[rtems commit] Merge branch 'master' of ssh://rgit/data/git/rtems
Sat Apr 28 16:56:52 UTC 2012
Nice write up Gedare. Is all of this in the wiki?
Gedare Bloom <gedare at rtems.org> wrote:
>Hi,
>To avoid these merge messages and spurious changesets please stick to
>using rebase on your checked-out master branch, e.g.
>$> git pull --rebase upstream master
>This helps to maintain a linear history in the rtems.git primary
>repository. Merge messages happen due to a non-fastforward merge on
>your master branch. The easiest way to avoid conflicts and non-ff
>merges is to always develop on a branch that you checkout from a
>vanilla master.
>When you do notice a non-ff merge the easiest thing to do is to reset
>your head right away (git reset HEAD^) and then clear the changes (git
>checkout -f). This should undo the merge and its merge message. Then
>you can do a rebase and hopefully things will go well.
>-Gedare
>On Fri, Apr 27, 2012 at 11:03 PM, Chris Johns <chrisj at rtems.org> wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    bb43b51e66e5ec8667eb6fddee970b2944a1ad09
>> Changeset: http://git.rtems.org/rtems/commit/?id=bb43b51e66e5ec8667eb6fddee970b2944a1ad09
>> Author:    Chris Johns <chrisj at rtems.org>
>> Date:      Sat Apr 28 13:06:44 2012 +1000
>> rtems-vc mailing list
>> rtems-vc at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-vc
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
