[GSOC] Docs(Xiaochen Pan)
Fri Aug 3 14:33:02 UTC 2012
On Tue, Jul 24, 2012 at 1:11 PM, Xiaochen Pan <xc.panfly at gmail.com> wrote:
> Hi,
> I downloaded two documentation from the web, the classic API docs and posix
> API docs.
> http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.99.3/share/rtems/html/index.html
> It is noted to be the RTEMS 4.6.99.3 version docs. Is it outdated? Are there
> modifications to the managers and directives for each manager?
Docs are often outdated. You ought to be able to find the current
versions through
http://rtems.org/onlinedocs/doc-current/share/rtems/html/
> What is the structure for RTEMS executive core, which includes the CPU
> dependent routines?
Try the Development Environment Guide for a start:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/develenv/develenv.html
> xiaochen Pan
> rtems-devel mailing list
> rtems-devel at rtems.org
