[PATCH 34.1 v2 2/6] LEON3: add console attributes such as parity and baudrate
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Apr 19 13:24:46 UTC 2012
OK to commit.
On 04/19/2012 08:21 AM, Daniel Hellstrom wrote:
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
> c/src/lib/libbsp/sparc/leon3/console/console.c | 71 +++++++++++++++++++++++-
> 1 files changed, 68 insertions(+), 3 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index fa67d37..45ec82e 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -13,8 +13,6 @@
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> * http://www.rtems.com/license/LICENSE.
> - * $Id$
> #include<bsp.h>
> @@ -102,6 +100,73 @@ int console_pollRead(int minor)
> return apbuart_inbyte_nonblocking(apbuarts[port].regs);
> +int console_set_attributes(int minor, const struct termios *t)
> + unsigned int scaler;
> + unsigned int ctrl;
> + int baud;
> + struct apbuart_priv *uart;
> + switch (t->c_cflag& CSIZE) {
> + default:
> + case CS5:
> + case CS6:
> + case CS7:
> + /* Hardware doesn't support other than CS8 */
> + return -1;
> + case CS8:
> + break;
> + if (minor == 0)
> + uart =&apbuarts[syscon_uart_index];
> + else
> + uart =&apbuarts[minor - 1];
> + /* Read out current value */
> + ctrl = uart->regs->ctrl;
> + switch (t->c_cflag& (PARENB|PARODD)) {
> + case (PARENB|PARODD):
> + /* Odd parity */
> + ctrl |= LEON_REG_UART_CTRL_PE|LEON_REG_UART_CTRL_PS;
> + break;
> + case PARENB:
> + /* Even parity */
> + ctrl&= ~LEON_REG_UART_CTRL_PS;
> + ctrl |= LEON_REG_UART_CTRL_PE;
> + break;
> + default:
> + case 0:
> + case PARODD:
> + /* No Parity */
> + ctrl&= ~(LEON_REG_UART_CTRL_PS|LEON_REG_UART_CTRL_PE);
> + if (!(t->c_cflag& CLOCAL)) {
> + ctrl |= LEON_REG_UART_CTRL_FL;
> + } else {
> + ctrl&= ~LEON_REG_UART_CTRL_FL;
> + /* Update new settings */
> + uart->regs->ctrl = ctrl;
> + /* Baud rate */
> + baud = rtems_termios_baud_to_number(t->c_cflag);
> + if (baud> 0) {
> + /* Calculate Baud rate generator "scaler" number */
> + scaler = (((uart->freq_hz * 10) / (baud * 8)) - 5) / 10;
> + /* Set new baud rate by setting scaler */
> + uart->regs->scaler = scaler;
> + return 0;
> /* AMBA PP find routine. Extract AMBA PnP information into data structure. */
> int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
> @@ -208,7 +273,7 @@ rtems_device_driver console_open(
> NULL, /* lastClose */
> console_pollRead, /* pollRead */
> console_write_support, /* write */
> - NULL, /* setAttributes */
> + console_set_attributes, /* setAttributes */
> NULL, /* stopRemoteTx */
> NULL, /* startRemoteTx */
> 0 /* outputUsesInterrupts */
Joel Sherrill, Ph.D. Director of Research& Development
