[PATCH 33.0 1/5] LEON: updated AMBA PnP API
Daniel Hellstrom
daniel at gaisler.com
Mon Apr 16 08:23:55 UTC 2012
Hello,
On 04/15/2012 08:34 PM, Gedare Bloom wrote:
> This is a big one! Most of this is specific to the leon bsps so I just
> glanced it over. I have just two comments.
> First you can eliminate the $Id$ tags.
Ok.
> Second is the indentation. We usually use 2 spaces per indent level
> while this code uses 6 or so.
Yes, it have hard TAB = 8 spaces. I believe I have asked before about indentation, and I've got the impression that it doesn't really matter as it is consistent within the file. At least it is easier
to go from hw-tab to soft, and of course I agree that all files should aim to have the same coding-style. I will update the patches and come back.
Daniel
> -Gedare
> On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom<daniel at gaisler.com> wrote:
>> The old layer had some limitations/problems for multiple AHB
>> buses since the data structure containing all AMBA devices
>> were allocated before scanning.
>> The new layer create devices as they are found and memory is
>> allocated using malloc() or bsp_early_malloc() during booting.
>> The old 8 functions for finding a specific AHB-Slave or
>> APB-Slave device has been replaced with one function,
>> ambapp_for_each(), which iterates over all devices matching
>> the specified search options and calls a user provided
>> function. The new way lowers the footprint and makes searching
>> more flexible.
>> The frequency information is now supported, if the frequency
>> of one device is reported by the user.
>> More AHB-to-AHB bridges are supported.
>> The API has been split into several parts in order to lower the
>> footprint.
>> The API also introduces the AMBAPP CORE concept, where one
>> ambapp_core can be created from one AHB Master, AHB Slave
>> and one APB Slave, at least one device is required for creating
>> a core.
>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>> c/src/lib/libbsp/sparc/Makefile.am | 10 +
>> c/src/lib/libbsp/sparc/leon2/Makefile.am | 15 +-
>> c/src/lib/libbsp/sparc/leon2/preinstall.am | 12 +-
>> c/src/lib/libbsp/sparc/leon3/Makefile.am | 15 +-
>> c/src/lib/libbsp/sparc/leon3/amba/amba.c | 47 +-
>> c/src/lib/libbsp/sparc/leon3/include/amba.h | 2 +-
>> c/src/lib/libbsp/sparc/leon3/preinstall.am | 4 +
>> c/src/lib/libbsp/sparc/shared/amba/ambapp.c | 866 ++++++++++----------
>> c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c | 28 +
>> c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c | 27 +
>> c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c | 27 +
>> .../libbsp/sparc/shared/amba/ambapp_find_by_idx.c | 42 +
>> c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c | 114 +++
>> c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c | 395 +++++++++
>> c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c | 92 ++
>> c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c | 26 +
>> c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c | 76 ++
>> c/src/lib/libbsp/sparc/shared/include/ambapp.h | 497 +++++++-----
>> c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h | 245 ++++++
>> 19 files changed, 1882 insertions(+), 658 deletions(-)
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
>> create mode 100644 c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h
>> diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
>> index 4f445ba..2b9909c 100644
>> --- a/c/src/lib/libbsp/sparc/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/Makefile.am
>> @@ -17,7 +17,17 @@ EXTRA_DIST += shared/irq/irq-shared.c
>> # AMBA Plug&Play bus
>> EXTRA_DIST += shared/include/ambapp.h
>> +EXTRA_DIST += shared/include/ambapp_ids.h
>> EXTRA_DIST += shared/amba/ambapp.c
>> +EXTRA_DIST += shared/amba/ambapp_alloc.c
>> +EXTRA_DIST += shared/amba/ambapp_count.c
>> +EXTRA_DIST += shared/amba/ambapp_depth.c
>> +EXTRA_DIST += shared/amba/ambapp_find_by_idx.c
>> +EXTRA_DIST += shared/amba/ambapp_freq.c
>> +EXTRA_DIST += shared/amba/ambapp_parent.c
>> +EXTRA_DIST += shared/amba/ambapp_names.c
>> +EXTRA_DIST += shared/amba/ambapp_old.c
>> +EXTRA_DIST += shared/amba/ambapp_show.c
>> # PCI bus
>> EXTRA_DIST += shared/include/pci.h
>> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> index 2acca78..c2310bc 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>> @@ -14,7 +14,6 @@ include_HEADERS = include/bsp.h
>> include_HEADERS += include/tm27.h
>> include_HEADERS += include/rasta.h
>> include_HEADERS += include/cchip.h
>> -include_HEADERS += ../../sparc/shared/include/ambapp.h
>> include_HEADERS += ../../sparc/shared/include/grspw.h
>> include_HEADERS += ../../sparc/shared/include/grspw_pci.h
>> include_HEADERS += ../../sparc/shared/include/grspw_rasta.h
>> @@ -79,8 +78,20 @@ libbsp_a_SOURCES += \
>> ../../shared/src/irq-legacy.c \
>> ../../shared/src/irq-server.c \
>> ../../shared/src/irq-shell.c
>> -# AMBA PnP Scanning
>> +# AMBA bus
>> +include_HEADERS += ../../sparc/shared/include/ambapp.h
>> +include_HEADERS += ../../sparc/shared/include/ambapp_ids.h
>> libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_alloc.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_count.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_depth.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_find_by_idx.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_freq.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_parent.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_old.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_names.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_show.c
>> # PCI
>> libbsp_a_SOURCES += pci/pci.c ../../sparc/shared/pci/pcifinddevice.c
>> # RASTA Kit
>> diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
>> index 00ed05e..2978d58 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
>> +++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
>> @@ -53,10 +53,6 @@ $(PROJECT_INCLUDE)/cchip.h: include/cchip.h $(PROJECT_INCLUDE)/$(dirstamp)
>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/cchip.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/cchip.h
>> -$(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLUDE)/$(dirstamp)
>> - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp.h
>> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp.h
>> $(PROJECT_INCLUDE)/grspw.h: ../../sparc/shared/include/grspw.h $(PROJECT_INCLUDE)/$(dirstamp)
>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw.h
>> @@ -157,6 +153,14 @@ $(PROJECT_INCLUDE)/bsp/irq.h: include/bsp/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstam
>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>> +$(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLUDE)/$(dirstamp)
>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp.h
>> +$(PROJECT_INCLUDE)/ambapp_ids.h: ../../sparc/shared/include/ambapp_ids.h $(PROJECT_INCLUDE)/$(dirstamp)
>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp_ids.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp_ids.h
>> $(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLUDE)/$(dirstamp)
>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i2cmst.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
>> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> index ebbeb46..6bcc53f 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> @@ -44,10 +44,21 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>> libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
>> # gnatsupp
>> libbsp_a_SOURCES += gnatsupp/gnatsupp.c ../../sparc/shared/gnatcommon.c
>> -# amba
>> +# AMBA bus
>> include_HEADERS += include/amba.h
>> -libbsp_a_SOURCES += amba/amba.c ../../sparc/shared/amba/ambapp.c
>> +libbsp_a_SOURCES += amba/amba.c
>> +libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp.c
>> # console
>> libbsp_a_SOURCES += console/console.c
>> # debugio
>> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> index 16fb8de..e41d0aa 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> @@ -1,10 +1,10 @@
>> - * AMBA Plag& Play Bus Driver
>> + * AMBA Plug& Play Bus Driver
>> * This driver hook performs bus scanning.
>> - * COPYRIGHT (c) 2004.
>> - * Gaisler Research
>> + * COPYRIGHT (c) 2011.
>> + * Aeroflex Gaisler
>> * The license and distribution terms for this file may be
>> * found in the file LICENSE in this distribution or at
>> @@ -14,9 +14,14 @@
>> #include<bsp.h>
>> +#include<ambapp.h>
>> -/* Structure containing address to devices found on the Amba Plug&Play bus */
>> -amba_confarea_type amba_conf;
>> +/* AMBA Plug&Play information description.
>> + * After software has scanned AMBA PnP it builds a tree to make
>> + * it easier for drivers to work with the bus architecture.
>> +struct ambapp_bus ambapp_plb;
>> /* GRLIB extended IRQ controller register */
>> extern void leon3_ext_irq_init(void);
>> @@ -38,16 +43,21 @@ extern int scan_uarts(void);
>> void amba_initialize(void)
>> - int i;
>> int icsel;
>> - amba_apb_device dev;
>> + struct ambapp_dev *adev;
>> - /* Scan the AMBA Plug&Play info at the default LEON3 area */
>> - amba_scan(&amba_conf,LEON3_IO_AREA,NULL);
>> + /* Scan AMBA Plug&Play read-only information. The routine builds a PnP
>> + * tree into ambapp_plb in RAM, after this we never access the PnP
>> + * information in hardware directly any more.
>> + * Since on Processor Local Bus (PLB) memory mapping is 1:1
>> + ambapp_scan(&ambapp_plb, LEON3_IO_AREA, NULL, NULL);
>> /* Find LEON3 Interrupt controller */
>> - i = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_IRQMP,&dev);
>> - if (i<= 0){
>> + adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
>> + VENDOR_GAISLER, GAISLER_IRQMP,
>> + ambapp_find_by_idx, NULL);
>> + if (adev == NULL) {
>> /* PANIC IRQ controller not found!
>> * What else can we do but stop ...
>> @@ -55,7 +65,8 @@ void amba_initialize(void)
>> asm volatile( "mov 1, %g1; ta 0x0" );
>> - LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *) dev.start;
>> + LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *)
>> + DEV_TO_APB(adev)->start;
>> if ((LEON3_IrqCtrl_Regs->ampctrl>> 28)> 0) {
>> /* IRQ Controller has support for multiple IRQ Controllers, each
>> * CPU can be routed to different Controllers, we find out which
>> @@ -74,9 +85,15 @@ void amba_initialize(void)
>> leon3_ext_irq_init();
>> /* find GP Timer */
>> - i = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&dev);
>> - if ( i> 0 ) {
>> - LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) dev.start;
>> + VENDOR_GAISLER, GAISLER_GPTIMER,
>> + if (adev) {
>> + LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *)DEV_TO_APB(adev)->start;
>> + /* Register AMBA Bus Frequency */
>> + ambapp_freq_init(&ambapp_plb, adev,
>> + (LEON3_Timer_Regs->scaler_reload + 1) * 1000000);
>> /* find UARTS */
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/amba.h b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>> index 9167ff1..aa13f2c 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/amba.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>> @@ -34,7 +34,7 @@ extern "C" {
>> #endif
>> /* The AMBA Plug&Play info of the bus that the LEON3 sits on */
>> -extern amba_confarea_type amba_conf;
>> +extern struct ambapp_bus ambapp_plb;
>> #ifdef __cplusplus
>> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> index 8c27b81..540e37b 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> @@ -85,6 +85,10 @@ $(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLU
>> $(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
>> index 814ee8c..62c96a0 100644
>> --- a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
>> @@ -1,499 +1,475 @@
>> + * AMBA Plug& Play routines
>> - * This driver hook performs bus scanning.
>> + * Aeroflex Gaisler.
>> * http://www.rtems.com/license/LICENSE.
