rtems-libbsd - Resolving static_hints undefined
Wed Apr 18 17:39:06 UTC 2012
Another variable needs to be treated the
same way.
extern int hintmode;
On 04/18/2012 12:35 PM, Joel Sherrill wrote:
> Hi
> sys/systm.h has this which is used by subr_hints.c
> extern char static_hints[];     /* by config for now */
> Is this normally in some generated code in FreeBSD?
> Any thoughts on where we should declare it?
Joel Sherrill, Ph.D.             Director of Research&   Development
