RTEMS synchronization primitives support for SMP
yangwei weiyang
wei.a.yang at gmail.com
Mon Aug 6 13:31:11 UTC 2012
Hi all,
As a GSOC project "atomic operations support for RTEMS" has completed
first milestone which includes atomic API design and its
implementation for i386 and PowerPC architecture (PowerPC atomic was
not tested under SMP mode). And then i want to do more developments
based on this project. The basic idear is to make existing kinds of
synchronization primitives on RTEMS support SMP and to add some new
SMP-safe synchronization primitives based on atomic operations.
And in there i attach the FreeBSD synchronization primitives which are
based on atomic operations:
FreeBSD kernel:
1. Mutexs
int atomic_cmpset_[acq_|rel_]<type>(volatile _type_ *dst,
_type_old, _type_ new);
void atomic_store_rel_<type>(volatile _type_ *p, _type_ v);
void atomic_set_[acq_|rel_]<type>(volatile _type_ *p, _type_ v);
void atomic_clear_[acq_|rel_]<type>(volatile _type_ *p, _type_ v);
2. Condition variables
Do not use atomic API directly instead of using mutexs API.
3. Shared/Exclusive locks
4. Semaphores
Do not use atomic API directly instead of using mutexs and
condition variables API in conjunction.
5. Reader-Writer locks
6. Read-Mostly locks
7. Refcounts
void atomic_add_[acq_|rel_]<type>(volatile _type_ *p, _type_ v);
_type_ atomic_fetchadd_<type>(volatile _type_ *p, _type_ v);
RTEMS existing synchronization primitives:
1. semaphore
2. message
3. event
4. mutexs
5. rwlock
6. spinlock
So i have two questions:
1. which primitives above should be modified to support SMP?
2. what kinds of new primitives should be added to support SMP more better?
If you have any comments please contact me freely.
Wei Yang
Best Regards