>> - * $Id$
>> + * $Id: ambapp.c,v 1.2 2009/11/29 15:33:27 ralf Exp $
>> + * 2008-12-01, Daniel Hellstrom<daniel at gaisler.com>
>> + * Created
>> -#include<bsp.h>
>> -#include<rtems/bspIo.h>
>> +#include<string.h>
>> +#include<stdlib.h>
>> +#include<string.h>
>> #include<ambapp.h>
>> +#include<bsp.h>
>> +#define AMBA_CONF_AREA 0xff000
>> +#define AMBA_AHB_SLAVE_CONF_AREA (1<< 11)
>> +#define AMBA_APB_SLAVES 16
>> -#define amba_insert_device(tab, address) \
>> - if (*(address)) \
>> - (tab)->addr[(tab)->devnr] = (address); \
>> - (tab)->devnr ++; \
>> -} while(0)
>> -#define amba_insert_apb_device(tab, address, apbmst) \
>> - if (*(address)) \
>> - (tab)->apbmst[(tab)->devnr] = (apbmst); \
>> -} while(0)
>> -static unsigned int
>> -addr_from (struct amba_mmap *mmaps, unsigned int address)
>> +/* Allocate one AMBA device */
>> +struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
>> - /* no translation? */
>> - if (!mmaps)
>> - return address;
>> - while (mmaps->size) {
>> - if ((address>= mmaps->remote_amba_adr)
>> -&& (address<= (mmaps->remote_amba_adr + (mmaps->size - 1)))) {
>> - return (address - mmaps->remote_amba_adr) + mmaps->cpu_adr;
>> - mmaps++;
>> - return 1;
>> + int size = sizeof(struct ambapp_dev);
>> + struct ambapp_dev *dev;
>> + if (dev_type == DEV_APB_SLV)
>> + size += sizeof(struct ambapp_apb_info);
>> + else
>> + size += sizeof(struct ambapp_ahb_info); /* AHB */
>> + dev = (struct ambapp_dev *)bsp_early_malloc(size);
>> + if (dev == NULL)
>> + return NULL;
>> + memset(dev, 0 , size);
>> + dev->dev_type = dev_type;
>> + return dev;
>> -void
>> -amba_scan (amba_confarea_type * amba_conf, unsigned int ioarea,
>> - struct amba_mmap *mmaps)
>> +unsigned int
>> +ambapp_addr_from (struct ambapp_mmap *mmaps, unsigned int address)
>> - unsigned int *cfg_area; /* address to configuration area */
>> - unsigned int mbar, conf, custom;
>> - int i, j;
>> - unsigned int apbmst;
>> - int maxloops = amba_conf->notroot ? 16 : 64; /* scan first bus for 64 devices, rest for 16 devices */
>> - amba_conf->ahbmst.devnr = 0;
>> - amba_conf->ahbslv.devnr = 0;
>> - amba_conf->apbslv.devnr = 0;
>> - cfg_area = (unsigned int *) (ioarea | AMBA_CONF_AREA);
>> - amba_conf->ioarea = ioarea;
>> - amba_conf->mmaps = mmaps;
>> - for (i = 0; i< maxloops; i++) {
>> - amba_insert_device (&amba_conf->ahbmst, cfg_area);
>> - cfg_area += AMBA_AHB_CONF_WORDS;
>> - cfg_area =
>> - (unsigned int *) (ioarea | AMBA_CONF_AREA | AMBA_AHB_SLAVE_CONF_AREA);
>> - amba_insert_device (&amba_conf->ahbslv, cfg_area);
>> - for (i = 0; i< amba_conf->ahbslv.devnr; i++){
>> - conf = amba_get_confword(amba_conf->ahbslv, i, 0);
>> - mbar = amba_ahb_get_membar(amba_conf->ahbslv, i, 0);
>> - if ( (amba_vendor(conf) == VENDOR_GAISLER)&& (amba_device(conf) == GAISLER_AHB2AHB) ){
>> - /* Found AHB->AHB bus bridge, scan it if more free amba_confarea_type:s available
>> - * Custom config 1 contain ioarea.
>> - custom = amba_ahb_get_custom(amba_conf->ahbslv,i,1);
>> - if ( amba_ver(conf)&& amba_conf->next ){
>> - amba_conf->next->notroot = 1;
>> - amba_scan(amba_conf->next,custom,mmaps);
>> - }else if ((amba_vendor(conf) == VENDOR_GAISLER)&& (amba_device(conf) == GAISLER_APBMST))
>> - apbmst = amba_membar_start(mbar);
>> - if ( (apbmst=addr_from(mmaps,apbmst)) == 1 )
>> - continue; /* no available memory translation available, will not be able to access
>> - * Plug&Play information for this AHB/APB bridge. Skip it.
>> - cfg_area = (unsigned int *)( apbmst | AMBA_CONF_AREA);
>> - for (j=0; (amba_conf->apbslv.devnr<AMBA_APB_SLAVES)&& (j<AMBA_APB_SLAVES); j++){
>> - amba_insert_apb_device(&amba_conf->apbslv, cfg_area, apbmst);
>> - cfg_area += AMBA_APB_CONF_WORDS;
>> + /* no translation? */
>> + if (!mmaps)
>> + return address;
>> + while (mmaps->size) {
>> + if ((address>= mmaps->remote_adr)&&
>> + (address<= (mmaps->remote_adr + (mmaps->size - 1)))) {
>> + return (address - mmaps->remote_adr) + mmaps->local_adr;
>> + mmaps++;
>> + return 1;
>> -void
>> -amba_print_dev(int devno, unsigned int conf){
>> - int irq = amba_irq(conf);
>> - if ( irq> 0 ){
>> - printk("%x.%x.%x: irq %d\n",devno,amba_vendor(conf),amba_device(conf),irq);
>> - }else{
>> - printk("%x.%x.%x: no irq\n",devno,amba_vendor(conf),amba_device(conf));
>> +void ambapp_ahb_dev_init(
>> + unsigned int ioarea,
>> + struct ambapp_mmap *mmaps,
>> + struct ambapp_pnp_ahb *ahb,
>> + struct ambapp_dev *dev,
>> + int ahbidx
>> + int bar;
>> + struct ambapp_ahb_info *ahb_info;
>> + unsigned int addr, mask, mbar;
>> + /* Setup device struct */
>> + dev->vendor = ambapp_pnp_vendor(ahb->id);
>> + dev->device = ambapp_pnp_device(ahb->id);
>> + ahb_info = DEV_TO_AHB(dev);
>> + ahb_info->ver = ambapp_pnp_ver(ahb->id);
>> + ahb_info->irq = ambapp_pnp_irq(ahb->id);
>> + ahb_info->ahbidx = ahbidx;
>> + ahb_info->custom[0] = (unsigned int)ahb->custom[0];
>> + ahb_info->custom[1] = (unsigned int)ahb->custom[1];
>> + ahb_info->custom[2] = (unsigned int)ahb->custom[2];
>> + /* Memory BARs */
>> + for (bar=0; bar<4; bar++) {
>> + mbar = ahb->mbar[bar];
>> + if (mbar == 0) {
>> + addr = 0;
>> + mask = 0;
>> + } else {
>> + addr = ambapp_pnp_start(mbar);
>> + if (ambapp_pnp_mbar_type(mbar) == AMBA_TYPE_AHBIO) {
>> + /* AHB I/O area is releative IO_AREA */
>> + addr = AMBA_TYPE_AHBIO_ADDR(addr, ioarea);
>> + mask = (((unsigned int)
>> + (ambapp_pnp_mbar_mask((~mbar))<<8) |
>> + 0xff)) + 1;
>> + } else {
>> + /* AHB memory area, absolute address */
>> + addr = ambapp_addr_from(mmaps, addr);
>> + mask = (~((unsigned int)
>> + (ambapp_pnp_mbar_mask(mbar)<<20))) + 1;
>> + ahb_info->start[bar] = addr;
>> + ahb_info->mask[bar] = mask;
>> + ahb_info->type[bar] = ambapp_pnp_mbar_type(mbar);
>> -void
>> -amba_apb_print_dev(int devno, unsigned int conf, unsigned int address){
>> - if ( irq> 0 ){
>> - printk("%x.%x.%x: irq %d, apb: 0x%lx\n",devno,amba_vendor(conf),amba_device(conf),irq,address);
>> - }else{
>> - printk("%x.%x.%x: no irq, apb: 0x%lx\n",devno,amba_vendor(conf),amba_device(conf),address);
>> +void ambapp_apb_dev_init(
>> + unsigned int base,
>> + struct ambapp_pnp_apb *apb,
>> + int ahbidx
>> + struct ambapp_apb_info *apb_info;
>> + dev->vendor = ambapp_pnp_vendor(apb->id);
>> + dev->device = ambapp_pnp_device(apb->id);
>> + apb_info = DEV_TO_APB(dev);
>> + apb_info->ver = ambapp_pnp_ver(apb->id);
>> + apb_info->irq = ambapp_pnp_irq(apb->id);
>> + apb_info->ahbidx = ahbidx;
>> + apb_info->start = ambapp_pnp_apb_start(apb->iobar, base);
>> + apb_info->mask = ambapp_pnp_apb_mask(apb->iobar);
>> -/* Print AMBA Plug&Play info on terminal */
>> -void
>> -amba_print_conf (amba_confarea_type * amba_conf)
>> +int ambapp_add_ahbbus(
>> + struct ambapp_bus *abus,
>> - int i,base=0;
>> - unsigned int conf, iobar, address;
>> - /* print all ahb masters */
>> - printk("--- AMBA AHB Masters ---\n");
>> - for(i=0; i<amba_conf->ahbmst.devnr; i++){
>> - conf = amba_get_confword(amba_conf->ahbmst, i, 0);
>> - amba_print_dev(i,conf);
>> + int i;
>> + for (i=0; i<AHB_BUS_MAX; i++) {
>> + if (abus->ahbs[i].ioarea == 0) {
>> + abus->ahbs[i].ioarea = ioarea;
>> + return i;
>> + } else if (abus->ahbs[i].ioarea == ioarea) {
>> + /* Bus already added */
>> + return -1;
>> + return -1;
>> - /* print all ahb slaves */
>> - printk("--- AMBA AHB Slaves ---\n");
>> - for(i=0; i<amba_conf->ahbslv.devnr; i++){
>> +/* Internal AMBA Scanning Function */
>> +static int ambapp_scan2(
>> + ambapp_memcpy_t memfunc,
>> + struct ambapp_dev *parent,
>> + struct ambapp_dev **root
>> + struct ambapp_pnp_ahb *ahb, ahb_buf;
>> + struct ambapp_pnp_apb *apb, apb_buf;
>> + struct ambapp_dev *dev, *prev, *prevapb, *apbdev;
>> + int maxloops = 64;
>> + unsigned int apbbase, bridge_adr;
>> + int i, j, ahbidx;
>> + *root = NULL;
>> + if (parent) {
>> + /* scan first bus for 64 devices, rest for 16 devices */
>> + maxloops = 16;
>> - /* print all apb slaves */
>> - apbmst = 0;
>> - for(i=0; i<amba_conf->apbslv.devnr; i++){
>> - if ( apbmst != amba_conf->apbslv.apbmst[i] ){
>> - apbmst = amba_conf->apbslv.apbmst[i];
>> - printk("--- AMBA APB Slaves on 0x%x ---\n",apbmst);
>> - base=i;
>> - conf = amba_get_confword(amba_conf->apbslv, i, 0);
>> - iobar = amba_apb_get_membar(amba_conf->apbslv, i);
>> - address = amba_iobar_start(amba_conf->apbslv.apbmst[i], iobar);
>> - amba_apb_print_dev(i-base,conf,address);
>> + ahbidx = ambapp_add_ahbbus(abus, ioarea);
>> + if (ahbidx< 0) {
>> + /* Bus already scanned, stop */
>> + return 0;
>> -/**** APB Slaves ****/
>> + prev = parent;
>> -/* Return number of APB Slave devices which has given vendor and device */
>> -int
>> -amba_get_number_apbslv_devices (amba_confarea_type * amba_conf, int vendor,
>> - int device)
>> - unsigned int conf;
>> - int cnt, i;
>> - for (cnt = i = 0; i< amba_conf->apbslv.devnr; i++) {
>> - conf = amba_get_confword (amba_conf->apbslv, i, 0);
>> - if ((amba_vendor (conf) == vendor)&& (amba_device (conf) == device))
>> - cnt++;
>> - return cnt;
>> + /* AHB MASTERS */
>> + ahb = (struct ambapp_pnp_ahb *) (ioarea | AMBA_CONF_AREA);
>> + for (i = 0; i< maxloops; i++, ahb++) {
>> + memfunc(&ahb_buf, ahb, sizeof(struct ambapp_pnp_ahb), abus);
>> + if (ahb_buf.id == 0)
>> + continue;
>> -/* Get First APB Slave device of this vendor&device id */
>> -int
>> -amba_find_apbslv (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_apb_device * dev)
>> - unsigned int conf, iobar;
>> - int i;
>> - for (i = 0; i< amba_conf->apbslv.devnr; i++) {
>> - if ((amba_vendor (conf) == vendor)&& (amba_device (conf) == device)) {
>> - iobar = amba_apb_get_membar (amba_conf->apbslv, i);
>> - dev->start = amba_iobar_start (amba_conf->apbslv.apbmst[i], iobar);
>> - dev->irq = amba_irq (conf);
>> - return 1;
>> - return 0;
>> + /* An AHB device present here */
>> + dev = ambapp_alloc_dev_struct(DEV_AHB_MST);
>> + if (!dev)
>> + return -1;
>> -/* Get APB Slave device of this vendor&device id. (setting nr to 0 is eqivalent to calling amba_find_apbslv() ) */
