[PATCH 34.5 v2 6/6] LEON3: added TX-wait-complete and CR on NL support for UART
Thu Apr 19 16:23:36 UTC 2012
Are the new do_cr_on_newline and wait_sent boolean flags? can we use a
bool type? Maybe I'm being difficult but it just will be a little
easier to read the code I think. Otherwise I think this looks ok given
the rename patch coming up.
On Thu, Apr 19, 2012 at 9:21 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/leon3/console/console.c   |   11 +++++++----
>  c/src/lib/libbsp/sparc/leon3/console/debugputs.c |   18 ++++++++++++++++--
>  2 files changed, 23 insertions(+), 6 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index aece47a..fc6d5b0 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -50,8 +50,11 @@ int syscon_uart_index __attribute__((weak)) = 0;
>  extern void apbuart_outbyte_polled(
>   ambapp_apb_uart *regs,
> -  char ch
> +  unsigned char ch,
> +  int do_cr_on_newline,
> +  int wait_sent
>  /* body is in debugputs.c */
> @@ -157,7 +160,7 @@ ssize_t console_write_polled(int minor, const char *buf, size_t len)
>     port = minor - 1;
>   while (nwrite < len) {
> -    apbuart_outbyte_polled(apbuarts[port].regs, *buf++);
> +    apbuart_outbyte_polled(apbuarts[port].regs, *buf++, 1, 0);
>     nwrite++;
>   return nwrite;
> @@ -324,7 +327,7 @@ rtems_device_driver console_initialize(
>    * On a MP system one should not open UARTs that other OS instances use.
>   if (syscon_uart_index < uarts) {
> -    status = rtems_io_register_name( "/dev/console", major, 0 );
> +    status = rtems_io_register_name("/dev/console", major, 0);
>     if (status != RTEMS_SUCCESSFUL)
>       rtems_fatal_error_occurred(status);
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> index 7058cf8..080d4fa 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> @@ -89,9 +89,12 @@ int bsp_debug_uart_init(void)
> -  unsigned char ch
> +  unsigned char ch,
> +  int wait_sent
> +send:
>   while ( (regs->status & LEON_REG_UART_STATUS_THE) == 0 ) {
>     /* Lower bus utilization while waiting for UART */
>     asm volatile ("nop"::); asm volatile ("nop"::);
> @@ -100,6 +103,17 @@ void apbuart_outbyte_polled(
>   regs->data = (unsigned int) ch;
> +  if ((ch == '\n') && do_cr_on_newline) {
> +    ch = '\r';
> +    goto send;
> +  /* Wait until the character has been sent? */
> +  if (wait_sent) {
> +    while ((regs->status & LEON_REG_UART_STATUS_THE) == 0)
> @@ -129,7 +143,7 @@ static void bsp_out_char(char c)
>     return;
> -  apbuart_outbyte_polled(dbg_uart, c);
> +  apbuart_outbyte_polled(dbg_uart, c, 1, 1);
> 1.7.0.4
