[rtems commit] rbheap: New files
Sebastian Huber
Sun Apr 15 10:56:04 UTC 2012
On 14/04/12 18:20, Gedare Bloom wrote:
> I have a couple concerns.
> First is the naming "rbheap";. I see it is implementing a memory
> manager using the rbtree and a couple chain controls. It's not really
> a heap so much as a custom free page allocator.
From my point of view everything that implements the malloc() and
free() interface is a heap. Why do you think this is not a heap?
> Second is the code placement. I'm not convinced this is best to just
> shim into the sapi layer.
Where else would you place this?
> The functionality is reminiscent of the
> Region Manager. What functionality is missing that this code is unable
> to use existing classic or score services to achieve? I have a feeling
> we could generalize the approach taken here by implementing an Arena
> Manager somewhere.
The region manager stores administration data in the managed memory
area. The rbheap separates this. You can use it to implement a task
stack allocator where each task has only access to is own task stack.
> Third is the use of the word "pages". Unless we are referring to
> fixed-size ranges of virtual memory I think we should avoid this word
> since it has a fairly common technical meaning and connotation as an
> OS concept.
The region manager and the first-fit heap code uses also this notation.
What do you think about "chunk" instead of "page"?
> Fourth is the lack of documentation. This is an addition to the public
> API and should be reflected somewhere in docu and the release notes.
Ok.
> Fifth is the lack of review before committing;)
Sorry, we can do the review now.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