>> -int
>> -amba_find_next_apbslv (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_apb_device * dev, int index)
>> - int cnt, i;
>> - if (cnt == index) {
>> - /* found device */
>> - return 1;
>> - cnt++;
>> - return 0;
>> + ambapp_ahb_dev_init(ioarea, abus->mmaps,&ahb_buf, dev, ahbidx);
>> -/* Get first nr APB Slave devices, put them into dev (which is an array of nr length) */
>> -int
>> -amba_find_apbslvs (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_apb_device * devs, int maxno)
>> - int cnt, i;
>> - for (cnt = i = 0; (i< amba_conf->apbslv.devnr)&& (cnt< maxno); i++) {
>> - devs[cnt].start = amba_iobar_start (amba_conf->apbslv.apbmst[i], iobar);
>> - devs[cnt].irq = amba_irq (conf);
>> - cnt++;
>> - return cnt;
>> + if (*root == NULL)
>> + *root = dev;
>> -/***** AHB SLAVES *****/
>> + if (prev != parent)
>> + prev->next = dev;
>> + dev->prev = prev;
>> + prev = dev;
>> -/* Return number of AHB Slave devices which has given vendor and device */
>> -int
>> -amba_get_number_ahbslv_devices (amba_confarea_type * amba_conf, int vendor,
>> - int device)
>> - int cnt, i;
>> - for (cnt = i = 0; i< amba_conf->ahbslv.devnr; i++) {
>> - conf = amba_get_confword (amba_conf->ahbslv, i, 0);
>> - cnt++;
>> - return cnt;
>> + /* AHB SLAVES */
>> + (ioarea | AMBA_CONF_AREA | AMBA_AHB_SLAVE_CONF_AREA);
>> + continue;
>> + dev = ambapp_alloc_dev_struct(DEV_AHB_SLV);
>> + if (!dev)
>> + return -1;
>> + *root = dev;
>> + prev->next = dev;
>> + dev->prev = prev;
>> + prev = dev;
>> + /* Is it a AHB/AHB Bridge ? */
>> + if (((dev->device == GAISLER_AHB2AHB)&&
>> + (dev->vendor == VENDOR_GAISLER)&& (ahb_info->ver>0)) ||
>> + ((dev->device == GAISLER_L2CACHE)&&
>> + (dev->vendor == VENDOR_GAISLER)) ||
>> + ((dev->device == GAISLER_GRIOMMU)&&
>> + (dev->vendor == VENDOR_GAISLER))) {
>> + /* AHB/AHB Bridge Found, recurse down the
>> + * Bridge
>> + if (ahb_info->custom[1] != 0) {
>> + bridge_adr = ambapp_addr_from(abus->mmaps,
>> + ahb_info->custom[1]);
>> + /* Scan next bus if not already scanned */
>> + if (ambapp_scan2(abus, bridge_adr, memfunc, dev,
>> +&dev->children))
>> + return -1;
>> + } else if ((dev->device == GAISLER_APBMST)&&
>> + (dev->vendor == VENDOR_GAISLER)) {
>> + /* AHB/APB Bridge Found, add the APB devices to this
>> + * AHB Slave's children
>> + prevapb = dev;
>> + apbbase = ahb_info->start[0];
>> + /* APB SLAVES */
>> + apb = (struct ambapp_pnp_apb *)
>> + (apbbase | AMBA_CONF_AREA);
>> + for (j=0; j<AMBA_APB_SLAVES; j++, apb++) {
>> + memfunc(&apb_buf, apb, sizeof(*apb), abus);
>> + if (apb_buf.id == 0)
>> + continue;
>> + apbdev = ambapp_alloc_dev_struct(DEV_APB_SLV);
>> + if (!dev)
>> + return -1;
>> + ambapp_apb_dev_init(apbbase, abus->mmaps,
>> +&apb_buf, apbdev, ahbidx);
>> + if (prevapb != dev)
>> + prevapb->next = apbdev;
>> + else
>> + dev->children = apbdev;
>> + apbdev->prev = prevapb;
>> + prevapb = apbdev;
>> -/* Get First AHB Slave device of this vendor&device id */
>> -int
>> -amba_find_ahbslv (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_ahb_device * dev)
>> - unsigned int conf, mbar, addr;
>> - int j, i;
>> - for (i = 0; i< amba_conf->ahbslv.devnr; i++) {
>> - for (j = 0; j< 4; j++) {
>> - mbar = amba_ahb_get_membar (amba_conf->ahbslv, i, j);
>> - addr = amba_membar_start (mbar);
>> - if (amba_membar_type (mbar) == AMBA_TYPE_AHBIO) {
>> - addr = AMBA_TYPE_AHBIO_ADDR (addr, amba_conf->ioarea);
>> - } else { /* convert address if needed */
>> - if ((addr = addr_from (amba_conf->mmaps, addr)) == 1) {
>> - addr = 0; /* no available memory translation available, will not be able to access
>> - * Plug&Play information for this AHB address. Skip it.
>> - dev->start[j] = addr;
>> - dev->ver = amba_ver (conf);
>> - return 1;
>> - return 0;
>> + /* Remember first AHB MST/SLV device on bus and Parent Bridge */
>> + abus->ahbs[ahbidx].dev = *root;
>> + abus->ahbs[ahbidx].bridge = parent;
>> -/* Get AHB Slave device of this vendor&device id. (setting nr to 0 is eqivalent to calling amba_find_ahbslv() ) */
>> -int
>> -amba_find_next_ahbslv (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_ahb_device * dev, int index)
>> - int i, j, cnt;
>> - } else {
>> - /* convert address if needed */
>> - return 1;
>> - cnt++;
>> - return 0;
>> + return 0;
>> -/* Get first nr AHB Slave devices, put them into dev (which is an array of nr length) */
>> -int
>> -amba_find_ahbslvs (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_ahb_device * devs, int maxno)
>> +/* Build AMBA Plug& Play device graph */
>> +int ambapp_scan(
>> - int i, j, cnt;
>> - for (cnt = i = 0; (i< amba_conf->ahbslv.devnr)&& (maxno< cnt); i++) {
>> - } else {
>> - devs[cnt].start[j] = addr;
>> - devs[cnt].ver = amba_ver (conf);
>> - cnt++;
>> - return cnt;
>> + memset(abus, 0, sizeof(*abus));
>> + abus->mmaps = mmaps;
>> + /* Default to memcpy() */
>> + if (!memfunc)
>> + memfunc = (ambapp_memcpy_t)memcpy;
>> -/***** AHB Masters *****/
>> + return ambapp_scan2(abus, ioarea, memfunc, NULL,&abus->root);
>> -int
>> -amba_get_number_ahbmst_devices (amba_confarea_type * amba_conf, int vendor,
>> - int device)
>> +/* Match search options againt device */
>> +int ambapp_dev_match_options(struct ambapp_dev *dev, unsigned int options, int vendor, int device)
>> - int cnt, i;
>> - for (cnt = i = 0; i< amba_conf->ahbmst.devnr; i++) {
>> - conf = amba_get_confword (amba_conf->ahbmst, i, 0);
>> - cnt++;
>> - return cnt;
>> + if ((((options& (OPTIONS_ALL_DEVS)) == OPTIONS_ALL_DEVS) || /* TYPE */
>> + ((options& OPTIONS_AHB_MSTS)&& (dev->dev_type == DEV_AHB_MST)) ||
>> + ((options& OPTIONS_AHB_SLVS)&& (dev->dev_type == DEV_AHB_SLV)) ||
>> + ((options& OPTIONS_APB_SLVS)&& (dev->dev_type == DEV_APB_SLV)))&&
>> + ((vendor == -1) || (vendor == dev->vendor))&& /* VENDOR/DEV ID */
>> + ((device == -1) || (device == dev->device))&&
>> + (((options& OPTIONS_ALL) == OPTIONS_ALL) || /* Allocated State */
>> + ((options& OPTIONS_FREE)&& DEV_IS_FREE(dev)) ||
>> + ((options& OPTIONS_ALLOCATED)&& DEV_IS_ALLOCATED(dev)))) {
>> + return 1;
>> + return 0;
>> -int
>> -amba_find_ahbmst (amba_confarea_type * amba_conf, int vendor, int device,
>> +/* If device is an APB bridge all devices on the APB bridge is processed */
>> +static int ambapp_for_each_apb(
>> + unsigned int options,
>> + int vendor,
>> + int device,
>> + ambapp_func_t func,
>> + void *arg)
>> - int j, i;
>> - for (i = 0; i< amba_conf->ahbmst.devnr; i++) {
>> - mbar = amba_ahb_get_membar (amba_conf->ahbmst, i, j);
>> - } else {
>> - return 1;
>> - return 0;
>> + int index, ret;
>> + struct ambapp_dev *apbslv;
>> + ret = 0;
>> + if (dev->children&& (dev->children->dev_type == DEV_APB_SLV)) {
>> + /* Found a APB Bridge */
>> + index = 0;
>> + apbslv = dev->children;
>> + while (apbslv) {
>> + if (ambapp_dev_match_options(apbslv, options,
>> + vendor, device) == 1) {
>> + ret = func(apbslv, index, arg);
>> + if (ret != 0)
>> + break; /* Signalled stopped */
>> + index++;
>> + apbslv = apbslv->next;
>> + return ret;
>> -int
>> -amba_find_next_ahbmst (amba_confarea_type * amba_conf, int vendor, int device,
>> +/* Traverse the prescanned device information */
>> +static int ambapp_for_each_dev(
>> + struct ambapp_dev *root,
>> + int vendor,
>> + int device,
>> + void *arg)
>> - int i, j, cnt;
>> - } else {
>> - return 1;
>> - cnt++;
>> - return 0;
>> + int ahb_slave = 0;
>> + int index, ret;
>> + /* Start at device 'root' and process downwards.
>> + * Breadth first search, search order
>> + * 1. AHB MSTS
>> + * 2. AHB SLVS
>> + * 3. APB SLVS on primary bus
>> + * 4. AHB/AHB secondary... -> step to 1.
>> + /* AHB MST / AHB SLV */
>> + if (options& (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_DEPTH_FIRST)) {
>> + index = 0;
>> + dev = root;
>> + while (dev) {
>> + if ((dev->dev_type == DEV_AHB_SLV)&& !ahb_slave) {
>> + /* First AHB Slave */
>> + ahb_slave = 1;
>> + index = 0;
>> + /* Conditions must be fullfilled for function to be
>> + * called
>> + if (ambapp_dev_match_options(dev, options, vendor,
>> + device) == 1) {
>> + /* Correct device and vendor ID */
>> + ret = func(dev, index, arg);
>> + if (ret != 0)
>> + return ret; /* Signalled stopped */
>> + if ((options& OPTIONS_DEPTH_FIRST)&&
>> + (options& OPTIONS_APB_SLVS)) {
>> + /* Check is APB bridge, and process all APB
>> + * Slaves in that case
>> + ret = ambapp_for_each_apb(dev, options, vendor,
>> + device, func, arg);
>> + if (ret != 0)
>> + if (options& OPTIONS_DEPTH_FIRST) {
>> + (dev->children->dev_type != DEV_APB_SLV)) {
>> + /* Found AHB Bridge, recurse */
>> + ret = ambapp_for_each_dev(dev->children,
>> + options, vendor,
>> + if (ret != 0)
>> + return ret;
>> + index++;
>> + dev = dev->next;
>> + /* Find APB Bridges */
>> + if ((options& OPTIONS_APB_SLVS)&& !(options& OPTIONS_DEPTH_FIRST)) {
>> + dev = root;
>> + while (dev) {
>> + /* Check is APB bridge, and process all APB Slaves in
>> + * that case
>> + ret = ambapp_for_each_apb(dev, options, vendor, device,
>> + func, arg);
>> + if (ret != 0)
>> + dev = dev->next;
>> + /* Find AHB Bridges */
>> + if (!(options& OPTIONS_DEPTH_FIRST)) {
>> + dev = root;
>> + while (dev) {
>> + options, vendor,
>> + if (ret != 0)
>> + return ret;
>> + dev = dev->next;
>> + return 0;
>> -int
>> -amba_find_ahbmsts (amba_confarea_type * amba_conf, int vendor, int device,
>> +int ambapp_for_each(
>> + int vendor,
>> + int device,
>> + void *arg)
>> - int i, j, cnt;
>> - for (cnt = i = 0; (i< amba_conf->ahbmst.devnr)&& (maxno< cnt); i++) {
>> - } else {
>> - cnt++;
>> - return cnt;
>> + return ambapp_for_each_dev(abus->root, options, vendor, device, func,
>> + arg);
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c
>> new file mode 100644
>> index 0000000..0188267
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_alloc.c
>> @@ -0,0 +1,28 @@
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.com/license/LICENSE.
