[PATCH 4/4] lm32: use shared setvec.c
Gedare Bloom
gedare at rtems.org
Mon Apr 16 17:02:48 UTC 2012
i built one of the m68ks. the lm32 has a typo in the Makefile.am for
the bsp that I needed to fix and am building it now. Will likely
commit these 4 soon.
On Mon, Apr 16, 2012 at 12:32 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> 1-4 look mechanical and OK to commit if you have spot
> checked a BSP in each architecture.
> Merge it and I will build all.
> On 04/16/2012 11:08 AM, Gedare Bloom wrote:
>> c/src/lib/libbsp/lm32/lm32_evr/Makefile.am | 2 +-
>> c/src/lib/libbsp/lm32/shared/startup/setvec.c | 43
>> 2 files changed, 1 insertions(+), 44 deletions(-)
>> delete mode 100644 c/src/lib/libbsp/lm32/shared/startup/setvec.c
>> diff --git a/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
>> b/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
>> index fe65922..6198f2d 100644
>> --- a/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
>> +++ b/c/src/lib/libbsp/lm32/lm32_evr/Makefile.am
>> @@ -37,7 +37,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c
>> ../../shared/bsplibc.c \
>> ../../shared/bsppost.c ../shared/startup/bspstart.c \
>> ../../shared/bspreset.c ../../shared/bsppretaskinghook.c \
>> ../../shared/bspgetworkarea.c ../../shared/bootcard.c \
>> - ../../shared/sbrk.c ../../lm32/shared/startup/setvec.c \
>> + ../../shared/sbrk.c ../../shared/startup/setvec.c \
>> ../../shared/gnatinstallhandler.c
>> # clock
>> libbsp_a_SOURCES += ../../lm32/shared/clock/ckinit.c
>> diff --git a/c/src/lib/libbsp/lm32/shared/startup/setvec.c
>> b/c/src/lib/libbsp/lm32/shared/startup/setvec.c
>> deleted file mode 100644
>> index 5dc8e61..0000000
>> --- a/c/src/lib/libbsp/lm32/shared/startup/setvec.c
>> +++ /dev/null
>> @@ -1,43 +0,0 @@
>> -/* set_vector
>> - * This routine installs an interrupt vector on the target Board/CPU.
>> - * This routine is allowed to be as board dependent as necessary.
>> - * INPUT:
>> - * handler - interrupt handler entry point
>> - * vector - vector number
>> - * type - 0 indicates raw hardware connect
>> - * 1 indicates RTEMS interrupt connect
>> - * RETURNS:
>> - * address of previous interrupt handler
>> - * COPYRIGHT (c) 1989-1999.
>> - * On-Line Applications Research Corporation (OAR).
>> - * The license and distribution terms for this file may be
>> - * found in the file LICENSE in this distribution or at
>> - * http://www.rtems.com/license/LICENSE.
>> - * $Id$
>> -#include<rtems.h>
>> -#include<bsp.h>
>> -rtems_isr_entry set_vector( /* returns old vector */
>> - rtems_isr_entry handler, /* isr routine */
>> - rtems_vector_number vector, /* vector number */
>> - int type /* RTEMS or RAW intr */
>> - rtems_isr_entry previous_isr;
>> - if ( type )
>> - rtems_interrupt_catch( handler, vector, (rtems_isr_entry
>> *)&previous_isr );
>> - else {
>> - /* XXX: install non-RTEMS ISR as "raw" interupt */
>> - return previous_isr;
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
