[PATCH] score: Change _Heap_Extend() API
Thu Aug 9 15:50:48 UTC 2012
Sorry to keep pestering but we ended up with a deliberately unused
parameter. Does that give a warning?
Do we need to use the gcc pragma to note it is unused? I know in the
test code, there is a conditional defined for this. It may have to move
into the core like the memory barrier and other compiler specific macros
On 8/9/2012 10:07 AM, Sebastian Huber wrote:
> The _Heap_Extend() has now the same signature as _Heap_Initialize().
> The 4th parameter is ignored (page size in _Heap_Initialize()).
> Add Heap_Area and Heap_Initialization_or_extend_handler.
> Add and test _Heap_No_extend().
> This helps to do a table based heap initialization and extension.
> Create a table of Heap_Area elements and iterate through it.  Set the
> handler to _Heap_Initialize() in the first iteration and then to
> _Heap_Extend().
>   cpukit/rtems/src/regionextend.c         |    7 ++--
>   cpukit/score/Makefile.am                |    2 +-
>   cpukit/score/include/rtems/score/heap.h |   59 +++++++++++++++++++++++++++---
>   cpukit/score/src/heapextend.c           |   15 +++-----
>   cpukit/score/src/heapnoextend.c         |   37 +++++++++++++++++++
>   cpukit/score/src/pheapextend.c          |    7 ++--
>   testsuites/libtests/malloctest/init.c   |    4 ++
>   7 files changed, 107 insertions(+), 24 deletions(-)
>   create mode 100644 cpukit/score/src/heapnoextend.c
> diff --git a/cpukit/rtems/src/regionextend.c b/cpukit/rtems/src/regionextend.c
> index cf4489e..205534b 100644
> --- a/cpukit/rtems/src/regionextend.c
> +++ b/cpukit/rtems/src/regionextend.c
> @@ -46,7 +46,6 @@ rtems_status_code rtems_region_extend(
>     uintptr_t           amount_extended;
> -  bool                extend_ok;
>     Objects_Locations   location;
>     rtems_status_code   return_status;
>     Region_Control     *the_region;
> @@ -61,14 +60,14 @@ rtems_status_code rtems_region_extend(
>         case OBJECTS_LOCAL:
> -        extend_ok = _Heap_Extend(
> +        amount_extended = _Heap_Extend(
>             &the_region->Memory,
>             starting_address,
>             length,
> -          &amount_extended
> +          0
> -        if ( extend_ok ) {
> +        if ( amount_extended > 0 ) {
>             the_region->length                += amount_extended;
>             the_region->maximum_segment_size  += amount_extended;
>             return_status = RTEMS_SUCCESSFUL;
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index cb512e4..dedcec7 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -178,7 +178,7 @@ endif
>   libscore_a_SOURCES += src/heap.c src/heapallocate.c src/heapextend.c \
>       src/heapfree.c src/heapsizeofuserarea.c src/heapwalk.c src/heapgetinfo.c \
>       src/heapgetfreeinfo.c src/heapresizeblock.c src/heapiterate.c \
> -    src/heapgreedy.c
> +    src/heapgreedy.c src/heapnoextend.c
>   ## OBJECT_C_FILES
>   libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
> diff --git a/cpukit/score/include/rtems/score/heap.h b/cpukit/score/include/rtems/score/heap.h
> index 8e6220c..964386a 100644
> --- a/cpukit/score/include/rtems/score/heap.h
> +++ b/cpukit/score/include/rtems/score/heap.h
> @@ -388,6 +388,33 @@ typedef enum {
>   } Heap_Resize_status;
> + * @brief Heap area structure for table based heap initialization and
> + * extension.
> + * @see Heap_Initialization_or_extend_handler.
> +typedef struct {
> +  void *begin;
> +  uintptr_t size;
> +} Heap_Area;
> + * @brief Heap initialization and extend handler type.
> + * This helps to do a table based heap initialization and extension.  Create a
> + * table of Heap_Area elements and iterate through it.  Set the handler to
> + * _Heap_Initialize() in the first iteration and then to _Heap_Extend().
> + * @see Heap_Area, _Heap_Initialize(), _Heap_Extend(), or _Heap_No_extend().
> +typedef uintptr_t (*Heap_Initialization_or_extend_handler)(
> +  Heap_Control *heap,
> +  void *area_begin,
> +  uintptr_t area_size,
> +  uintptr_t page_size_or_unused
>    * @brief Gets the first and last block for the heap area with begin
>    * @a heap_area_begin and size @a heap_area_size.
> @@ -419,6 +446,8 @@ bool _Heap_Get_first_and_last_block(
>    * @c CPU_ALIGNMENT, it is aligned up to the nearest @c CPU_ALIGNMENT boundary.
>    * Returns the maximum memory available, or zero in case of failure.
>   uintptr_t _Heap_Initialize(
>     Heap_Control *heap,
> @@ -431,22 +460,40 @@ uintptr_t _Heap_Initialize(
>    * @brief Extends the memory available for the heap @a heap using the memory
>    * area starting at @a area_begin of size @a area_size bytes.
