[PATCH] score: Change _Heap_Extend() API
Fri Aug 10 13:46:55 UTC 2012
On 08/10/2012 03:26 PM, Joel Sherrill wrote:
> It is shorter. I question better because the BSD names already
> are duplicated in newlib. With the libbsd work, I have noticed
> that the conflicts/duplications for sys/cdefs.h are popping up
> again. If we use the same names a third time, this is just going
> to be worse.
> If we can unify all this, it may be OK.  But sys/cdefs.h definitions
> have proven to be a thorn over the past years.
I think one of the main tasks will be to unify (or make compatible) the type
systems of Newlib, RTEMS, and FreeBSD.  The goal should be to use one
<sys/cdefs.h> for Newlib, RTEMS, and FreeBSD.  FreeBSD should be able to use
the <sys/types.h> etc. from RTEMS.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
