Debug for x86
Fered a_Fered at yahoo.com
Sat Apr 7 10:24:45 UTC 2012
Is GDB available only for x86 architecture?
Gedare Bloom wrote:
> http://www.rtems.com/wiki/index.php?title=Special%3ASearch&search=eclipse&go
> =Go
> not much info on using gdb+eclipse specifically in RTEMS but I think
> you can find that out other places once you have eclipse working.
> On Thu, Apr 5, 2012 at 11:41 PM, Fered <a_Fered at yahoo.com> wrote:
> > Hi Wendell;
> > Thank you for your answer.
> > It's a brief help. I need more explanation. Is it available manuals for
> > eclipse integration and usage of gdb and eclipse for RTEMS?
> > Regards.
> > Wendell Silva wrote:
> >> Hi Fered,
> >> If your target has a serial port, you could make use of gdb glue-code
> >> on
> >> the target.
> >> In the host side (eclipse) customize the debug properties to use
> >> i386-rtems<version>-gdb.exe.
> >> A detailed explanation on such a glue-code for gdb can be found:
> >>    - rtems/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO.
> >> Hope it helps.
> >> --Wendell.
> >> 2012/4/5 Fered <a_Fered at yahoo.com>
> >> > Hi;
> >> > How can I debug my RTEMS application for x86 target machine, on a
> >> > linux host
> >> > OS on a PC?
> >> > I mean, is there a solution same as developing and debugging a C
> >> > application
> >> > on a linux using an IDE such as eclipse?
> >> > Thanks.
> >> > _______________________________________________
> >> > rtems-devel mailing list
> >> > rtems-devel at rtems.org
> >> > http://www.rtems.org/mailman/listinfo/rtems-devel
