[PATCH 29] LEON3: console use register pointers instead of UART indexes
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Apr 5 15:29:46 UTC 2012
Looks OK to me.
On 04/05/2012 10:23 AM, Daniel Hellstrom wrote:
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
> c/src/lib/libbsp/sparc/leon3/console/console.c | 16 ++++----
> c/src/lib/libbsp/sparc/leon3/console/debugputs.c | 50 +++++++++++-----------
> 2 files changed, 33 insertions(+), 33 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index a07fb15..320aa37 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -40,13 +40,13 @@ int syscon_uart_index __attribute__((weak)) = 0;
> - * console_outbyte_polled
> + * apbuart_outbyte_polled
> * This routine transmits a character using polling.
> -void console_outbyte_polled(
> - int port,
> +extern void apbuart_outbyte_polled(
> + ambapp_apb_uart *regs,
> char ch
> @@ -58,7 +58,7 @@ void console_outbyte_polled(
> * This routine polls for a character.
> -int apbuart_inbyte_nonblocking(int port);
> +extern int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs);
> /* body is in debugputs.c */
> @@ -78,13 +78,13 @@ ssize_t console_write_support (int minor, const char *buf, size_t len)
> port = minor - 1;
> while (nwrite< len) {
> - console_outbyte_polled(port, *buf++);
> + apbuart_outbyte_polled((ambapp_apb_uart*)LEON3_Console_Uart[port], *buf++);
> nwrite++;
> return nwrite;
> -int console_inbyte_nonblocking(int minor)
> +int console_pollRead(int minor)
> int port;
> @@ -93,7 +93,7 @@ int console_inbyte_nonblocking(int minor)
> else
> port = minor - 1;
> - return apbuart_inbyte_nonblocking(port);
> + return apbuart_inbyte_nonblocking((ambapp_apb_uart*)LEON3_Console_Uart[port]);
> @@ -168,7 +168,7 @@ rtems_device_driver console_open(
> static const rtems_termios_callbacks pollCallbacks = {
> NULL, /* firstOpen */
> NULL, /* lastClose */
> - console_inbyte_nonblocking, /* pollRead */
> + console_pollRead, /* pollRead */
> console_write_support, /* write */
> NULL, /* setAttributes */
> NULL, /* stopRemoteTx */
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> index cf3f280..43c6d7d 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> @@ -21,6 +21,7 @@
> #include<rtems/libio.h>
> #include<stdlib.h>
> #include<assert.h>
> +#include<stdio.h>
> * Number of uarts on AMBA bus
> @@ -37,6 +38,7 @@ static int isinit = 0;
> int debug_uart_index __attribute__((weak)) = 0;
> +ambapp_apb_uart *dbg_uart = NULL;
> * Scan for UARTS in configuration
> @@ -74,9 +76,9 @@ int scan_uarts(void)
> /* initialize debug uart if present for printk */
> if (debug_uart_index< uarts) {
> - LEON3_Console_Uart[debug_uart_index]->ctrl |= LEON_REG_UART_CTRL_RE |
> - LEON_REG_UART_CTRL_TE;
> - LEON3_Console_Uart[debug_uart_index]->status = 0;
> + dbg_uart = (ambapp_apb_uart *)LEON3_Console_Uart[debug_uart_index];
> + dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> + dbg_uart->status = 0;
> isinit = 1;
> @@ -85,48 +87,43 @@ int scan_uarts(void)
> - int port,
> +void apbuart_outbyte_polled(
> unsigned char ch
> - if ((port>= 0)&& (port< uarts)) {
> - return;
> - while ( (LEON3_Console_Uart[port]->status& LEON_REG_UART_STATUS_THE) == 0 );
> - LEON3_Console_Uart[port]->data = (unsigned int) ch;
> + while ( (regs->status& LEON_REG_UART_STATUS_THE) == 0 );
> + regs->data = (unsigned int) ch;
> - * console_inbyte_nonblocking
> + * apbuart_inbyte_nonblocking
> +int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs)
> - assert( 0 );
> - return -1;
> /* Clear errors */
> - if (LEON3_Console_Uart[port]->status& LEON_REG_UART_STATUS_ERR)
> - LEON3_Console_Uart[port]->status = ~LEON_REG_UART_STATUS_ERR;
> + if (regs->status& LEON_REG_UART_STATUS_ERR)
> + regs->status = ~LEON_REG_UART_STATUS_ERR;
> - if ((LEON3_Console_Uart[port]->status& LEON_REG_UART_STATUS_DR) == 0)
> - return -1;
> + if ((regs->status& LEON_REG_UART_STATUS_DR) == 0)
> + return EOF;
> else
> - return (int) LEON3_Console_Uart[port]->data;
> + return (int) regs->data;
> /* putchar/getchar for printk */
> static void bsp_out_char(char c)
> - console_outbyte_polled(debug_uart_index, c);
> + if (dbg_uart == NULL)
> + return;
> + apbuart_outbyte_polled(dbg_uart, c);
> @@ -141,7 +138,10 @@ static int bsp_in_char(void)
> int tmp;
> - while ((tmp = apbuart_inbyte_nonblocking(debug_uart_index))< 0)
> + return EOF;
> + while ((tmp = apbuart_inbyte_nonblocking(dbg_uart))< 0)
> return tmp;
Joel Sherrill, Ph.D. Director of Research& Development