>> + * $Id: ambapp_alloc.c,v
>> +#include<ambapp.h>
>> +int ambapp_alloc_dev(struct ambapp_dev *dev, void *owner)
>> + if (dev->owner)
>> + return -1;
>> + dev->owner = owner;
>> + return 0;
>> +void ambapp_free_dev(struct ambapp_dev *dev)
>> + dev->owner = 0;
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c
>> index 0000000..5be4607
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_count.c
>> @@ -0,0 +1,27 @@
>> + * $Id: ambapp_count.c,v
>> +#include<ambapp.h>
>> +/* Get number of devices matching search options */
>> +int ambapp_dev_count(struct ambapp_bus *abus, unsigned int options,
>> + int vendor, int device)
>> + int count = 10000;
>> + ambapp_for_each(abus, options, vendor, device, ambapp_find_by_idx,
>> +&count);
>> + return 10000 - count;
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c
>> index 0000000..cd1a7b4
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_depth.c
>> @@ -0,0 +1,27 @@
>> + * $Id: ambapp_depth.c,v
>> +#include<ambapp.h>
>> +int ambapp_depth(struct ambapp_dev *dev)
>> + int depth = 0;
>> + do {
>> + dev = ambapp_find_parent(dev);
>> + depth++;
>> + } while (dev);
>> + return depth - 1;
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c
>> index 0000000..9d078c0
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c
>> @@ -0,0 +1,42 @@
>> + * $Id: ambapp_find_by_idx.c,v
>> +#include<ambapp.h>
>> +/* AMBAPP helper routine to find a device by index. The function is given to
>> + * ambapp_for_each, the argument may be NULL (find first device) or a pointer
>> + * to a index which is downcounted until 0 is reached. If the int-pointer
>> + * points to a value of:
>> + * 0 - first device is returned
>> + * 1 - second device is returned
>> + * The matching device is returned, which will stop the ambapp_for_each search.
>> + * If zero is returned from ambapp_for_each no device matching the index was
>> + * found
>> +int ambapp_find_by_idx(struct ambapp_dev *dev, int index, void *pcount)
>> + int *pi = pcount;
>> + if (pi) {
>> + if (*pi-- == 0)
>> + return (int)dev;
>> + else
>> + return 0;
>> + } else {
>> + /* Satisfied with first matching device, stop search */
>> + return (int)dev;
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
>> index 0000000..d3f0e78
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
>> @@ -0,0 +1,114 @@
>> + * $Id: ambapp_freq.c,v
>> +#include<ambapp.h>
>> +/* Calculate AHB Bus frequency of
>> + * - Bus[0] (inverse=1), relative to the frequency of Bus[ahbidx]
>> + * NOTE: set freq_hz to frequency of Bus[ahbidx].
>> + * or
>> + * - Bus[ahbidx] (inverse=0), relative to the frequency of Bus[0]
>> + * NOTE: set freq_hz to frequency of Bus[0].
>> + * If a unsupported bridge is found the invalid frequncy of 0Hz is
>> + * returned.
>> +unsigned int ambapp_freq_calc(
>> + int ahbidx,
>> + unsigned int freq_hz,
>> + int inverse)
>> + struct ambapp_ahb_info *ahb;
>> + struct ambapp_dev *bridge;
>> + unsigned char ffact;
>> + int dir;
>> + /* Found Bus0? */
>> + bridge = abus->ahbs[ahbidx].bridge;
>> + if (!bridge)
>> + return freq_hz;
>> + /* Find this bus frequency relative to freq_hz */
>> + if ((bridge->vendor == VENDOR_GAISLER)&&
>> + ((bridge->device == GAISLER_AHB2AHB) ||
>> + (bridge->device == GAISLER_L2CACHE))) {
>> + ahb = DEV_TO_AHB(bridge);
>> + ffact = (ahb->custom[0]& AMBAPP_FLAG_FFACT)>> 4;
>> + if (ffact != 0) {
>> + dir = ahb->custom[0]& AMBAPP_FLAG_FFACT_DIR;
>> + /* Calculate frequency by dividing or
>> + * multiplying system frequency
>> + if ((dir&& !inverse) || (!dir&& inverse))
>> + freq_hz = freq_hz * ffact;
>> + else
>> + freq_hz = freq_hz / ffact;
>> + return ambapp_freq_calc(abus, ahb->ahbidx, freq_hz, inverse);
>> + } else {
>> + /* Unknown bridge, impossible to calc frequency */
>> + return 0;
>> +/* Find the frequency of all AHB Buses from knowing the frequency of one
>> + * particular APB/AHB Device.
>> +void ambapp_freq_init(
>> + unsigned int freq_hz)
>> + struct ambapp_common_info *info;
>> + int i;
>> + abus->ahbs[i].freq_hz = 0;
>> + /* Register Frequency at the AHB bus that the device the user gave us
>> + * is located at.
>> + if (dev) {
>> + info = DEV_TO_COMMON(dev);
>> + abus->ahbs[info->ahbidx].freq_hz = freq_hz;
>> + /* Find Frequency of Bus 0 */
>> + abus->ahbs[0].freq_hz =
>> + ambapp_freq_calc(abus, info->ahbidx, freq_hz, 1);
>> + } else {
>> + abus->ahbs[0].freq_hz = freq_hz;
>> + /* Find Frequency of all except for Bus0 and the bus which frequency
>> + * was reported at
>> + for (i=1; i<AHB_BUS_MAX; i++) {
>> + break;
>> + if (abus->ahbs[i].freq_hz != 0)
>> + continue;
>> + ambapp_freq_calc(abus, i, abus->ahbs[0].freq_hz, 0);
>> +/* Assign a AMBA Bus a frequency but reporting the frequency of a
>> + * particular AHB/APB device */
>> +unsigned int ambapp_freq_get(struct ambapp_bus *abus, struct ambapp_dev *dev)
>> + struct ambapp_common_info *info = DEV_TO_COMMON(dev);
>> + return abus->ahbs[info->ahbidx].freq_hz;
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
>> index 0000000..1fe6553
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
>> @@ -0,0 +1,395 @@
>> + * AMBA Plug& Play Device and Vendor name database
>> + * COPYRIGHT (c) 2009.
>> + * The device and vendor definitions are extracted with a script from
>> + * GRLIB.
>> + * 2009-01-27, Daniel Hellstrom<daniel at gaisler.com>
>> + * Created from GRLIB 3386.
>> +#include<ambapp_ids.h>
>> +#include<string.h>
>> +#ifndef NULL
>> +#define NULL 0
>> +#endif
>> +typedef struct {
>> + int device_id;
>> + char *name;
>> +} ambapp_device_name;
>> +typedef struct {
>> + unsigned int vendor_id;
>> + char *name;
>> + ambapp_device_name *devices;
>> +} ambapp_vendor_devnames;
>> +/**************** AUTO GENERATED FROM devices.vhd ****************/
>> +static ambapp_device_name GAISLER_devices[] =
>> + {GAISLER_LEON2DSU, "LEON2DSU"},
>> + {GAISLER_LEON3, "LEON3"},
>> + {GAISLER_LEON3DSU, "LEON3DSU"},
>> + {GAISLER_ETHAHB, "ETHAHB"},
>> + {GAISLER_APBMST, "APBMST"},
>> + {GAISLER_AHBUART, "AHBUART"},
>> + {GAISLER_SRCTRL, "SRCTRL"},
>> + {GAISLER_SDCTRL, "SDCTRL"},
>> + {GAISLER_SSRCTRL, "SSRCTRL"},
>> + {GAISLER_APBUART, "APBUART"},
>> + {GAISLER_IRQMP, "IRQMP"},
>> + {GAISLER_AHBRAM, "AHBRAM"},
>> + {GAISLER_AHBDPRAM, "AHBDPRAM"},
>> + {GAISLER_GPTIMER, "GPTIMER"},
>> + {GAISLER_PCITRG, "PCITRG"},
>> + {GAISLER_PCISBRG, "PCISBRG"},
>> + {GAISLER_PCIFBRG, "PCIFBRG"},
>> + {GAISLER_PCITRACE, "PCITRACE"},
>> + {GAISLER_DMACTRL, "DMACTRL"},
>> + {GAISLER_AHBTRACE, "AHBTRACE"},
>> + {GAISLER_DSUCTRL, "DSUCTRL"},
>> + {GAISLER_CANAHB, "CANAHB"},
>> + {GAISLER_GPIO, "GPIO"},
>> + {GAISLER_AHBROM, "AHBROM"},
>> + {GAISLER_AHBJTAG, "AHBJTAG"},
>> + {GAISLER_ETHMAC, "ETHMAC"},
>> + {GAISLER_SWNODE, "SWNODE"},
>> + {GAISLER_SPW, "SPW"},
>> + {GAISLER_AHB2AHB, "AHB2AHB"},
>> + {GAISLER_USBDC, "USBDC"},
>> + {GAISLER_USB_DCL, "USB_DCL"},
>> + {GAISLER_DDRMP, "DDRMP"},
>> + {GAISLER_ATACTRL, "ATACTRL"},
>> + {GAISLER_DDRSP, "DDRSP"},
>> + {GAISLER_EHCI, "EHCI"},
>> + {GAISLER_UHCI, "UHCI"},
>> + {GAISLER_I2CMST, "I2CMST"},
>> + {GAISLER_SPW2, "SPW2"},
>> + {GAISLER_AHBDMA, "AHBDMA"},
>> + {GAISLER_NUHOSP3, "NUHOSP3"},
>> + {GAISLER_CLKGATE, "CLKGATE"},
>> + {GAISLER_SPICTRL, "SPICTRL"},
>> + {GAISLER_DDR2SP, "DDR2SP"},
>> + {GAISLER_SLINK, "SLINK"},
>> + {GAISLER_GRTM, "GRTM"},
>> + {GAISLER_GRTC, "GRTC"},
>> + {GAISLER_GRPW, "GRPW"},
>> + {GAISLER_GRCTM, "GRCTM"},
>> + {GAISLER_GRHCAN, "GRHCAN"},
>> + {GAISLER_GRFIFO, "GRFIFO"},
>> + {GAISLER_GRADCDAC, "GRADCDAC"},
>> + {GAISLER_GRPULSE, "GRPULSE"},
>> + {GAISLER_GRTIMER, "GRTIMER"},
>> + {GAISLER_AHB2PP, "AHB2PP"},
>> + {GAISLER_GRVERSION, "GRVERSION"},
>> + {GAISLER_APB2PW, "APB2PW"},
>> + {GAISLER_PW2APB, "PW2APB"},
>> + {GAISLER_GRCAN, "GRCAN"},
>> + {GAISLER_I2CSLV, "I2CSLV"},
>> + {GAISLER_U16550, "U16550"},
>> + {GAISLER_AHBMST_EM, "AHBMST_EM"},
>> + {GAISLER_AHBSLV_EM, "AHBSLV_EM"},
>> + {GAISLER_GRTESTMOD, "GRTESTMOD"},
>> + {GAISLER_ASCS, "ASCS"},
>> + {GAISLER_IPMVBCTRL, "IPMVBCTRL"},
>> + {GAISLER_SPIMCTRL, "SPIMCTRL"},
>> + {GAISLER_LEON4, "LEON4"},
>> + {GAISLER_LEON4DSU, "LEON4DSU"},
>> + {GAISLER_GRPWM, "GRPWM"},
>> + {GAISLER_FTAHBRAM, "FTAHBRAM"},
>> + {GAISLER_FTSRCTRL, "FTSRCTRL"},
>> + {GAISLER_AHBSTAT, "AHBSTAT"},
>> + {GAISLER_LEON3FT, "LEON3FT"},
>> + {GAISLER_FTMCTRL, "FTMCTRL"},
>> + {GAISLER_FTSDCTRL, "FTSDCTRL"},
>> + {GAISLER_FTSRCTRL8, "FTSRCTRL8"},
>> + {GAISLER_MEMSCRUB, "MEMSCRUB"},
>> + {GAISLER_APBPS2, "APBPS2"},
>> + {GAISLER_VGACTRL, "VGACTRL"},
>> + {GAISLER_LOGAN, "LOGAN"},
>> + {GAISLER_SVGACTRL, "SVGACTRL"},
>> + {GAISLER_T1AHB, "T1AHB"},
>> + {GAISLER_MP7WRAP, "MP7WRAP"},
>> + {GAISLER_GRSYSMON, "GRSYSMON"},
>> + {GAISLER_GRACECTRL, "GRACECTRL"},
>> + {GAISLER_B1553BC, "B1553BC"},
>> + {GAISLER_B1553RT, "B1553RT"},
>> + {GAISLER_B1553BRM, "B1553BRM"},
>> + {GAISLER_SATCAN, "SATCAN"},
>> + {GAISLER_CANMUX, "CANMUX"},
>> + {GAISLER_GRTMRX, "GRTMRX"},
>> + {GAISLER_GRTCTX, "GRTCTX"},
>> + {GAISLER_GRTMDESC, "GRTMDESC"},
>> + {GAISLER_GRTMVC, "GRTMVC"},
>> + {GAISLER_GEFFE, "GEFFE"},
>> + {GAISLER_AES, "AES"},
