rtems-libbsd - Resolving static_hints undefined
Sebastian Huber
Thu Apr 19 12:10:52 UTC 2012
This is related to device hints:
http://www.freebsd.org/doc/handbook/device-hints.html
The big question is: Do we need the resource API? For the USB stack I could
avoid this, but to use the FreeBSD network interface drivers I think we need
them. In RTEMS the hints and resources have to be provided by the BSP. We
have to evaluate this thoroughly.
On 04/18/2012 07:35 PM, Joel Sherrill wrote:
> Hi
> sys/systm.h has this which is used by subr_hints.c
> extern char static_hints[]; /* by config for now */
> Is this normally in some generated code in FreeBSD?
> Any thoughts on where we should declare it?
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
