[PATCH 4/4] lm32: use shared setvec.c
Mon Apr 16 16:08:08 UTC 2012
 c/src/lib/libbsp/lm32/lm32_evr/Makefile.am    |    2 +-
 c/src/lib/libbsp/lm32/shared/startup/setvec.c |   43 -------------------------
 2 files changed, 1 insertions(+), 44 deletions(-)
 delete mode 100644 c/src/lib/libbsp/lm32/shared/startup/setvec.c
diff --git a/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am b/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
index fe65922..6198f2d 100644
--- a/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
+++ b/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
@@ -37,7 +37,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
     ../../shared/bsppost.c ../shared/startup/bspstart.c \
     ../../shared/bspreset.c ../../shared/bsppretaskinghook.c \
     ../../shared/bspgetworkarea.c ../../shared/bootcard.c \
-    ../../shared/sbrk.c ../../lm32/shared/startup/setvec.c \
+    ../../shared/sbrk.c ../../shared/startup/setvec.c \
     ../../shared/gnatinstallhandler.c
 # clock
 libbsp_a_SOURCES += ../../lm32/shared/clock/ckinit.c
diff --git a/c/src/lib/libbsp/lm32/shared/startup/setvec.c b/c/src/lib/libbsp/lm32/shared/startup/setvec.c
deleted file mode 100644
index 5dc8e61..0000000
--- a/c/src/lib/libbsp/lm32/shared/startup/setvec.c
+++ /dev/null
@@ -1,43 +0,0 @@
-/*  set_vector
- *  This routine installs an interrupt vector on the target Board/CPU.
- *  This routine is allowed to be as board dependent as necessary.
- *  INPUT:
- *    handler - interrupt handler entry point
- *    vector  - vector number
- *    type    - 0 indicates raw hardware connect
- *              1 indicates RTEMS interrupt connect
- *  RETURNS:
- *    address of previous interrupt handler
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.com/license/LICENSE.
- *  $Id$
-#include <rtems.h>
-#include <bsp.h>
-rtems_isr_entry set_vector(                    /* returns old vector */
-  rtems_isr_entry     handler,                  /* isr routine        */
-  rtems_vector_number vector,                   /* vector number      */
-  int                 type                      /* RTEMS or RAW intr  */
-  rtems_isr_entry previous_isr;
-  if ( type )
-    rtems_interrupt_catch( handler, vector, (rtems_isr_entry *) &previous_isr );
-  else {
-    /* XXX: install non-RTEMS ISR as "raw" interupt */
-  return previous_isr;
1.7.1
