[PATCH 34.5 6/6] LEON3: added TX-wait-complete and CR on NL support for UART
Wed Apr 18 15:38:25 UTC 2012
apbuart_outbyte_polled prototype should still have closing
parenthesis on separate line.
rtems_io_register_name spacing on parentheses is inconsistent.
Is debugputs.c really the right name? There should no longer
be a method with that name. Only printk() support.  And I
don't know why you would need the cr/lf translation.
On 04/18/2012 10:19 AM, Daniel Hellstrom wrote:
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>   c/src/lib/libbsp/sparc/leon3/console/console.c   |   10 ++++++----
>   c/src/lib/libbsp/sparc/leon3/console/debugputs.c |   18 ++++++++++++++++--
>   2 files changed, 22 insertions(+), 6 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index 068aced..c095979 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -50,8 +50,10 @@ int syscon_uart_index __attribute__((weak)) = 0;
>   extern void apbuart_outbyte_polled(
>     ambapp_apb_uart *regs,
> -  char ch
> +  unsigned char ch,
> +  int do_cr_on_newline,
> +  int wait_sent);
>   /* body is in debugputs.c */
> @@ -157,7 +159,7 @@ ssize_t console_write_polled (int minor, const char *buf, size_t len)
>       port = minor - 1;
>     while (nwrite<  len) {
> -    apbuart_outbyte_polled(apbuarts[port].regs, *buf++);
> +    apbuart_outbyte_polled(apbuarts[port].regs, *buf++, 1, 0);
>       nwrite++;
>     return nwrite;
> @@ -346,7 +348,7 @@ rtems_device_driver console_initialize(
>      * On a MP system one should not open UARTs that other OS instances use.
>     if (syscon_uart_index<  uarts) {
> -    status = rtems_io_register_name( "/dev/console", major, 0 );
> +    status = rtems_io_register_name( "/dev/console", major, 0);
>       if (status != RTEMS_SUCCESSFUL)
>         rtems_fatal_error_occurred(status);
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> index 7058cf8..080d4fa 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> @@ -89,9 +89,12 @@ int bsp_debug_uart_init(void)
> -  unsigned char ch
> +  unsigned char ch,
> +  int wait_sent
> +send:
>     while ( (regs->status&  LEON_REG_UART_STATUS_THE) == 0 ) {
>       /* Lower bus utilization while waiting for UART */
>       asm volatile ("nop"::); asm volatile ("nop"::);
> @@ -100,6 +103,17 @@ void apbuart_outbyte_polled(
>     regs->data = (unsigned int) ch;
> +  if ((ch == '\n')&&  do_cr_on_newline) {
> +    ch = '\r';
> +    goto send;
> +  /* Wait until the character has been sent? */
> +  if (wait_sent) {
> +    while ((regs->status&  LEON_REG_UART_STATUS_THE) == 0)
> @@ -129,7 +143,7 @@ static void bsp_out_char(char c)
>       return;
> -  apbuart_outbyte_polled(dbg_uart, c);
> +  apbuart_outbyte_polled(dbg_uart, c, 1, 1);
Joel Sherrill, Ph.D.             Director of Research&   Development
