_FTAHBRAM,&ahb) != 1 ){
>> +       if ( ambapp_find_ahbslv(&cc1.amba_bus, VENDOR_GAISLER, GAISLER_FTAHBRAM,
>> +                                &ahb) != 1 ){
>>                printk("On Board FT SRAM not found (AHB)\n");
>>                return -1;
>> diff --git a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
>> index 7b66b07..0be7e4b 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
>> +++ b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
>> @@ -1,5 +1,9 @@
>> - *  $Id$
>> + *  GR-RASTA-IO PCI board driver
>>  #include <rtems/bspIo.h>
>> @@ -209,16 +213,18 @@ void rasta_interrrupt_register(void *handler, int irqno, void *arg)
>> -int rasta_get_gpio(amba_confarea_type *abus, int index, struct gpio_reg **regs, int *irq)
>> +int rasta_get_gpio(struct ambapp_bus *abus, int index, struct gpio_reg **regs,
>> +                   int *irq)
>> -  amba_apb_device dev;
>> +  struct ambapp_apb_info dev;
>>   int cores;
>>   if ( !abus )
>>     return -1;
>>   /* Scan PnP info for GPIO port number 'index' */
>> -  cores = amba_find_next_apbslv(abus,VENDOR_GAISLER,GAISLER_PIOPORT,&dev,index);
>> +  cores = ambapp_find_apbslv_next(abus, VENDOR_GAISLER, GAISLER_GPIO, &dev,
>> +                                  index);
>>   if ( cores < 1 )
>>     return -1;
>> @@ -232,8 +238,8 @@ int rasta_get_gpio(amba_confarea_type *abus, int index, struct gpio_reg **regs,
>>  /* AMBA Plug&Play information */
>> -static amba_confarea_type abus;
>> -static struct amba_mmap amba_maps[3];
>> +static struct ambapp_bus abus;
>> +static struct ambapp_mmap amba_maps[3];
>>  int rasta_register(void)
>> @@ -316,23 +322,24 @@ int rasta_register(void)
>>     /* AMBA MAP bar0 (in CPU) ==> 0x80000000(remote amba address) */
>>     amba_maps[0].size = 0x10000000;
>> -    amba_maps[0].cpu_adr = bar0;
>> -    amba_maps[0].remote_amba_adr = 0x80000000;
>> +    amba_maps[0].local_adr = bar0;
>> +    amba_maps[0].remote_adr = 0x80000000;
>>     /* AMBA MAP bar1 (in CPU) ==> 0x40000000(remote amba address) */
>>     amba_maps[1].size = 0x10000000;
>> -    amba_maps[1].cpu_adr = bar1;
>> -    amba_maps[1].remote_amba_adr = 0x40000000;
>> +    amba_maps[1].local_adr = bar1;
>> +    amba_maps[1].remote_adr = 0x40000000;
>>     amba_maps[2].size=0;
>> -    amba_maps[2].cpu_adr = 0;
>> -    amba_maps[2].remote_amba_adr = 0;
>> +    amba_maps[2].local_adr = 0;
>> +    amba_maps[2].remote_adr = 0;
>>     memset(&abus,0,sizeof(abus));
>>     /* Start AMBA PnP scan at first AHB bus */
>> -    amba_scan(&abus,bar0+(AHB1_IOAREA_BASE_ADDR&~0xf0000000),&amba_maps[0]);
>> +    ambapp_scan(&abus, bar0 + (AHB1_IOAREA_BASE_ADDR & ~0xf0000000), NULL,
>> +                &amba_maps[0]);
>>     printk("Registering RASTA GRCAN driver\n\r");
>> diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
>> index e447df2..deec908 100644
>> --- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
>> +++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
>> @@ -279,7 +279,7 @@ typedef struct {
>>  static int brm_cores;
>>  static unsigned int allbrm_memarea;
>>  static brm_priv *brms;
>> -static amba_confarea_type *amba_bus;
>> +static struct ambapp_bus *amba_bus;
>>  static unsigned int    allbrm_cfg_clksel;
>>  static unsigned int allbrm_cfg_clkdiv;
>>  static unsigned int allbrm_cfg_freq;
>> @@ -325,7 +325,7 @@ int brm_register_leon3_ramon_fpga(void){
>>         * The BRM is always clocked with 24MHz.
