[rtems-libbsd commit] Removed file
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 18 12:06:58 UTC 2012
What about the symbols that were in it? It was added for a reason whether the notice was right or wrong.
Sebastian Huber <sebh at rtems.org> wrote:
>Module: rtems-libbsd
>Branch: master
>Commit: c2b6395ddc8c1d5be87edbaa127b1880136ac1e4
>Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=c2b6395ddc8c1d5be87edbaa127b1880136ac1e4
>Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
>Date: Wed Apr 18 13:58:05 2012 +0200
>Removed file
>In this file the copyright information was wrong. It claimed to be
>copyrighted by embedded brains GmbH, but this is not the case. It seems
>to be a partial copy from FreeBSD "kern/kern_prot.c" with format
>changes.
> Makefile | 1 -
> freebsd-to-rtems.py | 1 -
> rtemsbsd/src/rtems-bsd-prot.c | 242 -----------------------------------------
> 3 files changed, 0 insertions(+), 244 deletions(-)
>diff --git a/Makefile b/Makefile
>index a5601cc..729204b 100644
>--- a/Makefile
>+++ b/Makefile
>@@ -38,7 +38,6 @@ C_FILES += rtemsbsd/src/rtems-bsd-callout.c
> C_FILES += rtemsbsd/src/rtems-bsd-init.c
> C_FILES += rtemsbsd/src/rtems-bsd-init-with-irq.c
> C_FILES += rtemsbsd/src/rtems-bsd-assert.c
>-C_FILES += rtemsbsd/src/rtems-bsd-prot.c
> C_FILES += rtemsbsd/src/rtems-bsd-resource.c
> C_FILES += rtemsbsd/src/rtems-bsd-jail.c
> C_FILES += rtemsbsd/src/rtems-bsd-shell.c
>diff --git a/freebsd-to-rtems.py b/freebsd-to-rtems.py
>index f0c579e..0e89845 100755
>--- a/freebsd-to-rtems.py
>+++ b/freebsd-to-rtems.py
>@@ -529,7 +529,6 @@ rtems.addRTEMSSourceFiles(
> 'src/rtems-bsd-init.c',
> 'src/rtems-bsd-init-with-irq.c',
> 'src/rtems-bsd-assert.c',
>- 'src/rtems-bsd-prot.c',
> 'src/rtems-bsd-resource.c',
> 'src/rtems-bsd-jail.c',
> 'src/rtems-bsd-shell.c',
>diff --git a/rtemsbsd/src/rtems-bsd-prot.c b/rtemsbsd/src/rtems-bsd-prot.c
>deleted file mode 100644
>index bf87c87..0000000
>--- a/rtemsbsd/src/rtems-bsd-prot.c
>+++ /dev/null
>@@ -1,242 +0,0 @@
>- * @file
>- * @ingroup rtems_bsd_rtems
>- * @brief TODO.
>- * Copyright (c) 2009, 2010 embedded brains GmbH. All rights reserved.
>- * embedded brains GmbH
>- * Obere Lagerstr. 30
>- * 82178 Puchheim
>- * Germany
>- * <rtems at embedded-brains.de>
>- * The license and distribution terms for this file may be
>- * found in the file LICENSE in this distribution or at
>- * http://www.rtems.com/license/LICENSE.
>-#include <freebsd/machine/rtems-bsd-config.h>
>-#include <freebsd/sys/types.h>
>-#include <freebsd/sys/systm.h>
>-#include <freebsd/vm/uma.h>
>-#include <freebsd/sys/malloc.h>
>-#include <freebsd/sys/ucred.h>
>-#include <freebsd/sys/refcount.h>
>-#include <freebsd/sys/sysctl.h>
>-static MALLOC_DEFINE(M_CRED, "cred", "credentials");
>-static void crextend(struct ucred *cr, int n);
>-static void crsetgroups_locked(struct ucred *cr, int ngrp,
>- gid_t *groups);
>- * Allocate a zeroed cred structure.
>-struct ucred *
>-crget(void)
>- register struct ucred *cr;
>- cr = malloc(sizeof(*cr), M_CRED, M_WAITOK | M_ZERO);
>- refcount_init(&cr->cr_ref, 1);
>-#ifdef AUDIT
>- audit_cred_init(cr);
>-#endif
>-#ifdef MAC
>- mac_cred_init(cr);
>-#endif
>- crextend(cr, XU_NGROUPS);
>- return (cr);
>- * Claim another reference to a ucred structure.
>-struct ucred *
>-crhold(struct ucred *cr)
>- refcount_acquire(&cr->cr_ref);
>- return (cr);
>- * Free a cred structure. Throws away space when ref count gets to 0.
>-void
>-crfree(struct ucred *cr)
>- KASSERT(cr->cr_ref > 0, ("bad ucred refcount: %d", cr->cr_ref));
>- KASSERT(cr->cr_ref != 0xdeadc0de, ("dangling reference to ucred"));
>- if (refcount_release(&cr->cr_ref)) {
>- * Some callers of crget(), such as nfs_statfs(),
>- * allocate a temporary credential, but don't
>- * allocate a uidinfo structure.
