[PATCH 1/3] score: Remove _Stack_Adjust_size()
Mon Apr 16 09:00:08 UTC 2012
On 04/15/2012 08:05 PM, Gedare Bloom wrote:
> Where did the original stack size adjustment come from / what was its
> motivation?
The
uint32_t _Stack_Adjust_size(size_t size)
   return size + CPU_STACK_ALIGNMENT;
is there since 1995-05-11 19:39:37.  It is probably there since the workspace
allocator only aligns the memory by CPU_HEAP_ALIGNMENT.  The stack needs to be
aligned by CPU_STACK_ALIGNMENT.  Thus if these values are arbitrary you have to
adjust the allocated memory to fit as a stack.  You need to allocate at least
CPU_STACK_ALIGNMENT - 1 additional bytes to do this.
> Will this break something that was "fixed" by the
> previous approach?
I think this fixed a non-existing problem.  The CPU_HEAP_ALIGNMENT and
CPU_STACK_ALIGNMENT are roughly the same on all supported architectures.  Also
the requested stack size must be considerable larger than CPU_STACK_ALIGNMENT,
otherwise you cannot call any functions.  Thus it is not a problem at all to
align the memory.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
