[PATCH 34.1 2/6] LEON3: add console attributes such as parity and baudrate
Wed Apr 18 15:29:22 UTC 2012
Rather than the switch on Bxxx, please use
rtems_termios_baud_to_number(). It does
the conversion so we don't end up with this
switch in every UART driver. :)
Other than that, the patch is OK.
On 04/18/2012 10:19 AM, Daniel Hellstrom wrote:
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>   c/src/lib/libbsp/sparc/leon3/console/console.c |   93 +++++++++++++++++++++++-
>   1 files changed, 90 insertions(+), 3 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index fa67d37..7eafaef 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -13,8 +13,6 @@
>    *  The license and distribution terms for this file may be
>    *  found in the file LICENSE in this distribution or at
>    *  http://www.rtems.com/license/LICENSE.
> - *  $Id$
>   #include<bsp.h>
> @@ -102,6 +100,95 @@ int console_pollRead(int minor)
>     return apbuart_inbyte_nonblocking(apbuarts[port].regs);
> +int console_set_attributes(int minor, const struct termios *t)
> +  unsigned int scaler;
> +  unsigned int ctrl;
> +  int baud;
> +  struct apbuart_priv *uart;
> +  switch (t->c_cflag&  CSIZE) {
> +    default:
> +    case CS5:
> +    case CS6:
> +    case CS7:
> +      /* Hardware doesn't support other than CS8 */
> +      return -1;
> +    case CS8:
> +      break;
> +  if (minor == 0)
> +    uart =&apbuarts[syscon_uart_index];
> +  else
> +    uart =&apbuarts[minor - 1];
> +  /* Read out current value */
> +  ctrl = uart->regs->ctrl;
> +  switch (t->c_cflag&  (PARENB|PARODD)) {
> +    case (PARENB|PARODD):
> +      /* Odd parity */
> +      ctrl |= LEON_REG_UART_CTRL_PE|LEON_REG_UART_CTRL_PS;
> +      break;
> +    case PARENB:
> +      /* Even parity */
> +      ctrl&= ~LEON_REG_UART_CTRL_PS;
> +      ctrl |= LEON_REG_UART_CTRL_PE;
> +      break;
> +    default:
> +    case 0:
> +    case PARODD:
> +      /* No Parity */
> +      ctrl&= ~(LEON_REG_UART_CTRL_PS|LEON_REG_UART_CTRL_PE);
> +  if (!(t->c_cflag&  CLOCAL)) {
> +    ctrl |= LEON_REG_UART_CTRL_FL;
> +  } else {
> +    ctrl&= ~LEON_REG_UART_CTRL_FL;
> +  /* Update new settings */
> +  uart->regs->ctrl = ctrl;
> +  /* Baud rate */
> +  switch (t->c_cflag&  CBAUD) {
> +    default:      baud = -1;      break;
> +    case B50:     baud = 50;      break;
> +    case B75:     baud = 75;      break;
> +    case B110:    baud = 110;     break;
> +    case B134:    baud = 134;     break;
> +    case B150:    baud = 150;     break;
> +    case B200:    baud = 200;     break;
> +    case B300:    baud = 300;     break;
> +    case B600:    baud = 600;     break;
> +    case B1200:   baud = 1200;    break;
> +    case B1800:   baud = 1800;    break;
> +    case B2400:   baud = 2400;    break;
> +    case B4800:   baud = 4800;    break;
> +    case B9600:   baud = 9600;    break;
> +    case B19200:  baud = 19200;   break;
> +    case B38400:  baud = 38400;   break;
> +    case B57600:  baud = 57600;   break;
> +    case B115200: baud = 115200;  break;
> +    case B230400: baud = 230400;  break;
> +    case B460800: baud = 460800;  break;
> +  if (baud>  0) {
> +    /* Calculate Baud rate generator "scaler" number */
> +    scaler = (((uart->freq_hz * 10)/(baud * 8)) - 5) / 10;
> +    /* Set new baud rate by setting scaler */
> +    uart->regs->scaler = scaler;
> +  return 0;
>   /* AMBA PP find routine. Extract AMBA PnP information into data structure. */
>   int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
> @@ -208,7 +295,7 @@ rtems_device_driver console_open(
>       NULL,                        /* lastClose */
>       console_pollRead,            /* pollRead */
>       console_write_support,       /* write */
> -    NULL,                        /* setAttributes */
> +    console_set_attributes,      /* setAttributes */
>       NULL,                        /* stopRemoteTx */
>       NULL,                        /* startRemoteTx */
>       0                            /* outputUsesInterrupts */
Joel Sherrill, Ph.D.             Director of Research&   Development
