GCC Version Questions
Sebastian Huber
Fri Apr 27 09:48:51 UTC 2012
On 04/27/2012 11:30 AM, Ralf Corsepius wrote:
>> How does this relate ? The 4.6 compiler can be EABI. I would like to see
>> the arm-eabi tools to go away and ARM default to EABI.
> Exactly this is what upstream GCC does not want.
> They _killed_ all 'arm' targets and are _forcing_
> all targets to match with 'arm*-*-*eabi*'
Yes, and they do this for good reasons. This arm-elf is now obsolete for
several years. The arm-eabi is based on the standard issued by ARM. Both
versions use ELF as a file format. Just look at the information stored an
object file to see the difference:
arm-elf:
readelf -hA test.o
ELF Header:
Magic: 7f 45 4c 46 01 01 01 61 00 00 00 00 00 00 00 00
Class: ELF32
Data: 2's complement, little endian
Version: 1 (current)
OS/ABI: ARM
ABI Version: 0
Type: REL (Relocatable file)
Machine: ARM
Version: 0x1
Entry point address: 0x0
Start of program headers: 0 (bytes into file)
Start of section headers: 208 (bytes into file)
Flags: 0x200, GNU EABI, software FP
Size of this header: 52 (bytes)
Size of program headers: 0 (bytes)
Number of program headers: 0
Size of section headers: 40 (bytes)
Number of section headers: 9
Section header string table index: 6
Attribute Section: aeabi
File Attributes
arm-eabi:
readelf -hA test.o
ELF Header:
Magic: 7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
Class: ELF32
OS/ABI: UNIX - System V
ABI Version: 0
Machine: ARM
Version: 0x1
Start of section headers: 244 (bytes into file)
Flags: 0x5000000, Version5 EABI
File Attributes
Tag_CPU_name: "ARM7TDMI"
Tag_CPU_arch: v4T
Tag_ARM_ISA_use: Yes
Tag_THUMB_ISA_use: Thumb-1
Tag_ABI_PCS_wchar_t: 4
Tag_ABI_FP_denormal: Needed
Tag_ABI_FP_exceptions: Needed
Tag_ABI_FP_number_model: IEEE 754
Tag_ABI_align8_needed: Yes
Tag_ABI_align8_preserved: Yes, except leaf SP
Tag_ABI_enum_size: small
Tag_ABI_optimization_goals: Aggressive Debug
Tag_unknown_44: 1 (0x1)
The arm-eabi uses file attributes to help the linker to issue warnings in case
incompatible ABI variants are linked together. For the arm-elf this is not
always the case.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
