[PATCH 36] LEON3: GPTIMER timer watchdog driver
Daniel Hellstrom daniel at gaisler.com
Wed Apr 18 15:19:37 UTC 2012
Last timer instance of GPTIMER is sometimes a watchdog timer that
can reset the system on timer underflow.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
 c/src/lib/libbsp/sparc/leon3/Makefile.am      |    1 +
 c/src/lib/libbsp/sparc/leon3/include/bsp.h    |   25 +++++++
 c/src/lib/libbsp/sparc/leon3/timer/watchdog.c |   89 +++++++++++++++++++++++++
 3 files changed, 115 insertions(+), 0 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index cc25993..9b8af4b 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -115,6 +115,7 @@ libbsp_a_SOURCES += ../../sparc/shared/i2c/i2cmst.c
 # timer
 libbsp_a_SOURCES += timer/timer.c
+libbsp_a_SOURCES += timer/watchdog.c
 if HAS_SMP
 libbsp_a_SOURCES += smp/getcpuid.c
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index d883064..32407dd 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -192,6 +192,31 @@ extern void BSP_shared_interrupt_unmask(int irq);
 extern void BSP_shared_interrupt_mask(int irq);
+/* Initialize BSP watchdog routines. Returns number of watchdog timers found.
+ * Currently only one is supported.
+extern int bsp_watchdog_init(void);
+/* Reload watchdog (last timer on the first GPTIMER core), all systems does not
+ * feature a watchdog, it is expected that if this function is called the
+ * user knows that there is a watchdog available.
+ * The prescaler is normally set to number of MHz of system, this is to
+ * make the system clock tick be stable.
+ * Arguments
+ *  watchdog       - Always 0 for now
+ *  reload_value   - Number of timer clocks (after prescaler) to count before
+ *                   watchdog is woken.
+extern void bsp_watchdog_reload(int watchdog, unsigned int reload_value);
+/* Stop watchdog timer */
+extern void bsp_watchdog_stop(int watchdog);
+/* Use watchdog0 timer to reset the system */
+extern void bsp_watchdog_system_reset(void);
 #ifdef __cplusplus
 #endif
diff --git a/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
new file mode 100644
index 0000000..d3a9c15
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
@@ -0,0 +1,89 @@
+/*  GPTIMER Watchdog timer routines. On some systems the first GPTIMER
+ *  core's last Timer instance underflow signal is connected to system
+ *  reset.
+ *  COPYRIGHT (c) 2011
+ *  Aeroflex Gaisler
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#include <bsp.h>
+#include <grlib.h>
+extern volatile struct gptimer_regs *LEON3_Timer_Regs;
+struct gptimer_watchdog_priv {
+	struct gptimer_regs *regs;
+	struct gptimer_timer_regs *timer;
+	int timerno;
+struct gptimer_watchdog_priv bsp_watchdogs[1];
+int bsp_watchdog_count = 0;
+int bsp_watchdog_init(void)
+	int timercnt;
+	if (!LEON3_Timer_Regs)
+		return 0;
+	/* Get Watchdogs in system, this is implemented for one GPTIMER core
+	 * only.
+	 * First watchdog is a special case, we can get the first timer core by
+	 * looking at LEON3_Timer_Regs, the watchdog within a timer core is
+	 * always the last timer. Unfortunately we can not know it the watchdog
+	 * functionality is available or not, we assume that it is if we
+	 * reached this function.
+	bsp_watchdogs[0].regs = (struct gptimer_regs *)LEON3_Timer_Regs;
+	/* Find Timer that has watchdog functionality */
+	timercnt = bsp_watchdogs[0].regs->cfg & 0x7;
+	if (timercnt < 2) /* First timer system clock timer */
+		return 0;
+	bsp_watchdogs[0].timerno = timercnt - 1;
+	bsp_watchdogs[0].timer = &bsp_watchdogs[0].regs->timer[bsp_watchdogs[0].timerno];
+	bsp_watchdog_count = 1;
+	return bsp_watchdog_count;
+void bsp_watchdog_reload(int watchdog, unsigned int reload_value)
+	if (bsp_watchdog_count == 0)
+		bsp_watchdog_init();
+	if (bsp_watchdog_count <= watchdog)
+		return;
+	/* Kick watchdog, and clear interrupt pending bit */
+	bsp_watchdogs[watchdog].timer->reload = reload_value;
+	bsp_watchdogs[watchdog].timer->ctrl =
+		(LEON3_GPTIMER_LD | LEON3_GPTIMER_EN) |
+		(bsp_watchdogs[watchdog].timer->ctrl & ~(1<<4));
+void bsp_watchdog_stop(int watchdog)
+		return;
+	/* Stop watchdog timer */
+	bsp_watchdogs[watchdog].timer->ctrl = 0;
+/* Use watchdog timer to reset system */
+void bsp_watchdog_system_reset(void)
+	sparc_disable_interrupts();
+	bsp_watchdog_reload(0, 1);
1.7.0.4