>>         * 3 in BRM enhanced register will select 24MHz
>> -       return b1553brm_register(&amba_conf,0,0,3);
>> +       return b1553brm_register(&ambapp_plb, 0, 0, 3);
>>  int brm_register_leon3_ramon_asic(void){
>> @@ -335,12 +335,12 @@ int brm_register_leon3_ramon_asic(void){
>> -       return b1553brm_register(&amba_conf,2,0,3);
>> +       return b1553brm_register(&ambapp_plb, 2, 0, 3);
>>  #endif
>>  #endif
>> -int B1553BRM_PREFIX(_register)(amba_confarea_type *bus, unsigned int clksel, unsigned int clkdiv, unsigned int brm_freq)
>> +int B1553BRM_PREFIX(_register)(struct ambapp_bus *bus, unsigned int clksel, unsigned int clkdiv, unsigned int brm_freq)
>>     rtems_status_code r;
>>     rtems_device_major_number m;
>> @@ -568,7 +568,7 @@ static rtems_device_driver brm_initialize(rtems_device_major_number major, rtems
>>        int dev_cnt;
>>        char fs_name[20];
>>        brm_priv *brm;
>> -       amba_ahb_device ambadev;
>> +       struct ambapp_ahb_info ambadev;
>>        char *mem;
>>        FUNCDBG("brm_initialize\n");
>> @@ -577,7 +577,7 @@ static rtems_device_driver brm_initialize(rtems_device_major_number major, rtems
>>        strcpy(fs_name,B1553BRM_DEVNAME);
>>        /* Find all BRM devices */
>> -       dev_cnt = amba_get_number_ahbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_BRM);
>> +       dev_cnt = ambapp_get_number_ahbslv_devices(amba_bus, VENDOR_GAISLER, GAISLER_B1553BRM);
>>        if ( dev_cnt < 1 ){
>>                /* Failed to find any CAN cores! */
>>                printk("BRM: Failed to find any BRM cores\n\r");
>> @@ -619,7 +619,8 @@ static rtems_device_driver brm_initialize(rtems_device_major_number major, rtems
>>                brm = &brms[minor];
>>                /* Get AMBA AHB device info from Plug&Play */
>> -               amba_find_next_ahbslv(amba_bus,VENDOR_GAISLER,GAISLER_BRM,&ambadev,minor);
>> +               ambapp_find_ahbslv_next(amba_bus, VENDOR_GAISLER,
>> +                                       GAISLER_B1553BRM, &ambadev, minor);
>>                /* Copy Basic HW info */
>>                brm->regs = (void *)ambadev.start[0];
>> diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
>> index 76c9f2e..3be26b1 100644
>> --- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
>> +++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
>> @@ -82,7 +82,7 @@ static void b1553brmpci_interrupt_handler(int irq, void *arg);
>>  int b1553brm_pci_register(
>> - amba_confarea_type *bus,
>> + struct ambapp_bus *bus,
>>  unsigned int brm_freq,
>> diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
>> index 10adb0a..d1fa4d6 100644
>> --- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
>> +++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
>> @@ -82,7 +82,7 @@ static void b1553brmrasta_interrupt_handler(int irq, void *arg);
>>  int b1553brm_rasta_register(
>> diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan.c b/c/src/lib/libbsp/sparc/shared/can/grcan.c
>> index fb48550..3b0a14a 100644
>> --- a/c/src/lib/libbsp/sparc/shared/can/grcan.c
>> +++ b/c/src/lib/libbsp/sparc/shared/can/grcan.c
>> @@ -212,7 +212,7 @@ struct grcan_priv {
>>  static int grcan_core_cnt;
>>  struct grcan_priv *grcans;
>>  struct grcan_device_info *grcan_cores;
>> @@ -1050,7 +1050,7 @@ static rtems_device_driver grcan_initialize(
>>   int minor;
>>   struct grcan_priv *pDev;
>>   rtems_status_code status;
>>   char fs_name[20];
>>   unsigned int sys_freq_hz;
>> @@ -1062,10 +1062,12 @@ static rtems_device_driver grcan_initialize(
>>   /* find GRCAN cores */
>>   if ( !grcan_cores ) {
>> -    grcan_core_cnt = amba_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,deviceid);
>> +    grcan_core_cnt = ambapp_get_number_apbslv_devices(amba_bus, VENDOR_GAISLER,
>> +                                                      deviceid);
>>     if ( grcan_core_cnt < 1 ){
>>       deviceid = GAISLER_GRCAN;
>> +                                                        deviceid);
>>       if ( grcan_core_cnt < 1 ) {
>>         DBG("GRCAN: Using AMBA Plug&Play, found %d cores\n",grcan_core_cnt);
>>         return RTEMS_UNSATISFIED;
>> @@ -1094,10 +1096,10 @@ static rtems_device_driver grcan_initialize(
>>  #if defined(LEON3)
>>   /* LEON3: find timer address via AMBA Plug&Play info */
>> -    amba_apb_device gptimer;
>> +    struct ambapp_apb_info gptimer;
>>     LEON3_Timer_Regs_Map *tregs;
>> -    if (amba_find_apbslv (&amba_conf, VENDOR_GAISLER, GAISLER_GPTIMER, &gptimer)
>> +    if (ambapp_find_apbslv (&ambapp_plb, VENDOR_GAISLER, GAISLER_GPTIMER, &gptimer)
>>         == 1) {
>>       tregs = (LEON3_Timer_Regs_Map *) gptimer.start;
>>       sys_freq_hz = (tregs->scaler_reload + 1) * 1000 * 1000;
>> @@ -1132,7 +1134,7 @@ static rtems_device_driver grcan_initialize(
>>     /* Find core address & IRQ */
>> -      amba_find_next_apbslv(amba_bus,VENDOR_GAISLER,deviceid,&dev,minor);
>> +      ambapp_find_apbslv_next(amba_bus, VENDOR_GAISLER, deviceid, &dev, minor);
>>       pDev->irq = dev.irq;
>>       pDev->regs = (struct grcan_regs *)dev.start;
