[PATCH 33.1 2/5] LEON3: clock driver use new AMBAPP layer
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 17 16:37:55 UTC 2012
On 04/17/2012 07:42 AM, Daniel Hellstrom wrote:
> On 04/16/2012 12:54 AM, Joel Sherrill wrote:
>> On 04/15/2012 01:39 PM, Gedare Bloom wrote:
>>> Looks ok.
>> Minor style issue. Arguments are supposed to be "(arg1, arg2)"
> But I am removing "(arg1,arg2)" and replacing with "(arg1, arg2)"? Do you want me to change coding-style on locations I'm not modifying in the patch?
if it isn't too much trouble.
My ever growing todo list now has style rules on it and
trying to find settings in indent and/or astyle that get us
close.
> Daniel
>> But OK to me if that is fixed and all required patches are OK.
>>> On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom<daniel at gaisler.com> wrote:
>>>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>>> c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 14 ++++++++------
>>>> 1 files changed, 8 insertions(+), 6 deletions(-)
>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>>> index 3cdbb20..dacfd2e 100644
>>>> --- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>>> +++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>>> @@ -22,6 +22,7 @@
>>>> #include<bsp.h>
>>>> #include<bspopts.h>
>>>> +#include<ambapp.h>
>>>> #if SIMSPARC_FAST_IDLE==1
>>>> #define CLOCK_DRIVER_USE_FAST_IDLE
>>>> @@ -59,14 +60,15 @@ static int clkirq;
>>>> #define Clock_driver_support_find_timer() \
>>>> do { \
>>>> - int cnt; \
>>>> - amba_apb_device dev; \
>>>> + struct ambapp_dev *adev; \
>>>> - /* Find LEON3 GP Timer */ \
>>>> - cnt = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&dev); \
>>>> - if ( cnt> 0 ) { \
>>>> + /* Find first LEON3 GP Timer */ \
>>>> + adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),\
>>>> + VENDOR_GAISLER, GAISLER_GPTIMER, ambapp_find_by_idx, NULL); \
>>>> + if (adev) { \
>>>> /* Found APB GPTIMER Timer */ \
>>>> - LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) dev.start; \
>>>> + LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) \
>>>> + DEV_TO_APB(adev)->start; \
>>>> clkirq = (LEON3_Timer_Regs->status& 0xf8)>> 3; \
>>>> Adjust_clkirq_for_node(); \
>>>> 1.7.0.4
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
Joel Sherrill, Ph.D. Director of Research& Development
