[PATCH] libcsupport: Add and use rtems_debug_putc()
Sebastian Huber
Mon Aug 13 16:13:25 UTC 2012
This reduces code size and provides a function similar to fputc().
cpukit/include/rtems/bspIo.h | 1 +
cpukit/libcsupport/Makefile.am | 1 +
cpukit/libcsupport/src/rtems_debug_putc.c | 24 ++++++++++++++++++++++++
cpukit/libcsupport/src/vprintk.c | 18 +++++++++---------
4 files changed, 35 insertions(+), 9 deletions(-)
create mode 100644 cpukit/libcsupport/src/rtems_debug_putc.c
diff --git a/cpukit/include/rtems/bspIo.h b/cpukit/include/rtems/bspIo.h
index d5a004a..f702ae9 100644
--- a/cpukit/include/rtems/bspIo.h
+++ b/cpukit/include/rtems/bspIo.h
@@ -53,6 +53,7 @@ extern int getchark(void);
extern void vprintk(const char *fmt, va_list ap);
extern void printk(const char *fmt, ...);
extern void putk(const char *s);
+extern void rtems_debug_putc(char c);
* This routine is passed into RTEMS reporting functions
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index ae23338..45d7684 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -120,6 +120,7 @@ BSD_LIBC_C_FILES = src/strlcpy.c src/strlcat.c src/issetugid.c
libcsupport_a_SOURCES = src/gxx_wrappers.c src/getchark.c src/printk.c \
src/printk_plugin.c src/putk.c src/vprintk.c \
+ src/rtems_debug_putc.c \
src/printf_plugin.c \
src/sup_fs_location.c \
src/sup_fs_eval_path.c \
diff --git a/cpukit/libcsupport/src/rtems_debug_putc.c b/cpukit/libcsupport/src/rtems_debug_putc.c
new file mode 100644
index 0000000..0283efd
--- /dev/null
+++ b/cpukit/libcsupport/src/rtems_debug_putc.c
@@ -0,0 +1,24 @@
+ * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/bspIo.h>
+void rtems_debug_putc(char c)
+ (*BSP_output_char)(c);
diff --git a/cpukit/libcsupport/src/vprintk.c b/cpukit/libcsupport/src/vprintk.c
index 1a8d5dd..d5255a7 100644
--- a/cpukit/libcsupport/src/vprintk.c
+++ b/cpukit/libcsupport/src/vprintk.c
@@ -55,7 +55,7 @@ void vprintk(
char c;
if (*fmt != '%') {
- BSP_output_char(*fmt);
+ rtems_debug_putc(*fmt);
continue;
fmt++;
@@ -80,7 +80,7 @@ void vprintk(
if ( c == 'c' ) {
/* need a cast here since va_arg() only takes fully promoted types */
char chr = (char) va_arg(ap, int);
- BSP_output_char(chr);
+ rtems_debug_putc(chr);
continue;
if ( c == 's' ) {
@@ -100,7 +100,7 @@ void vprintk(
/* leading spaces */
if ( !minus )
for ( i=len ; i<width ; i++ )
- BSP_output_char(' ');
+ rtems_debug_putc(' ');
/* no width option */
if (width == 0) {
@@ -109,12 +109,12 @@ void vprintk(
/* output the string */
for ( i=0 ; i<width && *str ; str++ )
- BSP_output_char(*str);
+ rtems_debug_putc(*str);
/* trailing spaces */
if ( minus )
continue;
@@ -132,7 +132,7 @@ void vprintk(
} else if ( c == 'p' ) {
base = 16; sign = false; lflag = true;
} else {
- BSP_output_char(c);
+ rtems_debug_putc(c);
continue;
@@ -166,7 +166,7 @@ static void printNum(
char toPrint[20];
if ( sign && (num < 0) ) {
- BSP_output_char('-');
+ rtems_debug_putc('-');
unsigned_num = (unsigned long) -num;
if (maxwidth) maxwidth--;
} else {
@@ -181,9 +181,9 @@ static void printNum(
toPrint[count++] = (char) unsigned_num;
for (n=maxwidth ; n > count; n-- )
- BSP_output_char(lead);
+ rtems_debug_putc(lead);
for (n = 0; n < count; n++) {
- BSP_output_char("0123456789ABCDEF"[(int)(toPrint[count-(n+1)])]);
+ rtems_debug_putc("0123456789ABCDEF"[(int)(toPrint[count-(n+1)])]);
1.7.7