>>     }else{
>> @@ -1799,7 +1801,7 @@ int GRCAN_PREFIX(_register_abs)(struct grcan_device_info *devices, int dev_cnt)
>>  /* Use prescanned AMBA Plug&Play information to find all GRCAN cores */
>> -int GRCAN_PREFIX(_register)(amba_confarea_type *abus)
>> +int GRCAN_PREFIX(_register)(struct ambapp_bus *abus)
>>   FUNCDBG();
>> diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c b/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
>> index f9b126f..7fad48e 100644
>> --- a/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
>> +++ b/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
>> @@ -77,7 +77,7 @@ unsigned int grcan_rasta_rambase;
>>  #include "grcan.c"
>> -int grcan_rasta_ram_register(amba_confarea_type *abus, int rambase)
>> +int grcan_rasta_ram_register(struct ambapp_bus *abus, int rambase)
>>   grcan_rasta_rambase = rambase;
>> diff --git a/c/src/lib/libbsp/sparc/shared/can/occan.c b/c/src/lib/libbsp/sparc/shared/can/occan.c
>> index 78c901a..4fb932d 100644
>> --- a/c/src/lib/libbsp/sparc/shared/can/occan.c
>> +++ b/c/src/lib/libbsp/sparc/shared/can/occan.c
>> @@ -282,7 +282,7 @@ static void occan_interrupt_handler(rtems_vector_number v);
>>  #endif
>>  static int can_cores;
>>  static occan_priv *cans;
>>  static unsigned int sys_freq_hz;
>> @@ -914,7 +914,7 @@ static int pelican_speed_auto(occan_priv *priv){
>>  static rtems_device_driver occan_initialize(rtems_device_major_number major, rtems_device_minor_number unused, void *arg){
>>        int dev_cnt,minor,subcore_cnt,devi,subi,subcores;
>>        occan_priv *can;
>>        char fs_name[20];
>> @@ -922,7 +922,8 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>>        strcpy(fs_name,OCCAN_DEVNAME);
>>        /* find device on amba bus */
>> -       dev_cnt = amba_get_number_ahbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_OCCAN);
>> +                                                   GAISLER_CANAHB);
>>        if ( dev_cnt < 1 ){
>>                printk("OCCAN: Failed to find any CAN cores\n\r");
>> @@ -934,10 +935,11 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>>  #if defined(LEON3)
>> -               if ( amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&gptimer) == 1 ){
>> +               if ( ambapp_find_apbslv(&ambapp_plb, VENDOR_GAISLER,
>> +                                        GAISLER_GPTIMER, &gptimer) == 1 ){
>>                        tregs = (LEON3_Timer_Regs_Map *)gptimer.start;
>>                        sys_freq_hz = (tregs->scaler_reload+1)*1000*1000;
>>                        DBG("OCCAN: detected %dHZ system frequency\n\r",sys_freq_hz);
>> @@ -973,7 +975,8 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>>        for(subcore_cnt=devi=0; devi<dev_cnt; devi++){
>> -               amba_find_next_ahbslv(amba_bus,VENDOR_GAISLER,GAISLER_OCCAN,&ambadev,devi);
>> +                                        GAISLER_CANAHB, &ambadev, devi);
>>                subcore_cnt += (ambadev.ver & 0x7)+1;
>> @@ -987,7 +990,8 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>>        for(devi=0; devi<dev_cnt; devi++){
>>                /* Get AHB device info */
>>                subcores = (ambadev.ver & 0x7)+1;
>>                DBG("OCCAN: on dev %d found %d sub cores\n\r",devi,subcores);
>> @@ -1802,7 +1806,7 @@ static void occan_interrupt_handler(rtems_vector_number v){
>>  static rtems_driver_address_table occan_driver = OCCAN_DRIVER_TABLE_ENTRY;
>> -int OCCAN_PREFIX(_register)(amba_confarea_type *bus){
>> +int OCCAN_PREFIX(_register)(struct ambapp_bus *bus){
>> diff --git a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
>> index 2dd2e5b..b27beb1 100644
>> --- a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
>> +++ b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
>> @@ -46,7 +46,7 @@ static void inline occanpci_set_channel(occan_priv *priv, int channel){
>>                *chan_sel = 0xffffffff;
>> -int occan_pci_register(amba_confarea_type *bus)
>> +int occan_pci_register(struct ambapp_bus *bus)
>>        /* Setup configuration */
>> diff --git a/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c b/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
>> index fb6a573..7ba7208 100644
>> --- a/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
>> +++ b/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
>> @@ -285,7 +285,7 @@ static gr_i2cmst_desc_t gr_i2cmst_desc = {
>>  /* Scans for I2CMST core and initalizes i2c library */
>> -rtems_status_code leon_register_i2c(amba_confarea_type *abus)
>> +rtems_status_code leon_register_i2c(struct ambapp_bus *abus)
>>  #if defined(DEBUG)
>>   printk("leon_register_i2c called...");
>> @@ -293,11 +293,11 @@ rtems_status_code leon_register_i2c(amba_confarea_type *abus)
>>   int rc;
>>   int device_found = 0;
>> -  amba_apb_device apbi2cmst;
>> +  struct ambapp_apb_info apbi2cmst;
>>   /* Scan AMBA bus for I2CMST core */
>> -  device_found = amba_find_apbslv(abus, VENDOR_GAISLER, GAISLER_I2CMST,
>> -                                 &apbi2cmst);
