genmcf548x patches
Fri Apr 20 12:00:03 UTC 2012
Hi,
I checked this now on real hardware.  The first problem was this for RTEMS 4.11:
https://www.rtems.org/bugzilla/show_bug.cgi?id=2055
The BSP must ensure that it is possible to restore a floating-point context in
the initialization code.  This is required by the _Thread_Start_multitasking().
This test for initialization threads is superfluous and will be removed.
Instead the FPU will be enabled unconditionally.
On 04/16/2012 11:36 PM, Joel Sherrill wrote:
> Hi
> Attached are two patches for review. The first adds
> a new method to determine if any initialization
> tasks/threads in any API use the FPU.
> The second modifies the genmcf548x BSP to use this
> new helper routine.
> If these are OK, then I will need to add some documentation
> and tests.
This patch is not needed.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
