Documentations
Mon Apr 30 14:27:27 UTC 2012
Generally speaking we try to keep the development version in a state
that can build and run. The main reason to use a release version is to
work on production code. I advise all research and new development be
done with the Git head.
For scheduling in particular I would encourage you to use the
development head since it contains improvements to the modular
scheduling framework made in the last year. You can read a little more
about the modular scheduler in RTEMS at [1] and [2]. The scheduler has
changed somewhat since I wrote those posts but they still make a
decent introduction. I believe the C User Manual contains some other
details about the scheduler as well including the additional EDF and
CBS schedulers.
-Gedare
[1] http://gedare-csphd.blogspot.com/2010/11/rtems-modular-task-scheduler.html
[2] http://gedare-csphd.blogspot.com/2010/12/rtems-adding-new-scheduler.html
On Mon, Apr 30, 2012 at 10:11 AM, Fered <a_Fered at yahoo.com> wrote:
> Thanks a lot.
> I prefer using of a released version. I want to evaluate some idea in
> scheduling through a stable release.
> Gedare Bloom wrote:
>> I don't think we have such a thing for the "kernel" code, and the
>> developer base probably is not large enough to warrant the effort to
>> make one.
>> A lot of that knowledge is in developer heads. Some of it leaches out
>> to documentation. Some of it can be gleaned from the doxygen [1].
>> Otherwise you can ask specific questions here and we will try to give
>> specific answers. :)
>> I can't think of anywhere else you could find useful documentation.
>> The code base is not big so unlike Linux you can reasonably go and
>> start figuring it out yourself with a little guidance.
>> I saw your email in the other list and if you are interested in kernel
>> hacking / BSP development then I would suggest you use the current
>> development head (which we are calling 4.11). While it is possible to
>> add BSPs and backport BSPs to prior releases of RTEMS they are much
>> harder to get accepted for inclusion and less likely to be maintained.
>> Your efforts will be much more rewarded by using the development head.
>> -Gedare
>> [1] http://www.rtems.org/onlinedocs/doxygen/cpukit/html/
>> On Sun, Apr 29, 2012 at 11:57 PM, Fered <a_Fered at yahoo.com> wrote:
>> > And I think I should shovel the code! :D
>> > I'm looking for a document same as "Linux Kernel Development" book, in
>> > linux. (It's just an example that you understand what I intend)
>> > Thanks.
>> >  Joel Sherrill wrote:
>> >> And there is always the source code. :)
>> >> Gedare Bloom <gedare at rtems.org> wrote:
>> >> >You can find them under doc/ in RTEMS, or built from the Git head at
>> >> >http://rtems.org/onlinedocs/doc-current/share/rtems/html/
>> >> >On Sun, Apr 29, 2012 at 7:47 AM, Fered <a_Fered at yahoo.com> wrote:
>> >> >> Hi;
>> >> >> Is there any document, defines architecture of RTEMS and
>> >> >> implementation of some functionalities such as scheduling and
>> >> >> interrupt handleing.
>> >> >> Thanks.
>> >> >> _______________________________________________
>> >> >> rtems-devel mailing list
>> >> >> rtems-devel at rtems.org
>> >> >> http://www.rtems.org/mailman/listinfo/rtems-devel