>> +  device_found = ambapp_find_apbslv(abus, VENDOR_GAISLER, GAISLER_I2CMST,
>> +                                   &apbi2cmst);
>>   if (device_found == 1) {
>> @@ -317,11 +317,11 @@ rtems_status_code leon_register_i2c(amba_confarea_type *abus)
>>  #if defined(LEON3)
>> -         if (amba_find_apbslv(abus,VENDOR_GAISLER,
>> -                              GAISLER_GPTIMER,&gptimer) == 1 ) {
>> +         if (ambapp_find_apbslv(abus, VENDOR_GAISLER,
>> +                                GAISLER_GPTIMER, &gptimer) == 1 ) {
>>            gr_i2cmst_desc.prv.sysfreq = (tregs->scaler_reload+1)*1000;
>>          } else {
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp.h b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>> index 651b7bf..5eb3f2a 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>> @@ -7,6 +7,8 @@
>> + *  $Id$
>>  #ifndef __AMBAPP_H__
>> @@ -28,21 +30,21 @@ struct ambapp_apb_info;
>>  struct ambapp_ahb_info;
>>  struct ambapp_dev {
>> -  struct ambapp_dev *next;      /* Next */
>> -  struct ambapp_dev *prev;      /* Previous Device. If (this ==
>> -                                 * rev->child) prev is bus bridge */
>> -  struct ambapp_dev *children;  /* Points to first device on sub-bus */
>> -  void *owner;                  /* Owner of this AMBA device */
>> -  unsigned char dev_type;       /* AHB MST, AHB SLV or APB SLV*/
>> -  unsigned char vendor;         /* Vendor ID */
>> -  unsigned short device;        /* Device ID */
>> -  int devinfo[0];               /* Device info (APB/AHB dep. on type) */
>> +       struct ambapp_dev *next;        /* Next */
>> +       struct ambapp_dev *prev;        /* Previous Device. If (this ==
>> +                                        * rev->child) prev is bus bridge */
>> +       struct ambapp_dev *children;    /* Points to first device on sub-bus */
>> +       void *owner;                    /* Owner of this AMBA device */
>> +       unsigned char dev_type;         /* AHB MST, AHB SLV or APB SLV*/
>> +       unsigned char vendor;           /* Vendor ID */
>> +       unsigned short device;          /* Device ID */
>> +       int devinfo[0];                 /* Device info (APB/AHB dep. on type) */
>> -#define AMBAPP_FLAG_FFACT_DIR  0x100  /* Frequency factor direction, 0=down, 1=up */
>> -#define AMBAPP_FLAG_FFACT  0x0f0  /* Frequency factor against top bus */
>> -#define AMBAPP_FLAG_MBUS  0x00c
>> -#define AMBAPP_FLAG_SBUS  0x003
>> +#define AMBAPP_FLAG_FFACT_DIR  0x100   /* Frequency factor direction, 0=down, 1=up */
>> +#define AMBAPP_FLAG_FFACT      0x0f0   /* Frequency factor against top bus */
>> +#define AMBAPP_FLAG_MBUS       0x00c
>> +#define AMBAPP_FLAG_SBUS       0x003
>>  /* Get APB or AHB information from a AMBA device */
>>  #define DEV_TO_APB(adev) ((struct ambapp_apb_info *)((adev)->devinfo))
>> @@ -50,70 +52,70 @@ struct ambapp_dev {
>>  #define DEV_TO_COMMON(adev) ((struct ambapp_common_info *)((adev)->devinfo))
>>  /* Convert address of ambapp_apb_info/ambapp_ahb_info into ambapp_dev */
>>  #define APB_TO_DEV(apb_info) ((struct ambapp_dev *)(unsigned int(apb_info) - \
>> -        offsetof(struct ambapp_dev, devinfo)))
>> +                               offsetof(struct ambapp_dev, devinfo)))
>>  #define AHB_TO_DEV(ahb_info) ((struct ambapp_dev *)(unsigned int(ahb_info) - \
>>  struct ambapp_common_info {
>> -  unsigned char irq;
>> -  unsigned char ver;
>> -  unsigned char ahbidx;   /* AHB Bus Index */
>> +       unsigned char irq;
>> +       unsigned char ver;
>> +       unsigned char ahbidx;   /* AHB Bus Index */
>>  struct ambapp_apb_info {
>> -  /* COMMON */
>> -  /* APB SPECIFIC */
>> -  unsigned int start;
>> -  unsigned int mask;
>> +       /* COMMON */
>> +       /* APB SPECIFIC */
>> +       unsigned int start;
>> +       unsigned int mask;
>>  struct ambapp_ahb_info {
>> -  /* COMMON */
>> -  /* AHB SPECIFIC */
>> -  unsigned int start[4];
>> -  unsigned int mask[4];
>> -  char type[4];           /* type[N] Determine type of start[N]-mask[N],
>> -                           * 2=AHB Memory Space, 3=AHB I/O Space */
>> -  unsigned int custom[3];
>> +       /* COMMON */
>> +       /* AHB SPECIFIC */
>> +       unsigned int start[4];
>> +       unsigned int mask[4];
>> +       char type[4];           /* type[N] Determine type of start[N]-mask[N],
>> +                                * 2=AHB Memory Space, 3=AHB I/O Space */
>> +       unsigned int custom[3];
>>  /* Describes a complete AMBA Core. Each device may consist of 3 interfaces */
>>  struct ambapp_core {
>> -  char irq;               /* irq=-1 indicate no IRQ */
>> -  int index;              /* Core index */
>> -  struct ambapp_ahb_info  *ahb_mst;
>> -  struct ambapp_ahb_info  *ahb_slv;
>> -  struct ambapp_apb_info  *apb_slv;
>> +       char                    irq;            /* irq=-1 indicate no IRQ */
>> +       int                     index;          /* Core index */
>> +       struct ambapp_ahb_info  *ahb_mst;
>> +       struct ambapp_ahb_info  *ahb_slv;
>> +       struct ambapp_apb_info  *apb_slv;
>>  struct ambapp_ahb_bus {