>> + {GAISLER_GRAESDMA, "GRAESDMA"},
>> + {GAISLER_ECC, "ECC"},
>> + {GAISLER_PCIF, "PCIF"},
>> + {GAISLER_CLKMOD, "CLKMOD"},
>> + {GAISLER_HAPSTRAK, "HAPSTRAK"},
>> + {GAISLER_TEST_1X2, "TEST_1X2"},
>> + {GAISLER_WILD2AHB, "WILD2AHB"},
>> + {GAISLER_BIO1, "BIO1"},
>> + {GAISLER_GR1553B, "GR1553B"},
>> + {GAISLER_L2CACHE, "L2CACHE"},
>> + {GAISLER_L4STAT, "L4STAT"},
>> + {GAISLER_GRPCI2, "GRPCI2"},
>> + {GAISLER_GRPCI2_DMA, "GRPCI2_DMA"},
>> + {GAISLER_GRIOMMU, "GRIOMMU"},
>> + {GAISLER_SPW2_DMA, "SPW2_DMA"},
>> + {GAISLER_SPW_ROUTER, "SPW_ROUTER"},
>> + {0, NULL}
>> +static ambapp_device_name PENDER_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name ESA_devices[] =
>> + {ESA_LEON2, "LEON2"},
>> + {ESA_LEON2APB, "LEON2APB"},
>> + {ESA_IRQ, "IRQ"},
>> + {ESA_TIMER, "TIMER"},
>> + {ESA_UART, "UART"},
>> + {ESA_CFG, "CFG"},
>> + {ESA_IO, "IO"},
>> + {ESA_MCTRL, "MCTRL"},
>> + {ESA_PCIARB, "PCIARB"},
>> + {ESA_HURRICANE, "HURRICANE"},
>> + {ESA_SPW_RMAP, "SPW_RMAP"},
>> + {ESA_AHBUART, "AHBUART"},
>> + {ESA_SPWA, "SPWA"},
>> + {ESA_BOSCHCAN, "BOSCHCAN"},
>> + {ESA_IRQ2, "IRQ2"},
>> + {ESA_AHBSTAT, "AHBSTAT"},
>> + {ESA_WPROT, "WPROT"},
>> + {ESA_WPROT2, "WPROT2"},
>> + {ESA_PDEC3AMBA, "PDEC3AMBA"},
>> + {ESA_PTME3AMBA, "PTME3AMBA"},
>> + {0, NULL}
>> +static ambapp_device_name ASTRIUM_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name OPENCHIP_devices[] =
>> + {OPENCHIP_APBGPIO, "APBGPIO"},
>> + {OPENCHIP_APBI2C, "APBI2C"},
>> + {OPENCHIP_APBSPI, "APBSPI"},
>> + {OPENCHIP_APBCHARLCD, "APBCHARLCD"},
>> + {OPENCHIP_APBPWM, "APBPWM"},
>> + {OPENCHIP_APBPS2, "APBPS2"},
>> + {OPENCHIP_APBMMCSD, "APBMMCSD"},
>> + {OPENCHIP_APBNAND, "APBNAND"},
>> + {OPENCHIP_APBLPC, "APBLPC"},
>> + {OPENCHIP_APBCF, "APBCF"},
>> + {OPENCHIP_APBSYSACE, "APBSYSACE"},
>> + {OPENCHIP_APB1WIRE, "APB1WIRE"},
>> + {OPENCHIP_APBJTAG, "APBJTAG"},
>> + {OPENCHIP_APBSUI, "APBSUI"},
>> + {0, NULL}
>> +static ambapp_device_name OPENCORES_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name CONTRIB_devices[] =
>> + {CONTRIB_CORE1, "CORE1"},
>> + {CONTRIB_CORE2, "CORE2"},
>> + {0, NULL}
>> +static ambapp_device_name EONIC_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name RADIONOR_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name GLEICHMANN_devices[] =
>> + {GLEICHMANN_CUSTOM, "CUSTOM"},
>> + {GLEICHMANN_GEOLCD01, "GEOLCD01"},
>> + {GLEICHMANN_DAC, "DAC"},
>> + {GLEICHMANN_HPI, "HPI"},
>> + {GLEICHMANN_SPI, "SPI"},
>> + {GLEICHMANN_HIFC, "HIFC"},
>> + {GLEICHMANN_ADCDAC, "ADCDAC"},
>> + {GLEICHMANN_SPIOC, "SPIOC"},
>> + {GLEICHMANN_AC97, "AC97"},
>> + {0, NULL}
>> +static ambapp_device_name MENTA_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name SUN_devices[] =
>> + {SUN_T1, "SUN_T1"},
>> + {SUN_S1, "SUN_S1"},
>> + {0, NULL}
>> +static ambapp_device_name MOVIDIA_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name ORBITA_devices[] =
>> + {ORBITA_1553B, "1553B"},
>> + {ORBITA_429, "429"},
>> + {ORBITA_SPI, "SPI"},
>> + {ORBITA_I2C, "I2C"},
>> + {ORBITA_SMARTCARD, "SMARTCARD"},
>> + {ORBITA_SDCARD, "SDCARD"},
>> + {ORBITA_UART16550, "UART16550"},
>> + {ORBITA_CRYPTO, "CRYPTO"},
>> + {ORBITA_SYSIF, "SYSIF"},
>> + {ORBITA_PIO, "PIO"},
>> + {ORBITA_RTC, "RTC"},
>> + {ORBITA_COLORLCD, "COLORLCD"},
>> + {ORBITA_PCI, "PCI"},
>> + {ORBITA_DSP, "DSP"},
>> + {ORBITA_USBHOST, "USBHOST"},
>> + {ORBITA_USBDEV, "USBDEV"},
>> + {0, NULL}
>> +static ambapp_device_name SYNOPSYS_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name NASA_devices[] =
>> + {NASA_EP32, "EP32"},
>> + {0, NULL}
>> +static ambapp_device_name CAL_devices[] =
>> + {CAL_DDRCTRL, "DDRCTRL"},
>> + {0, NULL}
>> +static ambapp_device_name EMBEDDIT_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name CETON_devices[] =
>> + {0, NULL}
>> +static ambapp_device_name ACTEL_devices[] =
>> + {ACTEL_COREMP7, "COREMP7"},
>> + {0, NULL}
>> +static ambapp_vendor_devnames vendors[] =
>> + {VENDOR_GAISLER, "GAISLER", GAISLER_devices},
>> + {VENDOR_PENDER, "PENDER", PENDER_devices},
>> + {VENDOR_ESA, "ESA", ESA_devices},
>> + {VENDOR_ASTRIUM, "ASTRIUM", ASTRIUM_devices},
>> + {VENDOR_OPENCHIP, "OPENCHIP", OPENCHIP_devices},
>> + {VENDOR_OPENCORES, "OPENCORES", OPENCORES_devices},
>> + {VENDOR_CONTRIB, "CONTRIB", CONTRIB_devices},
>> + {VENDOR_EONIC, "EONIC", EONIC_devices},
>> + {VENDOR_RADIONOR, "RADIONOR", RADIONOR_devices},
>> + {VENDOR_GLEICHMANN, "GLEICHMANN", GLEICHMANN_devices},
>> + {VENDOR_MENTA, "MENTA", MENTA_devices},
>> + {VENDOR_SUN, "SUN", SUN_devices},
>> + {VENDOR_MOVIDIA, "MOVIDIA", MOVIDIA_devices},
>> + {VENDOR_ORBITA, "ORBITA", ORBITA_devices},
>> + {VENDOR_SYNOPSYS, "SYNOPSYS", SYNOPSYS_devices},
>> + {VENDOR_NASA, "NASA", NASA_devices},
>> + {VENDOR_CAL, "CAL", CAL_devices},
>> + {VENDOR_EMBEDDIT, "EMBEDDIT", EMBEDDIT_devices},
>> + {VENDOR_CETON, "CETON", CETON_devices},
>> + {VENDOR_ACTEL, "ACTEL", ACTEL_devices},
>> + {0, NULL, NULL}
>> +static char *ambapp_get_devname(ambapp_device_name *devs, int id)
>> + while (devs->device_id> 0) {
>> + if (devs->device_id == id)
>> + return devs->name;
>> + devs++;
>> + return NULL;
>> +char *ambapp_device_id2str(int vendor, int id)
>> + ambapp_vendor_devnames *ven =&vendors[0];
>> + while (ven->vendor_id> 0) {
>> + if (ven->vendor_id == vendor)
>> + return ambapp_get_devname(ven->devices,id);
>> + ven++;
>> + return NULL;
>> +char *ambapp_vendor_id2str(int vendor)
>> + return ven->name;
>> + ven++;
>> + return NULL;
>> +int ambapp_vendev_id2str(int vendor, int id, char *buf)
>> + char *dstr, *vstr;
>> + *buf = '\0';
>> + vstr = ambapp_vendor_id2str(vendor);
>> + if (vstr == NULL)
>> + return 0;
>> + dstr = ambapp_device_id2str(vendor, id);
>> + if (dstr == NULL)
>> + return 0;
>> + strcpy(buf, vstr);
>> + strcat(buf, "_");
>> + strcat(buf, dstr);
>> + return strlen(buf);
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
>> index 0000000..c730173
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
>> @@ -0,0 +1,92 @@
>> +/* Old AMBA scanning Interface provided for backwards compability */
>> +#include<ambapp.h>
>> +struct ambapp_dev_find_match_arg {
>> + int index;
>> + int count;
>> + int type;
>> + void *dev;
>> +/* AMBA PP find routines */
>> +int ambapp_dev_find_match(struct ambapp_dev *dev, int index, void *arg)
>> + struct ambapp_dev_find_match_arg *p = arg;
>> + if (p->index == 0) {
>> + /* Found controller, stop */
>> + if (p->type == DEV_APB_SLV) {
>> + *(struct ambapp_apb_info *)p->dev = *DEV_TO_APB(dev);
>> + p->dev = ((struct ambapp_apb_info *)p->dev)+1;
>> + } else {
>> + *(struct ambapp_ahb_info *)p->dev = *DEV_TO_AHB(dev);
>> + p->dev = ((struct ambapp_ahb_info *)p->dev)+1;
>> + p->count--;
>> + if (p->count< 1)
>> + return 1;
>> + } else {
>> + p->index--;
>> + return 0;
>> +int ambapp_find_apbslvs_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int index, int maxno)
>> + struct ambapp_dev_find_match_arg arg;
>> + arg.index = index;
>> + arg.count = maxno;
>> + arg.type = DEV_APB_SLV; /* APB */
>> + arg.dev = dev;
>> + ambapp_for_each(abus, (OPTIONS_ALL|OPTIONS_APB_SLVS), vendor, device,
>> + ambapp_dev_find_match,&arg);
>> + return maxno - arg.count;
>> +int ambapp_find_apbslv(struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev)
>> + return ambapp_find_apbslvs_next(abus, vendor, device, dev, 0, 1);
>> +int ambapp_find_apbslv_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int index)
>> + return ambapp_find_apbslvs_next(abus, vendor, device, dev, index, 1);
>> +int ambapp_find_apbslvs(struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int maxno)
>> + return ambapp_find_apbslvs_next(abus, vendor, device, dev, 0, maxno);
>> +int ambapp_find_ahbslvs_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int index, int maxno)
>> + arg.type = DEV_AHB_SLV; /* AHB SLV */
>> + arg.dev = dev;
>> + ambapp_for_each(abus, (OPTIONS_ALL|OPTIONS_AHB_SLVS), vendor, device,
>> +int ambapp_find_ahbslv_next(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int index)
>> + return ambapp_find_ahbslvs_next(abus, vendor, device, dev, index, 1);
>> +int ambapp_find_ahbslv(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev)
>> + return ambapp_find_ahbslvs_next(abus, vendor, device, dev, 0, 1);
>> +int ambapp_find_ahbslvs(struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int maxno)
>> + return ambapp_find_ahbslvs_next(abus, vendor, device, dev, 0, maxno);
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c
>> index 0000000..44d3b26
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_parent.c
>> @@ -0,0 +1,26 @@
>> + * $Id: ambapp_parent.c,v
>> +#include<stdlib.h>
>> +#include<ambapp.h>
>> +struct ambapp_dev *ambapp_find_parent(struct ambapp_dev *dev)
>> + while (dev->prev) {
>> + if (dev == dev->prev->children)
>> + return dev->prev;
>> + dev = dev->prev;
>> + return NULL;
>> diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
>> index 0000000..eecca40
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
>> @@ -0,0 +1,76 @@
>> +/* AMBA Plug& Play device information printing.
