Debug for x86
Wendell Silva
silvawp at gmail.com
Thu Apr 5 12:13:39 UTC 2012
Hi Fered,
If your target has a serial port, you could make use of gdb glue-code on
the target.
In the host side (eclipse) customize the debug properties to use
i386-rtems<version>-gdb.exe.
A detailed explanation on such a glue-code for gdb can be found:
- rtems/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO.
Hope it helps.
--Wendell.
2012/4/5 Fered <a_Fered at yahoo.com>
> Hi;
> How can I debug my RTEMS application for x86 target machine, on a linux
> host
> OS on a PC?
> I mean, is there a solution same as developing and debugging a C
> application
> on a linux using an IDE such as eclipse?
> Thanks.
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120405/5a21264f/attachment-0001.html>