>- if (cr->cr_uidinfo != NULL)
>- uifree(cr->cr_uidinfo);
>- if (cr->cr_ruidinfo != NULL)
>- uifree(cr->cr_ruidinfo);
>- * Free a prison, if any.
>- if (cr->cr_prison != NULL)
>- prison_free(cr->cr_prison);
>-#ifdef AUDIT
>- audit_cred_destroy(cr);
>-#endif
>-#ifdef MAC
>- mac_cred_destroy(cr);
>-#endif
>- free(cr->cr_groups, M_CRED);
>- free(cr, M_CRED);
>- * Check to see if this ucred is shared.
>-int
>-crshared(struct ucred *cr)
>- return (cr->cr_ref > 1);
>- * Copy a ucred's contents from a template. Does not block.
>-void
>-crcopy(struct ucred *dest, struct ucred *src)
>- KASSERT(crshared(dest) == 0, ("crcopy of shared ucred"));
>- bcopy(&src->cr_startcopy, &dest->cr_startcopy,
>- (unsigned)((caddr_t)&src->cr_endcopy -
>- (caddr_t)&src->cr_startcopy));
>- crsetgroups(dest, src->cr_ngroups, src->cr_groups);
>- uihold(dest->cr_uidinfo);
>- uihold(dest->cr_ruidinfo);
>- prison_hold(dest->cr_prison);
>-#ifdef AUDIT
>- audit_cred_copy(src, dest);
>-#endif
>-#ifdef MAC
>- mac_cred_copy(src, dest);
>-#endif
>- * Dup cred struct to a new held one.
>-struct ucred *
>-crdup(struct ucred *cr)
>- struct ucred *newcr;
>- newcr = crget();
>- crcopy(newcr, cr);
>- return (newcr);
>- * Extend the passed in credential to hold n items.
>-static void
>-crextend(struct ucred *cr, int n)
>- int cnt;
>- /* Truncate? */
>- if (n <= cr->cr_agroups)
>- return;
>- * We extend by 2 each time since we're using a power of two
>- * allocator until we need enough groups to fill a page.
>- * Once we're allocating multiple pages, only allocate as many
>- * as we actually need. The case of processes needing a
>- * non-power of two number of pages seems more likely than
>- * a real world process that adds thousands of groups one at a
>- * time.
>- if ( n < PAGE_SIZE / sizeof(gid_t) ) {
>- if (cr->cr_agroups == 0)
>- cnt = MINALLOCSIZE / sizeof(gid_t);
>- else
>- cnt = cr->cr_agroups * 2;
>- while (cnt < n)
>- cnt *= 2;
>- } else
>- cnt = roundup2(n, PAGE_SIZE / sizeof(gid_t));
>- /* Free the old array. */
>- if (cr->cr_groups)
>- cr->cr_groups = malloc(cnt * sizeof(gid_t), M_CRED, M_WAITOK | M_ZERO);
>- cr->cr_agroups = cnt;
>- * Copy groups in to a credential, preserving any necessary invariants.
>- * Currently this includes the sorting of all supplemental gids.
>- * crextend() must have been called before hand to ensure sufficient
>- * space is available.
>-static void
>-crsetgroups_locked(struct ucred *cr, int ngrp, gid_t *groups)
>- int i;
>- int j;
>- gid_t g;
>- KASSERT(cr->cr_agroups >= ngrp, ("cr_ngroups is too small"));
>- bcopy(groups, cr->cr_groups, ngrp * sizeof(gid_t));
>- cr->cr_ngroups = ngrp;
>- * Sort all groups except cr_groups[0] to allow groupmember to
>- * perform a binary search.
>- * XXX: If large numbers of groups become common this should
>- * be replaced with shell sort like linux uses or possibly
>- * heap sort.
>- for (i = 2; i < ngrp; i++) {
>- g = cr->cr_groups[i];
>- for (j = i-1; j >= 1 && g < cr->cr_groups[j]; j--)
>- cr->cr_groups[j + 1] = cr->cr_groups[j];
>- cr->cr_groups[j + 1] = g;
>- * Copy groups in to a credential after expanding it if required.
>- * Truncate the list to (ngroups_max + 1) if it is too large.
>-void
>-crsetgroups(struct ucred *cr, int ngrp, gid_t *groups)
>- if (ngrp > ngroups_max + 1)
>- ngrp = ngroups_max + 1;
>- crextend(cr, ngrp);
>- crsetgroups_locked(cr, ngrp, groups);
>-SYSCTL_NODE(_security, OID_AUTO, bsd, CTLFLAG_RW, 0, "BSD security policy");
>_______________________________________________
>rtems-vc mailing list
>rtems-vc at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-vc
