[GSoC]Todo in POSIX Key project
Tue Aug 7 14:06:54 UTC 2012
On 08/07/2012 06:30 AM, Ashi wrote:
> Hi, all.
> Here is a short description of my first approach to POSIX Key project
> and an alternative approach. I haven't decided whether I should
> proceed to implement the alternative, and need discussion.
Just to remind everyone, both of these approaches are better than the
current approach
which is simply broken for unlimited task/threads.
> - Current approach: one rbtree approach
> In this approach, there is only one rbtree which is used to manage all
> POSIX Keys' data. If there are m POSIX Keys and t POSIX Threads, and
> each Thread has m Key values, then there is n( n = m x t ) nodes in
> the global rbtree. And the worst-case runtime of key deletion, thread
> deletion, key setspecific and key getspecific are all O(lg(n)), and
> the key creation operation has a constant runtime O(1). This approach
> is implemented now, which is in my first pull request[0].
IMO create and delete times are not as critical as set/get.
This approach is simpler and that generally is more desirable. Neither
approach completely
resolves the nature that when pushed far enough, the approach gets
pushed. Can we put
a rough instruction per m & T cost on set and get?  For example, if this
were a simple loop
of a chain, we would be fetching memory, checking for end of chain,
looking for match, etc.
We can count the memory accesses and rough instruction count (e.g. cmp,
branch, etc).
In practical terms, the seemingly growth in execution time per "unit"
increased may be
fairly small and not be critical until 100s or 1000s of tasks/keys are
in the system. Our
expected "normal worst case" is likely a few (2-3) keys and 100 tasks.
That would be a
huge system in my experience. Most systems are likely to be only 1 key
and a few dozen
tasks at most.
> - Alternative approach: one rbtree per thread approach
> Suppose there are also m POSIX Keys and t POSIX Threads in the system,
> then each thread maintains one rbtree, all key data of specific thread
> is in that rbtree. For example, say if each thread has m Key values,
> then there are m nodes in each thread's rbtree. Gedare suggested if
> there is no clear advantage than current approach, it may be not worth
> trying to implement this. So I try to figure out the advantage of this
> approach than current one. The runtime of this approach:
> (here n = m x t, there are m keys and t threads)
> Key create: O(1), create one key
> Key delete: O(tlg(m)), when key deleted, we must search each thread's
> rbtree to delete the specific key's node, there are t rbtree and each
> has m nodes.
> Key setspecific: O(lg(m)), insert one node to m-k nodes rbtree, in
> which k is constant.
> Key getspecfic: O(lg(m)), search in m nodes rbtree
> Thread delete: O(lg(m)), traverse the m nodes rbtree to release each
> node's data
> Compared to one rbtree approach, the runtime of Key setspecific,
> getspecific and thread delete are better. Though lg(m) = lg(n/t) =
> lg(n) - lg(t), not much better. But the key delete's runtime O(tlg(m))
> is kinds of slow than O(lg(n)) when n > n0, and O(tlg(m)) =
> O(tlg(n/t)), I also have drawn a comparison[1] between tlg(n/t) and
> lg(n) to illustrate. So there are both some advantage and disadvantage
> in this alternative approach. IMO, there seems not much advantage than
> current approach. However, I'm still not sure whether I should give up
> this alternative. Maybe I have missed some advantage in this approach.
Don't lose this. Please write up the O(x) information on the approaches
in your project page
in the RTEMS Wiki. Include any factors in our decision... etc
This write up is very good. Please put a table of the characteristics of
each algorithm
in O(), space, etc. Capture the same information for each approach.
This will really help in the future when we all ask the same questions
again. Trust me,
we all have shorter memories than the life of this code.
> - BTW, there is also a hash approach discussed before, however, it's
> worst case runtime is lg(n), and may be unacceptable to RTEMS as
> Sebastian suggested before[2].
I think it also has the disadvantage that we would have to add hash code
to RTEMS score
which is not there now. The other approaches reuse a score object.
> And another problem is how to know or analysis the memory overhead of
> these approaches on RTEMS. I've no idea about that yet. Could anyone
> give me some advice?
> links:
> [0]:https://github.com/RTEMS/rtems/pull/3
> [1]:https://docs.google.com/drawings/d/1P4B9ePAN57OGVywxDhsOVwne1JvGEmyPaGb0RvFolKo/edit
> [2]:http://www.rtems.org/pipermail/rtems-devel/2012-May/001138.html
> Best wishes!
> Zhongwei Yao
Joel Sherrill, Ph.D.             Director of Research&   Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120807/8e272fa1/attachment-0001.html>
