GCC Version Questions
Fri Apr 27 11:35:41 UTC 2012
On 04/27/2012 01:29 PM, Ralf Corsepius wrote:
> On 04/27/2012 01:15 PM, Sebastian Huber wrote:
>> On 04/27/2012 12:06 PM, Ralf Corsepius wrote:
>>> On 04/27/2012 11:57 AM, Sebastian Huber wrote:
>>>> On 04/27/2012 11:47 AM, Ralf Corsepius wrote:
>>>>> Or differently:
>>>>> Do _you_ (Sebastian) want to force the RTEMS-4.11 users to using
>>>>> arm-eabi and
>>>>> tell them the target they have been using in their products for years
>>>>> will now
>>>>> face a sudden death?
>>>> Yes, this is exactly what I want to tell the RTEMS 4.11 users.
>>> OK, the arm-rtems is gone from rtems-crossrpms.
>>> I'll remove the packages from the repositories, ASAP.
>> Ok, thanks for this. Can you please also rename the arm-rtemseabi into
>> arm-rtems to be in line with all other RTEMS targets.
> Errr? Upstream GCC _forces_ us to use arm-rtemseabi.
> We *can* not change this into arm-rtems
Oh, sorry.  I will provide a patch for GCC to remove the old arm-rtems target
and rename arm-rtemseabi into arm-rtems.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