> - * The extended space available for allocation will be returned in
> - * @a amount_extended.  This pointer may be @c NULL.
>    * There are no alignment requirements.  The memory area must be big enough to
>    * contain some maintainance blocks.  It must not overlap parts of the current
>    * heap areas.  Disconnected subordinate heap areas will lead to used blocks
>    * which cover the gaps.  Extending with an inappropriate memory area will
>    * corrupt the heap.
> - * Returns @c true in case of success, and @c false otherwise.
> + * The unused fourth parameter is provided to have the same signature as
> + * _Heap_Initialize().
> + * Returns the extended space available for allocation, or zero in case of failure.
> -bool _Heap_Extend(
> +uintptr_t _Heap_Extend(
>     Heap_Control *heap,
>     void *area_begin,
> -  uintptr_t *amount_extended
> +  uintptr_t unused
> + * @brief This function returns always zero.
> + * This function only returns zero and does nothing else.
> + * Returns always zero.
> +uintptr_t _Heap_No_extend(
> +  Heap_Control *unused_0,
> +  void *unused_1,
> +  uintptr_t unused_2,
> +  uintptr_t unused_3
> diff --git a/cpukit/score/src/heapextend.c b/cpukit/score/src/heapextend.c
> index 9d2d587..cb60427 100644
> --- a/cpukit/score/src/heapextend.c
> +++ b/cpukit/score/src/heapextend.c
> @@ -108,11 +108,11 @@ static void _Heap_Link_above(
>     last_block->size_and_flag |= HEAP_PREV_BLOCK_USED;
> -bool _Heap_Extend(
>     Heap_Control *heap,
>     void *extend_area_begin_ptr,
>     uintptr_t extend_area_size,
> -  uintptr_t *extended_size_ptr
> +  uintptr_t unused
>     Heap_Statistics *const stats = &heap->stats;
> @@ -134,7 +134,7 @@ bool _Heap_Extend(
>     bool extend_area_ok = false;
>     if ( extend_area_end < extend_area_begin ) {
> -    return false;
> +    return 0;
>     extend_area_ok = _Heap_Get_first_and_last_block(
> @@ -147,7 +147,7 @@ bool _Heap_Extend(
>     if (!extend_area_ok ) {
>       /* For simplicity we reject extend areas that are too small */
> -    return false;
> +    return 0;
>     do {
> @@ -160,7 +160,7 @@ bool _Heap_Extend(
>       if (
>         sub_area_end > extend_area_begin && extend_area_end > sub_area_begin
> -      return false;
> +      return 0;
>       if ( extend_area_end == sub_area_begin ) {
> @@ -234,8 +234,5 @@ bool _Heap_Extend(
>     /* Statistics */
>     stats->size += extended_size;
> -  if ( extended_size_ptr != NULL )
> -    *extended_size_ptr = extended_size;
> -  return true;
> +  return extended_size;
> diff --git a/cpukit/score/src/heapnoextend.c b/cpukit/score/src/heapnoextend.c
> new file mode 100644
> index 0000000..8a1585b
> --- /dev/null
> +++ b/cpukit/score/src/heapnoextend.c
> @@ -0,0 +1,37 @@
> + * @file
> + * @ingroup ScoreHeap
> + * @brief Heap Handler implementation.
> + * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Obere Lagerstr. 30
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#if HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/score/heap.h>
> +  void *unused_1,
> +  return 0;
> diff --git a/cpukit/score/src/pheapextend.c b/cpukit/score/src/pheapextend.c
> index be23c70..5f1a4df 100644
> --- a/cpukit/score/src/pheapextend.c
> +++ b/cpukit/score/src/pheapextend.c
> @@ -28,12 +28,11 @@ bool _Protected_heap_Extend(
>     uintptr_t     size
> -  bool      extend_ok;
>     _RTEMS_Lock_allocator();
> -    extend_ok = _Heap_Extend(the_heap, starting_address, size, &amount_extended);
> +    amount_extended = _Heap_Extend( the_heap, starting_address, size, 0 );
>     _RTEMS_Unlock_allocator();
> -  return extend_ok;
> +  return amount_extended != 0;
> diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
> index a93edc4..a044716 100644
> --- a/testsuites/libtests/malloctest/init.c
> +++ b/testsuites/libtests/malloctest/init.c
> @@ -948,6 +948,7 @@ static void test_heap_extend(void)
>     bool ret = false;
>     Heap_Control *heap = &TestHeap;
>     uint8_t *area_begin = TestHeapMemory;
> +  uintptr_t extended_space;
>     _Heap_Initialize( heap, area_begin + 768, 256, 0 );
> @@ -982,6 +983,9 @@ static void test_heap_extend(void)
>     puts( "heap extend - merge below with align up" );
>     ret = _Protected_heap_Extend( heap, area_begin + 512, 256 );
>     test_heap_assert( ret, true );
> +  extended_space = _Heap_No_extend( NULL, 0, 0, 0 );
> +  rtems_test_assert( extended_space == 0 );
>   static void test_heap_info(void)
Joel Sherrill, Ph.D.             Director of Research&  Development
