[GSoC]pull request: POSIX Key project
Ashi ashi08104 at gmail.com
Thu Aug 2 06:54:05 UTC 2012
I've updated the code after Gedare's comments now.
And I also have a question about Obect open and close related function:
I'm not clear about the _Objects_Open_u32 and _Objects_Close function. The
desription of _Objects_Open_u32() function says:
"This function places the_object control pointer and object name in the
Local Pointer and Local Name Tables, respectively. "
It seems that it is kind of registration opeartion, but when should I call
_Objects_Open_u32(), I feel I should call it just after _Object_Allocate()
is called(here[0] is_POSIX_Keys_Allocate()). And I'm also curious about
what the Local Pointer and Local Name Tables is used for.
links:
[0]
https://github.com/ashi08104/rtems/blob/POSIX_Key_review/cpukit/posix/src/keycreate.c
2012/8/1 Ashi <ashi08104 at gmail.com>
> Hi, all. Here is my first pull request:
> https://github.com/RTEMS/rtems/pull/3
> this is the POSIX Key manager's one rbtree implementation, and also with
> added 7 test cases.
> Many thanks to any comment and review!
> Best wishes!
> Zhongwei Yao
Best wishes!
Zhongwei Yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120802/34ca3823/attachment-0001.html>