>> -  unsigned int ioarea;        /* AHB Bus IOAREA */
>> -  unsigned int freq_hz;       /* Frequency of AHB Bus */
>> -  struct ambapp_dev *bridge;  /* Bridge Device on Parent AHB Bus */
>> -  struct ambapp_dev *dev;     /* First Device on AHB Bus */
>> +       unsigned int ioarea;    /* AHB Bus IOAREA */
>> +       unsigned int freq_hz;   /* Frequency of AHB Bus */
>> +       struct ambapp_dev *bridge;/* Bridge Device on Parent AHB Bus */
>> +       struct ambapp_dev *dev; /* First Device on AHB Bus */
>>  struct ambapp_mmap {
>> -  unsigned int size;
>> -  unsigned int local_adr;
>> -  unsigned int remote_adr;
>> +       unsigned int            size;
>> +       unsigned int            local_adr;
>> +       unsigned int            remote_adr;
>>  /* Complete AMBA PnP information */
>>  struct ambapp_bus {
>> -  struct ambapp_dev *root;                  /* AHB/APB Device Tree*/
>> -  struct ambapp_mmap *mmaps;                /* Memory MAP Array */
>> -  struct ambapp_ahb_bus ahbs[AHB_BUS_MAX];  /* AHB Buses */
>> +       struct ambapp_dev       *root;                  /* AHB/APB Device Tree*/
>> +       struct ambapp_mmap      *mmaps;                 /* Memory MAP Array */
>> +       struct ambapp_ahb_bus   ahbs[AHB_BUS_MAX];      /* AHB Buses */
>> @@ -127,17 +129,17 @@ typedef int (*ambapp_func_t)(struct ambapp_dev *dev, int index, void *arg);
>>  #define DEV_IS_ALLOCATED(dev) (dev->owner != NULL)
>>  /* Options to ambapp_for_each */
>> -#define OPTIONS_AHB_MSTS  0x00000001
>> -#define OPTIONS_AHB_SLVS  0x00000002
>> -#define OPTIONS_APB_SLVS  0x00000004
>> -#define OPTIONS_ALL_DEVS  (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_APB_SLVS)
>> +#define OPTIONS_AHB_MSTS       0x00000001
>> +#define OPTIONS_AHB_SLVS       0x00000002
>> +#define OPTIONS_APB_SLVS       0x00000004
>> +#define OPTIONS_ALL_DEVS       (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_APB_SLVS)
>> -#define OPTIONS_FREE    0x00000010
>> -#define OPTIONS_ALLOCATED  0x00000020
>> -#define OPTIONS_ALL    (OPTIONS_FREE|OPTIONS_ALLOCATED)
>> +#define OPTIONS_FREE           0x00000010
>> +#define OPTIONS_ALLOCATED      0x00000020
>> +#define OPTIONS_ALL            (OPTIONS_FREE|OPTIONS_ALLOCATED)
>>  /* Depth first search, Defualt is breath first search. */
>> -#define OPTIONS_DEPTH_FIRST  0x00000100
>> +#define OPTIONS_DEPTH_FIRST    0x00000100
>>  #define DEV_AHB_NONE 0
>>  #define DEV_AHB_MST  1
>> @@ -146,14 +148,14 @@ typedef int (*ambapp_func_t)(struct ambapp_dev *dev, int index, void *arg);
>>  /* Structures used to access Plug&Play information directly */
>>  struct ambapp_pnp_ahb {
>> -  const unsigned int id;        /* VENDOR, DEVICE, VER, IRQ, */
>> -  const unsigned int custom[3];
>> -  const unsigned int mbar[4];   /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
>> +       const unsigned int      id;             /* VENDOR, DEVICE, VER, IRQ, */
>> +       const unsigned int      custom[3];
>> +       const unsigned int      mbar[4];        /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
>>  struct ambapp_pnp_apb {
>> -  const unsigned int iobar;     /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
>> +       const unsigned int      iobar;          /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
>>  #define ambapp_pnp_vendor(id) (((id) >> 24) & 0xff)
>> @@ -168,7 +170,7 @@ struct ambapp_pnp_apb {
>>  #define ambapp_pnp_apb_start(iobar, base) ((base) | ((((iobar) & 0xfff00000)>>12) & (((iobar) & 0xfff0)<<4)) )
>>  #define ambapp_pnp_apb_mask(iobar) ((~(ambapp_pnp_mbar_mask(iobar)<<8) & 0x000fffff) + 1)
>> -#define AMBA_TYPE_AHBIO_ADDR(addr, base_ioarea) ((unsigned int)(base_ioarea) | ((addr) >> 12))
>> +#define AMBA_TYPE_AHBIO_ADDR(addr,base_ioarea) ((unsigned int)(base_ioarea) | ((addr) >> 12))
>>  #define AMBA_TYPE_APBIO 0x1
>>  #define AMBA_TYPE_MEM   0x2
>> @@ -176,11 +178,11 @@ struct ambapp_pnp_apb {
>>  /* Copy Data from AMBA PnP I/O Area */
>>  typedef void *(*ambapp_memcpy_t)(
>> -  void *dest,               /* Destination RAM copy */
>> -  const void *src,          /* Source AMBA PnP Address to copy from */
>> -  int n,                    /* Number of bytes to be copied */
>> -  struct ambapp_bus *abus   /* Optional AMBA Bus pointer */
>> +       void *dest,             /* Destination RAM copy */
>> +       const void *src,        /* Source AMBA PnP Address to copy from */
>> +       int n,                  /* Number of bytes to be copied */
>> +       struct ambapp_bus *abus /* Optional AMBA Bus pointer */
>>  /* Scan a AMBA Plug & Play bus and create all device structures describing the
>>  * the devices. The devices will form a tree, where every node describes one
>> @@ -196,24 +198,24 @@ typedef void *(*ambapp_memcpy_t)(
>>  extern int ambapp_scan(
>> -  struct ambapp_bus *abus,
>> -  unsigned int ioarea,
>> -  ambapp_memcpy_t memfunc,
>> +       struct ambapp_bus *abus,
>> +       unsigned int ioarea,
>> +       ambapp_memcpy_t memfunc,
>>  /* Initialize the frequency [Hz] of all AHB Buses from knowing the frequency
>>  * of one particular APB/AHB Device.
