[rtems commit] rbheap: New files
Sun Apr 15 22:52:49 UTC 2012
On 04/15/2012 12:04 PM, Gedare Bloom wrote:
> On Sun, Apr 15, 2012 at 6:56 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> On 14/04/12 18:20, Gedare Bloom wrote:
>>> I have a couple concerns.
>>> First is the naming "rbheap";. I see it is implementing a memory
>>> manager using the rbtree and a couple chain controls. It's not really
>>> a heap so much as a custom free page allocator.
>>  From my point of view everything that implements the malloc() and free()
>> interface is a heap.  Why do you think this is not a heap?
> Sorry I was confusing terms between a heap data structure versus a
> heap space of memory. rbheap should be fine on further thought. It
> might be nice to formalize/standardize this interface. Perhaps even
> implement this rbheap as an alternative Heap Control.
>>> Second is the code placement. I'm not convinced this is best to just
>>> shim into the sapi layer.
>> Where else would you place this?
> I'm not sure. sapi probably is the most appropriate place that we have
> currently. I am not happy with the sapi directory generally as it is
> quite vague how we
> should be using it / what should be implemented in it.
SAPI is an old joke for "sappy" as in sticky. It was intended to
include the parts of an OS that are NEVER addressed by any
standard. Think initialization, configuration, device driver
management, plug-ins, etc.
The core of it is initialization which is "logically above"
any API. It coordinates the initialization of all APIs
> I'm seeing a pattern between the Region Manager, Partition Manager,
> and your rbheap manager. They all offer quite similar functionality
> except for how they implement the memory pool. I wonder if we can
> unify them all in one Supercore Manager that uses a pluggable memory
> pool implementation. Region and Partition would still need to have a
> thin wrapper in the classic api, and the rbheap can be in the sapi
> since it is not part of any standardized features.
whatever an rbheap promotes as a user api would just be another
object in the Classic API.
If the choice is comparable to FIFO/priority blocking, then it
may make since to consider it an attribute of a Region which
algorithm to use.
> In my view the classic API is not consistent with a standard (orkid
> seems like it was doa unless I'm missing something) and we should
> consider it to be the RTEMS api and merge the sapi into it and move
> forward with implementing any RTEMS-specific non-standard APIs at that
> layer. This point should be discussed separately / elsewhere however.
You are missing the layering of at least the initialization
manager. The other parts could be moved to the Classic API
but the intent is that the functionality that is "beyond what
one can expect in an API definition" is in SAPI. Initialization,
configuration, user extensions, and device driver basics
meet that definition.
RTEID/ORKID were failed efforts for a short list of reasons
+ looking too much like an existing product (pSOS+)
+ politics of RTOS vendors pushing proprietary APIs
+ the general believe that the POSIX threads API work
which was underway at the end of the RTEID/ORKID effort
would produce a threading API suitable for hard real-time
embedded systems.
>>> The functionality is reminiscent of the
>>> Region Manager. What functionality is missing that this code is unable
>>> to use existing classic or score services to achieve? I have a feeling
>>> we could generalize the approach taken here by implementing an Arena
>>> Manager somewhere.
>> The region manager stores administration data in the managed memory area.
>>   The rbheap separates this.  You can use it to implement a task stack
>> allocator where each task has only access to is own task stack.
> Let me see if I understand. With the rbheap you can use one rbheap to
> allocate n task stacks, and the administrative data for the stack
> allocation will reside in the rbheap_page structure. So you can have
> precise definitions of which memory the task needs to access and a
> blown task stack will not directly access the administrative data.
> With the region manager you cannot use one region to allocate n task
> stacks because the administrative data (when using a Heap Control)
> resides within the heap so a blown task stack can overwrite the heap
> metadata to cause corruption elsewhere. You would need n regions to
> deal with n separate task stacks--quite a waste.
> The utility in the implementation of a memory pool using the rbheap
> approach is that the administrative data resides externally to the
> memory pool, which differs from a traditional heap implementation.
If your understanding is correct, this would have advantages
but memory can always be corrupted. You just eliminated a
potential source.
>>> Third is the use of the word "pages". Unless we are referring to
>>> fixed-size ranges of virtual memory I think we should avoid this word
>>> since it has a fairly common technical meaning and connotation as an
>>> OS concept.
>> The region manager and the first-fit heap code uses also this notation.
>>   What do you think about "chunk" instead of "page"?
> I like chunk better than page. The region manager actually uses page,
> segment, and block. In the region manager the page size refers only to
> the initial amount of memory that is allocated for the region manager
> to use. The region manager refers to allocated chunks as segments
> which might be ok though it suffers from a similar double-meaning as
> page. The partition manager uses buffer and blocks, which are
> overloaded terms in RTEMS since we use those in the fs layer. We
> should probably unify all this terminology.
The terminology is abused but does follow the RTEID/ORKID
specification.
 From memory, pSOS+, Nucleus, and ThreadX all have some
resemblance to RTEID/ORKID APIs. I don't mind any changes
but remember that changing terminology needs to be thorough
and it is difficult old language uses.
This may also impact type names which would break API compatibility.
For example, it took a LONG time to kill old versus new interrupt
model. We now say Simple Vectored and Programmable Interrupt
Controller models. Old vs. new was a bad side-effect of not
being able to convert all PowerPC applications at the same time.
I am not saying it it worth considering or doing. Just that we need to
be damned sure we want to do it. And we need to be committed
to following through completely and quickly (in RTEMS terms).
>>> Fourth is the lack of documentation. This is an addition to the public
>>> API and should be reflected somewhere in docu and the release notes.
>> Ok.
>>> Fifth is the lack of review before committing;)
>> Sorry, we can do the review now.
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone   : +49 89 18 90 80 79-6
>> Fax     : +49 89 18 90 80 79-9
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
