rtems-libbsd: M68K linkcmds Patches Galore
Kevin Polulak
kpolulak at gmail.com
Mon Aug 20 06:44:35 UTC 2012
On 8/17/2012 4:13 AM, Sebastian Huber wrote:
> I don't like this format. Each time you change the length of one
> field in the columns you have to adjust other lines as well. This
> makes a review harder.
So code should remain cryptic and hard to follow because git-diff
formats things strange sometimes? A review of the .diff output may be
hard but a review of the actual code is even harder. That's Git's fault.
I was just trying to clean things up for the next poor guy who has to
look at it.
Say "hello" to my logic:
I perform task A and I like to do task B and I do task C.
I do the same thing as A and I do something like B and I'm identical to C.
Versus:
I perform task A and I like to do task B and I sometimes do
task C.
The tabular flow forms these invisible columns that 1) are easier on the
eyes and 2) group similar things together.
| TASK A | TASK B | TASK C |
| I perform task A | and I like to do task B | and I sometimes
do task C. |
| I do the same thing as A | and I do something like B | and I'm
identical to C. |
(Hoping my email client doesn't screw up that formatting for me.)
> If you look at the default linker command file (e.g. m68k-rtems4.11-ld
> --verbose) then you will see that the previous format is used here
> (space before "(").
That's fine. I always say: I could care less what the format is, just so
long as it's followed. Sometimes there was a space, sometimes there
wasn't and it just seemed like there were more "no spaces" so that's
what I went with. Easy change.
> Why is this linkcmds.robsdsets and not linkcmds.rortems?
Didn't even realize I did that. The name got stuck in my head from
typing it so many times and I guess it stuck.
> Why do we have CPU specific variants of this? On ARM, PowerPC, etc.
> this file would look like identical.
You mean because it's in m68k/shared? I didn't know where else to put
linkcmds.rortems. Joel said to use your's or Gedare's way (I have no
clue, everyone's e-face blends together for me) from ARM so that's what
I did. There's still about 95% of unexplored RTEMS territory for me so I
didn't want to waste time trying to do something I didn't know how to.
How do I make it "attention all BSP's, you use this linkcmds file and
you use it now!"? ;)
And skipping forward to all this other GCC __underscore__ talk...
Hold on. Timeout.
To be honest, I don't even have a clue what that stuff is inside
linkcmds.robsdsets. I did a git-grep on some of those symbols a while
back and didn't find them referenced anywhere so their purpose has
always eluded me. But they fix the linkage issues so that's just what I
put in there.
But I'm not sure how the conversation got on this though? I mean,
whatever that stuff is, it works. What I was struggling with is
including it in an external file (i.e. linkcmds.rortems). So somehow
that train of thought didn't make a stop at my boarding station and I'm
kinda still waiting to be picked up. :/
(By the way, this
<http://sourceware.org/binutils/docs-2.17/ld/Source-Code-Reference.html#Source-Code-Reference>
says it's a compiler "feature".)
- Kevin Polulak (soh_cah_toa)
- http://cybercrud.net
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120820/c479bb42/attachment.html>