>>  extern void ambapp_freq_init(
>> -  struct ambapp_dev *dev,
>> -  unsigned int freq);
>> +       struct ambapp_dev *dev,
>> +       unsigned int freq);
>>  /* Returns the frequency [Hz] of a AHB/APB device */
>>  extern unsigned int ambapp_freq_get(
>> -  struct ambapp_dev *dev);
>> +       struct ambapp_dev *dev);
>>  /* Iterates through all AMBA devices previously found, it calls func
>>  * once for every device that match the search arguments.
>> @@ -242,12 +244,12 @@ extern unsigned int ambapp_freq_get(
>>  *  non-zero - stopped by user function returning the non-zero value
>>  extern int ambapp_for_each(
>> -  unsigned int options,
>> -  int vendor,
>> -  int device,
>> -  ambapp_func_t func,
>> -  void *arg);
>> +       unsigned int options,
>> +       int vendor,
>> +       int device,
>> +       ambapp_func_t func,
>> +       void *arg);
>>  /* Helper function for ambapp_for_each(), find a device by index. If pcount
>>  * is NULL the first device is returned, else pcount is interpreted as index
>> @@ -264,7 +266,7 @@ extern int ambapp_find_by_idx(struct ambapp_dev *dev, int index, void *pcount);
>>  * arguments are passed onto ambapp_for_each().
>>  extern int ambapp_dev_count(struct ambapp_bus *abus, unsigned int options,
>> -                            int vendor, int device);
>> +                               int vendor, int device);
>>  /* Print short information about devices on the AMBA bus onto the console */
>>  extern void ambapp_print(struct ambapp_bus *abus, int show_depth);
>> @@ -297,70 +299,61 @@ extern int ambapp_vendev_id2str(int vendor, int id, char *buf);
>>  /* Help functions for backwards compability */
>>  extern int ambapp_find_apbslv(
>> -  int vendor,
>> -  int device,
>> -  struct ambapp_apb_info *dev);
>> +       int vendor,
>> +       int device,
>> +       struct ambapp_apb_info *dev);
>>  extern int ambapp_find_apbslv_next(
>> -  int vendor,
>> -  int device,
>> -  struct ambapp_apb_info *dev,
>> -  int index);
>> +       int vendor,
>> +       int device,
>> +       struct ambapp_apb_info *dev,
>> +       int index);
>>  extern int ambapp_find_apbslvs_next(
>> -  int vendor,
>> -  int device,
>> -  int index,
>> -  int maxno);
>> +       int vendor,
>> +       int device,
>> +       int index,
>> +       int maxno);
>>  extern int ambapp_find_apbslvs(
>> -  int vendor,
>> -  int device,
>> -  int maxno);
>> -extern int ambapp_get_number_apbslv_devices(
>> -  int vendor,
>> -  int device);
>> +       int vendor,
>> +       int device,
>> +       int maxno);
>>  extern int ambapp_find_ahbslv(
>> -  int vendor,
>> -  int device,
>> -  struct ambapp_ahb_info *dev);
>> +       int vendor,
>> +       int device,
>> +       struct ambapp_ahb_info *dev);
>>  extern int ambapp_find_ahbslv_next(
>> -  int vendor,
>> -  int device,
>> -  struct ambapp_ahb_info *dev,
>> -  int index);
>> +       int vendor,
>> +       int device,
>> +       struct ambapp_ahb_info *dev,
>> +       int index);
>>  extern int ambapp_find_ahbslvs_next(
>> -  int vendor,
>> -  int device,
>> -  int index,
>> -  int maxno);
>> +       int vendor,
>> +       int device,
>> +       int index,
>> +       int maxno);
>>  extern int ambapp_find_ahbslvs(
>> -  int vendor,
>> -  int device,
>> -  int maxno);
>> -extern int ambapp_get_number_ahbslv_devices(
>> -  int vendor,
>> -  int device);
>> +       int vendor,
>> +       int device,
>> +       int maxno);
>>  /******** AMBA DEVICES *******/
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart.h b/c/src/lib/libbsp/sparc/shared/include/apbuart.h
>> index c8a6e35..c948b24 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/apbuart.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/apbuart.h
>> @@ -72,9 +72,9 @@ typedef struct {
>>  /* Register APBUART driver
>>  * bus =  pointer to AMBA bus description used to search for APBUART(s).
>> - *        (&amba_conf for LEON3), (LEON2: see amba_scan)
>> + *        (&ambapp_plb for LEON3), (LEON2: see amba_scan)
>> -int apbuart_register (amba_confarea_type * bus);
>> +int apbuart_register (struct ambapp_bus *bus);
>>  #ifdef __cplusplus
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h b/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
>> index e806429..11ac33e 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
>> @@ -24,7 +24,7 @@ extern "C" {
>> -int apbuart_pci_register (amba_confarea_type * bus);
>> +int apbuart_pci_register (struct ambapp_bus * bus);
>>  /* This function must be called on APBUART interrupt. Called from the
>>  * PCI interrupt handler.
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h b/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
>> index 1edf6f9..61c6144 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
>> -int apbuart_rasta_register(amba_confarea_type *bus);
>> +int apbuart_rasta_register(struct ambapp_bus *bus);
>>  * RASTA interrupt handler.
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/b1553brm.h b/c/src/lib/libbsp/sparc/shared/include/b1553brm.h
>> index f5fd343..f0f09c5 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/b1553brm.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/b1553brm.h
>> @@ -158,9 +158,9 @@ int brm_register_leon3_ramon_asic(void);
>>  /* Register BRM driver
>>  * See (struct brm_reg).w_ctrl for clksel and clkdiv.
