[GSoC] CSB337 and skyeye 1.2.2
Xi Yang hiyangxi at gmail.com
Fri Aug 3 07:22:03 UTC 2012
Hi,
You can use Gumstix BSP on patched Skyeye-1.2.8 simulator.
svn co https://skyeye.svn.sourceforge.net/svnroot/skyeye/skyeye-v1/branches/skyeye-1.2.8
I attached the patch.
You can find out the script for running programs here
http://git.rtems.org/joel/rtems-testing.git/tree/sim-scripts/gumstix.in
You can also check out http://git.rtems.org/joel/rtems-testing.git
and see how Joel use Gumstix BSP to do coverage test.
Regards.
On 2 August 2012 00:27, Gedare Bloom <gedare at rtems.org> wrote:
> The requirement is to find a suitable ARM target that uses the CP15
> MMU and can be tested under simulation. Alternatives or suggestions
> that are known to work are also welcome.
> -Gedare
> On Tue, Jul 31, 2012 at 9:29 PM, Xi Yang <hiyangxi at gmail.com> wrote:
>> Hi Hesham,
>> Do you must need CSB337 BSP?
>> Regards.
>> On 1 August 2012 05:47, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>>> Hi,
>>> I have tried to apply the patch here [1] to get CSB337 working on skyeye
>>> When i run the script at sim-scripts directory and cat log/hello that's i
>>> got
>>> $ ./csb337 ...../hello.exe
>>> running ...../hello.exe for maximum 60 seconds...
>>> and it hangs
>>> Then i run this command
>>> $cat log/hello
>>> and i got this output
>>> "  1 arch: arm
>>>   2 cpu info: armv4, arm920t, 41009200, ff00fff0, 2
>>>   3 mach info: name at91rm92, mach_init addr 0x8060420
>>>   4 SKYEYE: use arm920t mmu ops
>>>   5 uart_mod:1, desc_in:/dev/null, desc_out:/dev/stdout
>>>   6 exec file
>>> "/home/hesham/csb337/arm-rtems4.11/c/csb337/testsuites/samples/hello/hello.exe"'s
>>> format is elf32-little.
>>>   7 not load section .vector: addr = 0x00200000  size = 0x000005c0 .
>>>   8 load section .text: addr = 0x20104000  size = 0x00017eec.
>>>   9 load section .init: addr = 0x2011beec  size = 0x00000020.
>>>  10 load section .fini: addr = 0x2011bf0c  size = 0x0000001c.
>>>  11 load section .rodata: addr = 0x2011bf28  size = 0x00001984.
>>>  12 load section .eh_frame: addr = 0x2011d8ac  size = 0x00000004.
>>>  13 load section .ctors: addr = 0x2011d8b0  size = 0x00000008.
>>>  14 load section .dtors: addr = 0x2011d8b8  size = 0x00000008.
>>>  15 load section .jcr: addr = 0x2011d8c0  size = 0x00000004.
>>>  16 load section .data: addr = 0x2011d8c4  size = 0x00000a64.
>>>  17 not load section .bss: addr = 0x2011e340  size = 0x00001a68 .
>>>  18 not load section .work: addr = 0x2011fda8  size = 0x00ee0258 .
>>>  19 not load section .comment: addr = 0x00000000  size = 0x00000048 .
>>>  20 not load section .debug_aranges: addr = 0x00000000  size = 0x00002970 .
>>>  21 not load section .debug_info: addr = 0x00000000  size = 0x0015bc6b .
>>>  22 not load section .debug_abbrev: addr = 0x00000000  size = 0x00025767 .
>>>  23 not load section .debug_line: addr = 0x00000000  size = 0x0003dd19 .
>>>  24 not load section .debug_frame: addr = 0x00000000  size = 0x00004ff0 .
>>>  25 not load section .debug_str: addr = 0x00000000  size = 0x0001085b .
>>>  26 not load section .debug_loc: addr = 0x00000000  size = 0x0001dc51 .
>>>  27 not load section .debug_ranges: addr = 0x00000000  size = 0x00002db0 .
>>>  28 not load section .ARM.attributes: addr = 0x00000000  size = 0x00000010 .
>>>  29 start addr is set to 0x20104000 by exec file.
>>> I need to get this BSP working on Skyeye as my project depends or its core
>>> i think i am close, that's why i am sending this e-mail hoping to get some
>>> help.
>>> Thanks,
>>> Hesham
>>> [1]http://www.rtems.org/pipermail/rtems-users/attachments/20070625/ddf6facd/attachment.obj
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120803/29366a40/attachment-0001.obj>