>> + * Prints a short description of APB and AHB devices.
>> + * Created
>> +#include<stdio.h>
>> +#include<ambapp.h>
>> +extern char *ambapp_device_id2str(int vendor, int id);
>> +extern char *ambapp_vendor_id2str(int vendor);
>> +struct ambapp_dev_print_arg {
>> + int show_depth;
>> +static char *unknown = "unknown";
>> +int ambapp_dev_print(struct ambapp_dev *dev, int index, void *arg)
>> + char *dev_str, *ven_str, *type_str;
>> + struct ambapp_dev_print_arg *p = arg;
>> + char dp[32];
>> + int i=0;
>> + unsigned int basereg;
>> + if (p->show_depth) {
>> + for (i=0; i<ambapp_depth(dev)*2; i+=2) {
>> + dp[i] = ' ';
>> + dp[i+1] = ' ';
>> + dp[i] = '\0';
>> + ven_str = ambapp_vendor_id2str(dev->vendor);
>> + if (!ven_str) {
>> + ven_str = unknown;
>> + dev_str = unknown;
>> + } else {
>> + dev_str = ambapp_device_id2str(dev->vendor,dev->device);
>> + if (!dev_str)
>> + if (dev->dev_type == DEV_APB_SLV) {
>> + /* APB */
>> + basereg = DEV_TO_APB(dev)->start;
>> + type_str = "apb";
>> + } else {
>> + /* AHB */
>> + basereg = DEV_TO_AHB(dev)->start[0];
>> + type_str = "ahb";
>> + printf("%s |-> 0x%x:0x%x:0x%x: %s_%s, %s: 0x%x, 0x%x (OWNER: 0x%x)\n",
>> + dp, index, dev->vendor, dev->device, ven_str, dev_str, type_str,
>> + basereg, (unsigned int)dev, (unsigned int)dev->owner);
>> + return 0;
>> +void ambapp_print(struct ambapp_bus *abus, int show_depth)
>> + struct ambapp_dev_print_arg arg;
>> + arg.show_depth = show_depth;
>> + (OPTIONS_ALL_DEVS|OPTIONS_ALL|OPTIONS_DEPTH_FIRST), -1,
>> + -1, ambapp_dev_print,&arg);
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp.h b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>> index 7ca2d13..5eb3f2a 100644
>> --- a/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>> +++ b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>> @@ -1,10 +1,8 @@
>> - * AMBA Plag& Play Bus Driver Macros for LEON2
>> - * Macros used for AMBA Plug& Play bus scanning
>> - * COPYRIGHT (c) 2007.
>> @@ -16,224 +14,345 @@
>> #ifndef __AMBAPP_H__
>> #define __AMBAPP_H__
>> +/* Include VENDOR and DEVICE definitions */
>> #ifdef __cplusplus
>> extern "C" {
>> #endif
>> -#define AMBA_CONF_AREA 0xff000
>> -#define AMBA_AHB_SLAVE_CONF_AREA (1<< 11)
>> -#define AMBA_AHB_CONF_WORDS 8
>> -#define AMBA_APB_CONF_WORDS 2
>> -#define AMBA_AHB_MASTERS 16
>> -#define AMBA_AHB_SLAVES 16
>> -#define AMBA_APB_SLAVES 16
>> -#define AMBA_APBUARTS 8
>> -/* Vendor codes */
>> -#define VENDOR_GAISLER 1
>> -#define VENDOR_PENDER 2
>> -#define VENDOR_ESA 4
>> -#define VENDOR_OPENCORES 8
>> -/* Gaisler Research device id's */
>> -#define GAISLER_LEON3 0x03
>> -#define GAISLER_LEON3DSU 0x04
>> -#define GAISLER_ETHAHB 0x05
>> -#define GAISLER_APBMST 0x06
>> -#define GAISLER_AHBUART 0x07
>> -#define GAISLER_SRCTRL 0x08
>> -#define GAISLER_SDCTRL 0x09
>> -#define GAISLER_APBUART 0x0C
>> -#define GAISLER_IRQMP 0x0D
>> -#define GAISLER_AHBRAM 0x0E
>> -#define GAISLER_GPTIMER 0x11
>> -#define GAISLER_PCITRG 0x12
>> -#define GAISLER_PCISBRG 0x13
>> -#define GAISLER_PCIFBRG 0x14
>> -#define GAISLER_PCITRACE 0x15
>> -#define GAISLER_DMACTRL 0x16
>> -#define GAISLER_OCCAN 0x19
>> -#define GAISLER_PIOPORT 0x1A
>> -#define GAISLER_ETHMAC 0x1D
>> -#define GAISLER_SPACEWIRE 0x1f
>> -#define GAISLER_AHB2AHB 0x20
>> -#define GAISLER_I2CMST 0x28
>> -#define GAISLER_GRSPW2 0x29
>> -#define GAISLER_GRCAN 0x34
>> -#define GAISLER_GRHCAN 0x3d
>> -#define GAISLER_GRFIFO 0x35
>> -#define GAISLER_GRADCDAC 0x36
>> -#define GAISLER_GRPULSE 0x37
>> -#define GAISLER_GRTIMER 0x38
>> -#define GAISLER_FTAHBRAM 0x50
>> -#define GAISLER_FTMCTRL 0x54
>> -#define GAISLER_BRM 0x72
>> -/* European Space Agency device id's */
>> -#define ESA_LEON2 0x2
>> -#define ESA_MCTRL 0xF
>> -#define ESA_SPW2 0x12
>> -/* Opencores device id's */
>> -#define OPENCORES_PCIBR 0x4
>> -#define OPENCORES_ETHMAC 0x5
>> +/* Max supported AHB buses */
>> +#define AHB_BUS_MAX 6
>> +struct ambapp_dev;
>> +struct ambapp_core;
>> +struct ambapp_apb_info;
>> +struct ambapp_ahb_info;
>> +struct ambapp_dev {
>> + struct ambapp_dev *next; /* Next */
>> + struct ambapp_dev *prev; /* Previous Device. If (this ==
>> + * rev->child) prev is bus bridge */
>> + struct ambapp_dev *children; /* Points to first device on sub-bus */
>> + void *owner; /* Owner of this AMBA device */
>> + unsigned char dev_type; /* AHB MST, AHB SLV or APB SLV*/
>> + unsigned char vendor; /* Vendor ID */
>> + unsigned short device; /* Device ID */
>> + int devinfo[0]; /* Device info (APB/AHB dep. on type) */
>> - * Macros for manipulating Configuration registers
>> -#define amba_get_confword(tab, index, word) (*((tab).addr[(index)]+(word)))
>> +#define AMBAPP_FLAG_FFACT_DIR 0x100 /* Frequency factor direction, 0=down, 1=up */
>> +#define AMBAPP_FLAG_FFACT 0x0f0 /* Frequency factor against top bus */
>> +#define AMBAPP_FLAG_MBUS 0x00c
>> +#define AMBAPP_FLAG_SBUS 0x003
>> +/* Get APB or AHB information from a AMBA device */
>> +#define DEV_TO_APB(adev) ((struct ambapp_apb_info *)((adev)->devinfo))
>> +#define DEV_TO_AHB(adev) ((struct ambapp_ahb_info *)((adev)->devinfo))
>> +#define DEV_TO_COMMON(adev) ((struct ambapp_common_info *)((adev)->devinfo))
>> +/* Convert address of ambapp_apb_info/ambapp_ahb_info into ambapp_dev */
>> +#define APB_TO_DEV(apb_info) ((struct ambapp_dev *)(unsigned int(apb_info) - \
>> + offsetof(struct ambapp_dev, devinfo)))
>> +#define AHB_TO_DEV(ahb_info) ((struct ambapp_dev *)(unsigned int(ahb_info) - \
>> +struct ambapp_common_info {
>> + unsigned char irq;
>> + unsigned char ver;
>> + unsigned char ahbidx; /* AHB Bus Index */
>> -#define amba_vendor(x) (((x)>> 24)& 0xff)
>> +struct ambapp_apb_info {
>> + /* COMMON */
>> -#define amba_device(x) (((x)>> 12)& 0xfff)
>> + /* APB SPECIFIC */
>> + unsigned int start;
>> + unsigned int mask;
>> +struct ambapp_ahb_info {
>> + /* COMMON */
>> + /* AHB SPECIFIC */
>> + unsigned int start[4];
>> + unsigned int mask[4];
>> + char type[4]; /* type[N] Determine type of start[N]-mask[N],
>> + * 2=AHB Memory Space, 3=AHB I/O Space */
>> + unsigned int custom[3];
>> +/* Describes a complete AMBA Core. Each device may consist of 3 interfaces */
>> +struct ambapp_core {
>> + char irq; /* irq=-1 indicate no IRQ */
>> + int index; /* Core index */
>> + struct ambapp_ahb_info *ahb_mst;
>> + struct ambapp_ahb_info *ahb_slv;
>> + struct ambapp_apb_info *apb_slv;
>> +struct ambapp_ahb_bus {
>> + unsigned int ioarea; /* AHB Bus IOAREA */
>> + unsigned int freq_hz; /* Frequency of AHB Bus */
>> + struct ambapp_dev *bridge;/* Bridge Device on Parent AHB Bus */
>> + struct ambapp_dev *dev; /* First Device on AHB Bus */
>> -#define amba_ahb_get_membar(tab, index, nr) (*((tab).addr[(index)]+4+(nr)))
>> +struct ambapp_mmap {
>> + unsigned int size;
>> + unsigned int local_adr;
>> + unsigned int remote_adr;
>> -#define amba_ahb_get_custom(tab, index, nr) (*((tab).addr[(index)]+1+(nr)))
>> +/* Complete AMBA PnP information */
>> +struct ambapp_bus {
>> + struct ambapp_dev *root; /* AHB/APB Device Tree*/
>> + struct ambapp_mmap *mmaps; /* Memory MAP Array */
>> + struct ambapp_ahb_bus ahbs[AHB_BUS_MAX]; /* AHB Buses */
>> -#define amba_apb_get_membar(tab, index) (*((tab).addr[(index)]+1))
>> + * Return values
>> + * 0 - continue
>> + * 1 - stop scanning
>> +typedef int (*ambapp_func_t)(struct ambapp_dev *dev, int index, void *arg);
>> +#define DEV_IS_FREE(dev) (dev->owner == NULL)
>> +#define DEV_IS_ALLOCATED(dev) (dev->owner != NULL)
>> +/* Options to ambapp_for_each */
>> +#define OPTIONS_AHB_MSTS 0x00000001
>> +#define OPTIONS_AHB_SLVS 0x00000002
>> +#define OPTIONS_APB_SLVS 0x00000004
>> +#define OPTIONS_ALL_DEVS (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_APB_SLVS)
>> +#define OPTIONS_FREE 0x00000010
>> +#define OPTIONS_ALLOCATED 0x00000020
>> +#define OPTIONS_ALL (OPTIONS_FREE|OPTIONS_ALLOCATED)
>> +/* Depth first search, Defualt is breath first search. */
>> +#define OPTIONS_DEPTH_FIRST 0x00000100
>> +#define DEV_AHB_NONE 0
>> +#define DEV_AHB_MST 1
>> +#define DEV_AHB_SLV 2
>> +#define DEV_APB_SLV 3
>> +/* Structures used to access Plug&Play information directly */
>> +struct ambapp_pnp_ahb {
>> + const unsigned int id; /* VENDOR, DEVICE, VER, IRQ, */
>> + const unsigned int custom[3];
>> + const unsigned int mbar[4]; /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
>> -#define amba_membar_start(mbar) (((mbar)& 0xfff00000)& (((mbar)& 0xfff0)<< 16))
>> +struct ambapp_pnp_apb {
>> + const unsigned int iobar; /* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
>> -#define amba_iobar_start(base, iobar) ((base) | ((((iobar)& 0xfff00000)>>12)& (((iobar)& 0xfff0)<<4)) )
>> +#define ambapp_pnp_vendor(id) (((id)>> 24)& 0xff)
>> +#define ambapp_pnp_device(id) (((id)>> 12)& 0xfff)
>> +#define ambapp_pnp_ver(id) (((id)>>5)& 0x1f)
>> +#define ambapp_pnp_irq(id) ((id)& 0x1f)
>> -#define amba_irq(conf) ((conf)& 0x1f)
>> +#define ambapp_pnp_start(mbar) (((mbar)& 0xfff00000)& (((mbar)& 0xfff0)<< 16))
>> +#define ambapp_pnp_mbar_mask(mbar) (((mbar)>>4)& 0xfff)
>> +#define ambapp_pnp_mbar_type(mbar) ((mbar)& 0xf)
>> -#define amba_ver(conf) (((conf)>>5)& 0x1f)
>> +#define ambapp_pnp_apb_start(iobar, base) ((base) | ((((iobar)& 0xfff00000)>>12)& (((iobar)& 0xfff0)<<4)) )
>> +#define ambapp_pnp_apb_mask(iobar) ((~(ambapp_pnp_mbar_mask(iobar)<<8)& 0x000fffff) + 1)
>> -#define amba_membar_type(mbar) ((mbar)& 0xf)
