[PATCH 36] LEON3: GPTIMER timer watchdog driver
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 18 16:35:36 UTC 2012
On 04/18/2012 10:53 AM, Joel Sherrill wrote:
> + Looks like tabs on indentation in the new C file
> + 2011 date
> + You are proposing new bsp_watchdog methods. I am
> not opposed to them but they shouldn't go in your bsp.h.
> It would be better to add this as a possible API for all BSPs.
> This would have to be reconciled with the following existing
> code in the tree:
> ./cpukit/libcsupport/include/rtems/watchdogdrv.h
> ./c/src/lib/libcpu/powerpc/mpc55xx/include/watchdog.h
> ./c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-watchdog.c
> And I did some work on a prototype which never got the
> attention it deserved. Chris and I discussed this as a libchip
> framework where you could have multiple reset watchdogs
> for different pieces of hardware.
> I prototyped a simple one based upon a test fixture reset
> driver and a some code for the Intel ich4 chipset watchdog.
> Longer term, we envisioned a library of watchdog management
> code which helped the application. Say reset from timer or
> a special task.
http://www.rtems.org/ftp/pub/rtems/people/joel/watchdog/
> I would like to take this as an opportunity to discuss this
> all again and get on the right path long term. Your
> "bsp_watchdog_xxx" could be the names for the
> main board reset and the framework could be
> layered on top of it.
> You seem to be the lucky guy who asks the questions which
> need to be answered. :)
> On 04/18/2012 10:19 AM, Daniel Hellstrom wrote:
>> Last timer instance of GPTIMER is sometimes a watchdog timer that
>> can reset the system on timer underflow.
>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>> c/src/lib/libbsp/sparc/leon3/Makefile.am | 1 +
>> c/src/lib/libbsp/sparc/leon3/include/bsp.h | 25 +++++++
>> c/src/lib/libbsp/sparc/leon3/timer/watchdog.c | 89 +++++++++++++++++++++++++
>> 3 files changed, 115 insertions(+), 0 deletions(-)
>> create mode 100644 c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> index cc25993..9b8af4b 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> @@ -115,6 +115,7 @@ libbsp_a_SOURCES += ../../sparc/shared/i2c/i2cmst.c
>> # timer
>> libbsp_a_SOURCES += timer/timer.c
>> +libbsp_a_SOURCES += timer/watchdog.c
>> if HAS_SMP
>> libbsp_a_SOURCES += smp/getcpuid.c
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> index d883064..32407dd 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> @@ -192,6 +192,31 @@ extern void BSP_shared_interrupt_unmask(int irq);
>> extern void BSP_shared_interrupt_mask(int irq);
>> +/* Initialize BSP watchdog routines. Returns number of watchdog timers found.
>> + * Currently only one is supported.
>> +extern int bsp_watchdog_init(void);
>> +/* Reload watchdog (last timer on the first GPTIMER core), all systems does not
>> + * feature a watchdog, it is expected that if this function is called the
>> + * user knows that there is a watchdog available.
>> + * The prescaler is normally set to number of MHz of system, this is to
>> + * make the system clock tick be stable.
>> + * Arguments
>> + * watchdog - Always 0 for now
>> + * reload_value - Number of timer clocks (after prescaler) to count before
>> + * watchdog is woken.
>> +extern void bsp_watchdog_reload(int watchdog, unsigned int reload_value);
>> +/* Stop watchdog timer */
>> +extern void bsp_watchdog_stop(int watchdog);
>> +/* Use watchdog0 timer to reset the system */
>> +extern void bsp_watchdog_system_reset(void);
>> #ifdef __cplusplus
>> #endif
>> diff --git a/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>> new file mode 100644
>> index 0000000..d3a9c15
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>> @@ -0,0 +1,89 @@
>> +/* GPTIMER Watchdog timer routines. On some systems the first GPTIMER
>> + * core's last Timer instance underflow signal is connected to system
>> + * reset.
>> + * COPYRIGHT (c) 2011
>> + * Aeroflex Gaisler
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.com/license/LICENSE.
>> +#include<bsp.h>
>> +#include<grlib.h>
>> +extern volatile struct gptimer_regs *LEON3_Timer_Regs;
>> +struct gptimer_watchdog_priv {
>> + struct gptimer_regs *regs;
>> + struct gptimer_timer_regs *timer;
>> + int timerno;
>> +struct gptimer_watchdog_priv bsp_watchdogs[1];
>> +int bsp_watchdog_count = 0;
>> +int bsp_watchdog_init(void)
>> + int timercnt;
>> + if (!LEON3_Timer_Regs)
>> + return 0;
>> + /* Get Watchdogs in system, this is implemented for one GPTIMER core
>> + * only.
>> + * First watchdog is a special case, we can get the first timer core by
>> + * looking at LEON3_Timer_Regs, the watchdog within a timer core is
>> + * always the last timer. Unfortunately we can not know it the watchdog
>> + * functionality is available or not, we assume that it is if we
>> + * reached this function.
>> + bsp_watchdogs[0].regs = (struct gptimer_regs *)LEON3_Timer_Regs;
>> + /* Find Timer that has watchdog functionality */
>> + timercnt = bsp_watchdogs[0].regs->cfg& 0x7;
>> + if (timercnt< 2) /* First timer system clock timer */
>> + return 0;
>> + bsp_watchdogs[0].timerno = timercnt - 1;
>> + bsp_watchdogs[0].timer =&bsp_watchdogs[0].regs->timer[bsp_watchdogs[0].timerno];
>> + bsp_watchdog_count = 1;
>> + return bsp_watchdog_count;
>> +void bsp_watchdog_reload(int watchdog, unsigned int reload_value)
>> + if (bsp_watchdog_count == 0)
>> + bsp_watchdog_init();
>> + if (bsp_watchdog_count<= watchdog)
>> + return;
>> + /* Kick watchdog, and clear interrupt pending bit */
>> + bsp_watchdogs[watchdog].timer->reload = reload_value;
>> + bsp_watchdogs[watchdog].timer->ctrl =
>> + (LEON3_GPTIMER_LD | LEON3_GPTIMER_EN) |
>> + (bsp_watchdogs[watchdog].timer->ctrl& ~(1<<4));
>> +void bsp_watchdog_stop(int watchdog)
>> + return;
>> + /* Stop watchdog timer */
>> + bsp_watchdogs[watchdog].timer->ctrl = 0;
>> +/* Use watchdog timer to reset system */
>> +void bsp_watchdog_system_reset(void)
>> + sparc_disable_interrupts();
>> + bsp_watchdog_reload(0, 1);
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120418/fa68e8cc/attachment-0001.html>
