[rtems-crossrpms commit] Remove.
Ralf Corsepius ralf.corsepius at rtems.org
Mon Apr 30 04:21:39 UTC 2012
On 04/30/2012 04:31 AM, Chris Johns wrote:
> On 29/04/12 6:56 PM, Ralf Corsepius wrote:
>> Module: rtems-crossrpms
>> Branch: master
>> Commit: 4c912408bdd8bddcff79cb785455e5214f3d4ce2
>> Changeset:
>> http://git.rtems.org/rtems-crossrpms/commit/?id=4c912408bdd8bddcff79cb785455e5214f3d4ce2
>> Author: Ralf Corsépius<ralf.corsepius at rtems.org>
>> Date: Sun Apr 29 10:57:11 2012 +0200
>> Remove.
> Is this fix also related to the issue I posted about where the arm-eabi
> spec file was not being created ?
This is. I removed @TARGET_SUBDIRS@ from the configure.ac and Makefile.am.
The magic in configure.ac did not work for the rtems4.11/arm-eabi
directory and had caused rtems4.11/arm-eabi not to get added to ./Makefile.
This likely was the cause of your observation: Running make from the
toplevel did not enter rtems4.11/arm-eabi and not create the arm-eabi
*.specs.
Ralf
