[PATCH 34.4 5/6] LEON3: debugputs removed pointless isinit code, invoked only once
Wed Apr 18 15:33:50 UTC 2012
This looks OK.
On 04/18/2012 10:19 AM, Daniel Hellstrom wrote:
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>   c/src/lib/libbsp/sparc/leon3/console/debugputs.c |   60 +++++++++------------
>   1 files changed, 26 insertions(+), 34 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> index a189f5b..7058cf8 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> @@ -21,8 +21,6 @@
>   #include<assert.h>
>   #include<stdio.h>
> -static int isinit = 0;
>   /* Let user override which on-chip APBUART will be debug UART
>    * 0 = Default APBUART. On MP system CPU0=APBUART0, CPU1=APBUART1...
>    * 1 = APBUART[0]
> @@ -50,44 +48,38 @@ int bsp_debug_uart_init(void)
>     struct ambapp_dev *adev;
>     struct ambapp_apb_info *apb;
> -  if (isinit == 0) {
> -    /* Update debug_uart_index to index used as debug console.
> -     * Let user select Debug console by setting debug_uart_index. If the
> -     * BSP is to provide the default UART (debug_uart_index==0):
> -     *   non-MP: APBUART[0] is debug console
> -     *   MP: LEON CPU index select UART
> -    if (debug_uart_index == 0) {
> +  /* Update debug_uart_index to index used as debug console.
> +   * Let user select Debug console by setting debug_uart_index. If the
> +   * BSP is to provide the default UART (debug_uart_index==0):
> +   *   non-MP: APBUART[0] is debug console
> +   *   MP: LEON CPU index select UART
> +  if (debug_uart_index == 0) {
>   #if defined(RTEMS_MULTIPROCESSING)
> -      debug_uart_index = LEON3_Cpu_Index;
> +    debug_uart_index = LEON3_Cpu_Index;
>   #else
> -      debug_uart_index = 0;
> +    debug_uart_index = 0;
>   #endif
> -    } else {
> -      debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
> -    /* Find APBUART core for System Debug Console */
> -    i = debug_uart_index;
> -    adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
> -                                   VENDOR_GAISLER, GAISLER_APBUART,
> -                                   ambapp_find_by_idx, (void *)&i);
> -    if (adev) {
> -      /* Found a matching debug console, initialize debug uart if present
> -       * for printk
> -      apb = (struct ambapp_apb_info *)adev->devinfo;
> -      dbg_uart = (ambapp_apb_uart *)apb->start;
> -      dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> -      dbg_uart->status = 0;
> -    isinit = 1;
> +  } else {
> +    debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
> -  if (dbg_uart == NULL)
> -    return 0;
> -  else
> +  /* Find APBUART core for System Debug Console */
> +  i = debug_uart_index;
> +  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
> +                                 VENDOR_GAISLER, GAISLER_APBUART,
> +                                 ambapp_find_by_idx, (void *)&i);
> +  if (adev) {
> +    /* Found a matching debug console, initialize debug uart if present
> +     * for printk
> +    apb = (struct ambapp_apb_info *)adev->devinfo;
> +    dbg_uart = (ambapp_apb_uart *)apb->start;
> +    dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> +    dbg_uart->status = 0;
>       return 1;
> +  } else
> +    return 0;
Joel Sherrill, Ph.D.             Director of Research&   Development
