[PATCH 36 v2] LEON3: GPTIMER timer watchdog driver
Daniel Hellstrom
daniel at gaisler.com
Thu Apr 19 13:21:27 UTC 2012
Last timer instance of GPTIMER is sometimes a watchdog timer that
can reset the system on timer underflow.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
c/src/lib/libbsp/sparc/leon3/Makefile.am | 2 +
c/src/lib/libbsp/sparc/leon3/include/watchdog.h | 49 ++++++++++++
c/src/lib/libbsp/sparc/leon3/preinstall.am | 4 +
c/src/lib/libbsp/sparc/leon3/timer/watchdog.c | 90 +++++++++++++++++++++++
4 files changed, 145 insertions(+), 0 deletions(-)
create mode 100644 c/src/lib/libbsp/sparc/leon3/include/watchdog.h
create mode 100644 c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index cc25993..09d8b8e 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -115,6 +115,8 @@ libbsp_a_SOURCES += ../../sparc/shared/i2c/i2cmst.c
# timer
libbsp_a_SOURCES += timer/timer.c
+libbsp_a_SOURCES += timer/watchdog.c
+include_HEADERS += include/watchdog.h
if HAS_SMP
libbsp_a_SOURCES += smp/getcpuid.c
diff --git a/c/src/lib/libbsp/sparc/leon3/include/watchdog.h b/c/src/lib/libbsp/sparc/leon3/include/watchdog.h
new file mode 100644
index 0000000..8110efd
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/include/watchdog.h
@@ -0,0 +1,49 @@
+/* watchdog.h
+ * The LEON3 BSP timer watch-dog interface
+ * COPYRIGHT (c) 2012
+ * Aeroflex Gaisler
+ * http://www.rtems.com/license/LICENSE.
+#ifndef __WATCHDOG_H__
+#define __WATCHDOG_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Initialize BSP watchdog routines. Returns number of watchdog timers found.
+ * Currently only one is supported.
+int bsp_watchdog_init(void);
+/* Reload watchdog (last timer on the first GPTIMER core), all systems does not
+ * feature a watchdog, it is expected that if this function is called the
+ * user knows that there is a watchdog available.
+ * The prescaler is normally set to number of MHz of system, this is to
+ * make the system clock tick be stable.
+ * Arguments
+ * watchdog - Always 0 for now
+ * reload_value - Number of timer clocks (after prescaler) to count before
+ * watchdog is woken.
+void bsp_watchdog_reload(int watchdog, unsigned int reload_value);
+/* Stop watchdog timer */
+void bsp_watchdog_stop(int watchdog);
+/* Use watchdog0 timer to reset the system */
+void bsp_watchdog_system_reset(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index dffbb5a..b55cf35 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -149,3 +149,7 @@ $(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLU
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i2cmst.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
+$(PROJECT_INCLUDE)/watchdog.h: include/watchdog.h $(PROJECT_INCLUDE)/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/watchdog.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/watchdog.h
diff --git a/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
index 0000000..b09ab9c
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
@@ -0,0 +1,90 @@
+/* GPTIMER Watchdog timer routines. On some systems the first GPTIMER
+ * core's last Timer instance underflow signal is connected to system
+ * reset.
+#include <bsp.h>
+#include <watchdog.h>
+#include <grlib.h>
+extern volatile struct gptimer_regs *LEON3_Timer_Regs;
+struct gptimer_watchdog_priv {
+ struct gptimer_regs *regs;
+ struct gptimer_timer_regs *timer;
+ int timerno;
+struct gptimer_watchdog_priv bsp_watchdogs[1];
+int bsp_watchdog_count = 0;
+ int timercnt;
+ if (!LEON3_Timer_Regs)
+ return 0;
+ /* Get Watchdogs in system, this is implemented for one GPTIMER core
+ * only.
+ * First watchdog is a special case, we can get the first timer core by
+ * looking at LEON3_Timer_Regs, the watchdog within a timer core is
+ * always the last timer. Unfortunately we can not know it the watchdog
+ * functionality is available or not, we assume that it is if we
+ * reached this function.
+ bsp_watchdogs[0].regs = (struct gptimer_regs *)LEON3_Timer_Regs;
+ /* Find Timer that has watchdog functionality */
+ timercnt = bsp_watchdogs[0].regs->cfg & 0x7;
+ if (timercnt < 2) /* First timer system clock timer */
+ return 0;
+ bsp_watchdogs[0].timerno = timercnt - 1;
+ bsp_watchdogs[0].timer = &bsp_watchdogs[0].regs->timer[bsp_watchdogs[0].timerno];
+ bsp_watchdog_count = 1;
+ return bsp_watchdog_count;
+ if (bsp_watchdog_count == 0)
+ bsp_watchdog_init();
+ if (bsp_watchdog_count <= watchdog)
+ return;
+ /* Kick watchdog, and clear interrupt pending bit */
+ bsp_watchdogs[watchdog].timer->reload = reload_value;
+ bsp_watchdogs[watchdog].timer->ctrl =
+ (LEON3_GPTIMER_LD | LEON3_GPTIMER_EN) |
+ (bsp_watchdogs[watchdog].timer->ctrl & ~(1<<4));
+ return;
+ /* Stop watchdog timer */
+ bsp_watchdogs[watchdog].timer->ctrl = 0;
+/* Use watchdog timer to reset system */
+ sparc_disable_interrupts();
+ bsp_watchdog_reload(0, 1);
1.7.0.4