>>  * See Enhanced register (the least signinficant 2 bits) in BRM Core for brm_freq
>> - * bus = &amba_conf for LEON3. (LEON2 not yet supported for this driver)
>> + * bus = &ambapp_plb for LEON3. (LEON2 not yet supported for this driver)
>> -int b1553brm_register(amba_confarea_type *bus, unsigned int clksel, unsigned int clkdiv, unsigned int brm_freq);
>> +int b1553brm_register(struct ambapp_bus *bus, unsigned int clksel, unsigned int clkdiv, unsigned int brm_freq);
>>  #ifdef __cplusplus
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h b/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
>> index 74f9d32..9861dc3 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
>> @@ -22,7 +22,7 @@ extern "C" {
>>  * Memory setup:
>>  * memarea = 128k aligned pointer to memory (if zero malloc will be used) (as the CPU sees it)
>> @@ -30,7 +30,7 @@ extern "C" {
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h b/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
>> index cd51658..360b72f 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
>>  * Memory setup:
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/grcan.h b/c/src/lib/libbsp/sparc/shared/include/grcan.h
>> index 8b3ed15..f8f577d 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/grcan.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/grcan.h
>> @@ -190,7 +190,7 @@ struct grcan_device_info {
>>  int grcan_register_abs(struct grcan_device_info *devices, int dev_cnt);
>>  /* Use prescanned AMBA Plug&Play information to find all GRFIFO cores */
>> -int grcan_register(amba_confarea_type *abus);
>> +int grcan_register(struct ambapp_bus *abus);
>>  #if 0
>>  void grcan_register(unsigned int baseaddr, unsigned int ram_base);
>>  void grcan_interrupt_handler(rtems_vector_number v);
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h b/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
>> index 1f96da6..20a2fac 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
>> @@ -13,7 +13,7 @@ extern "C" {
>>  * rambase is address of the first GRCAN core has it's TX buffer, followed by
>>  * it's RX buffer
>> -int grcan_rasta_ram_register(amba_confarea_type *abus, int rambase);
>> +int grcan_rasta_ram_register(struct ambapp_bus *abus, int rambase);
>>  extern void (*grcan_rasta_int_reg)(void *handler, int irq, void *arg);
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw.h b/c/src/lib/libbsp/sparc/shared/include/grspw.h
>> index 4c6c869..e60aa87 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/grspw.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/grspw.h
>> @@ -111,7 +111,7 @@ typedef struct {
>>  #define SPACEWIRE_IOCTRL_START               64
>>  #define SPACEWIRE_IOCTRL_STOP                65
>> -int grspw_register(amba_confarea_type *bus);
>> +int grspw_register(struct ambapp_bus *bus);
>>  #if 0
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h b/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
>> index aea50f3..9e2cd60 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
>> @@ -20,14 +20,14 @@ extern "C" {
>>  #endif
>>  /* Register GRSPW Driver
>>  * Memory setup:
>>  * hw_address = address that HW must use to access memarea. (used in the translation process)
>> -int grspw_pci_register (amba_confarea_type * bus,
>> +int grspw_pci_register (struct ambapp_bus *bus,
>>                         unsigned int memarea, unsigned int hw_address);
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h b/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
>> index 0e4e5be..c4c0cd0 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
>>  #endif
>>  * Memory setup:
>>  * ram_base = 128k aligned pointer to memory (as the CPU sees it)
>>  int grspw_rasta_register(
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/i2cmst.h b/c/src/lib/libbsp/sparc/shared/include/i2cmst.h
>> index 21780ee..9f612fa 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/i2cmst.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/i2cmst.h
>> @@ -68,7 +68,7 @@ typedef struct gr_i2cmst_desc {
>>  } gr_i2cmst_desc_t;
>> -rtems_status_code leon_register_i2c(amba_confarea_type *abus);
>> +rtems_status_code leon_register_i2c(struct ambapp_bus *abus);
>>  #ifdef __cplusplus
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/occan.h b/c/src/lib/libbsp/sparc/shared/include/occan.h
>> index 12ec42a..5c875b3 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/occan.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/occan.h
>> @@ -147,7 +147,7 @@ struct occan_afilter {
>>  #define OCCAN_BLK_MODE_RX 0x1
>>  #define OCCAN_BLK_MODE_TX 0x2
>> -int occan_register(amba_confarea_type *bus);
>> +int occan_register(struct ambapp_bus *bus);
>>  #define OCCAN_SPEED_500K 500000
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/occan_pci.h b/c/src/lib/libbsp/sparc/shared/include/occan_pci.h
>> index 2f46293..d351f85 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/occan_pci.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/occan_pci.h
>> @@ -23,7 +23,7 @@ extern "C" {
>>  * bus = pointer to AMBA bus description used to search for OC_CAN contrller(s).