>> +#define AMBA_TYPE_AHBIO_ADDR(addr,base_ioarea) ((unsigned int)(base_ioarea) | ((addr)>> 12))
>> #define AMBA_TYPE_APBIO 0x1
>> #define AMBA_TYPE_MEM 0x2
>> #define AMBA_TYPE_AHBIO 0x3
>> -#define AMBA_TYPE_AHBIO_ADDR(addr,base_ioarea) ((unsigned int)(base_ioarea) | ((addr)>> 12))
>> - * Types and structure used for AMBA Plug& Play bus scanning
>> +/* Copy Data from AMBA PnP I/O Area */
>> +typedef void *(*ambapp_memcpy_t)(
>> + void *dest, /* Destination RAM copy */
>> + const void *src, /* Source AMBA PnP Address to copy from */
>> + int n, /* Number of bytes to be copied */
>> + struct ambapp_bus *abus /* Optional AMBA Bus pointer */
>> +/* Scan a AMBA Plug& Play bus and create all device structures describing the
>> + * the devices. The devices will form a tree, where every node describes one
>> + * interface. The resulting tree is placed in the location pointed to by root.
>> + * Since it the tree is located in RAM it is easier to work with AMBA buses
>> + * that is located over PCI and SpaceWire etc.
>> + * \param ioarea The IO-AREA where Plug& Play information can be found.
>> + * \param parent Used internally when recursing down a bridge. Set to NULL.
>> + * \param mmaps Is used to perform address translation if needed.
>> + * \param root Resulting device node tree root is stored here.
>> -typedef struct amba_device_table {
>> - int devnr; /* numbrer of devices on AHB or APB bus */
>> - unsigned int *addr[16]; /* addresses to the devices configuration tables */
>> -} amba_device_table;
>> -typedef struct {
>> - int devnr;
>> - unsigned int *addr[AMBA_APB_SLAVES]; /* addresses to the devices configuration tables */
>> - unsigned int apbmst[AMBA_APB_SLAVES]; /* pointer to AHB slave (which is a APB master) */
>> -} amba_apb_dev;
>> -struct amba_mmap {
>> - unsigned int cpu_adr;
>> - unsigned int size;
>> - unsigned int remote_amba_adr;
>> -typedef struct _amba_confarea_type amba_confarea_type;
>> -struct _amba_confarea_type {
>> - amba_confarea_type *next; /* next bus in chain */
>> - int notroot; /* is root of a bus (mother AHB has 64 masters/slaves rest 16) */
>> - unsigned int ioarea;
>> - struct amba_mmap *mmaps;
>> - amba_device_table ahbmst;
>> - amba_device_table ahbslv;
>> - amba_apb_dev apbslv;
>> -typedef struct {
>> - unsigned int start, irq, bus_id;
>> -} amba_apb_device;
>> -typedef struct {
>> - unsigned int start[4], irq, ver;
>> -} amba_ahb_device;
>> -/* Scans AMBA Plug&Play Information and convers that information
>> - * to a more readable format in RAM.
>> +extern int ambapp_scan(
>> +/* Initialize the frequency [Hz] of all AHB Buses from knowing the frequency
>> + * of one particular APB/AHB Device.
>> +extern void ambapp_freq_init(
>> + unsigned int freq);
>> +/* Returns the frequency [Hz] of a AHB/APB device */
>> +extern unsigned int ambapp_freq_get(
>> + struct ambapp_dev *dev);
>> +/* Iterates through all AMBA devices previously found, it calls func
>> + * once for every device that match the search arguments.
>> - * Will scan for - AHB Masters
>> - * - AHB Slaves
>> - * - APB Slaves (if a AHB/APB bridge is found)
>> + * SEARCH OPTIONS
>> + * All search options must be fulfilled, type of devices searched (options)
>> + * and AMBA Plug&Play ID [VENDOR,DEVICE], before func() is called. The options
>> + * can be use to search only for AMBA APB or AHB Slaves or AHB Masters for
>> + * example. Note that when VENDOR=-1 or DEVICE=-1 it will match any vendor or
>> + * device ID, this means setting both VENDOR and DEVICE to -1 will result in
>> + * calling all devices matches the options argument.
>> - * \param amba_conf AMBA P&P device info is placed here.
>> - * \param ioarea address of AMBA Plug&Play information,
>> - * on LEON3 systems default is 0xfff00000
>> - * \param mmaps Memory mmap specific to this amba bus,
>> - * if NULL no translation will be made (default).
>> - * A array of maps, ending with a entry with size=0.
>> + * \param abus AMBAPP Bus to search
>> + * \param options Search options, see OPTIONS_* above
>> + * \param vendor AMBAPP VENDOR ID to search for
>> + * \param device AMBAPP DEVICE ID to search for
>> + * \param func Function called for every device matching search options
>> + * \param arg Optional argument passed on to func
>> + * func return value affects the search, returning a non-zero value will
>> + * stop the search and ambapp_for_each will return immediately returning the
>> + * same non-zero value.
>> + * Return Values
>> + * 0 - all devices was scanned
>> + * non-zero - stopped by user function returning the non-zero value
>> -void amba_scan (amba_confarea_type * amba_conf, unsigned int ioarea,
>> - struct amba_mmap *mmaps);
>> -void amba_print_conf (amba_confarea_type * amba_conf);
>> -/***** APB SLAVES *****/
>> -int amba_get_number_apbslv_devices (amba_confarea_type * amba_conf, int vendor,
>> - int device);
>> -int amba_find_apbslv (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_apb_device * dev);
>> -int amba_find_next_apbslv (amba_confarea_type * amba_conf, int vendor,
>> - int device, amba_apb_device * dev, int index);
>> -int amba_find_apbslvs (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_apb_device * devs, int maxno);
>> -int amba_get_number_ahbslv_devices (amba_confarea_type * amba_conf, int vendor,
>> - int device);
>> -int amba_find_ahbslv (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_ahb_device * dev);
>> +extern int ambapp_for_each(
>> + int vendor,
>> + int device,
>> + void *arg);
>> +/* Helper function for ambapp_for_each(), find a device by index. If pcount
>> + * is NULL the first device is returned, else pcount is interpreted as index
>> + * by decrementing the value until zero is reaced: *count=0 first device,
>> + * *count=1 second device etc.
>> + * found
>> +extern int ambapp_find_by_idx(struct ambapp_dev *dev, int index, void *pcount);
>> -int amba_find_next_ahbslv (amba_confarea_type * amba_conf, int vendor,
>> - int device, amba_ahb_device * dev, int index);
>> +/* Get number of devices matching the options/vendor/device arguments, the
>> + * arguments are passed onto ambapp_for_each().
>> +extern int ambapp_dev_count(struct ambapp_bus *abus, unsigned int options,
>> + int vendor, int device);
>> -int amba_find_ahbslvs (amba_confarea_type * amba_conf, int vendor, int device,
>> - amba_ahb_device * devs, int maxno);
>> +/* Print short information about devices on the AMBA bus onto the console */
>> +extern void ambapp_print(struct ambapp_bus *abus, int show_depth);
>> +/* Mark a device taken (allocate), Owner field is set with owner Data. Returns
>> + * -1 if device has already been allocated.
>> +extern int ambapp_alloc_dev(struct ambapp_dev *dev, void *owner);
>> +/* Owner field is cleared, which indicates that device is not allocated */
>> +extern void ambapp_free_dev(struct ambapp_dev *dev);
>> -/***** AHB MASTERS *****/
>> +/* Find AHB/APB Bridge or AHB/AHB Bridge Parent */
>> +extern struct ambapp_dev *ambapp_find_parent(struct ambapp_dev *dev);
>> -/* Return number of AHB Master devices which has given vendor and device */
>> -int amba_get_number_ahbmst_devices (amba_confarea_type * amba_conf, int vendor,
>> - int device);
>> +/* Returns bus depth (number of sub AHB buses) of device from root bus */
>> +extern int ambapp_depth(struct ambapp_dev *dev);
>> -/* Get First AHB Master device of this vendor&device id */
>> -int amba_find_ahbmst (amba_confarea_type * amba_conf, int vendor, int device,
>> +/* Get Device Name from AMBA PnP name database */
>> -/* Get AHB Master device of this vendor&device id. (setting nr to 0 is eqivalent to calling amba_find_ahbmst() ) */
>> -int amba_find_next_ahbmst (amba_confarea_type * amba_conf, int vendor,
>> +/* Get Vendor Name from AMBA PnP name database */
>> -/* Get first nr AHB Master devices, put them into dev (which is an array of nr length) */
>> -int amba_find_ahbmsts (amba_confarea_type * amba_conf, int vendor, int device,
>> +/* Set together VENDOR_DEVICE Name from AMBA PnP name database. Return length
>> + * of C-string stored in buf not including string termination '\0'.
>> +extern int ambapp_vendev_id2str(int vendor, int id, char *buf);
>> +/* Help functions for backwards compability */
>> +extern int ambapp_find_apbslv(
>> + int vendor,
>> + int device,
>> + struct ambapp_apb_info *dev);
>> +extern int ambapp_find_apbslv_next(
>> + int vendor,
>> + int device,
>> + struct ambapp_apb_info *dev,
>> + int index);
>> +extern int ambapp_find_apbslvs_next(
>> + int vendor,
>> + int device,
>> + int index,
>> + int maxno);
>> +extern int ambapp_find_apbslvs(
>> + int vendor,
>> + int device,
>> + int maxno);
>> +extern int ambapp_find_ahbslv(
>> + int vendor,
>> + int device,
>> + struct ambapp_ahb_info *dev);
>> +extern int ambapp_find_ahbslv_next(
>> + int vendor,
>> + int device,
>> + struct ambapp_ahb_info *dev,
>> + int index);
>> +extern int ambapp_find_ahbslvs_next(
>> + int vendor,
>> + int device,
>> + int index,
>> + int maxno);
>> +extern int ambapp_find_ahbslvs(
>> + int vendor,
>> + int device,
>> + int maxno);
>> /******** AMBA DEVICES *******/
>> diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h b/c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h
>> index 0000000..e6f3601
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h
>> @@ -0,0 +1,245 @@
>> +/* AMBA Plug& Play Bus Vendor and Device IDs.
