[PATCH 37] LEON3: renamed console/debugputs.c to printk_support.c
Thu Apr 19 16:48:57 UTC 2012
looks good to me
On Thu, Apr 19, 2012 at 9:21 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/leon3/Makefile.am           |    2 +-
>  c/src/lib/libbsp/sparc/leon3/console/debugputs.c   |  169 --------------------
>  .../libbsp/sparc/leon3/console/printk_support.c    |  169 ++++++++++++++++++++
>  3 files changed, 170 insertions(+), 170 deletions(-)
>  delete mode 100644 c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>  create mode 100644 c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index 09d8b8e..a9badce 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -63,7 +63,7 @@ libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_show.c
>  # console
>  libbsp_a_SOURCES += console/console.c
>  # debugio
> -libbsp_a_SOURCES += console/debugputs.c
> +libbsp_a_SOURCES += console/printk_support.c
>  # clock
>  libbsp_a_SOURCES += clock/ckinit.c
>  libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> deleted file mode 100644
> index 9815053..0000000
> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> +++ /dev/null
> @@ -1,169 +0,0 @@
> - *  This file contains the TTY driver for the serial ports on the LEON.
> - *  This driver uses the termios pseudo driver.
> - *  COPYRIGHT (c) 1989-1999.
> - *  On-Line Applications Research Corporation (OAR).
> - *  Modified for LEON3 BSP.
> - *  COPYRIGHT (c) 2011.
> - *  Aeroflex Gaisler.
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.com/license/LICENSE.
> -#include <bsp.h>
> -#include <rtems/libio.h>
> -#include <stdlib.h>
> -#include <assert.h>
> -#include <stdio.h>
> -/* Let user override which on-chip APBUART will be debug UART
> - * 0 = Default APBUART. On MP system CPU0=APBUART0, CPU1=APBUART1...
> - * 1 = APBUART[0]
> - * 2 = APBUART[1]
> - * 3 = APBUART[2]
> -int debug_uart_index __attribute__((weak)) = 0;
> -struct apbuart_regs *dbg_uart = NULL;
> -/* Before UART driver has registered (or when no UART is available), calls to
> - * printk that gets to bsp_out_char() will be filling data into the
> - * pre_printk_dbgbuf[] buffer, hopefully the buffer can help debugging the
> - * early BSP boot.. At least the last printk() will be caught.
> -char pre_printk_dbgbuf[32] = {0};
> -int pre_printk_pos = 0;
> -/* Initialize the BSP system debug console layer. It will scan AMBA Plu&Play
> - * for a debug APBUART and enable RX/TX for that UART.
> -int bsp_debug_uart_init(void)
> -  int i;
> -  struct ambapp_dev *adev;
> -  struct ambapp_apb_info *apb;
> -  /* Update debug_uart_index to index used as debug console.
> -   * Let user select Debug console by setting debug_uart_index. If the
> -   * BSP is to provide the default UART (debug_uart_index==0):
> -   *   non-MP: APBUART[0] is debug console
> -   *   MP: LEON CPU index select UART
> -  if (debug_uart_index == 0) {
> -#if defined(RTEMS_MULTIPROCESSING)
> -    debug_uart_index = LEON3_Cpu_Index;
> -#else
> -    debug_uart_index = 0;
> -#endif
> -  } else {
> -    debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
> -  /* Find APBUART core for System Debug Console */
> -  i = debug_uart_index;
> -  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
> -                                 VENDOR_GAISLER, GAISLER_APBUART,
> -                                 ambapp_find_by_idx, (void *)&i);
> -  if (adev) {
> -    /* Found a matching debug console, initialize debug uart if present
> -     * for printk
> -    apb = (struct ambapp_apb_info *)adev->devinfo;
> -    dbg_uart = (struct apbuart_regs *)apb->start;
> -    dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> -    dbg_uart->status = 0;
> -    return 1;
> -  } else
> -    return 0;
> - *  apbuart_outbyte_polled
> - *  This routine transmits a character using polling.
> -void apbuart_outbyte_polled(
> -  struct apbuart_regs *regs,
> -  unsigned char ch,
> -  int do_cr_on_newline,
> -  int wait_sent
> -send:
> -  while ( (regs->status & LEON_REG_UART_STATUS_THE) == 0 ) {
> -    /* Lower bus utilization while waiting for UART */
> -    asm volatile ("nop"::); asm volatile ("nop"::);
> -  regs->data = (unsigned int) ch;
> -  if ((ch == '\n') && do_cr_on_newline) {
> -    ch = '\r';
> -    goto send;
> -  /* Wait until the character has been sent? */
> -  if (wait_sent) {
> -    while ((regs->status & LEON_REG_UART_STATUS_THE) == 0)
> - *  apbuart_inbyte_nonblocking
> - *  This routine polls for a character.
> -int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
> -  /* Clear errors */
> -  if (regs->status & LEON_REG_UART_STATUS_ERR)
> -    regs->status = ~LEON_REG_UART_STATUS_ERR;
> -  if ((regs->status & LEON_REG_UART_STATUS_DR) == 0)
> -    return EOF;
> -  else
> -    return (int) regs->data;
> -/* putchar/getchar for printk */
> -static void bsp_out_char(char c)
> -  if (dbg_uart == NULL) {
> -    /* Local debug buffer when UART driver has not registered */
> -    pre_printk_dbgbuf[pre_printk_pos++] = c;
> -    pre_printk_pos = pre_printk_pos & (sizeof(pre_printk_dbgbuf)-1);
> -    return;
> -  apbuart_outbyte_polled(dbg_uart, c, 1, 1);
> - *  To support printk
> -#include <rtems/bspIo.h>
> -BSP_output_char_function_type BSP_output_char = bsp_out_char;
> -static int bsp_in_char(void)
> -  int tmp;
> -    return EOF;
> -  while ((tmp = apbuart_inbyte_nonblocking(dbg_uart)) < 0)
> -  return tmp;
> -BSP_polling_getchar_function_type BSP_poll_char = bsp_in_char;
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> new file mode 100644
> index 0000000..9815053
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> @@ -0,0 +1,169 @@
> + *  This file contains the TTY driver for the serial ports on the LEON.