>> -int occan_pci_register(amba_confarea_type *bus);
>> +int occan_pci_register(struct ambapp_bus *bus);
>>  /* This function must be called on OC_CAN interrupt. Called from the
>>  * PCI interrupt handler. irq = AMBA IRQ assigned to the OC_CAN device,
>> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw.c b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
>> index 6a9da79..8ab5020 100644
>> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw.c
>> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
>> @@ -370,9 +370,9 @@ static rtems_device_driver grspw_control(
>>     grspw_control }
>>  static rtems_driver_address_table grspw_driver = GRSPW_DRIVER_TABLE_ENTRY;
>> -int GRSPW_PREFIX(_register)(amba_confarea_type *bus)
>> +int GRSPW_PREFIX(_register)(struct ambapp_bus *bus)
>> @@ -389,10 +389,11 @@ int GRSPW_PREFIX(_register)(amba_confarea_type *bus)
>>  #ifdef LEON3
>>                        sys_freq_khz = (tregs->scaler_reload+1)*1000;
>>                        SPACEWIRE_DBG("GRSPW: detected %dkHZ system frequency\n\r",sys_freq_khz);
>> @@ -609,7 +610,7 @@ static rtems_device_driver grspw_initialize(
>>         char c;
>>         GRSPW_DEV *pDev;
>>         char console_name[20];
>>         SPACEWIRE_DBG2("spacewire driver initialization\n");
>> @@ -620,19 +621,10 @@ static rtems_device_driver grspw_initialize(
>>         i=0; spw_cores = 0; spw_cores2 = 0;
>>         /* get number of GRSPW cores */
>> -        spw_cores = amba_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_SPACEWIRE);
>> -        spw_cores2 = amba_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_GRSPW2);
>> -#if 0
>> -                               if ( spw_cores > SPACEWIRE_MAX_CORENR )
>> -                                       spw_cores = SPACEWIRE_MAX_CORENR;
>> -        while (i < amba_conf.apbslv.devnr) {
>> -                conf = amba_get_confword(amba_conf.apbslv, i, 0);
>> -                if ((amba_vendor(conf) == VENDOR_GAISLER) && (amba_device(conf) == GAISLER_SPACEWIRE))
>> -                        spw_cores++;
>> -                i++;
>> -#endif
>> +        spw_cores = ambapp_get_number_apbslv_devices(amba_bus, VENDOR_GAISLER,
>> +                                                     GAISLER_SPW);
>> +        spw_cores2 = ambapp_get_number_apbslv_devices(amba_bus, VENDOR_GAISLER,
>> +                                                      GAISLER_SPW2);
>>         if ( (spw_cores+spw_cores2) < 1 ){
>>                 /* No GRSPW cores around... */
>> @@ -653,10 +645,13 @@ static rtems_device_driver grspw_initialize(
>>                 /* Get device */
>>                 if ( spw_cores > minor ) {
>> -                        amba_find_next_apbslv(amba_bus,VENDOR_GAISLER,GAISLER_SPACEWIRE,&dev,minor);
>> +                                                GAISLER_SPW, &dev, minor);
>>                         pDev->core_ver = 1;
>>                 } else {
>> -                        amba_find_next_apbslv(amba_bus,VENDOR_GAISLER,GAISLER_GRSPW2,&dev,minor-spw_cores);
>> +                                                GAISLER_SPW2, &dev,
>> +                                                minor - spw_cores);
>>                         pDev->core_ver = 2;
>> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
>> index a8003be..2a9a8d6 100644
>> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
>> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
>> @@ -79,7 +79,7 @@ int grspwpci_interrupt_handler(int irq, void *arg);
>>  int grspw_pci_register(
>> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
>> index 6cd5698..9bf9437 100644
>> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
>> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
>> @@ -88,7 +88,7 @@ unsigned int grspw_rasta_memarea_address;
>> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
>> index b3f4bbd..d442e80 100644
>> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
>> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
>> @@ -116,7 +116,7 @@ static unsigned int sys_freq_hz;
>>  #define APBUART_DRIVER_TABLE_ENTRY { apbuart_initialize, apbuart_open, apbuart_close, apbuart_read, apbuart_write, apbuart_control }
>>  static rtems_driver_address_table apbuart_driver = APBUART_DRIVER_TABLE_ENTRY;
>>  static void apbuart_interrupt(apbuart_priv *uart);
>>  #ifdef APBUART_DEFINE_INTHANDLER
>> @@ -322,7 +322,7 @@ static void apbuart_interrupt(apbuart_priv *uart){
>> -int APBUART_PREFIX(_register)(amba_confarea_type *bus) {
>> +int APBUART_PREFIX(_register)(struct ambapp_bus *bus) {
>> @@ -353,13 +353,14 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number  major,
>>        int i;
>>        char fs_name[20];
>>        FUNCDBG("apbuart_initialize\n");
>>        /* Find all APB UART devices */
>> -       dev_cnt = amba_get_number_apbslv_devices(amba_bus,VENDOR_GAISLER,GAISLER_APBUART);
>> +       dev_cnt = ambapp_get_number_apbslv_devices(amba_bus, VENDOR_GAISLER,
>> +                                                  GAISLER_APBUART);
>>        if ( dev_cnt < 1 ){
>>                printk("APBUART: Failed to find any APBUART cores\n\r");
>> @@ -384,10 +385,11 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number  major,
>>  #if defined(LEON3)
>>                        DBG("APBUART: detected %dHZ system frequency\n\r",sys_freq_hz);
>> @@ -413,7 +415,7 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number  major,
>>        for(i=0; i<dev_cnt; i++){
>> -               amba_find_next_apbslv(amba_bus,VENDOR_GAISLER,GAISLER_APBUART,&dev,i);
>> +               ambapp_find_apbslv_next(amba_bus,VENDOR_GAISLER,GAISLER_APBUART,&dev,i);
>>                printk("APBUART[%d]: at 0x%x irq %d (0x%x)\n\r",i,dev.start,dev.irq,(unsigned int)&apbuarts[i]);
>> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
>> index 54d14ce..fce1197 100644
>> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
>> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
>> @@ -24,7 +24,7 @@ void apbuartpci_interrupt_handler(int irq, void *arg);
>>  #include "apbuart.c"
>> -int apbuart_pci_register(amba_confarea_type *bus)
>> +int apbuart_pci_register(struct ambapp_bus *bus)
>> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
>> index 4b8734f..3196bbb 100644
>> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
>> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
>> @@ -24,7 +24,7 @@ void apbuartrasta_interrupt_handler(int irq, void *arg);
>> 1.7.0.4
