[PATCH 33.1 2/5] LEON3: clock driver use new AMBAPP layer
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Apr 15 22:54:04 UTC 2012
On 04/15/2012 01:39 PM, Gedare Bloom wrote:
> Looks ok.
Minor style issue. Arguments are supposed to be "(arg1, arg2)"
But OK to me if that is fixed and all required patches are OK.
> On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom<daniel at gaisler.com> wrote:
>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>> c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 14 ++++++++------
>> 1 files changed, 8 insertions(+), 6 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>> index 3cdbb20..dacfd2e 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>> @@ -22,6 +22,7 @@
>> #include<bsp.h>
>> #include<bspopts.h>
>> +#include<ambapp.h>
>> #if SIMSPARC_FAST_IDLE==1
>> #define CLOCK_DRIVER_USE_FAST_IDLE
>> @@ -59,14 +60,15 @@ static int clkirq;
>> #define Clock_driver_support_find_timer() \
>> do { \
>> - int cnt; \
>> - amba_apb_device dev; \
>> + struct ambapp_dev *adev; \
>> - /* Find LEON3 GP Timer */ \
>> - cnt = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&dev); \
>> - if ( cnt> 0 ) { \
>> + /* Find first LEON3 GP Timer */ \
>> + adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),\
>> + VENDOR_GAISLER, GAISLER_GPTIMER, ambapp_find_by_idx, NULL); \
>> + if (adev) { \
>> /* Found APB GPTIMER Timer */ \
>> - LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) dev.start; \
>> + LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) \
>> + DEV_TO_APB(adev)->start; \
>> clkirq = (LEON3_Timer_Regs->status& 0xf8)>> 3; \
>> Adjust_clkirq_for_node(); \
>> 1.7.0.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
