ioctl_return and ioctl handler type
Ralf Corsepius
ralf.corsepius at rtems.org
Tue Apr 3 13:11:59 UTC 2012
On 04/03/2012 01:44 PM, Joel Sherrill wrote:
> Tradition?
> There was a heavy use of unsigned 32 bit integers and as we have moved more and more to POSIX, some are left.
> This makes sense to change but the ripple will be tedious.
>> int devFS_ioctl(
>> rtems_libio_t *iop,
>> uint32_t command,
>> void *buffer
While we're at it, all ioctl's are supposed to take an ioctl_command_t
as command argument.
Ralf