>> + * COPYRIGHT (c) 2008.
>> + * Gaisler Research
>> + * This header file provide all known VENDOR and DEVICE IDs available
>> + * in the AMBA Plug& Play information. Taken from GRLIB 3386.
>> +#ifndef __AMBAPP_DEVS_H__
>> +#define __AMBAPP_DEVS_H__
>> +/* Vendor codes */
>> +#define VENDOR_GAISLER 1
>> +#define VENDOR_PENDER 2
>> +#define VENDOR_ESA 4
>> +#define VENDOR_ASTRIUM 6
>> +#define VENDOR_OPENCHIP 7
>> +#define VENDOR_OPENCORES 8
>> +#define VENDOR_CONTRIB 9
>> +#define VENDOR_EONIC 11
>> +#define VENDOR_RADIONOR 15
>> +#define VENDOR_GLEICHMANN 16
>> +#define VENDOR_MENTA 17
>> +#define VENDOR_SUN 19
>> +#define VENDOR_MOVIDIA 20
>> +#define VENDOR_ORBITA 23
>> +#define VENDOR_SYNOPSYS 33
>> +#define VENDOR_NASA 34
>> +#define VENDOR_ACTEL 172
>> +#define VENDOR_CAL 202
>> +#define VENDOR_EMBEDDIT 234
>> +#define VENDOR_CETON 203
>> +/* Gaisler Research device id's */
>> +#define GAISLER_LEON2DSU 0x002
>> +#define GAISLER_LEON3 0x003
>> +#define GAISLER_LEON3DSU 0x004
>> +#define GAISLER_ETHAHB 0x005
>> +#define GAISLER_APBMST 0x006
>> +#define GAISLER_AHBUART 0x007
>> +#define GAISLER_SRCTRL 0x008
>> +#define GAISLER_SDCTRL 0x009
>> +#define GAISLER_SSRCTRL 0x00a
>> +#define GAISLER_APBUART 0x00c
>> +#define GAISLER_IRQMP 0x00d
>> +#define GAISLER_AHBRAM 0x00e
>> +#define GAISLER_AHBDPRAM 0x00f
>> +#define GAISLER_GPTIMER 0x011
>> +#define GAISLER_PCITRG 0x012
>> +#define GAISLER_PCISBRG 0x013
>> +#define GAISLER_PCIFBRG 0x014
>> +#define GAISLER_PCITRACE 0x015
>> +#define GAISLER_DMACTRL 0x016
>> +#define GAISLER_AHBTRACE 0x017
>> +#define GAISLER_DSUCTRL 0x018
>> +#define GAISLER_CANAHB 0x019
>> +#define GAISLER_GPIO 0x01a
>> +#define GAISLER_AHBROM 0x01b
>> +#define GAISLER_AHBJTAG 0x01c
>> +#define GAISLER_ETHMAC 0x01d
>> +#define GAISLER_SWNODE 0x01e
>> +#define GAISLER_SPW 0x01f
>> +#define GAISLER_AHB2AHB 0x020
>> +#define GAISLER_USBDC 0x021
>> +#define GAISLER_USB_DCL 0x022
>> +#define GAISLER_DDRMP 0x023
>> +#define GAISLER_ATACTRL 0x024
>> +#define GAISLER_DDRSP 0x025
>> +#define GAISLER_EHCI 0x026
>> +#define GAISLER_UHCI 0x027
>> +#define GAISLER_I2CMST 0x028
>> +#define GAISLER_SPW2 0x029
>> +#define GAISLER_AHBDMA 0x02a
>> +#define GAISLER_NUHOSP3 0x02b
>> +#define GAISLER_CLKGATE 0x02c
>> +#define GAISLER_SPICTRL 0x02d
>> +#define GAISLER_DDR2SP 0x02e
>> +#define GAISLER_SLINK 0x02f
>> +#define GAISLER_GRTM 0x030
>> +#define GAISLER_GRTC 0x031
>> +#define GAISLER_GRPW 0x032
>> +#define GAISLER_GRCTM 0x033
>> +#define GAISLER_GRHCAN 0x034
>> +#define GAISLER_GRFIFO 0x035
>> +#define GAISLER_GRADCDAC 0x036
>> +#define GAISLER_GRPULSE 0x037
>> +#define GAISLER_GRTIMER 0x038
>> +#define GAISLER_AHB2PP 0x039
>> +#define GAISLER_GRVERSION 0x03a
>> +#define GAISLER_APB2PW 0x03b
>> +#define GAISLER_PW2APB 0x03c
>> +#define GAISLER_GRCAN 0x03d
>> +#define GAISLER_I2CSLV 0x03e
>> +#define GAISLER_U16550 0x03f
>> +#define GAISLER_AHBMST_EM 0x040
>> +#define GAISLER_AHBSLV_EM 0x041
>> +#define GAISLER_GRTESTMOD 0x042
>> +#define GAISLER_ASCS 0x043
>> +#define GAISLER_IPMVBCTRL 0x044
>> +#define GAISLER_SPIMCTRL 0x045
>> +#define GAISLER_L4STAT 0x047
>> +#define GAISLER_LEON4 0x048
>> +#define GAISLER_LEON4DSU 0x049
>> +#define GAISLER_GRPWM 0x04a
>> +#define GAISLER_L2CACHE 0x04b
>> +#define GAISLER_GR1553B 0x04d
>> +#define GAISLER_GRIOMMU 0x04f
>> +#define GAISLER_FTAHBRAM 0x050
>> +#define GAISLER_FTSRCTRL 0x051
>> +#define GAISLER_AHBSTAT 0x052
>> +#define GAISLER_LEON3FT 0x053
>> +#define GAISLER_FTMCTRL 0x054
>> +#define GAISLER_FTSDCTRL 0x055
>> +#define GAISLER_FTSRCTRL8 0x056
>> +#define GAISLER_MEMSCRUB 0x057
>> +#define GAISLER_APBPS2 0x060
>> +#define GAISLER_VGACTRL 0x061
>> +#define GAISLER_LOGAN 0x062
>> +#define GAISLER_SVGACTRL 0x063
>> +#define GAISLER_T1AHB 0x064
>> +#define GAISLER_MP7WRAP 0x065
>> +#define GAISLER_GRSYSMON 0x066
>> +#define GAISLER_GRACECTRL 0x067
>> +#define GAISLER_B1553BC 0x070
>> +#define GAISLER_B1553RT 0x071
>> +#define GAISLER_B1553BRM 0x072
>> +#define GAISLER_GRAES 0x073
>> +#define GAISLER_SATCAN 0x080
>> +#define GAISLER_CANMUX 0x081
>> +#define GAISLER_GRTMRX 0x082
>> +#define GAISLER_GRTCTX 0x083
>> +#define GAISLER_GRTMDESC 0x084
>> +#define GAISLER_GRTMVC 0x085
>> +#define GAISLER_GEFFE 0x086
>> +#define GAISLER_AES 0x073
>> +#define GAISLER_ECC 0x074
>> +#define GAISLER_PCIF 0x075
>> +#define GAISLER_CLKMOD 0x076
>> +#define GAISLER_HAPSTRAK 0x077
>> +#define GAISLER_TEST_1X2 0x078
>> +#define GAISLER_WILD2AHB 0x079
>> +#define GAISLER_BIO1 0x07a
>> +#define GAISLER_GRAESDMA 0x07b
>> +#define GAISLER_GRPCI2 0x07c
>> +#define GAISLER_GRPCI2_DMA 0x07d
>> +#define GAISLER_SPWCUC 0x089
>> +#define GAISLER_SPW2_DMA 0x08a
>> +#define GAISLER_SPW_ROUTER 0x08b
>> +#define GAISLER_PIPEWRAPPER 0xffa
>> +#define GAISLER_L2TIME 0xffd /* internal device: leon2 timer */
>> +#define GAISLER_L2C 0xffe /* internal device: leon2compat */
>> +#define GAISLER_PLUGPLAY 0xfff /* internal device: plug& play configarea */
>> +/* European Space Agency device id's */
>> +#define ESA_LEON2 0x002
>> +#define ESA_LEON2APB 0x003
>> +#define ESA_IRQ 0x005
>> +#define ESA_TIMER 0x006
>> +#define ESA_UART 0x007
>> +#define ESA_CFG 0x008
>> +#define ESA_IO 0x009
>> +#define ESA_MCTRL 0x00f
>> +#define ESA_PCIARB 0x010
>> +#define ESA_HURRICANE 0x011
>> +#define ESA_SPW_RMAP 0x012
>> +#define ESA_SPW2 0x012
>> +#define ESA_AHBUART 0x013
>> +#define ESA_SPWA 0x014
>> +#define ESA_BOSCHCAN 0x015
>> +#define ESA_IRQ2 0x016
>> +#define ESA_AHBSTAT 0x017
>> +#define ESA_WPROT 0x018
>> +#define ESA_WPROT2 0x019
>> +#define ESA_PDEC3AMBA 0x020
>> +#define ESA_PTME3AMBA 0x021
>> +#define OPENCHIP_APBGPIO 0x001
>> +#define OPENCHIP_APBI2C 0x002
>> +#define OPENCHIP_APBSPI 0x003
>> +#define OPENCHIP_APBCHARLCD 0x004
>> +#define OPENCHIP_APBPWM 0x005
>> +#define OPENCHIP_APBPS2 0x006
>> +#define OPENCHIP_APBMMCSD 0x007
>> +#define OPENCHIP_APBNAND 0x008
>> +#define OPENCHIP_APBLPC 0x009
>> +#define OPENCHIP_APBCF 0x00a
>> +#define OPENCHIP_APBSYSACE 0x00b
>> +#define OPENCHIP_APB1WIRE 0x00c
>> +#define OPENCHIP_APBJTAG 0x00d
>> +#define OPENCHIP_APBSUI 0x00e
>> +#define CONTRIB_CORE1 0x001
>> +#define CONTRIB_CORE2 0x002
>> +#define GLEICHMANN_CUSTOM 0x001
>> +#define GLEICHMANN_GEOLCD01 0x002
>> +#define GLEICHMANN_DAC 0x003
>> +#define GLEICHMANN_HPI 0x004
>> +#define GLEICHMANN_SPI 0x005
>> +#define GLEICHMANN_HIFC 0x006
>> +#define GLEICHMANN_ADCDAC 0x007
>> +#define GLEICHMANN_SPIOC 0x008
>> +#define GLEICHMANN_AC97 0x009
>> +#define SUN_T1 0x001
>> +#define SUN_S1 0x011
>> +#define ORBITA_1553B 0x001
>> +#define ORBITA_429 0x002
>> +#define ORBITA_SPI 0x003
>> +#define ORBITA_I2C 0x004
>> +#define ORBITA_SMARTCARD 0x064
>> +#define ORBITA_SDCARD 0x065
>> +#define ORBITA_UART16550 0x066
>> +#define ORBITA_CRYPTO 0x067
>> +#define ORBITA_SYSIF 0x068
>> +#define ORBITA_PIO 0x069
>> +#define ORBITA_RTC 0x0c8
>> +#define ORBITA_COLORLCD 0x12c
>> +#define ORBITA_PCI 0x190
>> +#define ORBITA_DSP 0x1f4
>> +#define ORBITA_USBHOST 0x258
>> +#define ORBITA_USBDEV 0x2bc
>> +#define NASA_EP32 0x001
>> +#define CAL_DDRCTRL 0x188
>> +#define ACTEL_COREMP7 0x001
>> +/* Opencores device id's */
>> +#define OPENCORES_PCIBR 0x4
>> +#define OPENCORES_ETHMAC 0x5
>> +#endif
>> 1.7.0.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
