GCC Version Questions
Chris Johns
chrisj at rtems.org
Fri Apr 27 22:07:23 UTC 2012
On 27/04/12 11:15 PM, Chris Johns wrote:
> On 27/04/12 7:30 PM, Ralf Corsepius wrote:
>> On 04/27/2012 11:14 AM, Chris Johns wrote:
>>> On 27/04/12 11:22 AM, Ralf Corsepius wrote:
>>> Also I tied to build the crossrpm spec files from git and arm-eabi specs
>>> where not generated. Should they ?
>> Look again, they are there:
>> rtems4.11/arm-eabi/rtems-4.11-arm-rtemseabi4.11*.spec
> That was not the question. I see them in your repo. I wish to make
> changes for MacOS and would like to know if they are normally built or
> generated by the configure and Makefile in crossrpms.git ? My testing
> does not seem to be able to build them.
On rtems.org ...
$ git clone git://git.rtems.org/rtems-crossrpms.git
$ cd rtems-crossrpms/
$ rm $(find . -name \*.spec)
$ ./bootstrap
$ ./configure
$ make
$ ls rtems4.11/arm-eabi/*.spec
ls: cannot access rtems4.11/arm-eabi/*.spec: No such file or directory
$ make clean | grep arm
I have no idea what you are using or what you are building. You have a
bug in the aclocal.m4 m4 stuff you use.
I also think the removal of the rtems4.11/arm directory is childish. You
were clearly asked to change rtems4.11/arm to EABI, not to remove it.