> + *  This driver uses the termios pseudo driver.
> + *  COPYRIGHT (c) 1989-1999.
> + *  On-Line Applications Research Corporation (OAR).
> + *  Modified for LEON3 BSP.
> + *  COPYRIGHT (c) 2011.
> + *  Aeroflex Gaisler.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> +#include <bsp.h>
> +#include <rtems/libio.h>
> +#include <stdlib.h>
> +#include <assert.h>
> +#include <stdio.h>
> +/* Let user override which on-chip APBUART will be debug UART
> + * 0 = Default APBUART. On MP system CPU0=APBUART0, CPU1=APBUART1...
> + * 1 = APBUART[0]
> + * 2 = APBUART[1]
> + * 3 = APBUART[2]
> +int debug_uart_index __attribute__((weak)) = 0;
> +struct apbuart_regs *dbg_uart = NULL;
> +/* Before UART driver has registered (or when no UART is available), calls to
> + * printk that gets to bsp_out_char() will be filling data into the
> + * pre_printk_dbgbuf[] buffer, hopefully the buffer can help debugging the
> + * early BSP boot.. At least the last printk() will be caught.
> +char pre_printk_dbgbuf[32] = {0};
> +int pre_printk_pos = 0;
> +/* Initialize the BSP system debug console layer. It will scan AMBA Plu&Play
> + * for a debug APBUART and enable RX/TX for that UART.
> +int bsp_debug_uart_init(void)
> +  int i;
> +  struct ambapp_dev *adev;
> +  struct ambapp_apb_info *apb;
> +  /* Update debug_uart_index to index used as debug console.
> +   * Let user select Debug console by setting debug_uart_index. If the
> +   * BSP is to provide the default UART (debug_uart_index==0):
> +   *   non-MP: APBUART[0] is debug console
> +   *   MP: LEON CPU index select UART
> +  if (debug_uart_index == 0) {
> +#if defined(RTEMS_MULTIPROCESSING)
> +    debug_uart_index = LEON3_Cpu_Index;
> +#else
> +    debug_uart_index = 0;
> +#endif
> +  } else {
> +    debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
> +  /* Find APBUART core for System Debug Console */
> +  i = debug_uart_index;
> +  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
> +                                 VENDOR_GAISLER, GAISLER_APBUART,
> +                                 ambapp_find_by_idx, (void *)&i);
> +  if (adev) {
> +    /* Found a matching debug console, initialize debug uart if present
> +     * for printk
> +    apb = (struct ambapp_apb_info *)adev->devinfo;
> +    dbg_uart = (struct apbuart_regs *)apb->start;
> +    dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> +    dbg_uart->status = 0;
> +    return 1;
> +  } else
> +    return 0;
> + *  apbuart_outbyte_polled
> + *  This routine transmits a character using polling.
> +void apbuart_outbyte_polled(
> +  struct apbuart_regs *regs,
> +  unsigned char ch,
> +  int do_cr_on_newline,
> +  int wait_sent
> +send:
> +  while ( (regs->status & LEON_REG_UART_STATUS_THE) == 0 ) {
> +    /* Lower bus utilization while waiting for UART */
> +    asm volatile ("nop"::); asm volatile ("nop"::);
> +  regs->data = (unsigned int) ch;
> +  if ((ch == '\n') && do_cr_on_newline) {
> +    ch = '\r';
> +    goto send;
> +  /* Wait until the character has been sent? */
> +  if (wait_sent) {
> +    while ((regs->status & LEON_REG_UART_STATUS_THE) == 0)
> + *  apbuart_inbyte_nonblocking
> + *  This routine polls for a character.
> +int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
> +  /* Clear errors */
> +  if (regs->status & LEON_REG_UART_STATUS_ERR)
> +    regs->status = ~LEON_REG_UART_STATUS_ERR;
> +  if ((regs->status & LEON_REG_UART_STATUS_DR) == 0)
> +    return EOF;
> +  else
> +    return (int) regs->data;
> +/* putchar/getchar for printk */
> +static void bsp_out_char(char c)
> +  if (dbg_uart == NULL) {
> +    /* Local debug buffer when UART driver has not registered */
> +    pre_printk_dbgbuf[pre_printk_pos++] = c;
> +    pre_printk_pos = pre_printk_pos & (sizeof(pre_printk_dbgbuf)-1);
> +    return;
> +  apbuart_outbyte_polled(dbg_uart, c, 1, 1);
> + *  To support printk
> +#include <rtems/bspIo.h>
> +BSP_output_char_function_type BSP_output_char = bsp_out_char;
> +static int bsp_in_char(void)
> +  int tmp;
> +    return EOF;
> +  while ((tmp = apbuart_inbyte_nonblocking(dbg_uart)) < 0)
> +  return tmp;
> +BSP_polling_getchar_function_type BSP_poll_char = bsp_in_char;
> 1.7.0.4
