Microblaze Branch and Tool Hack
Gedare Bloom
gedare at rtems.org
Thu Apr 19 23:00:32 UTC 2012
for reference
http://git.rtems.org/joel/rtems.git/commit/?h=microblaze
On Thu, Apr 19, 2012 at 5:36 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Forgot the tool hack. :)
> The BSP has a linker script. Copy that to
> /opt/rtems-4.11/microblaze-rtems4.11/lib/ldscripts/xilinx.ld
> On 04/19/2012 04:33 PM, Joel Sherrill wrote:
>> Hi,
>> I had a shell of a port started about 18 months ago to
>> evaluate the tools. I have placed this on a microblaze
>> branch on my personal repository. It includes:
>> + shell/stub port
>> + first cut at BSP for Microblaze simulator in gdb
>> It compiles and links but appears to get rapidly confused
>> when I run it in the simulator. This code was based on
>> a CVS snapshot from sometime in 2010 so may be
>> suffering some bitrot but it is enough to:
>> + get the tools working
>> + get all of port except context switch working
>> - (maybe minus other odd features)
>> + when port works - run all gcc tests
>> This simulator BSP is important for long term maintenance
>> in spite of its limitations.
>> I don't think the simulator could support interrupts
>> and likely does not match your real hardware.
>> It is just what I said .. a starting point.
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org
